- Apr 17, 2015
- 275
- 86
- South Africa
- C?ID=133909
Can somebody help with the login code to adapt the max speed limit in the engine control unit?
Tuesday,17,January,2023,11:02:11:26803
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Dealer/Shop Name: RyMar Auto
VIN: WV1ZZZSYZM9005750 License Plate: FNS702L
Mileage: 57118km-35491mi Repair Order:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 02 03 08 09 15 17 19 42 44 52 69 BB BC
VIN: WV1ZZZSYZM9005750 Mileage: 57118km-35491miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DAUA) Labels: None
Part No SW: 04L 906 056 DM HW: 04L 907 445 K
Component: R4 2.0l TDI H01 6049
Revision: 23202001
Coding: 002A01146304000800000000000000000000000000000000
Shop #: WSC 00000 000 00015
ASAM Dataset: EV_ECM20TDI03004L906056DM 005004
ROD: EV_ECM20TDI03004L906056DM.rod
VCID: 7BA2F6E63363EBE3BE0-802E
VINID: 9E606AAAA8E9A9D2400051C500B9F19C5D
Readiness: N/A
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 CT HW: 09G 927 158
Component: AISIN AQ8 206 3508
CVN: 1EF87AF1
Coding: 0000000000000000010000000000000000000000
ROD: EV_TCMAQ450031_VN54.rod
VCID: 074A9A167FABBF03AA8-8052
Part No SW: 2N0 907 379 E HW: 2N0 907 379 C
Component: ESC_base H02 0870
Serial number: 08504584200721
Coding: 25A82477483DB687A44E246512436D062B00443A
ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 704031
ROD: EV_Brake1ESP90iBOSCHVN54X_704.rod
VCID: 382829EA42D500FB132-806C
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 7C0 907 426 AD HW: 7C0 907 426 AD
Component: AC Manuell H01 0401
Coding: A03110000800000000000800000101000000000000000000000000000000
Shop #: WSC 00000 000 00011
ASAM Dataset: EV_AirCondiBHTCVN54X 003020
ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
VCID: 6B82C6A643037B632E0-803E
Part No SW: 5Q0 937 084 DM HW: 5Q0 937 084 DM
Component: BCM MQBAB B H42 0411
Serial number: 01102021000469
ASAM Dataset: EV_BCMMQB 021001
ROD: EV_BCMBOSCH_021_VN54.rod
VCID: 0654971278A1A60BD1E-8052
Steering Column Switch:
Subsystem 1 - Part No SW: 5Q1 953 521 DN HW: 5Q1 953 569 D
Component: Lenks.Modul H04 0180
Serial number: 0100280420200C303299
Part No SW: 3Q0 959 655 CL HW: 3Q0 959 655 CL
Component: Airbag VW21 007 0720
Revision: -------- Serial number: 003Z1PDJHTER
Coding: 8800C00000000000400000CF008800000065
ROD: EV_AirbaVW21TS6VW48X_VN54.rod
VCID: 0A4CA3226CB9C26BB56-805E
Subsystem 1 - Part No SW: ----------- HW: 454 800 807 20
Component: FrontSensor_D 305 0109
Serial number: 3550069B9021C000000K
Subsystem 2 - Part No SW: ----------- HW: 454 800 807 20
Component: FrontSensor_P 305 0109
Serial number: 356006912691B000000G
Part No SW: 7C0 920 741 D HW: 7C0 920 741 D
Component: KOMBI 202 8400
Coding: 27A411082000000800080A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 2516F09EE5678D13B84-8070
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 442 4424
Revision: -------- Serial number: 0000986171
Coding: 010000380005730000000000000E00000001070000000000000000000000
GVL: 01403C0000000000C00C00000000C00000000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 74B0DDDA1E3DA49BFFA-8020
Generator:
Component: 4-00-05-00-04
Part No SW: 5Q4 959 393 K HW: 5Q4 959 393 K
Component: TSG FS 007 0485
Serial number: 0000415377088
Coding: 00300B200101020100001000
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
VCID: 4BC2662623439B634E0-801E
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 2N0 909 144 J HW: 2N0 909 144 E
Component: EPS_MQB_ZFLS 732 7031
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002009
ROD: EV_SteerAssisMNB.rod
VCID: 353620DE55C7FD93084-8060
Part No SW: 5Q4 959 392 K HW: 5Q4 959 392 K
Component: TSG BFS 007 0485
Serial number: 0000415452028
ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
VCID: 4ACC63222C39826B756-801E
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 7C0 907 383 HW: 7C0 907 383
Component: Anhaenger H10 0055
Serial number: 000000000005510
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6888B9AA52F5507B432-803C
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 00:41, VBatt start/end: 13.5V/13.3V)----------
