A3 8V S3 2015 - disable warning ligth about licence plate light
ka_rai
France
C?ID=102276
hi friends
which ecu have warning ligth about licence plate ligthing ?
i am looking for to coding off this warning
thanks ;)
Westbury, UK
Is it legal in France to not have the licence plate lighting not working?
Having said that, it would be a lot easier to answer your question if you post an Auto-Scan of your S3
ka_rai
France
C?ID=102276
yes is not legal, i will repair it with time but i not want this warning on dash now ;)
the license plate lighting works except when I start the engine, I noticed that it goes out when I slightly open the trunk then turns on again when the trunk is half open, I think a bad electrical contact
Monday,26,December,2022,12:06:36:51859
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WAUZZZ8V6G1036892   License Plate:
Mileage: 90543km-56260mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 3C 42 44 52 55 5F A5 A9
          BB BC
VIN: WAUZZZ8V6G1036892   Mileage: 90543km-56260miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---    CVN: AD8DD0AA
   Coding: 0A1D00122466010B2004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259F 001004
   ROD: EV_ECM20TFS0205G0906259F.rod
   VCID: 43D34702BB197123B60-8016
   VINID: 9D196AAAA2261970400C6209089D25FA16
Readiness: 1110 0001
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4912
   Revision: 06253104    Serial number: TFK01508182421 CVN: 00007ACF
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 53F377424B79E1A3060-8006
   Revision: 00000000    Serial number: 62075000000375
   Coding: 31F16BA254232A72017F070941C5698CD62A5480E08296F6184150748208
   VCID: 7AADFAE68C53F0EBA56-802E
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000717999
   Coding: 03000004000000011000000000001100
   VCID: 333317C2EBB9C1A3260-8066
   Humidity sensor: exterior:
   Serial number: DA6883C7000000000001
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061524402033
   Coding: 04041B46C24122F503804004B11807A80000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F952AD9B5EB73BCC-805C
   Component: WWS371 150721  042 0585
   Serial number:         150808003202
   Coding: 0A47F7
   Serial number: 20576600
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 24 06 2015  00000509
   Serial number: 000000000ZY151883A9L
   Serial number: 00000000000063412315
12298 - License Plate Light
          B12CA 15 [009] - Open or Short to Plus
                    Reset counter: 74
                    Mileage: 90543 km
                    Date: 2022.12.26
                    Time: 12:02:05
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    Voltage: 12.2 V
                    Outside temperature: 17.0 °C
   Revision: --------    Serial number: 39331524104990
   Coding: 0070050011
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 P    HW: 5Q0 907 567 P
   Component: ACC3          H10 0100
   Serial number: 28081503074678
   Coding: 003E1701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 48C9502E823F527B632-801C
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    015 0388
   Serial number: 003MMR11ZGVT
   Coding: 98CCC0000C0000005C5400CA004800000065
   VCID: 0059880EEA8FAA3BEB2-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 002 508 15
   Serial number: 35767000000D8951261U
   Subsystem 2 - Part No SW: -----------    HW: 480 002 508 15
   Serial number: 35867000000CC951261Y
   Subsystem 3 - Part No SW: -----------    HW: 480 402 408 15
   Serial number: 3516502B51C1EFA1A0CS
   Subsystem 4 - Part No SW: -----------    HW: 480 402 808 15
   Serial number: 3526502B31C1EFA5834O
   Subsystem 5 - Part No SW: -----------    HW: 480 400 705 15
   Serial number: 3556502C51A87872805D
   Subsystem 6 - Part No SW: -----------    HW: 480 402 007 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502AB1B7E8E4F2F8
   Subsystem 7 - Part No SW: -----------    HW: 480 402 007 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502AB1B7E8E522AZ
   Subsystem 8 - Part No SW: -----------    HW: 480 002 404 15
   Serial number: I0M80000000D567D141C
   Subsystem 9 - Part No SW: -----------    HW: 480 002 404 15
   Serial number: I0N80000000497D44419
   Part No SW: 8V0 953 521 GD    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 22081508490290
   Coding: E818
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 025D8206E483B82BFD6-8056
   Part No SW: 8V0 920 872 A    HW: 8V0 920 872 A
   Component: KOMBI         H03 6420
   Coding: 078D180A6F8C00080081FE001000000000000000
   VCID: 3B233FE2C3E909E3FE0-806E
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 30081510800561
   Coding: 030100043F085A005B0002781C0B00000001010000000000000000000000
   GVL: 01D43C100000000040CC90000000C80000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E9DAA54D9F93C84-8020
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 07 08 2015  E0022787
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001508313288
   Serial number: HA1-00013.07.15
   Coding: 0001
   VCID: 4ACD6A269C33A06B756-801E
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H05 0080
   Serial number: 0378488496
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 382920EEF2DF22FB132-806C
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0080
   Serial number: 0375600663
   Coding: 030311
   Serial number: 060815BH506788
   Coding: 00108A205C00040000001003
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 9103
   VCID: 392F25EAC9D53BF3ECC-806C
   Serial number: 170815DHF25055
   Coding: 001082205E00040000001003
   VCID: 42DD4206A403782BBD6-8016
   Coding: 01AA000001000000
   Part No SW: 8V0 035 035 N    HW: 8V0 035 035 B
   Component: MU-H-LN-EU    H45 0397
   Serial number: A301G0F7552353
   Coding: 01730101FF0A000021110001000A00132F000205010001009E
   ROD: EV_MUHig6C3HBAS_VW48.rod
   VCID: 3C213CFEC6E70EDBF7A-8068
   Subsystem 1 - Part No SW: V03 959 800 Q    HW: -----------
   Component: ECE 2015/2016  --- 0122
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY203UK8
   Subsystem 3 - Part No SW: 8V0 919 614 K    HW: 8V0 919 614 K
   Component: ControlUnit_H  H81 0816
   Serial number: C1000011051500040067
   Compact disc data bank:
   Component: Gracenote  --- 1010
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000413990
   Coding: 0101010001010303000300010100000100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 150716200373
   VCID: 7DA7F1FA9D7DC7D3804-8028
   Serial number: 090815BH808792
   Coding: 000082204000040000001002
   VCID: 45D7591AB52D4F13984-8010
   Serial number: 090815BH810385
End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.2V)-----------
That's a bad idea. The warning is your incentive to actually fix the problem.
Westbury, UK
Sounds more like a classic case of the cable being weakened leading to partial fracture and intermittent continuity where it passes between the body and the trunk lid.
ka_rai
France
C?ID=102276
+1 also doubt about it
but is A3 sedan (limousine), all wires under coversss :facepalm::facepalm::facepalm::facepalm:
Westbury, UK
Just because the wires are in a sleeve does not prevent them being damaged, history on here and many other VAG owners websites proves that.
IMHO it's time to do a physical and visual check on the wires.
  • Agree
ka_rai
France
C?ID=102276
Hi friends
problem found, wires cable made one U so broken one wire and second wire will broke near little time , look here
what you think better way to repair it ?
wire with long cable or just soldering it
problem found
How long would you have ignored the problem if you could have made the warning go away? ;)
Without a better understanding why the wire broke, it is difficult to answer that.
ka_rai
France
C?ID=102276
hi,
i buy this car 10 days ago with this problem but seller not say to me times driving with this problem, removing all covers i see guy already remove it ...
i am in holidays so i take time to check it ;)
the wire broken because the cable path is poorly designed, it makes a U which deviates when you open the trunk of the car
ka_rai
France
C?ID=102276
Here photo to understand where wires travel when trunk opened
red arrow is where wire broken
It does not seem like the wires are too short there, but that the type of wire used is less than optimal for the application -- repeated bending and unbending in a tight radius at that point. If you want a really long-lasting repair, replace the section that of wires that is subject to that bending with better wire -- ideally high strand-count, with silicone insulation. Amazon has many choices:
