- Aug 8, 2022
- 16
- 9
- Northern Ireland
- C?ID=526131
I'm having issues with the infotainment system on my 2014 Skoda Octavia (VW MQB platform).
The main issue is the infotainment will not switch on with the ignition, will not connect to bluetooth, and will not communicate with the steering wheel buttons or the display in the dash.
I believe this is related to a freak cold weather snap we've just had in the UK. It might be related to battery or voltage? I've tried taking the negative off the battery for a while but I get the same codes.
I've posted an auto-scan below. The biggest red-flag seems to be the 5F module not working at all! I've checked all fuses and everything appears okay. I haven't done any recent repairs etc. and the car hasn't been tinkered with or worked on in nearly a year.
Tuesday,20,December,2022,13:40:09:31540
VCDS Version: 22.3.1.4 HEX-V2 CB: 0.4615.4
VIN: TMBKK7NE4F005**** License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69 A5 A9
VIN: TMBKK7NE4F005**** Mileage: 146734km-91176miles
Address 01: Engine (J623-CUPA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 EL HW: 04L 907 309 D
Component: R4 2,0L EDC X22 7542
Revision: 83X22--- CVN: 7ED3A2D0
Coding: 12190012033501080000
Shop #: WSC 92521 052 12345
ASAM Dataset: EV_ECM20TDI01104L906021EL 002008
ROD: EV_ECM20TDI01104L906021EL_SK37.rod
VCID: 73B3DCC20B329BD3C2D-8026
VINID: 91D49B6C77951160001420C31879F6F90F
17158 - Databus
U1123 00 [047] - Received Error Message
Mileage: 142826 km
Date: 2022.08.19
Time: 13:34:56
Engine RPM: 0.00 /min
Coolant temperature: 41 °C
Intake air temperature: 44 °C
Voltage terminal 30: 12.040 V
Drivetrain coordinator: brake fault status-Bits 0-7: 17
Acceleration: 0.000 m/s²
18111 - Oxygen (Lambda) Sensor B1 S1
P2237 00 [096] - Pump Current Open Circuit
Mileage: 146122 km
Date: 2022.12.09
Time: 10:11:29
Engine RPM: 3808.00 /min
Normed load value: 89.8 %
Vehicle speed: 79 km/h
Coolant temperature: 90 °C
Intake air temperature: 106 °C
Voltage terminal 30: 14.180 V
Unlearning counter according OBD: 30
Oxygen sensor bank 1 before oxi cat: signal qual. pump flow controller: 14
Oxygen sensor bank 1 before oxi cat: signal qual. temperature regulator: 6
Oxygen sensor bank 1 before oxi cat: electric. corrected Pump current: 0.0000000 A
Oxygen sensor bank 1 before oxi cat: heater activation: 83.893 %
Oxygen sensor bank 1 before oxi cat: electric. corrected Urie sensor value: 0.5376 V
Oxygen sensor bank 1 before oxi cat: adjustable resistor: 89.4 Ohm
Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0789
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 61854000005022
Coding: 1C0793915425096E007A060341C92938C92A9000608294F400630070C009
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: 44D14F1E1E1C6C6BAB7-8010
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [009] - -
[FCAN: Coding of ESP and TSK does not fit together]
Fault Frequency: 218
Reset counter: 238
Mileage: 142826 km
Date: 2022.08.19
Time: 13:34:56
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 254
Mileage: 142986 km
Date: 2022.08.24
Time: 09:06:17
Part No SW: 5E0 907 044 N HW: 5E0 907 044 N
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 02110104000100011005000110101000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
VCID: 303913CEBAA4E0CB7FF-8064
Air quality sensor:
329479 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [008] - Open or Short to Plus
Fault Frequency: 86
Reset counter: 22
Mileage: 143000 km
Date: 2022.08.24
Time: 12:50:49
Voltage terminal 30: 13.2 V
Outside temperature: 20.0 °C
Inside temperature: 27.7 °C
Actual value for fresh air/recirculation air flow flap: 32
Actual value for fresh air/recirculation air flow flap: 0.0 %
Fresh air/recirculating air/back pressure door specified value: 32
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86581907140222
Coding: 0F020B66C24722FB03A04082B11C07280000000000000000000000000000
Shop #: WSC 73430 790 00161
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: 79AFEEEA295EE183881-802C
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140703 041 0570
Serial number: 140708022021
Coding: 0E4DFD
Component: RLHS 037 0059
Serial number: S4Y14M07D21H17M26S53
Coding: 04805D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1410524F1
Serial number: 00000000000030191858
Humidity sensor: interior:
787212 - Windshield Washer Pump
B1261 01 [008] - Electrical Failure
Reset counter: 12
Mileage: 146367 km
Date: 2022.12.15
Time: 10:15:50
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
last_wakeup: gültiges Funktelegramm
Voltage: 13.0 V
Outside temperature: -3.0 °C
133387 - Voltage Supply; Terminal 30 for Central Locking
B140F 13 [008] - Open Circuit
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 D HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0048
Revision: -------- Serial number: 39231419703182
Coding: 0001150101
ASAM Dataset: EV_EPHVA14AU3700000 002022
VCID: 3A2D31E66CD82A9BC1B-806E
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4PDGZJJU
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5B00F2377ACFB3B65-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 907 14
Serial number: 3576U000000F3D144016
Subsystem 2 - Part No SW: ----------- HW: 454 000 507 14
Serial number: 3586U000000DD6013013
Subsystem 3 - Part No SW: ----------- HW: 454 801 207 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R61001B04000000M
Subsystem 4 - Part No SW: ----------- HW: 454 802 906 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R78F60D04000000A
Subsystem 5 - Part No SW: ----------- HW: 454 802 105 14
Component: FrontSensor_D 114 0149
Serial number: 3556V86F6B003000000D
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Revision: -------- Serial number: 18071404220547
Coding: 1400
VCID: 77ABE8D21F4AF7F3FE5-8022
Part No SW: 5E0 920 947 HW: 5E0 920 947
Component: KOMBI 204 4290
Coding: 27AD09006980AE0001007A021000000000000000
Shop #: WSC 73430 031 00161
VCID: 698FBEAA59FE5103781-803C
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 9
Mileage: 146291 km
Date: 2022.12.13
Time: 11:31:19
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_NAV SD_0x32 keine Kommunikation]
Reset counter: 9
Mileage: 146291 km
Date: 2022.12.13
Time: 11:31:19
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002223796
Coding: 030100040F087300EF00026A080F00010001050000000000000000000000
GVL: 01543C1000000000C08C10000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011.rod
VCID: 42DD49060408625B99B-8016
Generator:
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A2011260614
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 1428593903
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
[Globaler Timeout CAN-Infotainment]
Reset counter: 9
Mileage: 146290 km
Date: 2022.12.13
Time: 11:30:53
Terminal 30 power supply: 14.0 V
Terminal 15: On
66564 - Infotainment CAN Bus (SAE Bus E)
U0064 00 [009] - Malfunction
[Bus defekt CAN-Infotainment]
Reset counter: 236
Mileage: 146284 km
Date: 2022.12.13
Time: 10:19:47
Terminal 30 power supply: 13.5 V
Terminal 15: On
65796 - Infotainment CAN in One-Wire Mode
U0072 00 [009] - -
[Eindrahtfehler CAN-Infotainment]
Reset counter: 234
Mileage: 146257 km
Date: 2022.12.13
Time: 08:16:18
Terminal 30 power supply: 11.2 V
Terminal 15: On
8526355 - Voltage Drop in Generator Leads too large
P30DE 00 [008] - -
Reset counter: 23
Mileage: 142837 km
Date: 2022.08.20
Time: 07:34:41
Terminal 30 power supply: 13.7 V
Terminal 15: On
Part No SW: 5Q4 959 393 B HW: 5Q4 959 393 B
Component: TSG FS 009 0014
Serial number: 0000111140715
Coding: 001C00208001040000001100
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003267211
Coding: 1D0200
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 9103
ROD: EV_SteerAssisMQB_010.rod
VCID: 353722DA45C6C5E32C9-8060
Part No SW: 5Q4 959 392 B HW: 5Q4 959 392 B
Component: TSG BFS 009 0014
Serial number: 0000111534605
Coding: 001C00200C01040000001100
VCID: 41DF460A010E7943801-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003279086
Coding: 050200
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03DE02003F000000
Shop #: WSC 73430 790 00063
VCID: 40D9430E0A04704B8FF-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Part No SW: 5Q0 907 383 J HW: 5Q0 907 383 B
Component: Anhaenger H21 0204
Revision: 8C001003 Serial number: 0409994950
Coding: 0100000000000000
VCID: 3E253DF670F006BBFD3-806A
656138 - Bulb for Right Tail Light on Trailer
C10F4 15 [008] - Open or Short to Plus
Fault Frequency: 15
Reset counter: 6
Mileage: 145450 km
Date: 2022.11.19
Time: 15:18:14
656394 - Bulb for Left Tail Light on Trailer
C10F5 15 [008] - Open or Short to Plus
Fault Frequency: 15
Reset counter: 6
Mileage: 145450 km
Date: 2022.11.19
Time: 15:18:13
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 10000106201
Coding: 0100010001030303000300000000010101
ROD: EV_MFKBoschAU370.rod
VCID: 3B2334E263E21393DAD-806E
7536641 - Databus
[MAINUNIT_01_TO_FAILURE]
Fault Frequency: 52
Reset counter: 238
Mileage: 146286 km
Date: 2022.12.13
Time: 11:21:00
Control Module temperature: 13 °C
Outside temperature: 4.0 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 13.8 V
Terminal 15 on: 11.7 s
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 140620201151
End----------(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.1V)-----------
