I have a Hex+Can USB cable that seemed to lose its connection after version 12.x with the WinXP laptops I used for scanning. I have been wrestling with this issues for some time now and originally thought it was either a cable issue or an "old and slow laptop" issue. I try to fix this problem, I bought a Winbook TW700 tablet running Win 8.1 figuring a faster computer with an upgraded OS would do the trick. I installed, reinstalled, re-reinstalled the VCDS SW and drivers, did all of the "stupid computer tricks" and I just can't get the cable to be seen by the computer. Other USB devices are seen without fail and show up in the Device Manager, but for some reason, the VCDS cable just won't.
This is what brought me to the conclusion that it HAS to be a cable issue, so I tried it again on my WinXP computers and lo and behold, I was able to connect to BOTH of the old laptops.
To test if the USB connection issue just happens on that tablet, I tried plugging in the cable to my work computer running Win7 with the same results as with the tablet...the USB bus doesn't even see the cable. I tried all 6 of the USB ports on my Win7 tower and...nothing. Device Manager shows nothing, the Port manager shows nothing, Devices and Printers shows nothing.
I see that others are using the cable with their Win7 and Win8 tablets and was wondering if they are using different drivers or config files?
Any clue as to what the problem might be? The VCDS software seems to run on the machine, it's just the USB cable that can't connect.
Thanks.
Thanks.
