- Feb 14, 2022
- 23
- 4
- Santa Monica, CA, USA
- C?ID=509524
Drove 60 minutes on the freeway with no issues, at the first stop light engine shake at idle. Drove another 10 minutes and any speed above idle was smooth, idle continued to shake. Turn off engine and now will not start.
Not sure how to read this diagnostic, any advice on if this an indicator of something specific would be appreciated.
Audi 2014 Coupe A5 2.0T Flex Quattro Automatic USA
Cheers and happy new year!
Saturday,31,December,2022,15:03:53:07449
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: License Plate:
Mileage: 134130km-83344mi Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56
5F 6C
VIN: Mileage: 134130km-83344miles
Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 N HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09--- CVN: FE64ECCA
Coding: 5A2A0013242600062000
Shop #: WSC 43379 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
ROD: EV_ECM20TFS0118K5907115N.rod
VCID: 3D27360C0DF07F73CC5-8068
VINID: 9D195C5915A221544008704000E6F64389
2822 - Bank 1; System Too Rich off Idle
P2178 00 [101] - -
Mileage: 134050 km
Date: 2022.12.31
Time: 10:28:09
Engine RPM: 1643.00 /min
Normed load value: 39.2 %
Vehicle speed: 104 km/h
Coolant temperature: 98 ∞C
Intake air temperature: 24 ∞C
Voltage terminal 30: 14.489 V
Unlearning counter according OBD: 80
Engine status: COENG_RUNNING
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [101] - -
Mileage: 134070 km
Date: 2022.12.31
Time: 10:39:26
Engine RPM: 1694.00 /min
Normed load value: 11.8 %
Vehicle speed: 106 km/h
Coolant temperature: 97 ∞C
Intake air temperature: 20 ∞C
Voltage terminal 30: 14.418 V
10593 - Cylinder 3
P0303 00 [101] - Misfire Detected
Mileage: 134071 km
Date: 2022.12.31
Time: 10:39:38
Engine RPM: 1721.00 /min
Normed load value: 21.6 %
Vehicle speed: 109 km/h
Intake air temperature: 19 ∞C
Voltage terminal 30: 14.465 V
10594 - Cylinder 4
P0304 00 [101] - Misfire Detected
Mileage: 134071 km
Date: 2022.12.31
Time: 10:39:38
10205 - Cylinder Disabling
P130A 00 [036] - -
Mileage: 134136 km
Date: 2022.12.31
Time: 11:23:14
Engine RPM: 809.50 /min
Normed load value: 30.6 %
Coolant temperature: 96 ∞C
Voltage terminal 30: 12.863 V
Part No SW: 8K0 927 158 T HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1005
Revision: --H16--- CVN: 1A6EAFCC
Coding: 000002
VCID: 47CB54E45F2C25A3669-8012
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Coding: 2D1D1801
Shop #: WSC 06325 000 00000
VCID: 094F92DC093893D3B0D-805C
Part No SW: 8K0 907 064 HM HW: 8K0 907 064 GM
Component: BCM2 2.0 H13 0641
Coding: 0D804040000000000000
VCID: 025D85F0340EC08BF17-8056
Subsystem 1 - Part No SW: 8Tz y59 u4 Cz HW: 8T: y59 7u4 C"
Component: FBSAUDIB8 IDG H50 00}
Serial number: 081p000p905w700w
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0213000310211010
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 38
Mileage: 132482 km
Date: 2022.11.26
Time: 01:25:31
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000073379379
Coding: 08037025002400001000
VCID: 45D75EEC65A037B3945-8010
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01180920130742
Coding: 6482208000
VCID: 392F221C19584353E0D-806C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000050589701
Coding: 26000091863CAFE00100488300003D0D0F9CD288A2090221000008004000030100000030000000
VCID: 78A9E71862D29A5BDF3-802C
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160913 H15 0080
Serial number: SWF13090165161
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21734249
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000001109131359
Component: USHL4.2 H30 0030
Serial number: 0000002274555R7N7103
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 8CE88AC6000000000001
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Component: AirbagVW-AU10 H47 0610
Serial number: 003KJDB0G2DB
Coding: 303343334830303030304A55304C38543053
VCID: 4ACD6DD04C3ED8CB797-801E
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R130000F4RB
Serial number: 6334MSME7E002C09H
Serial number: 6344MSME7F041711A
Serial number: 6352QSME7F371950O
Serial number: 6362QSME3539406EM
Serial number: 63732SME2F3A5768C
Serial number: 63832SME4A360068.
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862MII000L7
Coding: 000036
VCID: 48C957D852B22ADB6F3-801C
Part No SW: 8T0 920 984 N HW: 8T0 920 984 N
Component: KOMBIINSTR. H35 0563
Revision: 00400000 Serial number: WVH32CP9E
Coding: 8BB701000301D705020000
VCID: 4ACD6DD04CBED8CB797-801E
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z138300D1C
Coding: 80C303FF00
VCID: 4CC16BC846CAC6FB4BB-8018
Serial number: 5067181303
02256 - Quiescent Current
001 - Upper Limit Exceeded
Fault Status: 01100001
Reset counter: 123
Mileage: 133473 km
Date: 2022.12.24
Time: 21:10:01
Fault Frequency: 8
Reset counter: 163
Mileage: 133487 km
Date: 2022.12.25
Time: 04:14:59
Bin. Bits: 00000
Voltage: 12.70 V
Count: 7
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000073586391
Coding: 081B7B25002400001000
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0369775031
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3FDB4C0407FC6D63DE9-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0334355647
Coding: 010211
267776 - Data Set Implausible
B2012 00 [009] - -
[Implausible dataset]
Reset counter: 172
Mileage: 130603 km
Date: 2022.10.08
Time: 12:01:16
729349 - Control Module for Lane Change Assistance
C1114 54 [009] - Missing Calibration / Basic Setting
Reset counter: 172
Mileage: 130603 km
Date: 2022.10.08
Time: 12:01:16
729605 - Control Module 2 for Lane Change Assistance
C1115 54 [009] - Missing Calibration / Basic Setting
Reset counter: 172
Mileage: 130603 km
Date: 2022.10.08
Time: 12:01:16
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C13224E00120102
VCID: 56F589A088068C2BEDF-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H38 0507
Revision: 00001000 Serial number: 0009843214
Coding: 100000010001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 343113283EBABE3B33B-8060
Revision: 00002001 Serial number: 0314956816
Coding: 0106029A00FA400580B0003200000000
Component: GTO BF H01 0080
Serial number: 00000000000000728436
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813020043103
VCID: 2D07064CDD10EFF37C5-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
VCID: 55F78EAC95008733E45-8000
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 10000000266348
ROD: EV_ParkiBrake_AU48.rod
VCID: 392F221C19D84353E0D-806C
Revision: AB001007 Serial number: 156I10D7906633
Coding: 020007010000000001
VCID: 2411E3688EDA2EBBA3B-8070
Part No SW: 8R1 035 746 D HW: 8R1 035 746 D
Component: H-BNT-NA H40 0738
Revision: -------- Serial number: 204IU0D7601228
Coding: 130200020006A1EF55028B4E00000403140000000000000000
VCID: 3829271822525A5B1F3-806C
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Component: DU7 High H42 0104
Serial number: A130I-0D2824594
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001619909
Component: CD-Database 5298
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H08--- Serial number: 525PA8-J3792YG
Coding: 1000008
VCID: 382927182E525A5B1F3-806C
End----------(Elapsed Time: 02:11, VBatt start/end: 12.2V/12.2V)-----------
