Wednesday,18,January,2023,17:11:18:20960
VCDS Version: 22.10.0.1 (x64) HEX-NET2 CB: 0.4623.4
VIN: 3VW4T7AU0FM000294 License Plate: SELL IT
Mileage: 264414km-164299mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75 A9
VIN: 3VW4T7AU0FM000294 Mileage: 264414km-164299miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CNTA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: AA57C253
Coding: 091D00124424000F1004
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 3720443E6FC89AB31A8-8062
VINID: 0E69C4907465016740000089105E0B5E18
21388 - Valve for Exhaust Flap 1 (N321)
P3019 00 [047] - Open Circuit
Mileage: 264414 km
Date: 2023.01.15
Time: 14:37:00
Engine RPM: 582.25 /min
Normed load value: 18.0 %
Coolant temperature: 20 °C
Intake air temperature: 20 °C
Ambient air pressure: 900 mbar
Voltage terminal 30: 10.917 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 77 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 16.796875 %
FUP_H_SAE: 280.0 kPa
21399 - Valve for Exhaust Flap 2 (N322)
P3023 00 [047] - Open Circuit
Mileage: 264414 km
Date: 2023.01.15
Time: 14:37:00
T_AST_SAE: 0 s
MAP_MES_SAE: 77 kPa
17790 - Coolant Pump Control Circuit
P2600 00 [047] - Open
Mileage: 264414 km
Date: 2023.01.15
Time: 14:11:26
Engine RPM: 0.00 /min
Coolant temperature: 21 °C
Intake air temperature: 21 °C
Voltage terminal 30: 12.050 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 90 kPa
FAC_TPS_1_SAE: 16.015625 %
FUP_H_SAE: 20.0 kPa
14994 - Fuel Pump Control Module
P025C 00 [032] - Short to Ground
Mileage: 264414 km
Date: 2023.01.15
Time: 14:11:30
Voltage terminal 30: 12.031 V
FUP_EFP_MES: 11000.8 hPa
N_TOOTH: 0 /min
Activation of fuel pump electronics: 10.00 %
PV: 0.00 %
High-pressure system: status: VCV_OPEN
FUP_H_SAE: 20.0 kPa
14995 - Fuel Pump Control Module
P025A 00 [032] - Electrical Fault
Mileage: 264414 km
Date: 2023.01.15
Time: 14:37:31
Vehicle speed: 255 km/h
Coolant temperature: 22 °C
Voltage terminal 30: 11.835 V
N_TOOTH: 0 /min
PV: 0.00 %
FUP_H_SAE: 290.0 kPa
17178 - Databus
U1123 00 [046] - Received Error Message
Mileage: 264414 km
Date: 2023.01.15
Time: 14:11:58
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 1101
Part No SW: 0D9 300 040 S HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4313
Revision: 05852204 Serial number: TFK01312232338 CVN: 00002816
Shop #: WSC 00066 790 07031
ROD: EV_TCMDQ250021.rod
VCID: 2700947EBF680A338A8-8072
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 518430000000CC
Coding: 01FA6BA13420096C0079020981C72980D62C9000408194B400430050C008
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 44DA23F22E1EC12B8FA-8010
9 Faults Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.18
Time: 00:32:57
8246 - Databus
[FCAN: Motor_Code_01 message is not received]
Fault Frequency: 70
Reset counter: 28
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:48
8250 - Databus
[FCAN: Motor_07 message is not received]
Fault Frequency: 119
Reset counter: 28
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:48
8252 - Databus
[FCAN: Motor_11 message is not received]
Fault Frequency: 116
Reset counter: 28
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:43
8254 - Databus
[FCAN: Motor_12 message is not received]
Reset counter: 28
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:43
8256 - Databus
[FCAN: Motor_14 message is not received]
Fault Frequency: 141
Reset counter: 28
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:44
8258 - Databus
[FCAN: Motor_20 message is not received]
Fault Frequency: 113
Reset counter: 28
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:43
8351 - Databus
[FCAN: Motor_17_alt veraltet bit is set]
Fault Frequency: 97
Reset counter: 28
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:43
C1146 02 [008] - Signal Failure
Reset counter: 28
Mileage: 264414 km
Date: 2022.12.18
Time: 14:11:12
Revision: 00021000 Serial number: 0322827832
Coding: 030C1C
VCID: 3A265D0A5CDA87DBE56-806E
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 N HW: 5G0 907 426 N
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00020004100100000000000010000000
VCID: 363E493A68C263BB01E-8062
459525 - Databus
[Diagnoseinterface für Datenbus - bitte Fehlerspeicher auslesen]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:44
459023 - Databus
[Motorsteuergerät - kein Signal/Kommunikation]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:44
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 242
Mileage: 264414 km
Date: 2023.01.11
Time: 01:06:37
Outside temperature: 20.0 °C
Engine RPM: 0 /min
Temperature downstream of evaporator: 20.7 °C
System run time-Terminal 15 on: 6 s
590082 - Control Circuit for A/C Compressor
B10A9 15 [008] - Open or Short to Plus
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:49
Outside temperature: 19.0 °C
Engine RPM: 0 /min
Compressor shut-off condition: A/C off or fan control switch in 0 position
Compressor current: actual value: 0.020 A
Compressor current: specified value: 0.000 A
Part No SW: 5Q0 937 087 K HW: 5Q0 937 087 K
Component: BCM PQ37BOSCH 026 0097
Revision: -------- Serial number: 86580910130547
Coding: 001118464041826969E44000001407201800000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_012.rod
VCID: 43D820EE2B10C613B60-8016
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 130205 042 0581
Serial number: 131206170619
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y13M11D26H20M46S26S6
Coding: 00A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO26283959
Coding: 181801
9 Faults Found:
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
Reset counter: 28
Mileage: 264414 km
Date: 2023.01.16
Time: 09:01:21
Terminal 15 status: On
Terminal 50 status: On
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): On
Status Bremslichtschalter (CAN): On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 8.9 V
Outside temperature: 12.0 °C
541973 - Databus
[Motor_04 Datenbus fehlende Botschaft]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:44
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.7 V
559125 - Databus
[Motor_07 Datenbus fehlende Botschaft]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:49
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.8 V
555541 - Databus
[Motor_12_alt aktiv]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:44
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.7 V
542229 - Databus
[Motor_14 Datenbus fehlende Botschaft]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:45
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.7 V
542485 - Databus
[Motor_18 Datenbus fehlende Botschaft]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:49
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.8 V
17674 - Bulb for Front Left Side Marker Lamp
B12BA 15 [009] - Open or Short to Plus
Reset counter: 238
Mileage: 264358 km
Date: 2022.12.16
Time: 23:11:46
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: operated
Voltage: 12.2 V
Outside temperature: 1.5 °C
17930 - Bulb for Front Right Side Marker Lamp
B12BB 15 [009] - Open or Short to Plus
Reset counter: 238
Mileage: 264358 km
Date: 2022.12.16
Time: 23:11:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
Reset counter: 28
Mileage: 264386 km
Date: 2022.12.17
Time: 12:07:26
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.5 V
Outside temperature: 4.0 °C
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM000MWW
Shop #: WSC 01383 790 50316
VCID: 51F41AA6E16C248334C-8004
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. 005 0016
Serial number: IBH0000-130005000308
Coding: 303136
Subsystem 2 - Part No SW: ----------- HW: 480 000 210 13
Serial number: 357000000006BC90ED0.
Subsystem 3 - Part No SW: ----------- HW: 480 000 210 13
Serial number: 358000000000D549DD0U
Subsystem 4 - Part No SW: ----------- HW: 480 400 605 13
Serial number: 3510002C31050651A38M
Subsystem 5 - Part No SW: ----------- HW: 480 401 804 13
Serial number: 3520002C10FEADA4532F
Subsystem 6 - Part No SW: ----------- HW: 480 402 608 13
Serial number: 3550002B91088B13509
Subsystem 7 - Part No SW: ----------- HW: 480 402 608 13
Component: FrontSensor_P 001 6149
Serial number: 3560002B71088B11334V
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 18011404221162
Coding: 0410
VCID: 79A48206195C4CC3ACC-802C
Part No SW: 5G6 920 970 C HW: 5G6 920 970 C
Component: KOMBI 316 2210
Coding: 03AD091A21804F0502087A00000000
VCID: 30327F228AA64D8B5B2-8064
16776971 - Databus
[Motor_04 keine Kommunikation]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
16776983 - Databus
[WBA_03 keine Kommunikation]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:43
16776988 - Databus
[TSK_07 keine Kommunikation]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2163
Revision: -------- Serial number: 07011410001183
Coding: 0101000820085900EF000028180F00000001000000000000000000000000
Shop #: WSC 00066 790 00201
GVL: 01503C1000000600400C00008000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_010.rod
VCID: 3E2E511A40F2ABFBD9E-806A
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0101
Serial number: 27130001802820103461
Coding: 28FFFF
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
[Timeout Knoten 0x76 / 01 - Motorsteuergerät]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:45
Terminal 30 power supply: 11.6 V
Terminal 15: On
131703 - No Communication with Transmission Control Module
U0101 00 [008] - -
[Timeout Knoten 0x77 / 02 - Steuergerät für Getriebe]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:45
Terminal 15: On
197149 - Generator
U1052 00 [008] - No Communication
[Generator (LIN#1) Timeout]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:02
Terminal 30 power supply: 12.1 V
Terminal 15: OFF
8782090 - Cruise Control Switch
B1154 96 [008] - Component Internal Failure
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Terminal 30 power supply: 12.0 V
Terminal 15: On
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 13000217570002
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 343A73327EBE71AB3FA-8060
12666369 - Databus
[Timeout Message Motor_14]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:41
ELV State: 24
Information Clamps: 77 6A
CoCo State: A0 01
WFS State: 17 0E
Vehicle speed: 0.00 km/h
Voltage: 68
AD-Value H-bridge: 33
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
12666381 - Databus
[Timeout Message Motor_09]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
ELV State: 24
Information Clamps: 77 68
CoCo State: A0 01
WFS State: 17 0E
Voltage: 67
AD-Value H-bridge: 32
CAN signals: 00
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 17101300120018
Coding: 003E13200000040000000000
VCID: 40D22FE23A06DD0BAB2-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001208344
Coding: 011000
458803 - Databus
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
Shop #: WSC 00066 790 00218
ROD: EV_SteerAssisMQB_010.rod
VCID: 353C4E3675C468A3084-8060
22272 - Databus
[KFC_MOTOR_11 Botschaft - CAN-Timeout]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Motor status: 03
System status: Driving mode
Supply voltage: 12.00 V
Temperature: 25.0 °C
KFC: 57
KFA: 00 00
Freeze frame conditions: 20
uioUdNotFilt_xdu16: 12.20 V
uAdSensI_SwitchedKl30_xdu16: 12.21 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
22528 - Databus
[MOTOR_12 Botschaft - CAN-Timeout]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Motor status: 03
KFC: 58
KFA: 00 00
23040 - Databus
[MOTOR_20 Botschaft - CAN-Timeout]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Motor status: 03
KFC: 5A
KFA: 00 00
uioUdNotFilt_xdu16: 12.08 V
uAdSensI_SwitchedKl30_xdu16: 12.06 V
22784 - Databus
[MOTOR_14-Botschaft - CAN-Timeout]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Motor status: 03
KFC: 59
KFA: 00 00
Freeze frame conditions: 21
19460 - Databus
[ESP_05 Botschaft - SNA-Check]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:44
Motor status: 03
Supply voltage: 11.75 V
KFC: 4C
KFA: 00 04
uioUdNotFilt_xdu16: 11.78 V
uAdSensI_SwitchedKl30_xdu16: 11.79 V
23296 - Databus
[MOTOR_CODE_01 Botschaft - CAN-Timeout]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:46
Motor status: 03
KFC: 5B
KFA: 00 00
uioUdNotFilt_xdu16: 11.88 V
uAdSensI_SwitchedKl30_xdu16: 11.89 V
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 18101300120104
VCID: 3FD02C1E47F8A2F3D28-806A
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001239816
Coding: 191000
458803 - Databus
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 013 0645
Serial number: V7B01401140158
Coding: 027300000000000021220002001800001F0207340100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 649AC3728EDEA12B6FA-8030
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H51 0022
Serial number: VWZ8Z9NK000063
B11CF 53 [009] - Deactivated
Reset counter: 238
Mileage: 264358 km
Date: 2022.12.16
Time: 23:09:12
Voltage terminal 30: 14.6 V
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
6708 - Databus
[Engine: no communication]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
Voltage terminal 30: 12.0 V
Network diagnosis-Status: Enabled
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0524
Shop #: WSC 00066 790 00062
ROD: EV_OCULowMQB.rod
VCID: 0256E5EA748A0F1BFD6-8056
0041 - Databus
[CAN TO Motor ECU]
Reset counter: 27
Mileage: 264414 km
Date: 2023.01.11
Time: 16:11:18
2103040 - Control Module Blocked
B2017 00 [009] - -
[ECU blocked]
Fault Priority: 8
Reset counter: 238
Mileage: 264358 km
Date: 2022.12.16
Time: 23:09:15
1247488 - Start Prevention Active
B1309 00 [009] - -
Fault Priority: 8
Reset counter: 0
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 131121200087
VCID: 6B88A84E6300EE532E0-803E
0005 - Incorrect Vehicle Type
U10D9 00 [008] - -
[Keine Funktion durch Falschverbau im Fahrzeug--> keine Funktion]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:34:51
0006 - Actuator for Structural Accoustics
P193A 00 [009] - Open Circuit
Fault Frequency: 68
Reset counter: 243
0010 - Databus
[Keine Funktion durch CAN FehlerMotorsteuergerätebotschaft fehlt--> keine Klangerzeugung]
Reset counter: 27
Mileage: 264414 km
Date: 2022.12.20
Time: 00:00:42
End----(Elapsed Time: 01:21, VBatt start/end: 11.6V/11.5V. VIgn 11.3V)-----
Car got a new engine put in because of a spark plug electrode snapping off, (NGK R7437-9). Car started fine at first then I shut the car off and put together the whole front end. Next day, I opened the door and I hear a pop around the fuse box area and noticed that the wire for the boost gauge had exposed wire and touching a metal surface, previous owner of the car just hard wired it into the fuel pump fuse so it was blowing that fuse out. Dumbass me just kept putting a new fuse instead of actually inspecting what was causing that fuse to blow. So after about 3-4 15 amps fuses and actually realizing the boost gauge wire was grounding itself out and causing the fuel pump fuse to blow, I removed the boost gauge wire off the fuel pump fuse and put a new fuse in there, I tried starting the car and it starts then dies and got the codes above. Is it possible that I screwed up the fuel pump control module, ECM...? It also has the P2600 code which I cant get any info on .
