This 2013 Passat was involved in a crash. The body shop replaced the Air Bag module and the Clock Spring/Steering Column module. I was able to successfully code the Air Bag module but I can't code the Steering Column module with a valid Access Code. When I hover over the code box there is no pop-up with a valid Access Code. I am currently using the beta version 15.6.1 and I have also tried the older version 14.10. I have attached an auto scan. Can you provide me with a valid Access Code?
VCDS Version: Beta 15.6.1
Data version: 20150612
Sunday,19,July,2015,19:16:32:61215
Chassis Type: A3 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 46 4F 52 56 62 72 77
VIN: 1VWAH7A35DC144384 Mileage: 48660km-30235miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 DD HW: 07K 907 309 A
Component: 2,5l R5/4V G01 4735
Revision: T6H02--- Serial number:
Coding: 0000075
Shop #: WSC 09003 957 00200
VCID: 73EFA456125A37A7F4-8026
005699 - Please check DTC Memory of Electric Load Controller
P1643 - 000 -
Mileage: 48664 km
Date: 2015.07.17
Time: 02:10:45
Temperature: 81.0°C
Temperature: 50.0°C
Absolute Pres.: 1010.0 mbar
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal - Intermittent
Mileage: 48664 km
Date: 2015.07.17
Time: 03:08:09
Temperature: 63.0°C
Temperature: 45.0°C
Readiness: 1010 0101
Part No SW: 09G 927 750 LH HW: 09G 927 750 LH
Component: AQ 250 6F 2251
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 0201F1925DE00E2FEF-8056
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Revision: 00H31001
Coding: C54BC0F5492608FEA30E03EC921D1061A61000
VCID: 7CFD8F6AFF0478DFA5-8028
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 561 907 426 A HW: 561 907 426 A
Component: AC Manuell H02 0101
Revision: 00001K07
Coding: 0010001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1933B6FE1876ADF71E-804C
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 S HW: 5K0 937 085 S
Component: BCM PQ35 B+ 021 0068
Revision: BH021001
Coding: 6F200E18902B08D408800001160004480071008640801D60648060000C70
VCID: 438F3496C27AC727A4-8016
Fault Status: 00101010
Reset counter: 218
Mileage: 48664 km
Date: 2015.07.17
Time: 04:05:58
Voltage: 14.05 V
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM02SGJF
Coding: 00005033
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 75EB9A4ED42E2997DA-8020
Serial number: 6940000Y130000TWJP0X
Coding: 303044
Serial number: 3572MSME630B217AZZZX
Serial number: 3582MSME020A217AZZZQ
Serial number: 3516KSME5C5D2C23ZZZ0
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME0F146E23ZZZZ
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME36126D21ZZZS
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME25276721ZZZR
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0162
Revision: --X01--- Serial number: 20150313200567
Coding: 7982A00000
Shop #: WSC 01286 386 08256
VCID: 0201F19295E00E2FEF-8056
Subsystem 1 - Part No SW: 561 959 537 HW: 561 959 537
Component: E221__MFL-YVJ H07 0022
Serial number: 00000000000000881159
Coding: 620000
226827 - Turn Signal Switch
B1144 13 [008] - Open Circuit
Reset counter: 217
Mileage: 48664 km
Date: 2015.07.17
Time: 03:08:46
226839 - Turn Signal Switch
B1144 11 [008] - Short to Ground
Reset counter: 217
Mileage: 48664 km
Date: 2015.07.17
Time: 03:08:45
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Reset counter: 177
Mileage: 48664 km
Date: 2015.07.17
Time: 03:06:28
229147 - Cruise Control Switch
B1154 13 [009] - Open Circuit
Reset counter: 177
Mileage: 48664 km
Date: 2015.07.17
Time: 03:06:28
Part No SW: 561 920 960 C HW: 561 920 960 C
Component: KOMBI H06 0705
Coding: 230E01
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 17051303290218
Coding: 461000
VCID: 76E99D42C128228FD3-8022
Component: IMMO H06 0705
VCID: 6AD1B9328D90F66F47-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664696027
Coding: 010100
VCID: 2A5179324510366F87-807E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0006668839
Coding: 0404D5
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BBFECF652CA9FE7CC-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B
Component: J388__TSG_HL 006 5470
Serial number: 14102630130508065430
Coding: 800000
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 00000008
VCID: 6FE7A826BE72134710-803A
Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0006670831
Coding: 0404D4
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CBDEFEA57C498DFC5-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B
Component: J389__TSG_HR 006 5470
Serial number: 14102631130506175600
Coding: 800000
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 164 F HW: 1K0 035 164 F
Component: LOW NAR SDARS H03 0005
Revision: -----07S Serial number: VWZ4Z6N3574059
Coding: 0100040002000B
VCID: 254B8A0E2C0E1917AA-8070
Reset counter: 177
Mileage: 48664 km
Date: 2015.07.17
Time: 03:05:22
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664482586
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A714972BDB086EFF7-806E
End-------------------------(Elapsed Time: 03:05)--------------------------
