Hi, after a long absence from VW, I picked up a Polo AW (mk6) GTI. Forgot about the stupid VAG design where it diverts braking force (dynamically) to front / rear and how annoying it is.
In fact, I'd go as far as to say it's dangerous... you get used to x force and do the same at low speed and it's an abrupt experience.
Also, I believe this stupid software arrangement contributes towards the "mooing" from the rear brakes in reverse whilst performing low speed driving.
I currently had OBD11 and I see there are settings for dynamic braking, which can be turned off (which would be a start) and also brake drying (which i want to turn off as even tepid driving has the back discs hot).
I've tried to change the settings and it appears as if the security is accepted, but the changes are reverted.
Can I make these changes with VCDS?
I used to have a Polo GTI 9N3 with exactly the same issue, just silly.
Ridiculous given VAG resources how they can mess this up.
I need the braking consistent, would like to know if a purchase here will help me.
Neil
Neil
