Resolved 2006 8H Audi A4 Cabrio 3.2 Quattro - Cent. Elec. wrong coding and no VIN (UK)
Resolved
Chris Tyas
East Yorkshire, UK
C?ID=531536
Hi,
received my HEX-V2 from Gendan yesterday and auto-scanned my 8H 2006 Audi A4 Cabrio 3.2 Quattro (attached).
Amongst other issues, the car has a headlight switch with 'auto' setting, auto lights have never worked in the time I have owned it.
The central electrics module has the following info:
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.LBL
Control Module Part Number: 8E0 907 279 N
Component and/or Version: int. Lastmodul ECE 1107
Software Coding: 10001
Work Shop Code: WSC 06441
VCID: 3D2735989462AA63C04-4AA4
30-00 - Open or Short to Plus
02737 - Bulb for Tail/Fog Light; Right
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
I assume the module has been changed at some point and the VIN number not updated.
Does the '-' after '35-00 - ' mean there is no VIN number installed in the module?
The current coding for the unit (10001) is:
1 - Avant
0 - Rain/light sensor not installed
0 - Trailer hitch not installed
0 - Halogen headlights w/o daytime running lights
1 - Rest of World Countries with Bi-Xenon
Obviously Avant is not correct and I assume the vehicle has a rain/light sensor as it has an 'auto' position on headlight switch.
I believe coding should be 21001; I'm a little unsure about the halogen/bi-xenon - I believe the vehicle has halogen not bi-xenon headlights but have no way of confirming this, I'm not sure if you can confirm visually; is there a visual difference between the halogen and bi-xenon headlights (outside the different light colour/temperature)?
I can recode the module with HEX-V2 once I am happy that 21001 is correct, with regard the incorrect VIN in Cent. Elec. wiki states:
Channel 081: Component Protection
To start the process of Vehicle Identification Number (VIN) learning, enter/save 46992 as new value.
Are there any precursor steps necessary before trying this? I assume I:
Click 'Select'
Click '09-Cent. Elect.'
Click 'Adaptation - 10'
Type '081' in Channel
Click 'Read'
Type '46992' in New value
Click 'Test' or 'Save'? Understand Test is to evaluate effect of change but I am unsure what effect should be (i.e. what should happen or if anything visible should happen).
Should VIN learning happen immediately/quickly? Are there any further steps? Does the value for Channel 081 need to be returned to previous once VIN learning complete?
Thanks in advance for any help.
Chris.
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUZZZ8H17K000676   Mileage: 196440km-122062miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 8E0 910 559 Q    HW: 8E0 907 559
   Component: 3.2l V6 FSI         0020
   Revision: --H16---    Serial number:
   Coding: 01040003180F0120
   Shop #: WSC 00672 785 00200
   VCID: 3B233B808F66A453FE0-806E
   VINID: 9D196AAAA2180476C00001871897D61152
   Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
   Component: ESP8 quattro    H05 0120
   Coding: 0004379
   Shop #: WSC 00508 210 59464
   VCID: 290FF1C875FA26C39CC-807C
                    Fault Status: 01101100
                    Fault Frequency: 9
                    Hex Value: 0x7200
                    Hex Value: 0x4306
                    Hex Value: 0x0009
                    Hex Value: 0xB0AF
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6D87C5D88482FAE3304-50F4
01810 - Actuating Motor for Temperature Flap; Right (V159)
            41-00 - Blocked or No Voltage
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 1107
   Coding: 10001
   Shop #: WSC 06441
            35-00 - -
Address 15: Airbags        Labels: 8H0-959-655-94.lbl
   Part No SW: 8H0 959 655 E    HW: 8H0 959 655 E
   Component:    Airbag 9.42  H09 1840
   Revision: 92H09184    Serial number: 0037Y0001LYE
   Coding: 0071114
   VCID: 3C21389C8A68A36BF7A-8068
   Subsystem 1 - Serial number: 6332BRB4009B3B13J
   Subsystem 2 - Serial number: 6342BRB4009B46BE.
   Subsystem 3 - Serial number: 63729RB400C6EC43Y
   Subsystem 4 - Serial number: 63829RB400C6EBD0/
   Part No: 8E0 953 549 R
   Component: Lenksáulenmodul     0501
   Coding: 04041
   Shop #: WSC 00508
   VCID: 42DD4664ED9CD59BBD6-4AA4
01301 - Control Module for Voice Recognition (J507)
            49-00 - No Communications
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8H0 920 981 E    HW: 8H0 920 981 E
   Component: KOMBI+WFS 4     H12 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0023411
   Shop #: WSC 00508 210 91413
   VCID: 323D16A4583C651B2D6-5118
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.clb
   Coding: 0023411
Address 26: Auto Roof        Labels: 8H0-959-255.clb
   Part No: 8H0 959 255 A
   Component:  VSG  B6 CABRIO     6792
   VCID: 343110BCA2286B2B3FA-50F4
            015 - Cannot Be Tested at this Time - Intermittent
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8H0 035 192 A    HW: 8H0 035 192 A
   Component: RNS-E HIGH EU   H70 0650
   Revision:      01S    Serial number: AUZBZ7E1201285
   Coding: 0419717
   VCID: 2517FDF819C202A3B84-5160
                    Reset counter: 164
                    Date: 2018.08.23
                    Time: 10:06:44
                    Voltage: 11.90 V
                    Fault Frequency: 8
                    Reset counter: 164
                    Date: 2018.08.23
                    Time: 08:06:33
                    Voltage: 11.90 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Reset counter: 149
                    Date: 2005.02.10
                    Time: 00:00:31
                    Bin. Bits: 11011011
                    Bin. Bits:       11
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8H0 951 178
   Component: Innenraumueberw.   0411
   Coding: 00001
   VCID: 6FBBDFD08E8E08F3028-50AE
01349 - Alarm via Theft Warning System; Front
            43-00 - Closed
   Part No: 8H0 959 433 H
   Component: Komfortgerát T3B    4135
   Coding: 06799
   Shop #: WSC 00672
   VCID: 392F2188804A9643ECC-4AA4
   Subsystem 1 - Part No: 8H2959802D
   Component: Tõrsteuer.FS BRM 1205
   Component: Tõrsteuer.BF BRM 3020
9 Faults Found:
            29-00 - Short to Ground
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
00962 - Alarm via. Tilt Sensor
            35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
00892 - Switch for Trunk Closing Cylinder (F248)
00955 - Key 1
            35-10 - - - Intermittent
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0419717
                    Reset counter: 164
                    Date: 2018.08.23
                    Time: 10:06:44
                    Voltage: 11.90 V
                    Fault Frequency: 8
                    Reset counter: 164
                    Date: 2018.08.23
                    Time: 08:06:33
                    Voltage: 11.90 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Reset counter: 149
                    Date: 2005.02.10
                    Time: 00:00:31
                    Bin. Bits: 11011011
                    Bin. Bits:       11
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802020532
   Coding: 0000024
   VCID: 313F19A85D0A5E0354C-5184
   Part No SW: 8P0 862 335 F    HW: 8P0 862 335 F
   Component: FSE_255x BT     H21 0190
   Revision: 00000001    Serial number: 00000000350398
   Coding: 0011802
   VCID: 392F2188854A9643ECC-50F4
End----(Elapsed Time: 05:39, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
No, those are the DTC 'status'. For example 30 means "Open or Short to Plus" and 35 is defined as blank.
If it had Xenons, it should have a Headlight Range module at address 55, but it doesn't, so I believe you are correct; it likely has halogens.
Yes. Give that a try please.
Chris Tyas
East Yorkshire, UK
C?ID=531536
Thanks for your help Uwe.
Just lost half an hour to this and achieved nothing; pressing 'read' for channel 081 did nothing so restarted VCDS, restarted laptop etc etc, eventually realised I have to click 'read' multiple times (up to ten) to get it to read the current value (0) and enable the 'new value' field. I also get 'Pin?' in the top left white box.
Enter 46992 in the 'New value' box and Save is disabled, click test and nothing apparent happens. Been here fifteen mins now..
Any ideas?
Thanks, Chris.
Chris Tyas
East Yorkshire, UK
C?ID=531536
Hi, Once again, multiple (ten) presses needed on Test to enable Save button.
Once Save clicked, all values clear and Test and Saved greyed out.
Clicked 'Done, go back', read and cleared faults and all show clear :)
Is the multiple clicks required common? I am fairly sure I wasn't just being impatient as 1. a couple of times I waited ten mins+ after one click and 2. each time I clicked 'read' or 'test' the button responded (UI colour change etc).
I then ran an auto scan and the incorrect VIN was still showing.
Did a 'clear all DTCs' in thr auto scan window and all showed as clear :)
I then recoded the module with 21001 and auto lights started working immediately :)
Also headlight height adjustment is now working which wasn't previously!
Definitely worth the wait. Will now start to work through other fault codes.
Updated auto scan attached.
Thanks again, Chris.
Thursday,05,January,2023,16:32:41:12360
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WAUZZZ8H17K000676   License Plate:
VIN: WAUZZZ8H17K000676   Mileage: 196540km-122124miles
Readiness: 0110 0101
   Coding: 0004379
   Coding: 00100
   Shop #: WSC 00672
   Coding: 21001
   Shop #: WSC 06441
   Coding: 0071114
   Coding: 04041
   Shop #: WSC 00508
   Coding: 0023411
   Coding: 0023411
   Coding: 0419717
   Coding: 00001
   Coding: 06799
   Shop #: WSC 00672
No Faults Found
   Coding: 0419717
   Coding: 0000024
   Coding: 0011802
   VCID: 392F2188854A9643ECC-50D0
End----(Elapsed Time: 05:53, VBatt start/end: 11.6V/11.8V. VIgn 11.9V)-----
Those old modules are a bit goofy. I'm not sure whether it's multiple clicks that does the trick or whether just waiting an equivalent amount of time for the control module to gather its thoughts are what's required. Unfortunately, we don't have a car like that handy to play with.
