G450 - acceptable pressure difference
kuebk
Poland
C?ID=139835
What is acceptable pressure difference read by G450? By acceptable I mean: ECU not getting errors about insufficent flow and the car rides properly.
Thanks.
Is the exhaust system or engine controller modified or are you just looking for baseline information?
If this is baseline related that would depend on the vehicle in addition to the condition of downstream emissions control devices IMO. Assuming this vehicle is not modified (or broken) I would take a guess at live reading in the 1 to 10 mbar range but you may want to post the scan and a control module map at idle. We may have something similar here already Reference Scans and Maps of Non-Broken Cars
kuebk
Poland
C?ID=139835
Sorry, I didn't put enough details in my last post.
Conditions:
- ECU is stock
- Exhaust is stock
- A3 2.0TDI CBBB
You are right, I'm getting 3-10 mbar reading at idle and IMO this is ok. What I would like to know is how high the pressure difference can be before the problems begin.
By problems I mean:
- the car is sluggish
- errors in ECU about insufficent DPF flow
Here is the autoscan:
Thursday,04,June,2015,02:25:15:35018
VCDS Version: 15.5.0.0 (x64)
Data version: 20150510
VIN: WAUZZZ8P4AAxxxxxx   License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 62 72
          77
VIN: WAUZZZ8P4AAxxxxxx   Mileage: 197460km-122695miles
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 RB    HW: 03L 906 022 BQ
   Component: R4 2,0L EDC G000SG  3615
   Revision: 13H01---    Serial number: AUX7Z0I5FNI0FO
   Coding: 0000172
   Shop #: WSC 84296 792 616680
   VCID: 76E9126B014FF78FA5-8023
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 1442601209230001280B06EA902200423C00
   Shop #: WSC 06314 000 00000
   VCID: 000574B3938BC93F8F-8055
   Part No SW: 8P0 820 043 BK    HW: 8P0 820 043 BK
   Component: KlimavollautomatH09 0130
   Revision: 000355      Serial number: 8P0820043BK
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
   Component: BCM PQ35  M   104 0541
   Revision: 00104 AG
   Coding: 06000A3FF0051AC0207240E00100095C477E2BAA316DD129E40008840040
   Shop #: WSC 06314 123 12345
   VCID: 3261EE7B6DA7ABAF49-8067
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 D  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
Address 10: Park/Steer Assist (J446)       Labels: 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93630916503983
   Coding: 000003
   VCID: 4281BEBBDD071B2FD9-8017
Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0140
   Revision: --------    Serial number: 003FB001N91K
   Coding: 30314238303830303035554A304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FA7878F1655E64746-801A
   Serial number: 3572DRB400008F05032J
   Serial number: 3582DRB400008F350A7Z
   Serial number: 35128RB400004DED203O
   Serial number: 35228RB400004DEB6FB7
   Serial number: 35547RB400004E3612FP
   Serial number: 35647RB400004E36115F
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004042
   VCID: 4689A2AB312F270FF5-8013
   Component: E0221           H02 0030
   Part No SW: 8P0 920 932 C    HW: 8P0 920 932 C
   Component: KOMBIINSTR. VDO H02 0980
   Revision: D0H02002    Serial number: 2245I002009555
   Coding: 0037028
   Shop #: WSC 00152 223 176563
   VCID: 346DE86357B3A59F5B-8061
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4020K09618099A
   Coding: E9A37F06400602002102
   VCID: 66C9422B51EF070F15-8033
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 438FBBBF021D1227D2-8016
   Revision: D0H02002    Serial number: AUX7Z0I5FNI0FO
   Shop #: WSC 03620 001 1048576
Address 37: Navigation        Labels: 8J0-035-192-RNSL.lbl
   Part No SW: 8P0 035 192 P    HW: 8P0 035 192 P
   Component: J0503 RNS-LOW       0250
   Revision: 00012000    Serial number: AUZ1Z1H8163518
   Coding: 0037097
   Shop #: WSC 17537 136 73459
   VCID: 3C7DC0437FE36DDF93-8069
                    Reset counter: 88
                    Mileage: 192705 km
                    Date: 2015.03.28
                    Time: 16:17:01
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 M    HW: 8P0 959 801 M
   Component: Tuer-SG         H04 0100
   Coding: 0004348
   VCID: 458BA5A70C292C17FC-8010
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 233    2901
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2F67E70FBE95864726-807A
   Part No SW: 8P0 959 802 M    HW: 8P0 959 802 M
   Coding: 0004348
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0050
   Coding: 0000028
   VCID: 69D3491740F1287738-803C
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Modul links H03 0004
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Modul rechtsH03 0004
Address 56: Radio        Labels: 8J0-035-192-RNSL.lbl
   Coding: 0037097
                    Reset counter: 88
                    Mileage: 192705 km
                    Date: 2015.03.28
                    Time: 16:17:01
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0000216
   Shop #: WSC 06314 000 1012544
   VCID: 4281BEBB1D071B2FD9-8017
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0000216
   Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0600
   Revision: 00000000    Serial number: 00000005099893
   Coding: 0011422
   VCID: 75EB15671C49FC97AC-8020
End-------------------------(Elapsed Time: 02:09)--------------------------
Hope its clear right now, let me know if not.
Thanks.
Although it may be unrelated to this exact inquiry I looked through your prior posts yesterday and noticed that Uwe asked if the EDC software was up to date. I dug a bit and this EDC (03L 906 022 RB) had a few TPIs/Flash updates over the years. Those includes the following software Levels; 3134, 3615 (which is the current version) and lastly 6552 (which was a cooling function fan problem).
You might want to check out TPI 2024764/10 and have the EGR cooler and pipes checked for excessive carbon (restrictions) followed by the latest flash update which should bump that EDC to SW# 03L 997 021 G with SWL 0508 or higher.
I can't answer the specific question but the values would have to be different depending on the load, time since last regen, driving type, temp, etc. If that vehicle uses an EGR cooler (like our US models) and the EGR cooler, or any part of the exhaust emissions system, is restricted engine performance problems in addition to DPF faults wouldn't be unheard of.
I think this thread would receive more feedback in the Car Repair Support sub-forum.
AIB Wolfgang
These are the values which I prefer to work with.
DPF new or loading up to 15%
engine at idle and operating temperature > 0-10 mbar
>1500/min > 5-20 mbar
>2000/min > 15-35 mbar
DPF loading up to 40-60% (regeneration required)
>1500/min > more than 50-80 mbar
>2000/min > more than 150 mbar
For excample, 2.0 l CR DPF loading 15%
at idle > 5 mbar
2100/min > 20 mbar
3100/min > 65 mbar
4000/min > 105 mbar
Coreyj
C?ID=42955
sorry misread post.
