Tuesday,21,July,2015,15:17:21:03538
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WVWZZZ1KZCW027647 License Plate: WWC2288
Mileage: 68540km-42588mi Repair Order: 3.17pm_21Jul2015
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZCW027647 Mileage: 68540km-42588miles
Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
Part No SW: 03C 906 027 BA HW: 03C 907 309 B
Component: MED17.5.5 G 9660
Revision: LAH16--- Serial number:
Coding: 0000077
Shop #: WSC 20740 002 1048576
VCID: 61C989E9B8447829011-8034
008803 - Turbo/Super Charger Boost System
P2263 - 000 - Performance - Intermittent
Mileage: 67354 km
Date: 2015.07.08
Time: 13:17:08
RPM: 4059 /min
Load: 81.9 %
Speed: 184.0 km/h
Temperature: 87.0癈
Temperature: 46.0癈
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - Intermittent
Mileage: 68504 km
Date: 2015.07.21
Time: 11:10:20
Temperature: 85.0癈
Temperature: 65.0癈
Voltage: 11.938 V
000264 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0108 - 000 - Signal too High - Intermittent
Mileage: 68504 km
Date: 2015.07.21
Time: 11:10:21
Temperature: 85.0癈
Temperature: 65.0癈
Voltage: 11.938 V
Address 02: Auto Trans Labels: 0AM-927-769.lbl
Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5272
Revision: 00043014 Serial number: CU501311297772
VCID: 3E731295697A67D15C3-806B
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 163B600D21240001681106E884200080310000
VCID: 7BF5DB81FAE8B2F93BD-802E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
Component: Climatronic H17 1010
Revision: 00001003
Coding: 0000001002
VCID: 000FAC6D9B0ED1216EF-8055
Address 09: Cent. Elect. Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
Component: BCM PQ35 M 110 BCM PQ35 M 110 06510651
Coding: 40180A3A882518C0400800C0340089E44B550488736D8920E48400240040
VCID: 3A7B1E85B5524BF160B-806F
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 02061
Coding: 009795
Component: RLS 150611 05
Coding: 0230AD
No Faults Found
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: -------- Serial number: 12501114403709
Coding: 108101
VCID: 387F048D8B5E59E196F-806D
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA6LSXK
Coding: 00003954
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: 316939A9602488A9D11-8064
Subsystem 1 - Part No: 5K0 959 354
Component: S.Sens.Fahr.V H01 5K0959354
Serial number: 3572MSME42752060ZZZJ
Serial number: 3582MSME010C265FZZZZ
Serial number: 3512QSME52254E6AZZZ$
Serial number: 3522QSME422D2E69ZZZ1
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Revision: -------- Serial number: 90422KF8000NL
Coding: 1892140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76E3CAB5C9CAEF91443-8023
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 400
Component: E221__MFL-TK6 0022
Coding: E30000
Part No SW: 5K0 920 872 HW: 5K0 920 872
Component: KOMBI H03 0607
Coding: 170F00
VCID: 6CD7E8DD87862541A27-8039
Coding: 170F00
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 190611F2000643
Coding: 350003
VCID: 35610DB99C4CA4898D9-8060
Component: IMMO H03 0607
VCID: 6ADBEEC58D723B71D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660220558
VCID: 2959D1C940F4F069191-807C
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2120
Coding: 0004790
VCID: 326B36A5AD22B3B1A8B-8067
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 346730BD5736BD81BA7-8061
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Coding: 0005046
VCID: 336533A15238BAB9A3D-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0148
Coding: 1443164
Subsystem 1 - Part No: 7L6 941 329 B
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B
Coding: 00000022
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 032 0079
Revision: 01000001 Serial number: VWZ1Z2L3085458
Coding: 01000400040005
VCID: 72EBF6A5ADA2F3B168B-8027
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 35610DB95C4CA4898D9-8060
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 36630AB5414AAF91843-8063
End-------------------------(Elapsed Time: 02:45)--------------------------
