MQB and Vehicle Data Learning (VIN)
Raynold
Poland
Hi,
Some modules on MQB platform are not component protected so in fact there shouldn't be a problem with VIN changing when you try to replace oryginal module to another (the same or similar model)
For example
Front Sensors Driver Assistance System MQB_MFK 5Q0980653E
Could you confirm that VCDS is able (latest stable or beta version) to update VIN(s) in non protected modules?
Regards
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Feel free to post an Auto-Scan of the vehicle in question and clarify your customer status by updating your user profile accordingly. Once that's done, we can probably take a closer look at this.
Raynold
Poland
Autoscan from vag can pro (presales group :)):
Control unit						CU name		P/N.            S/W		H/W	DTC
01 - Engine Control Module 1 				1.8l R4 TFSI 	8V0906264B 	2		H09	0
02 - Transmission Control Module 			GSG DQ200-MQB	0CW300045E 	3902	        H43	0
03 - Brakes 1 						ESC 		5Q0907379A 	333		H75	0
08 - Air Conditioning 					Climatronic	5F0907044	503		H02	0
09 - Central Electrics 					BCM MQBAB H     5Q0937084Q 	106		H14	0
13 - Adaptive Cruise Control 				ACC Bosch MQB	5Q0907572A 	150		H04	2*
15 - Airbag 						Airbag VW20 	3Q0959655AC	188		11	0
16 - Steering Column Electronics 			Lenks. Modul 	5Q0953507AN	70		7	0
17 - Dash Board 					KOMBI 		5F0920870F 	556		336	0
19 - Gateway 						GW MQB High 	5Q0907530F 	1109	        125	0
42 - Door Electronics Driver Side 			TSG FS 		5Q4959593    	6		7	0
44 - Steering Assistance 				EPS_MQB_ZFLS 	5Q0909144L 	1021	        119	0
52 - Door Electronics Passenger Side 			TSG BFS 	5Q4959592        6		7	0
55 - Headlight Regulation 				LWR-ECU 	5Q0907357        70		5	0
5F - Information Control Unit 1 			MU-S-N-ER 	5F0035846        171		39	1*
76 - Parking Assistance					PARKHILFE 8K 	5Q0919294B 	26		2	0
A5 - Front Sensors Driver Assistance System 		MQB_MFK 	5Q0980653E 	50		H05	0
A9 - Actuator For Structure-Borne Sound 		SAS-GEN 2 	5F0907159A 	1		H06	0
VCP+K v4.0.1 11.07.2015 SmartCard Autoscan protocol2015-07-18 17:09:24.004
Adressword  : 01
VAG no.     :8V0906264B
Name        :Engine Control Module 1
Description :J623 1.8l R4 TFSI
Comm.mode   :UDS, EV_ECM18TFS0218V0906264B 001002
SW version  :0002
Coding      :0B2500322424010B0000
No erros found
ECU scanning finished
Adressword  : 02
VAG no.     :0CW300045E
Name        :Transmission Control Module
Description :J743  GSG DQ200-MQB
Comm.mode   :UDS, EV_TCMDQ200021 001001
SW version  :3902
Coding      :0014
No erros found
Adressword  : 03
VAG no.     :5Q0907379A
Description :J104  ESC
Comm.mode   :UDS, EV_Brake1UDSContiMK100ESP 008020
SW version  :0333
Coding      :20EE6A9230242A71007E060101CA2904560C5400608094F4004D0020C0
No erros found
Adressword  : 08
VAG no.     :5F0907044
Name        :Air Conditioning
Description :J255  Climatronic
Comm.mode   :UDS, EV_ACClimaBHBVW37X 002017
SW version  :0503
Coding      :00000014200100011105004000101000
No erros found
Adressword  : 09
VAG no.     :5Q0937084Q
Name        :Central Electrics
Description :J519  BCM MQBAB H
Comm.mode   :UDS, EV_BCMCONTI 010001
SW version  :0106
Coding      :08101942C2C102FB0BA44000B11C0728002A000000000000000000000000
No erros found
Adressword  : 13
VAG no.     :5Q0907572A
Name        :Adaptive Cruise Control
Description :J428  ACC Bosch MQB
Comm.mode   :UDS, EV_ACCMRRBoschVW372 001013
SW version  :0150
Coding      :00001200FE0309
Errors found
000422 (U112300) Databus error value received
00070F (B203200) no enable identification active
Adressword  : 15
VAG no.     :3Q0959655AC
Description :J234  Airbag VW20
Comm.mode   :UDS, EV_AirbaVW20TS6VW48X 001116
SW version  :0188
Coding      :98CCC000000000005C0000CC000800000065
No erros found
Adressword  : 16
VAG no.     :5Q0953507AN
Name        :Steering Column Electronics
Description :J527  Lenks. Modul
Comm.mode   :UDS, EV_SMLSKLOMQB 009001
SW version  :0070
Coding      :AC00
No erros found
Adressword  : 17
VAG no.     :5F0920870F
Description :J285  KOMBI
Comm.mode   :UDS, EV_DashBoardVDDMQBAB 008026
SW version  :0556
Coding      :07AD0A086D84000801897A03010000
No erros found
Adressword  : 19
VAG no.     :5Q0907530F
Description :J533  GW MQB High
Comm.mode   :UDS, EV_GatewLear 006010
SW version  :1109
Coding      :030100F42B085800CF0006E81C0F00010001000000000000000000000000
No erros found
Adressword  : 42
VAG no.     :5Q4959593
Name        :Door Electronics Driver Side
Description :J386  TSG FS
Comm.mode   :UDS, EV_DCUDriveSideEWMAXCONT 006001
SW version  :0006
Coding      :00100220DC00020000001000
No erros found
Adressword  : 44
VAG no.     :5Q0909144L
Name        :Steering Assistance
Description :J500  EPS_MQB_ZFLS
Comm.mode   :UDS, EV_SteerAssisMQB 008022
SW version  :1021
Coding      :91
No erros found
Adressword  : 52
VAG no.     :5Q4959592
Name        :Door Electronics Passenger Side
Description :J387  TSG BFS
Comm.mode   :UDS, EV_DCUPasseSideEWMAXCONT 006001
SW version  :0006
No erros found
Adressword  : 55
VAG no.     :5Q0907357
Name        :Headlight Regulation
Description :J431  LWR-ECU
Comm.mode   :UDS, EV_HeadlRegulVWLWRMQB 001110
SW version  :0070
Coding      :049A000009000000
No erros found
Adressword  : 5F
VAG no.     :5F0035846
Name        :Information Control Unit 1
Description :J794  MU-S-N-ER
Comm.mode   :UDS, EV_MUStd6C1PASE 002030
SW version  :0171
Coding      :04730001D70A000021110001000800002F01010401000100C6
Errors found
001C05 (U111100) Function limitation due to missing message
Adressword  : 76
VAG no.     :5Q0919294B
Name        :Parking Assistance
Description :J791  PARKHILFE 8K
Comm.mode   :UDS, EV_EPHVA18AU3700000 002016
SW version  :0026
Coding      :0031251051
No erros found
Adressword  : A5
VAG no.     :5Q0980653E
Name        :Front Sensors Driver Assistance System
Description :R242  MQB_MFK
Comm.mode   :UDS, EV_MFKBoschAU370 001001
SW version  :0050
Coding      :0101010101040304020501000100000000
No erros found
Adressword  : A9
VAG no.     :5F0907159A
Name        :Actuator For Structure-Borne Sound
Description :J869  SAS-GEN 2
Comm.mode   :UDS, EV_SoundActuaGen2AU64X 003010
SW version  :0001
Coding      :
No erros found
I'd like to change 5Q0919294B to 5Q0919298A to enable 360 Park Assist and auto-parking capability like in Golf Mk7
Don't worry about module 13, trying to add ACC but it is much harder (swap codes)
Bruce
Near Philadelphia, PA, USA
Sorry Raynold. This is not the VCP support group. You are not asking about capabilities of VCDS. You are asking for very vehicle specific questions that we are only willing to attempt with our licensed registered users. Seems to us that you have everything except information which you seek to pull from us without buying anything from Ross-Tech. Your request goes beyond what we are willing to answer in a pre-sales forum.
We know that once we supply the information you desire, the sale is over. You will find a way to use your VAS clone, your VCP, and other tools to which we know you have access to implement that which you hope to do. We have answered as much as were going to answer now.
Regards,
Bruce A. Ruhf
Director of Operations, Marketing and Sales
Raynold
Poland
Sorry Bruce but i'm looking for a reason (see http://forums.ross-tech.com/showthread.php?3509-MQB-ACC-retrofit) to buy VCDS AND *i'm asking about VCDS feature(s)* about i'm not sure. And you're right i'm asking about very specific features which not exists in other products especially VCP or ODIS.
In fact i planned buy VCDS (via local importer) this week but due to lack of feedback, decision is postponed.
Only information i want to get is: *Yes, VCDS can work with MQB and write VIN* (i'dont care how and i don't want to know at this moment, google is still open so i can close answer related to other cars eg. what channel and what to do on that channel. Again i don't expect answer like that but confirmation it will work vith MQB/Leon 5F).
The answer is very important for me, if VCDS + interface *will not do what i want (or i ask for)*, i will return it.
I don't care about interface clones because with it i don't get support on this forum and i will not be able to return it (not mentioning about future features, new functions and 100% compatibility with car and vcds. we are talking about newest VW platform so compatibility is a key). Vehicle Data learning is one question. i suspect i will have tons more.
Lets summary: Question is not about HOW (to do smth) but about compatibility or ability.
Have a nice day
Regards
R.
Bruce
Raynold, I do not believe that any diagnostic tool will be able to change VINs in the control modules. I'm not sure that the factory tool can do so with it's diagnostic capabilities. My guess is that to change VIN, one needs to do it through a re-flash of the module.
I am not aware of any function within our VCDS that would let one change VIN on any module whether it be MQB or other platform.
Spacewalker
Poland
C?ID=159607
Reflash not touch OTP and FAZIT area. Imagine ECU or cluster after reflash will be virgin ? No way
NEtech
Denmark
C?ID=56995
If for example, it is because a new ECU ([A5]) is installed, and there is no VIN.
Then my guess would be, the VIN is transferred after a calibration process is performed and not by the diagnostic equipment as such.
But it is only an guess, I have never tried it.
Raynold
Poland
As far i know it depends on the module
Eg. 5Q0919298A has no VIN-coded (empty field), and working perfectly with leon 5f (Park Assist with OPS)
another module - 5Q0907572A (ACC Radar) has been adopted to my car (VIN is the same) during removing component protection, without any calibration (guys at the official workshop didn't have board fo calibration)
Probably only way is scan CAN transmission during ODIS operations and it is not guarantee of success due to possible encryption of data...
