Resolved 2007 VW Golf Steering 00778 & 02546
Resolved
Souriau
Newry, NI
C?ID=86928
A VW Golf arrived with me with the steering light MIL on aswell as ESP.
The car had a flat battery, they replaced the batery and can not get rid of the DTC for 0x44.
I came across another post with same issue I have but it wasn't completed to know the final outcome.
I have also followed Jack@European_Parts post#3.
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Control Module Part Number: 1K2 909 144 L
Component and/or Version: EPS_ZFLS Kl.068 H07 1806
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 3522E8895CF60B2561-8060
to:
Software Coding:
Work Shop Code: WSC 18261 028 18261
Frame:
And then follow the calibration procedure but still same DTC.
Can anyone help?
Wednesday,14,December,2022,14:51:52:46973
VCDS Version: 22.10.0.1  HEX-NET CB: 0.4623.4
Workshop Code: 000 18261 018261
VIN: WVWZZZ1KZ7W199812   License Plate:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ7W199812   Mileage: 319970km-198820miles
Address 01: Engine        Labels: 03G-906-016-BDJ.clb
   Part No SW: 03G 906 016 LD    HW: 03G 906 016 LD
   Component: R4 2,0L EDC 0000SG  0544
   Revision: 12345678    Serial number: VWZ7Z0G8049553
   Coding: 0000071
   Shop #: WSC 01279 785 00200
   VCID: 70AC199D63146E0D72-8024
   VINID: 9E69EAAAA05BA879C1249201089DF6C72A
Readiness: 0 0 1 1 1
   Revision: 00H11001
   Coding: 0021121
   VCID: 73A61691120255158F-8026
   Part No: 1K0 820 047 GK
   Component: Climatic PQ35   120 0606
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006685161
   Coding: 00890F2700041500471400001400000000087B075C0001
   Shop #: WSC 01287 785 00200
   VCID: 6B960EF14A328DD547-803E
   Component: Wischer 060207 020  0501
   Coding: 00038805
   Shop #: WSC 01287
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD11L860
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D32F0A964C6D365A9-8068
   Subsystem 1 - Serial number: 6332MSME16525957B
   Subsystem 2 - Serial number: 6342MSME16520F4DI
   Subsystem 3 - Serial number: 6352QSME21512C112
   Subsystem 4 - Serial number: 6362QSME21193835A
   Part No SW: 1K0 953 549 BB    HW: 1K0 953 549 BB
   Component: Lenksäulenmodul 036 0070
   Coding: 0000002
   Part No SW: 1K0 920 953 N    HW: 1K0 920 953 N
   Revision: V0003000    Serial number: VWZ7Z0G8049553
   Coding: 0003403
   VCID: 3620EF8541F0003D68-8062
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 120207F1002033
   Coding: 3D0F034007000001
   VCID: 2F2EDAE1BEAA31F52B-807A
                    Reset counter: 37
                    Mileage: 319845 km
                    Time: 10:59:53
   Component: IMMO            VDD 1610
   Component: Tuer-SG         005 0984
   Coding: 0000564
   VCID: 383CE1BD4BE4F64D7A-806C
00096 - Drivers Door Central Locking (Safe) Motor (V161)
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.068 H07 1806
02546 - Steering Limit Stop
                    Mileage: 319950 km
                    Temperature: 20.0°C
                    Voltage: 13.80 V
                    Voltage: 13.60 V
   Part No: 1K0 959 433 AJ
   Coding: 00C802087F2D8405485A038010CC
   VCID: 78BC21BD0B64364DBA-802C
   Coding: 0000564
   VCID: 393AE4B970EEEF4585-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G4498166
   Coding: 0020200
   VCID: 373EE28146FAF93573-8062
End----------(Elapsed Time: 01:01, VBatt start/end: 14.2V/14.4V)-----------
After recoding 0x44 and clearing DTC. Carried out basic calibration for the G85 in bioth 0x03 and 0x44.
Saturday,17,December,2022,16:02:32:46973
VIN: WVWZZZ1KZ7W199812   Mileage: 319980km-198826miles
   Coding: 0000071
   Revision: 00H11001
   Coding: 0021121
   Coding: 00038805
   Shop #: WSC 01287
   Coding: 0013112
   Coding: 0000002
   Coding: 0003403
   Shop #: WSC 18261 785 18261
                    Reset counter: 37
                    Mileage: 319989 km
                    Time: 15:17:21
                    Mileage: 319980 km
                    Temperature: 9.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Coding: 0000564
   Coding: 0020200
End----------(Elapsed Time: 01:14, VBatt start/end: 12.0V/12.1V)-----------
My guess (and it's only a guess) is that the angle sensor in the rack is FUBAR. The ABS isn't complaining about it because the ABS doesn't use data from that sensor, but rather data from the sensor at (just under) the steering wheel.
Souriau
Newry, NI
C?ID=86928
I got a replacement steering rack and still having the same fault codes.
Any ideas?
Saturday,07,January,2023,17:03:32:46973
VIN: WVWZZZ1KZ7W199812   Mileage: 320010km-198844miles
   Coding: 0000071
   VCID: F0AC999DE314EE0DF2-80A4
   Revision: 00H11001
   Coding: 0021121
   VCID: F3A696919202D5150F-80A6
   VCID: EB968EF1CA320DD5C7-80BE
   Coding: 00038805
   Shop #: WSC 01287
   Coding: 0013112
   VCID: BD3270A9E4C6536529-80E8
   Coding: 0000002
   Coding: 0003403
   VCID: B6206F85C1F0803DE8-80E2
   VCID: AF2E5AE13EAAB1F5AB-80FA
                    Reset counter: 37
                    Mileage: 320010 km
                    Time: 16:59:57
   Coding: 0000564
   VCID: B83C61BDCBE4764DFA-80EC
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 18261 028 18261
                    Mileage: 320000 km
                    Temperature: 15.0°C
                    Voltage: 13.70 V
                    Voltage: 13.50 V
   VCID: F8BCA1BD8B64B64D3A-80AC
   Coding: 0000564
   VCID: B93A64B9F0EE6F4505-80EC
   Coding: 0020200
   VCID: B73E6281C6FA7935F3-80E2
End----------(Elapsed Time: 01:08, VBatt start/end: 13.9V/13.9V)-----------
Souriau
Newry, NI
C?ID=86928
MVB and Adaptions valuse for Steering 44
;SW:1K2-909-144-M   HW: ---  Steering Assist
;Component:EPS_ZFLS Kl.069 H08 1901, Coding:
;Saturday,07,January,2023,17:04:55:46973
;VCDS Version: Release 22.10.0  Data version: 20221026 DS344.0
;VCID: B6206F85C1F0803DE8-80E2
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,15.0°C,,-0.125 Nm,,0 /min,, ,,
2,13.70 V,,13.50 V,, ,,0,,
3,832 /min,,0.0 km/h,,Engine ON,, ,,
4,2,,Term 15 On,, ,, ,,
5,-0.125 Nm,,-0.125 Nm,,-0.125 Nm,,-0.5 Nm,,
6,15.0°C,,ON,,-44.80°,,0.00°,,
7,0.00°,,0.0°/s,,OK,,SteerAng n.Init,,
8,0,,3,, ,, ,,
9,69,,Normal 3,, ,, ,,
80,ZFO-103 03.12.07 00H08000 4080 0261,,
125,ABS 1,,Steer. ang. 1,,Engine 1,,Instruments 1,,
126,Gateway 1,, ,,Cent. Elect. 1,,El.Ign.Lock 1,,
;Saturday,07,January,2023,17:05:26:46973
Channel,,Field 1,Field 2,Field 3,Field 4,
01,,ERROR:,Channel 01,Not,Available,
02,0,K-Lamp 2-col.,N/A,N/A,N/A,
03,0, ,N/A,N/A,N/A,
04,2, ,N/A,N/A,N/A,
05,0, ,N/A,N/A,N/A,
06,,ERROR:,Channel 06,Not,Available,
07,0,OFF,N/A,N/A,N/A,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
11,,ERROR:,Channel 11,Not,Available,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,,ERROR:,Channel 22,Not,Available,
23,,ERROR:,Channel 23,Not,Available,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
181,,ERROR:,Channel 181,Not,Available,
182,,ERROR:,Channel 182,Not,Available,
183,,ERROR:,Channel 183,Not,Available,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Channel 191,Not,Available,
192,,ERROR:,Channel 192,Not,Available,
193,,ERROR:,Channel 193,Not,Available,
194,,ERROR:,Channel 194,Not,Available,
195,,ERROR:,Channel 195,Not,Available,
196,,ERROR:,Channel 196,Not,Available,
197,,ERROR:,Channel 197,Not,Available,
198,,ERROR:,Channel 198,Not,Available,
199,,ERROR:,Channel 199,Not,Available,
200,,ERROR:,Channel 200,Not,Available,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Channel 202,Not,Available,
203,,ERROR:,Channel 203,Not,Available,
204,,ERROR:,Channel 204,Not,Available,
205,,ERROR:,Channel 205,Not,Available,
206,,ERROR:,Channel 206,Not,Available,
207,,ERROR:,Channel 207,Not,Available,
208,,ERROR:,Channel 208,Not,Available,
209,,ERROR:,Channel 209,Not,Available,
210,,ERROR:,Channel 210,Not,Available,
211,,ERROR:,Channel 211,Not,Available,
212,,ERROR:,Channel 212,Not,Available,
213,,ERROR:,Channel 213,Not,Available,
214,,ERROR:,Channel 214,Not,Available,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,,ERROR:,Channel 221,Not,Available,
222,,ERROR:,Channel 222,Not,Available,
223,,ERROR:,Channel 223,Not,Available,
224,,ERROR:,Channel 224,Not,Available,
225,,ERROR:,Channel 225,Not,Available,
226,,ERROR:,Channel 226,Not,Available,
227,,ERROR:,Channel 227,Not,Available,
228,,ERROR:,Channel 228,Not,Available,
229,,ERROR:,Channel 229,Not,Available,
230,,ERROR:,Channel 230,Not,Available,
231,,ERROR:,Channel 231,Not,Available,
232,,ERROR:,Channel 232,Not,Available,
233,,ERROR:,Channel 233,Not,Available,
234,,ERROR:,Channel 234,Not,Available,
235,,ERROR:,Channel 235,Not,Available,
236,,ERROR:,Channel 236,Not,Available,
237,,ERROR:,Channel 237,Not,Available,
238,,ERROR:,Channel 238,Not,Available,
239,,ERROR:,Channel 239,Not,Available,
240,,ERROR:,Channel 240,Not,Available,
241,,ERROR:,Channel 241,Not,Available,
242,,ERROR:,Channel 242,Not,Available,
243,,ERROR:,Channel 243,Not,Available,
244,,ERROR:,Channel 244,Not,Available,
245,,ERROR:,Channel 245,Not,Available,
246,,ERROR:,Channel 246,Not,Available,
247,,ERROR:,Channel 247,Not,Available,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
Souriau
Newry, NI
C?ID=86928
MVB and Adaptions valuse for ABS 03
;SW:1K0-907-379-AC   HW:1K0-907-379-AC ---  ABS Brakes
;Component:ESP FRONT MK60      0101, Coding:0021121
;Saturday,07,January,2023,16:54:41:46973
;VCID: F3A696919202D5150F-80A6
1,0.0 km/h,Speed,0.0 km/h,Speed,0.0 km/h,Speed,0.0 km/h,Speed,
3,Not Oper., ,OFF, ,OFF, ,ON, ,
4,0.00°,Steering Angle,-0.08 m/s^2,Lateral Accel.,-0.90°/s,Turn Rate,N/A,,
5,0.46 bar,Pressure,SteerAng n.Init, ,N/A,,N/A,,
7,Not Oper., ,N/A,,N/A,,N/A,,
10, , ,OFF, ,N/A,,N/A,,
11,0,Count,0,Count,0,Count,N/A,,
12,0,Count,0,Count,0,Count,N/A,,
13,0,Count,0,Count,0,Count,N/A,,
14,0,Count,0,Count,0,Count,N/A,,
16,0 km,Mileage,N/A,,N/A,,N/A,,
17,0 km,Mileage,N/A,,N/A,,N/A,,
18,Not Oper., ,Not Oper., ,N/A,,N/A,,
21,128,Count,4352,Count,0,Count,256,Count,
31,50000,Count,50000,Count,50000,Count,N/A,,
32,0,Count,0,Count,0,Count,0,Count,
87,DC77B09Y3C,,
90,59,Count,N/A,,N/A,,N/A,,
91,ZQP154F1.IC1,Count,
98,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
99,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
125,Engine 1, ,Steer. ang. 1, , , , , ,
126,Instruments 1, ,Gateway 1, ,Immo 1, ,Steering 1, ,
225,7.0,(no units),1.0,(no units),0.0,(no units),0.0,(no units),
226,0.0,(no units),0.0,(no units),0.0,(no units),2.0,(no units),
;Saturday,07,January,2023,16:55:20:46973
01,1,Tire Pressure,16 inch,N/A,N/A,
02,,ERROR:,Channel 02,Not,Available,
03,,ERROR:,Channel 03,Not,Available,
04,,ERROR:,Channel 04,Not,Available,
05,,ERROR:,Channel 05,Not,Available,
07,,ERROR:,Channel 07,Not,Available,
09,0,Brake assist.,center,N/A,N/A,
10,1,Brake Booster,Enabled,N/A,N/A,
55,1,Brake discs,wiper,Enabled,N/A,
56,0,Trailer,Stabiliz.,Deactivated,N/A,
57,1,Steer,recommend,Enabled,N/A,
90,1,ESP On,N/A,N/A,N/A,
91,0,Automatic,ESP-switch-on,Speed,Deactivated,
92,0,Automatic,ESP-switch-on,Damp.failure,Deactivated,
93,0,Sport,Startup mode,Deactivated,N/A,
94,0,ParkSteerAss.,Not Installed,N/A,N/A,
Souriau
Newry, NI
C?ID=86928
I took the steering angle sensor out of the steering column to see what fault code am I getting.
I am trying to determine with G85 sensor is the problem.
Now I need to find why the steering column G85 is the problem.
What is confusing me is the Gateway list scan below show "00-Steering Angle Sensor -- Status: OK 0000" when I actually removed the steering angle sensot G85.
Is this some software issue?
Monday,09,January,2023,15:06:09:46973
   Coding: 0000071
   Revision: 00H11001
   Coding: 0021121
            014 - Defective
   Coding: 00038805
   Shop #: WSC 01287
   Coding: 0013112
   Coding: 0000002
   Coding: 0003403
                    Reset counter: 37
                    Mileage: 320010 km
                    Time: 15:04:23
   Coding: 0000564
                    Mileage: 320000 km
                    Temperature: 8.0°C
                    Voltage: 14.40 V
                    Voltage: 14.20 V
            014 - Defective
   Coding: 0000564
   Coding: 0020200
End----------(Elapsed Time: 01:10, VBatt start/end: 14.4V/14.5V)-----------
Perhaps a software issue in the car. VCDS reports what the car knows.
Souriau
Newry, NI
C?ID=86928
OK,I have completed a ABS whell sensor speed test and logged the data.
Even ther was no DTC in the ABS.
From the log listed below, Is this the rear left wheel bearing fault?
I will go ahead and install a new wheel bearing.
S
Thu,Jan,26,2023,14:47:30 -VCID:73A94CCF4AAB38ADE693FB-8026,VCDS Mobile: 0.4623
1K0 907 379 AC,ADVMB,ESP FRONT MK60 0101,
,,G001,F0,G001,F1,G001,F2,G001,F3,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Group 1 - Field 0,TIME,Group 1 - Field 1,TIME,Group 1 - Field 2,TIME,Group 1 - Field 3,,,,,,,,,,,,,,,,,
,STAMP,Speed,STAMP,Speed,STAMP,Speed,STAMP,Speed,,,,,,,,,,,,,,,,,
,, km/h,, km/h,, km/h,, km/h,,,,,,,,,,,,,,,,,
,0.00,0.0,0.00,0.0,0.00,0.0,0.00,0.0,,,,,,,,,,,,,,,,,
,0.14,0.0,0.14,0.0,0.14,0.0,0.14,0.0,,,,,,,,,,,,,,,,,
,0.35,0.0,0.35,0.0,0.35,0.0,0.35,0.0,,,,,,,,,,,,,,,,,
,0.55,0.0,0.55,0.0,0.55,0.0,0.55,0.0,,,,,,,,,,,,,,,,,
,0.76,0.0,0.76,0.0,0.76,0.0,0.76,0.0,,,,,,,,,,,,,,,,,
,0.96,0.0,0.96,0.0,0.96,0.0,0.96,0.0,,,,,,,,,,,,,,,,,
,1.17,0.0,1.17,0.0,1.17,0.0,1.17,0.0,,,,,,,,,,,,,,,,,
,1.37,0.0,1.37,0.0,1.37,0.0,1.37,0.0,,,,,,,,,,,,,,,,,
,1.58,0.0,1.58,0.0,1.58,0.0,1.58,0.0,,,,,,,,,,,,,,,,,
,1.78,0.0,1.78,0.0,1.78,0.0,1.78,0.0,,,,,,,,,,,,,,,,,
,1.99,0.0,1.99,0.0,1.99,0.0,1.99,0.0,,,,,,,,,,,,,,,,,
,2.19,0.0,2.19,0.0,2.19,0.0,2.19,0.0,,,,,,,,,,,,,,,,,
,2.40,0.0,2.40,0.0,2.40,0.0,2.40,0.0,,,,,,,,,,,,,,,,,
,2.60,0.0,2.60,0.0,2.60,0.0,2.60,0.0,,,,,,,,,,,,,,,,,
,2.81,0.0,2.81,0.0,2.81,0.0,2.81,0.0,,,,,,,,,,,,,,,,,
,3.01,0.0,3.01,0.0,3.01,0.0,3.01,0.0,,,,,,,,,,,,,,,,,
,3.22,0.0,3.22,0.0,3.22,0.0,3.22,0.0,,,,,,,,,,,,,,,,,
,3.42,0.0,3.42,0.0,3.42,0.0,3.42,0.0,,,,,,,,,,,,,,,,,
,3.63,0.0,3.63,0.0,3.63,0.0,3.63,0.0,,,,,,,,,,,,,,,,,
,3.83,0.0,3.83,0.0,3.83,0.0,3.83,0.0,,,,,,,,,,,,,,,,,
,4.06,0.0,4.06,0.0,4.06,0.0,4.06,0.0,,,,,,,,,,,,,,,,,
,4.24,0.0,4.24,0.0,4.24,1.0,4.24,0.0,,,,,,,,,,,,,,,,,
,4.45,0.0,4.45,0.0,4.45,0.0,4.45,0.0,,,,,,,,,,,,,,,,,
,4.65,1.0,4.65,1.0,4.65,2.0,4.65,1.0,,,,,,,,,,,,,,,,,
,4.86,1.0,4.86,1.0,4.86,1.0,4.86,1.0,,,,,,,,,,,,,,,,,
,5.08,1.0,5.08,1.0,5.08,1.0,5.08,1.0,,,,,,,,,,,,,,,,,
,5.27,2.0,5.27,2.0,5.27,5.0,5.27,2.0,,,,,,,,,,,,,,,,,
,5.47,2.0,5.47,2.0,5.47,1.0,5.47,2.0,,,,,,,,,,,,,,,,,
,5.68,2.0,5.68,2.0,5.68,2.0,5.68,2.0,,,,,,,,,,,,,,,,,
,5.88,2.0,5.88,2.0,5.88,2.0,5.88,2.0,,,,,,,,,,,,,,,,,
,6.11,2.0,6.11,2.0,6.11,2.0,6.11,2.0,,,,,,,,,,,,,,,,,
,6.29,2.0,6.29,3.0,6.29,2.0,6.29,3.0,,,,,,,,,,,,,,,,,
,6.50,3.0,6.50,3.0,6.50,2.0,6.50,3.0,,,,,,,,,,,,,,,,,
,6.70,3.0,6.70,3.0,6.70,3.0,6.70,3.0,,,,,,,,,,,,,,,,,
,6.91,3.0,6.91,4.0,6.91,3.0,6.91,4.0,,,,,,,,,,,,,,,,,
,7.13,3.0,7.13,4.0,7.13,3.0,7.13,4.0,,,,,,,,,,,,,,,,,
,7.32,3.0,7.32,4.0,7.32,4.0,7.32,4.0,,,,,,,,,,,,,,,,,
,7.52,4.0,7.52,4.0,7.52,4.0,7.52,4.0,,,,,,,,,,,,,,,,,
,7.73,4.0,7.73,5.0,7.73,4.0,7.73,4.0,,,,,,,,,,,,,,,,,
,7.93,4.0,7.93,5.0,7.93,4.0,7.93,5.0,,,,,,,,,,,,,,,,,
,8.16,5.0,8.16,5.0,8.16,4.0,8.16,5.0,,,,,,,,,,,,,,,,,
,8.34,5.0,8.34,6.0,8.34,5.0,8.34,5.0,,,,,,,,,,,,,,,,,
,8.55,5.0,8.55,6.0,8.55,5.0,8.55,6.0,,,,,,,,,,,,,,,,,
,8.75,5.0,8.75,6.0,8.75,5.0,8.75,6.0,,,,,,,,,,,,,,,,,
,8.96,6.0,8.96,7.0,8.96,6.0,8.96,7.0,,,,,,,,,,,,,,,,,
,9.18,6.0,9.18,7.0,9.18,6.0,9.18,7.0,,,,,,,,,,,,,,,,,
,9.37,7.0,9.37,8.0,9.37,13.0,9.37,7.0,,,,,,,,,,,,,,,,,
,9.57,7.0,9.57,8.0,9.57,7.0,9.57,8.0,,,,,,,,,,,,,,,,,
,9.78,7.0,9.78,8.0,9.78,7.0,9.78,8.0,,,,,,,,,,,,,,,,,
,9.98,7.0,9.98,8.0,9.98,9.0,9.98,8.0,,,,,,,,,,,,,,,,,
,10.21,8.0,10.21,8.0,10.21,8.0,10.21,8.0,,,,,,,,,,,,,,,,,
,10.39,8.0,10.39,9.0,10.39,8.0,10.39,9.0,,,,,,,,,,,,,,,,,
,10.60,8.0,10.60,9.0,10.60,9.0,10.60,9.0,,,,,,,,,,,,,,,,,
,10.80,8.0,10.80,9.0,10.80,10.0,10.80,9.0,,,,,,,,,,,,,,,,,
,11.01,9.0,11.01,9.0,11.01,9.0,11.01,9.0,,,,,,,,,,,,,,,,,
,11.22,9.0,11.22,10.0,11.22,9.0,11.22,10.0,,,,,,,,,,,,,,,,,
,11.42,9.0,11.42,10.0,11.42,19.0,11.42,10.0,,,,,,,,,,,,,,,,,
,11.62,10.0,11.62,10.0,11.62,10.0,11.62,10.0,,,,,,,,,,,,,,,,,
,11.83,10.0,11.83,10.0,11.83,10.0,11.83,10.0,,,,,,,,,,,,,,,,,
,12.03,10.0,12.03,10.0,12.03,10.0,12.03,10.0,,,,,,,,,,,,,,,,,
,12.25,11.0,12.25,11.0,12.25,11.0,12.25,10.0,,,,,,,,,,,,,,,,,
,12.44,11.0,12.44,11.0,12.44,11.0,12.44,11.0,,,,,,,,,,,,,,,,,
,12.65,11.0,12.65,11.0,12.65,11.0,12.65,11.0,,,,,,,,,,,,,,,,,
,12.85,12.0,12.85,11.0,12.85,12.0,12.85,11.0,,,,,,,,,,,,,,,,,
,13.06,12.0,13.06,11.0,13.06,12.0,13.06,11.0,,,,,,,,,,,,,,,,,
,13.26,12.0,13.26,12.0,13.26,25.0,13.26,11.0,,,,,,,,,,,,,,,,,
,13.47,13.0,13.47,12.0,13.47,11.0,13.47,12.0,,,,,,,,,,,,,,,,,
,13.67,13.0,13.67,12.0,13.67,13.0,13.67,12.0,,,,,,,,,,,,,,,,,
,13.88,14.0,13.88,12.0,13.88,15.0,13.88,12.0,,,,,,,,,,,,,,,,,
,14.08,14.0,14.08,13.0,14.08,14.0,14.08,13.0,,,,,,,,,,,,,,,,,
,14.29,14.0,14.29,13.0,14.29,15.0,14.29,13.0,,,,,,,,,,,,,,,,,
,14.49,15.0,14.49,14.0,14.49,15.0,14.49,14.0,,,,,,,,,,,,,,,,,
,14.70,15.0,14.70,14.0,14.70,15.0,14.70,14.0,,,,,,,,,,,,,,,,,
,14.90,16.0,14.90,15.0,14.90,16.0,14.90,15.0,,,,,,,,,,,,,,,,,
,15.11,16.0,15.11,15.0,15.11,18.0,15.11,15.0,,,,,,,,,,,,,,,,,
,15.31,17.0,15.31,16.0,15.31,16.0,15.31,16.0,,,,,,,,,,,,,,,,,
,15.52,17.0,15.52,16.0,15.52,19.0,15.52,16.0,,,,,,,,,,,,,,,,,
,15.72,17.0,15.72,16.0,15.72,17.0,15.72,16.0,,,,,,,,,,,,,,,,,
,15.93,17.0,15.93,17.0,15.93,17.0,15.93,17.0,,,,,,,,,,,,,,,,,
,16.13,17.0,16.13,17.0,16.13,17.0,16.13,17.0,,,,,,,,,,,,,,,,,
,16.34,17.0,16.34,17.0,16.34,22.0,16.34,17.0,,,,,,,,,,,,,,,,,
,16.54,17.0,16.54,17.0,16.54,17.0,16.54,17.0,,,,,,,,,,,,,,,,,
,16.75,17.0,16.75,17.0,16.75,30.0,16.75,17.0,,,,,,,,,,,,,,,,,
,16.95,17.0,16.95,17.0,16.95,17.0,16.95,17.0,,,,,,,,,,,,,,,,,
,17.16,17.0,17.16,17.0,17.16,34.0,17.16,17.0,,,,,,,,,,,,,,,,,
,17.35,17.0,17.36,17.0,17.36,36.0,17.36,17.0,,,,,,,,,,,,,,,,,
,17.57,18.0,17.57,18.0,17.57,30.0,17.57,18.0,,,,,,,,,,,,,,,,,
,17.77,18.0,17.77,18.0,17.77,18.0,17.77,18.0,,,,,,,,,,,,,,,,,
,17.98,18.0,17.98,18.0,17.98,31.0,17.98,18.0,,,,,,,,,,,,,,,,,
,18.18,18.0,18.18,19.0,18.18,19.0,18.18,19.0,,,,,,,,,,,,,,,,,
,18.39,19.0,18.39,19.0,18.39,18.0,18.39,19.0,,,,,,,,,,,,,,,,,
,18.59,19.0,18.59,19.0,18.59,19.0,18.59,19.0,,,,,,,,,,,,,,,,,
,18.80,19.0,18.80,19.0,18.80,20.0,18.80,20.0,,,,,,,,,,,,,,,,,
,19.00,20.0,19.00,20.0,19.00,20.0,19.00,19.0,,,,,,,,,,,,,,,,,
,19.21,20.0,19.21,20.0,19.21,19.0,19.21,20.0,,,,,,,,,,,,,,,,,
,19.41,20.0,19.41,20.0,19.41,17.0,19.41,20.0,,,,,,,,,,,,,,,,,
,19.61,20.0,19.61,20.0,19.62,20.0,19.62,20.0,,,,,,,,,,,,,,,,,
,19.82,20.0,19.82,20.0,19.82,20.0,19.82,20.0,,,,,,,,,,,,,,,,,
,20.03,20.0,20.03,20.0,20.03,22.0,20.03,20.0,,,,,,,,,,,,,,,,,
,20.23,20.0,20.23,20.0,20.23,20.0,20.23,20.0,,,,,,,,,,,,,,,,,
,20.43,21.0,20.44,21.0,20.44,21.0,20.44,21.0,,,,,,,,,,,,,,,,,
,20.64,21.0,20.64,21.0,20.64,21.0,20.64,21.0,,,,,,,,,,,,,,,,,
,20.85,21.0,20.85,21.0,20.85,43.0,20.85,21.0,,,,,,,,,,,,,,,,,
,21.05,22.0,21.05,21.0,21.05,32.0,21.05,22.0,,,,,,,,,,,,,,,,,
,21.27,22.0,21.28,22.0,21.28,22.0,21.28,22.0,,,,,,,,,,,,,,,,,
,21.46,22.0,21.46,22.0,21.46,21.0,21.46,22.0,,,,,,,,,,,,,,,,,
,21.67,23.0,21.67,22.0,21.67,36.0,21.67,22.0,,,,,,,,,,,,,,,,,
,21.87,23.0,21.87,23.0,21.87,23.0,21.87,23.0,,,,,,,,,,,,,,,,,
,22.08,23.0,22.08,23.0,22.08,25.0,22.08,23.0,,,,,,,,,,,,,,,,,
,22.30,23.0,22.30,23.0,22.30,23.0,22.30,23.0,,,,,,,,,,,,,,,,,
,22.49,23.0,22.49,23.0,22.49,35.0,22.49,23.0,,,,,,,,,,,,,,,,,
,22.69,24.0,22.69,24.0,22.69,23.0,22.69,24.0,,,,,,,,,,,,,,,,,
,22.90,24.0,22.90,24.0,22.90,23.0,22.90,24.0,,,,,,,,,,,,,,,,,
,23.10,24.0,23.10,24.0,23.10,36.0,23.10,24.0,,,,,,,,,,,,,,,,,
,23.33,24.0,23.33,24.0,23.33,25.0,23.33,24.0,,,,,,,,,,,,,,,,,
,23.51,24.0,23.51,24.0,23.51,33.0,23.51,24.0,,,,,,,,,,,,,,,,,
,23.72,24.0,23.72,24.0,23.72,26.0,23.72,24.0,,,,,,,,,,,,,,,,,
,23.92,24.0,23.92,24.0,23.92,36.0,23.92,24.0,,,,,,,,,,,,,,,,,
,24.13,24.0,24.13,24.0,24.13,24.0,24.13,24.0,,,,,,,,,,,,,,,,,
,24.35,24.0,24.35,24.0,24.35,24.0,24.35,24.0,,,,,,,,,,,,,,,,,
,24.53,23.0,24.53,23.0,24.53,38.0,24.53,23.0,,,,,,,,,,,,,,,,,
,24.74,23.0,24.74,23.0,24.74,23.0,24.74,23.0,,,,,,,,,,,,,,,,,
,24.95,23.0,24.95,23.0,24.95,23.0,24.95,23.0,,,,,,,,,,,,,,,,,
,25.15,22.0,25.15,22.0,25.15,23.0,25.15,22.0,,,,,,,,,,,,,,,,,
,25.38,22.0,25.38,22.0,25.38,23.0,25.38,22.0,,,,,,,,,,,,,,,,,
,25.56,22.0,25.56,22.0,25.56,23.0,25.56,22.0,,,,,,,,,,,,,,,,,
,25.77,23.0,25.77,22.0,25.77,24.0,25.77,22.0,,,,,,,,,,,,,,,,,
,25.97,23.0,25.97,23.0,25.97,35.0,25.97,22.0,,,,,,,,,,,,,,,,,
,26.17,23.0,26.17,23.0,26.17,23.0,26.17,23.0,,,,,,,,,,,,,,,,,
,26.40,23.0,26.40,23.0,26.40,24.0,26.40,23.0,,,,,,,,,,,,,,,,,
,26.59,23.0,26.59,23.0,26.59,36.0,26.59,23.0,,,,,,,,,,,,,,,,,
,26.79,24.0,26.79,23.0,26.79,24.0,26.79,23.0,,,,,,,,,,,,,,,,,
,27.00,24.0,27.00,24.0,27.00,34.0,27.00,23.0,,,,,,,,,,,,,,,,,
,27.19,24.0,27.19,24.0,27.19,26.0,27.20,24.0,,,,,,,,,,,,,,,,,
,27.43,24.0,27.43,24.0,27.43,37.0,27.43,24.0,,,,,,,,,,,,,,,,,
,27.61,25.0,27.61,24.0,27.61,25.0,27.61,24.0,,,,,,,,,,,,,,,,,
,27.82,25.0,27.82,25.0,27.82,25.0,27.82,24.0,,,,,,,,,,,,,,,,,
,28.01,25.0,28.01,25.0,28.01,38.0,28.01,25.0,,,,,,,,,,,,,,,,,
,28.23,25.0,28.23,25.0,28.23,38.0,28.23,25.0,,,,,,,,,,,,,,,,,
,28.43,25.0,28.43,25.0,28.43,25.0,28.43,25.0,,,,,,,,,,,,,,,,,
,28.64,26.0,28.64,25.0,28.64,31.0,28.64,25.0,,,,,,,,,,,,,,,,,
,28.83,26.0,28.83,25.0,28.83,23.0,28.83,25.0,,,,,,,,,,,,,,,,,
,29.05,26.0,29.05,25.0,29.05,28.0,29.05,25.0,,,,,,,,,,,,,,,,,
,29.25,25.0,29.25,25.0,29.25,25.0,29.25,25.0,,,,,,,,,,,,,,,,,
,29.45,25.0,29.45,25.0,29.45,25.0,29.45,25.0,,,,,,,,,,,,,,,,,
,29.66,25.0,29.66,25.0,29.66,25.0,29.66,25.0,,,,,,,,,,,,,,,,,
,29.87,25.0,29.87,25.0,29.87,33.0,29.87,25.0,,,,,,,,,,,,,,,,,
,30.07,25.0,30.07,25.0,30.07,25.0,30.07,25.0,,,,,,,,,,,,,,,,,
,30.27,25.0,30.27,25.0,30.27,25.0,30.27,25.0,,,,,,,,,,,,,,,,,
,30.48,24.0,30.48,24.0,30.48,25.0,30.48,25.0,,,,,,,,,,,,,,,,,
,30.69,24.0,30.69,24.0,30.69,37.0,30.69,24.0,,,,,,,,,,,,,,,,,
,30.89,24.0,30.89,24.0,30.89,24.0,30.89,24.0,,,,,,,,,,,,,,,,,
,31.09,24.0,31.09,24.0,31.09,38.0,31.09,24.0,,,,,,,,,,,,,,,,,
,31.30,24.0,31.30,24.0,31.30,24.0,31.30,24.0,,,,,,,,,,,,,,,,,
,31.51,24.0,31.51,24.0,31.51,37.0,31.51,24.0,,,,,,,,,,,,,,,,,
,31.71,24.0,31.71,24.0,31.71,24.0,31.71,24.0,,,,,,,,,,,,,,,,,
,31.92,25.0,31.92,25.0,31.92,25.0,31.92,25.0,,,,,,,,,,,,,,,,,
,32.12,25.0,32.12,25.0,32.12,38.0,32.12,25.0,,,,,,,,,,,,,,,,,
,32.33,25.0,32.33,24.0,32.33,37.0,32.33,25.0,,,,,,,,,,,,,,,,,
,32.53,25.0,32.53,25.0,32.53,25.0,32.53,25.0,,,,,,,,,,,,,,,,,
,32.74,25.0,32.74,25.0,32.74,25.0,32.74,25.0,,,,,,,,,,,,,,,,,
,32.94,25.0,32.94,25.0,32.94,38.0,32.94,25.0,,,,,,,,,,,,,,,,,
,33.15,25.0,33.15,25.0,33.15,38.0,33.15,25.0,,,,,,,,,,,,,,,,,
,33.35,25.0,33.35,25.0,33.35,25.0,33.35,25.0,,,,,,,,,,,,,,,,,
,33.56,25.0,33.56,25.0,33.56,25.0,33.56,25.0,,,,,,,,,,,,,,,,,
,33.76,25.0,33.76,25.0,33.76,40.0,33.76,25.0,,,,,,,,,,,,,,,,,
,33.97,24.0,33.97,25.0,33.97,34.0,33.97,25.0,,,,,,,,,,,,,,,,,
,34.17,24.0,34.17,25.0,34.17,24.0,34.17,25.0,,,,,,,,,,,,,,,,,
,34.38,24.0,34.38,25.0,34.38,25.0,34.38,25.0,,,,,,,,,,,,,,,,,
,34.58,24.0,34.58,25.0,34.58,37.0,34.58,25.0,,,,,,,,,,,,,,,,,
,34.79,24.0,34.79,25.0,34.79,24.0,34.79,25.0,,,,,,,,,,,,,,,,,
,34.99,24.0,34.99,25.0,34.99,24.0,34.99,25.0,,,,,,,,,,,,,,,,,
,35.19,24.0,35.19,25.0,35.19,25.0,35.19,25.0,,,,,,,,,,,,,,,,,
,35.40,24.0,35.40,25.0,35.40,37.0,35.40,25.0,,,,,,,,,,,,,,,,,
,35.61,24.0,35.61,25.0,35.61,24.0,35.61,25.0,,,,,,,,,,,,,,,,,
,35.81,24.0,35.81,25.0,35.81,24.0,35.81,24.0,,,,,,,,,,,,,,,,,
,36.01,24.0,36.01,25.0,36.01,24.0,36.01,25.0,,,,,,,,,,,,,,,,,
,36.21,24.0,36.21,25.0,36.22,43.0,36.22,25.0,,,,,,,,,,,,,,,,,
,36.43,24.0,36.43,25.0,36.43,22.0,36.43,24.0,,,,,,,,,,,,,,,,,
,36.63,24.0,36.63,24.0,36.63,24.0,36.63,24.0,,,,,,,,,,,,,,,,,
,36.83,24.0,36.83,24.0,36.83,32.0,36.83,24.0,,,,,,,,,,,,,,,,,
,37.03,23.0,37.03,24.0,37.03,24.0,37.03,24.0,,,,,,,,,,,,,,,,,
,37.25,24.0,37.25,24.0,37.25,24.0,37.25,24.0,,,,,,,,,,,,,,,,,
,37.45,23.0,37.45,24.0,37.45,23.0,37.45,24.0,,,,,,,,,,,,,,,,,
,37.65,23.0,37.65,23.0,37.65,31.0,37.65,23.0,,,,,,,,,,,,,,,,,
,37.85,23.0,37.85,23.0,37.85,23.0,37.85,23.0,,,,,,,,,,,,,,,,,
,38.07,23.0,38.07,23.0,38.07,22.0,38.07,23.0,,,,,,,,,,,,,,,,,
,38.27,23.0,38.27,23.0,38.27,30.0,38.27,23.0,,,,,,,,,,,,,,,,,
,38.49,23.0,38.49,23.0,38.49,23.0,38.49,23.0,,,,,,,,,,,,,,,,,
,38.67,23.0,38.67,23.0,38.67,23.0,38.67,23.0,,,,,,,,,,,,,,,,,
,38.89,23.0,38.89,23.0,38.89,25.0,38.89,23.0,,,,,,,,,,,,,,,,,
,39.09,23.0,39.09,23.0,39.09,24.0,39.09,23.0,,,,,,,,,,,,,,,,,
,39.29,23.0,39.29,23.0,39.29,24.0,39.29,23.0,,,,,,,,,,,,,,,,,
,39.51,24.0,39.51,24.0,39.51,24.0,39.51,24.0,,,,,,,,,,,,,,,,,
,39.71,24.0,39.71,24.0,39.71,34.0,39.71,24.0,,,,,,,,,,,,,,,,,
,39.91,24.0,39.91,24.0,39.91,24.0,39.91,24.0,,,,,,,,,,,,,,,,,
,40.11,25.0,40.11,24.0,40.11,38.0,40.11,24.0,,,,,,,,,,,,,,,,,
,40.31,25.0,40.31,25.0,40.31,22.0,40.31,25.0,,,,,,,,,,,,,,,,,
,40.55,25.0,40.55,25.0,40.55,37.0,40.55,25.0,,,,,,,,,,,,,,,,,
,40.73,25.0,40.73,25.0,40.73,25.0,40.73,25.0,,,,,,,,,,,,,,,,,
,40.93,25.0,40.93,25.0,40.93,38.0,40.93,25.0,,,,,,,,,,,,,,,,,
,41.13,25.0,41.13,25.0,41.13,25.0,41.13,25.0,,,,,,,,,,,,,,,,,
,41.35,25.0,41.35,25.0,41.35,37.0,41.35,25.0,,,,,,,,,,,,,,,,,
,41.57,25.0,41.57,25.0,41.57,25.0,41.57,25.0,,,,,,,,,,,,,,,,,
,41.75,25.0,41.75,25.0,41.76,38.0,41.76,25.0,,,,,,,,,,,,,,,,,
,41.95,25.0,41.95,25.0,41.95,25.0,41.95,25.0,,,,,,,,,,,,,,,,,
,42.17,25.0,42.17,24.0,42.17,37.0,42.17,25.0,,,,,,,,,,,,,,,,,
,42.37,25.0,42.37,25.0,42.37,25.0,42.37,24.0,,,,,,,,,,,,,,,,,
,42.59,25.0,42.59,25.0,42.59,35.0,42.59,25.0,,,,,,,,,,,,,,,,,
,42.77,25.0,42.77,25.0,42.77,25.0,42.77,25.0,,,,,,,,,,,,,,,,,
,42.99,26.0,42.99,26.0,42.99,34.0,42.99,25.0,,,,,,,,,,,,,,,,,
,43.19,26.0,43.19,26.0,43.19,25.0,43.19,26.0,,,,,,,,,,,,,,,,,
,43.39,26.0,43.39,26.0,43.39,26.0,43.39,26.0,,,,,,,,,,,,,,,,,
,43.61,27.0,43.61,26.0,43.61,27.0,43.61,26.0,,,,,,,,,,,,,,,,,
,43.81,27.0,43.81,27.0,43.81,49.0,43.81,27.0,,,,,,,,,,,,,,,,,
,44.01,27.0,44.01,27.0,44.01,41.0,44.01,27.0,,,,,,,,,,,,,,,,,
,44.21,27.0,44.21,27.0,44.21,27.0,44.21,28.0,,,,,,,,,,,,,,,,,
,44.41,28.0,44.41,28.0,44.41,28.0,44.41,27.0,,,,,,,,,,,,,,,,,
,44.65,28.0,44.65,28.0,44.65,28.0,44.65,28.0,,,,,,,,,,,,,,,,,
,44.83,28.0,44.83,28.0,44.83,29.0,44.83,28.0,,,,,,,,,,,,,,,,,
,45.03,28.0,45.03,28.0,45.03,38.0,45.03,28.0,,,,,,,,,,,,,,,,,
,45.23,28.0,45.23,27.0,45.23,39.0,45.23,28.0,,,,,,,,,,,,,,,,,
,45.45,27.0,45.45,27.0,45.45,28.0,45.45,27.0,,,,,,,,,,,,,,,,,
,45.65,27.0,45.65,27.0,45.65,27.0,45.65,27.0,,,,,,,,,,,,,,,,,
,45.85,27.0,45.85,27.0,45.85,27.0,45.85,27.0,,,,,,,,,,,,,,,,,
,46.05,27.0,46.05,27.0,46.05,27.0,46.05,27.0,,,,,,,,,,,,,,,,,
,46.27,26.0,46.27,26.0,46.27,33.0,46.27,26.0,,,,,,,,,,,,,,,,,
,46.47,26.0,46.47,26.0,46.47,26.0,46.47,26.0,,,,,,,,,,,,,,,,,
,46.67,26.0,46.67,26.0,46.67,26.0,46.67,26.0,,,,,,,,,,,,,,,,,
,46.87,26.0,46.87,26.0,46.87,26.0,46.87,26.0,,,,,,,,,,,,,,,,,
,47.08,26.0,47.08,26.0,47.08,36.0,47.09,26.0,,,,,,,,,,,,,,,,,
,47.28,26.0,47.28,26.0,47.28,39.0,47.29,26.0,,,,,,,,,,,,,,,,,
,47.49,26.0,47.49,26.0,47.49,26.0,47.49,26.0,,,,,,,,,,,,,,,,,
,47.69,26.0,47.69,26.0,47.69,41.0,47.69,26.0,,,,,,,,,,,,,,,,,
,47.91,26.0,47.91,26.0,47.91,26.0,47.91,26.0,,,,,,,,,,,,,,,,,
,48.11,26.0,48.11,26.0,48.11,34.0,48.11,26.0,,,,,,,,,,,,,,,,,
,48.31,26.0,48.31,26.0,48.31,26.0,48.31,26.0,,,,,,,,,,,,,,,,,
,48.51,26.0,48.51,26.0,48.51,26.0,48.51,26.0,,,,,,,,,,,,,,,,,
,48.72,26.0,48.72,26.0,48.72,26.0,48.72,26.0,,,,,,,,,,,,,,,,,
,48.92,26.0,48.92,26.0,48.92,26.0,48.92,26.0,,,,,,,,,,,,,,,,,
,49.13,26.0,49.13,26.0,49.13,29.0,49.13,26.0,,,,,,,,,,,,,,,,,
,49.33,26.0,49.33,27.0,49.33,26.0,49.33,26.0,,,,,,,,,,,,,,,,,
,49.54,26.0,49.54,26.0,49.54,26.0,49.54,26.0,,,,,,,,,,,,,,,,,
,49.75,26.0,49.75,26.0,49.75,27.0,49.75,27.0,,,,,,,,,,,,,,,,,
,49.95,27.0,49.95,27.0,49.95,28.0,49.95,27.0,,,,,,,,,,,,,,,,,
,50.15,27.0,50.15,27.0,50.15,40.0,50.15,27.0,,,,,,,,,,,,,,,,,
,50.37,27.0,50.37,27.0,50.37,27.0,50.37,27.0,,,,,,,,,,,,,,,,,
,50.57,27.0,50.57,26.0,50.57,26.0,50.57,27.0,,,,,,,,,,,,,,,,,
,50.77,27.0,50.77,27.0,50.77,29.0,50.77,27.0,,,,,,,,,,,,,,,,,
,50.99,27.0,50.99,27.0,50.99,27.0,50.99,27.0,,,,,,,,,,,,,,,,,
,51.19,27.0,51.19,27.0,51.19,30.0,51.19,27.0,,,,,,,,,,,,,,,,,
,51.39,27.0,51.39,27.0,51.39,26.0,51.39,26.0,,,,,,,,,,,,,,,,,
,51.59,26.0,51.59,27.0,51.59,26.0,51.59,27.0,,,,,,,,,,,,,,,,,
,51.81,27.0,51.81,27.0,51.81,26.0,51.81,27.0,,,,,,,,,,,,,,,,,
,52.01,27.0,52.01,27.0,52.01,24.0,52.01,27.0,,,,,,,,,,,,,,,,,
,52.21,27.0,52.21,27.0,52.21,40.0,52.21,26.0,,,,,,,,,,,,,,,,,
,52.41,27.0,52.41,27.0,52.41,27.0,52.41,27.0,,,,,,,,,,,,,,,,,
,52.61,27.0,52.61,27.0,52.61,26.0,52.61,27.0,,,,,,,,,,,,,,,,,
,52.83,27.0,52.83,27.0,52.83,27.0,52.83,27.0,,,,,,,,,,,,,,,,,
,53.03,27.0,53.03,27.0,53.03,29.0,53.03,27.0,,,,,,,,,,,,,,,,,
,53.23,27.0,53.23,27.0,53.23,41.0,53.23,27.0,,,,,,,,,,,,,,,,,
,53.44,27.0,53.44,27.0,53.44,29.0,53.44,27.0,,,,,,,,,,,,,,,,,
,53.65,27.0,53.65,27.0,53.65,27.0,53.65,27.0,,,,,,,,,,,,,,,,,
,53.85,27.0,53.85,27.0,53.85,27.0,53.85,27.0,,,,,,,,,,,,,,,,,
,54.05,27.0,54.05,27.0,54.05,27.0,54.05,27.0,,,,,,,,,,,,,,,,,
,54.25,27.0,54.25,27.0,54.25,45.0,54.25,27.0,,,,,,,,,,,,,,,,,
,54.46,27.0,54.46,27.0,54.47,41.0,54.47,27.0,,,,,,,,,,,,,,,,,
,54.69,27.0,54.69,27.0,54.69,27.0,54.69,27.0,,,,,,,,,,,,,,,,,
,54.87,27.0,54.87,27.0,54.87,27.0,54.87,27.0,,,,,,,,,,,,,,,,,
,55.08,28.0,55.08,27.0,55.08,27.0,55.08,27.0,,,,,,,,,,,,,,,,,
,55.28,28.0,55.28,27.0,55.28,27.0,55.28,27.0,,,,,,,,,,,,,,,,,
,55.49,27.0,55.49,27.0,55.49,27.0,55.49,27.0,,,,,,,,,,,,,,,,,
,55.71,27.0,55.71,27.0,55.71,27.0,55.71,27.0,,,,,,,,,,,,,,,,,
,55.89,27.0,55.89,27.0,55.89,27.0,55.89,26.0,,,,,,,,,,,,,,,,,
,56.10,27.0,56.10,26.0,56.10,36.0,56.10,26.0,,,,,,,,,,,,,,,,,
,56.31,27.0,56.31,26.0,56.31,28.0,56.31,27.0,,,,,,,,,,,,,,,,,
,56.51,27.0,56.51,27.0,56.51,44.0,56.51,26.0,,,,,,,,,,,,,,,,,
,56.74,27.0,56.74,27.0,56.74,36.0,56.74,26.0,,,,,,,,,,,,,,,,,
,56.92,27.0,56.92,26.0,56.92,26.0,56.92,26.0,,,,,,,,,,,,,,,,,
,57.13,27.0,57.13,26.0,57.13,27.0,57.13,26.0,,,,,,,,,,,,,,,,,
,57.33,27.0,57.33,26.0,57.33,28.0,57.33,26.0,,,,,,,,,,,,,,,,,
,57.53,26.0,57.53,26.0,57.53,40.0,57.53,26.0,,,,,,,,,,,,,,,,,
,57.76,26.0,57.76,26.0,57.76,40.0,57.76,26.0,,,,,,,,,,,,,,,,,
,57.95,26.0,57.95,26.0,57.95,26.0,57.95,26.0,,,,,,,,,,,,,,,,,
,58.15,27.0,58.15,26.0,58.15,29.0,58.15,26.0,,,,,,,,,,,,,,,,,
,58.35,26.0,58.35,26.0,58.35,27.0,58.35,26.0,,,,,,,,,,,,,,,,,
,58.56,26.0,58.56,26.0,58.56,36.0,58.56,26.0,,,,,,,,,,,,,,,,,
,58.79,26.0,58.79,26.0,58.79,37.0,58.79,26.0,,,,,,,,,,,,,,,,,
,58.97,27.0,58.97,26.0,58.97,27.0,58.97,26.0,,,,,,,,,,,,,,,,,
,59.18,27.0,59.18,27.0,59.18,27.0,59.19,26.0,,,,,,,,,,,,,,,,,
,59.38,27.0,59.38,27.0,59.38,28.0,59.38,26.0,,,,,,,,,,,,,,,,,
,59.59,27.0,59.59,26.0,59.59,43.0,59.59,26.0,,,,,,,,,,,,,,,,,
,59.81,27.0,59.81,26.0,59.81,40.0,59.81,26.0,,,,,,,,,,,,,,,,,
,60.01,27.0,60.01,26.0,60.01,26.0,60.01,26.0,,,,,,,,,,,,,,,,,
,60.21,27.0,60.21,26.0,60.21,27.0,60.21,26.0,,,,,,,,,,,,,,,,,
,60.41,27.0,60.41,27.0,60.41,27.0,60.41,26.0,,,,,,,,,,,,,,,,,
,60.61,28.0,60.61,27.0,60.61,37.0,60.61,27.0,,,,,,,,,,,,,,,,,
,60.84,28.0,60.84,27.0,60.84,40.0,60.84,27.0,,,,,,,,,,,,,,,,,
,61.02,28.0,61.02,27.0,61.02,28.0,61.02,27.0,,,,,,,,,,,,,,,,,
,61.23,29.0,61.23,28.0,61.23,28.0,61.23,28.0,,,,,,,,,,,,,,,,,
,61.43,29.0,61.43,29.0,61.43,29.0,61.43,28.0,,,,,,,,,,,,,,,,,
,61.64,29.0,61.64,29.0,61.64,42.0,61.64,29.0,,,,,,,,,,,,,,,,,
,61.85,30.0,61.85,30.0,61.85,29.0,61.85,29.0,,,,,,,,,,,,,,,,,
,62.05,30.0,62.05,30.0,62.05,32.0,62.05,30.0,,,,,,,,,,,,,,,,,
,62.25,30.0,62.25,30.0,62.25,46.0,62.25,30.0,,,,,,,,,,,,,,,,,
,62.46,31.0,62.46,31.0,62.46,32.0,62.46,30.0,,,,,,,,,,,,,,,,,
,62.66,31.0,62.66,31.0,62.66,46.0,62.66,31.0,,,,,,,,,,,,,,,,,
,62.88,31.0,62.88,31.0,62.88,46.0,62.88,31.0,,,,,,,,,,,,,,,,,
,63.07,31.0,63.07,31.0,63.07,31.0,63.07,31.0,,,,,,,,,,,,,,,,,
,63.28,32.0,63.28,31.0,63.28,31.0,63.28,31.0,,,,,,,,,,,,,,,,,
,63.48,32.0,63.48,32.0,63.48,31.0,63.48,31.0,,,,,,,,,,,,,,,,,
,63.69,32.0,63.69,32.0,63.69,32.0,63.69,32.0,,,,,,,,,,,,,,,,,
,63.89,32.0,63.89,32.0,63.89,32.0,63.89,32.0,,,,,,,,,,,,,,,,,
,64.10,32.0,64.10,32.0,64.10,32.0,64.11,32.0,,,,,,,,,,,,,,,,,
,64.30,32.0,64.30,32.0,64.30,33.0,64.31,32.0,,,,,,,,,,,,,,,,,
,64.51,33.0,64.51,33.0,64.51,33.0,64.51,33.0,,,,,,,,,,,,,,,,,
,64.71,33.0,64.71,33.0,64.71,33.0,64.71,33.0,,,,,,,,,,,,,,,,,
,64.92,33.0,64.92,33.0,64.92,33.0,64.92,33.0,,,,,,,,,,,,,,,,,
,65.12,33.0,65.12,33.0,65.12,33.0,65.12,33.0,,,,,,,,,,,,,,,,,
,65.33,33.0,65.33,33.0,65.33,33.0,65.33,33.0,,,,,,,,,,,,,,,,,
,65.53,33.0,65.53,33.0,65.53,33.0,65.53,33.0,,,,,,,,,,,,,,,,,
,65.74,33.0,65.74,33.0,65.74,33.0,65.74,33.0,,,,,,,,,,,,,,,,,
,65.94,33.0,65.94,33.0,65.94,32.0,65.94,33.0,,,,,,,,,,,,,,,,,
,66.15,33.0,66.15,33.0,66.15,33.0,66.15,33.0,,,,,,,,,,,,,,,,,
,66.35,33.0,66.35,33.0,66.35,51.0,66.35,33.0,,,,,,,,,,,,,,,,,
,66.56,33.0,66.56,33.0,66.56,47.0,66.56,33.0,,,,,,,,,,,,,,,,,
,66.76,33.0,66.76,33.0,66.76,45.0,66.76,33.0,,,,,,,,,,,,,,,,,
,66.97,34.0,66.97,34.0,66.97,36.0,66.97,34.0,,,,,,,,,,,,,,,,,
,67.17,34.0,67.17,34.0,67.17,48.0,67.17,34.0,,,,,,,,,,,,,,,,,
,67.38,34.0,67.38,34.0,67.38,34.0,67.38,34.0,,,,,,,,,,,,,,,,,
,67.58,34.0,67.58,34.0,67.58,35.0,67.58,34.0,,,,,,,,,,,,,,,,,
,67.79,34.0,67.79,34.0,67.79,34.0,67.79,34.0,,,,,,,,,,,,,,,,,
,67.99,34.0,67.99,34.0,67.99,34.0,67.99,34.0,,,,,,,,,,,,,,,,,
,68.20,34.0,68.20,34.0,68.20,34.0,68.21,34.0,,,,,,,,,,,,,,,,,
,68.40,35.0,68.40,35.0,68.40,34.0,68.40,34.0,,,,,,,,,,,,,,,,,
,68.61,35.0,68.61,34.0,68.61,34.0,68.61,34.0,,,,,,,,,,,,,,,,,
,68.81,35.0,68.81,34.0,68.81,35.0,68.81,34.0,,,,,,,,,,,,,,,,,
,69.02,35.0,69.02,35.0,69.02,34.0,69.02,34.0,,,,,,,,,,,,,,,,,
,69.22,35.0,69.22,35.0,69.22,34.0,69.22,34.0,,,,,,,,,,,,,,,,,
,69.43,34.0,69.43,34.0,69.43,35.0,69.43,34.0,,,,,,,,,,,,,,,,,
,69.63,35.0,69.63,35.0,69.63,42.0,69.63,34.0,,,,,,,,,,,,,,,,,
,69.84,35.0,69.84,35.0,69.84,53.0,69.84,35.0,,,,,,,,,,,,,,,,,
,70.04,35.0,70.04,35.0,70.04,52.0,70.04,35.0,,,,,,,,,,,,,,,,,
,70.25,35.0,70.25,35.0,70.25,46.0,70.25,35.0,,,,,,,,,,,,,,,,,
,70.45,35.0,70.45,34.0,70.45,42.0,70.45,35.0,,,,,,,,,,,,,,,,,
,70.66,35.0,70.66,35.0,70.66,54.0,70.66,35.0,,,,,,,,,,,,,,,,,
,70.86,35.0,70.86,34.0,70.86,33.0,70.86,34.0,,,,,,,,,,,,,,,,,
,71.07,35.0,71.07,35.0,71.07,36.0,71.07,34.0,,,,,,,,,,,,,,,,,
,71.27,35.0,71.27,34.0,71.27,37.0,71.27,34.0,,,,,,,,,,,,,,,,,
,71.48,35.0,71.48,34.0,71.48,34.0,71.48,34.0,,,,,,,,,,,,,,,,,
,71.68,35.0,71.68,34.0,71.68,35.0,71.68,34.0,,,,,,,,,,,,,,,,,
,71.91,35.0,71.91,35.0,71.91,35.0,71.91,34.0,,,,,,,,,,,,,,,,,
,72.09,35.0,72.09,35.0,72.09,35.0,72.09,34.0,,,,,,,,,,,,,,,,,
,72.30,35.0,72.30,35.0,72.30,35.0,72.30,35.0,,,,,,,,,,,,,,,,,
,72.50,35.0,72.50,35.0,72.50,35.0,72.50,35.0,,,,,,,,,,,,,,,,,
,72.71,36.0,72.71,35.0,72.71,35.0,72.71,35.0,,,,,,,,,,,,,,,,,
,72.93,36.0,72.93,36.0,72.93,36.0,72.93,35.0,,,,,,,,,,,,,,,,,
,73.12,36.0,73.12,36.0,73.12,37.0,73.12,36.0,,,,,,,,,,,,,,,,,
,73.32,36.0,73.32,36.0,73.32,35.0,73.32,36.0,,,,,,,,,,,,,,,,,
,73.53,36.0,73.53,36.0,73.53,51.0,73.53,36.0,,,,,,,,,,,,,,,,,
,73.73,36.0,73.73,36.0,73.73,37.0,73.73,36.0,,,,,,,,,,,,,,,,,
,73.96,37.0,73.96,36.0,73.96,60.0,73.96,36.0,,,,,,,,,,,,,,,,,
,74.14,37.0,74.14,36.0,74.14,37.0,74.14,36.0,,,,,,,,,,,,,,,,,
,74.35,37.0,74.35,36.0,74.35,38.0,74.35,36.0,,,,,,,,,,,,,,,,,
,74.55,37.0,74.55,36.0,74.55,37.0,74.55,36.0,,,,,,,,,,,,,,,,,
,74.76,36.0,74.76,36.0,74.76,44.0,74.76,36.0,,,,,,,,,,,,,,,,,
,74.98,36.0,74.98,36.0,74.98,36.0,74.98,36.0,,,,,,,,,,,,,,,,,
,75.17,36.0,75.17,36.0,75.17,37.0,75.17,36.0,,,,,,,,,,,,,,,,,
,75.37,36.0,75.37,36.0,75.37,36.0,75.37,36.0,,,,,,,,,,,,,,,,,
,75.58,37.0,75.58,37.0,75.58,37.0,75.58,37.0,,,,,,,,,,,,,,,,,
,75.78,37.0,75.78,37.0,75.78,59.0,75.78,37.0,,,,,,,,,,,,,,,,,
,76.01,37.0,76.01,37.0,76.01,56.0,76.01,37.0,,,,,,,,,,,,,,,,,
,76.19,37.0,76.19,37.0,76.19,39.0,76.19,37.0,,,,,,,,,,,,,,,,,
,76.40,37.0,76.40,37.0,76.40,38.0,76.40,37.0,,,,,,,,,,,,,,,,,
,76.60,37.0,76.60,37.0,76.60,36.0,76.60,36.0,,,,,,,,,,,,,,,,,
,76.81,37.0,76.81,36.0,76.81,52.0,76.81,36.0,,,,,,,,,,,,,,,,,
,77.03,36.0,77.03,36.0,77.03,37.0,77.03,36.0,,,,,,,,,,,,,,,,,
,77.22,36.0,77.22,35.0,77.22,36.0,77.22,36.0,,,,,,,,,,,,,,,,,
,77.42,36.0,77.42,36.0,77.42,36.0,77.42,35.0,,,,,,,,,,,,,,,,,
,77.63,35.0,77.63,35.0,77.63,34.0,77.63,36.0,,,,,,,,,,,,,,,,,
,77.83,36.0,77.83,35.0,77.83,36.0,77.83,36.0,,,,,,,,,,,,,,,,,
,78.06,35.0,78.06,35.0,78.06,54.0,78.06,35.0,,,,,,,,,,,,,,,,,
,78.24,35.0,78.24,35.0,78.24,39.0,78.24,35.0,,,,,,,,,,,,,,,,,
,78.45,35.0,78.45,36.0,78.45,48.0,78.45,35.0,,,,,,,,,,,,,,,,,
,78.65,36.0,78.65,36.0,78.65,67.0,78.65,35.0,,,,,,,,,,,,,,,,,
,78.86,35.0,78.86,35.0,78.86,36.0,78.86,35.0,,,,,,,,,,,,,,,,,
,79.07,35.0,79.07,35.0,79.07,37.0,79.07,35.0,,,,,,,,,,,,,,,,,
,79.27,35.0,79.27,35.0,79.27,37.0,79.27,35.0,,,,,,,,,,,,,,,,,
,79.47,35.0,79.47,35.0,79.47,35.0,79.47,35.0,,,,,,,,,,,,,,,,,
,79.68,36.0,79.68,36.0,79.68,35.0,79.68,36.0,,,,,,,,,,,,,,,,,
,79.88,35.0,79.88,36.0,79.88,55.0,79.88,35.0,,,,,,,,,,,,,,,,,
,80.10,35.0,80.10,36.0,80.10,35.0,80.10,35.0,,,,,,,,,,,,,,,,,
,80.29,35.0,80.29,35.0,80.29,35.0,80.29,35.0,,,,,,,,,,,,,,,,,
,80.50,35.0,80.50,35.0,80.50,35.0,80.50,35.0,,,,,,,,,,,,,,,,,
,80.70,35.0,80.70,35.0,80.70,34.0,80.70,35.0,,,,,,,,,,,,,,,,,
,80.91,35.0,80.91,35.0,80.91,35.0,80.91,35.0,,,,,,,,,,,,,,,,,
,81.11,35.0,81.11,35.0,81.11,33.0,81.11,35.0,,,,,,,,,,,,,,,,,
,81.32,35.0,81.32,35.0,81.32,53.0,81.32,35.0,,,,,,,,,,,,,,,,,
,81.52,36.0,81.52,36.0,81.52,63.0,81.52,36.0,,,,,,,,,,,,,,,,,
,81.73,35.0,81.73,35.0,81.73,54.0,81.73,35.0,,,,,,,,,,,,,,,,,
,81.93,35.0,81.93,35.0,81.93,41.0,81.93,35.0,,,,,,,,,,,,,,,,,
,82.14,35.0,82.14,35.0,82.14,53.0,82.14,35.0,,,,,,,,,,,,,,,,,
,82.34,35.0,82.34,35.0,82.34,37.0,82.34,35.0,,,,,,,,,,,,,,,,,
,82.55,35.0,82.55,35.0,82.55,36.0,82.55,34.0,,,,,,,,,,,,,,,,,
,82.75,35.0,82.75,34.0,82.75,34.0,82.75,34.0,,,,,,,,,,,,,,,,,
,82.96,35.0,82.96,34.0,82.96,34.0,82.96,34.0,,,,,,,,,,,,,,,,,
,83.16,35.0,83.16,34.0,83.16,34.0,83.16,34.0,,,,,,,,,,,,,,,,,
,83.37,35.0,83.37,34.0,83.37,37.0,83.37,34.0,,,,,,,,,,,,,,,,,
,83.57,34.0,83.57,34.0,83.57,36.0,83.57,34.0,,,,,,,,,,,,,,,,,
,83.78,34.0,83.78,34.0,83.78,33.0,83.78,34.0,,,,,,,,,,,,,,,,,
,83.98,34.0,83.98,33.0,83.98,34.0,83.98,33.0,,,,,,,,,,,,,,,,,
,84.19,34.0,84.19,33.0,84.19,48.0,84.19,33.0,,,,,,,,,,,,,,,,,
,84.39,33.0,84.39,33.0,84.39,33.0,84.39,33.0,,,,,,,,,,,,,,,,,
,84.60,34.0,84.60,33.0,84.60,47.0,84.60,33.0,,,,,,,,,,,,,,,,,
,84.80,33.0,84.80,33.0,84.80,32.0,84.80,33.0,,,,,,,,,,,,,,,,,
,85.01,33.0,85.01,33.0,85.01,47.0,85.01,33.0,,,,,,,,,,,,,,,,,
,85.21,34.0,85.21,33.0,85.21,33.0,85.21,33.0,,,,,,,,,,,,,,,,,
,85.42,34.0,85.42,33.0,85.42,45.0,85.42,33.0,,,,,,,,,,,,,,,,,
,85.62,34.0,85.62,33.0,85.62,34.0,85.62,33.0,,,,,,,,,,,,,,,,,
,85.83,34.0,85.83,33.0,85.83,45.0,85.83,33.0,,,,,,,,,,,,,,,,,
,86.03,33.0,86.03,33.0,86.03,40.0,86.03,33.0,,,,,,,,,,,,,,,,,
,86.24,33.0,86.24,33.0,86.24,50.0,86.24,33.0,,,,,,,,,,,,,,,,,
,86.44,33.0,86.44,33.0,86.44,33.0,86.44,33.0,,,,,,,,,,,,,,,,,
,86.65,33.0,86.65,33.0,86.65,39.0,86.65,32.0,,,,,,,,,,,,,,,,,
,86.85,33.0,86.85,32.0,86.85,33.0,86.85,32.0,,,,,,,,,,,,,,,,,
,87.06,32.0,87.06,32.0,87.06,33.0,87.06,32.0,,,,,,,,,,,,,,,,,
,87.26,33.0,87.26,32.0,87.26,31.0,87.26,32.0,,,,,,,,,,,,,,,,,
,87.47,32.0,87.47,32.0,87.47,32.0,87.47,32.0,,,,,,,,,,,,,,,,,
,87.67,32.0,87.67,32.0,87.67,32.0,87.67,32.0,,,,,,,,,,,,,,,,,
,87.88,32.0,87.88,32.0,87.88,33.0,87.88,32.0,,,,,,,,,,,,,,,,,
,88.08,32.0,88.08,32.0,88.08,32.0,88.08,32.0,,,,,,,,,,,,,,,,,
,88.29,32.0,88.29,32.0,88.29,33.0,88.29,32.0,,,,,,,,,,,,,,,,,
,88.49,32.0,88.49,32.0,88.49,48.0,88.49,31.0,,,,,,,,,,,,,,,,,
,88.70,32.0,88.70,31.0,88.70,60.0,88.70,31.0,,,,,,,,,,,,,,,,,
,88.90,31.0,88.90,31.0,88.90,47.0,88.90,31.0,,,,,,,,,,,,,,,,,
,89.13,31.0,89.13,31.0,89.13,34.0,89.13,31.0,,,,,,,,,,,,,,,,,
,89.31,31.0,89.31,31.0,89.31,33.0,89.31,30.0,,,,,,,,,,,,,,,,,
,89.52,30.0,89.52,30.0,89.52,30.0,89.52,30.0,,,,,,,,,,,,,,,,,
,89.72,30.0,89.72,30.0,89.72,30.0,89.72,30.0,,,,,,,,,,,,,,,,,
,89.93,29.0,89.93,29.0,89.93,29.0,89.93,29.0,,,,,,,,,,,,,,,,,
,90.15,28.0,90.15,29.0,90.15,29.0,90.15,29.0,,,,,,,,,,,,,,,,,
,90.34,28.0,90.34,28.0,90.34,30.0,90.34,28.0,,,,,,,,,,,,,,,,,
,90.54,28.0,90.54,28.0,90.54,42.0,90.54,28.0,,,,,,,,,,,,,,,,,
,90.75,28.0,90.75,28.0,90.75,28.0,90.75,28.0,,,,,,,,,,,,,,,,,
,90.95,28.0,90.95,29.0,90.95,26.0,90.95,29.0,,,,,,,,,,,,,,,,,
,91.18,28.0,91.18,29.0,91.18,28.0,91.18,29.0,,,,,,,,,,,,,,,,,
,91.36,28.0,91.36,29.0,91.36,29.0,91.36,29.0,,,,,,,,,,,,,,,,,
,91.57,29.0,91.57,29.0,91.57,29.0,91.57,29.0,,,,,,,,,,,,,,,,,
,91.77,29.0,91.77,30.0,91.77,29.0,91.77,30.0,,,,,,,,,,,,,,,,,
,91.98,30.0,91.98,30.0,91.98,31.0,91.98,30.0,,,,,,,,,,,,,,,,,
,92.20,29.0,92.20,30.0,92.20,45.0,92.20,30.0,,,,,,,,,,,,,,,,,
,92.39,30.0,92.39,30.0,92.39,45.0,92.39,31.0,,,,,,,,,,,,,,,,,
,92.59,30.0,92.59,31.0,92.59,30.0,92.59,30.0,,,,,,,,,,,,,,,,,
,92.80,30.0,92.80,31.0,92.80,30.0,92.80,31.0,,,,,,,,,,,,,,,,,
,93.00,30.0,93.00,31.0,93.00,30.0,93.00,31.0,,,,,,,,,,,,,,,,,
,93.23,31.0,93.23,31.0,93.23,31.0,93.23,31.0,,,,,,,,,,,,,,,,,
,93.41,31.0,93.41,31.0,93.41,37.0,93.41,31.0,,,,,,,,,,,,,,,,,
,93.62,31.0,93.62,32.0,93.62,32.0,93.62,32.0,,,,,,,,,,,,,,,,,
,93.82,32.0,93.82,32.0,93.82,33.0,93.82,32.0,,,,,,,,,,,,,,,,,
,94.03,32.0,94.03,33.0,94.03,33.0,94.03,32.0,,,,,,,,,,,,,,,,,
,94.25,32.0,94.25,33.0,94.25,32.0,94.25,32.0,,,,,,,,,,,,,,,,,
,94.44,33.0,94.44,33.0,94.44,29.0,94.44,32.0,,,,,,,,,,,,,,,,,
,94.64,32.0,94.64,33.0,94.64,49.0,94.64,33.0,,,,,,,,,,,,,,,,,
,94.85,32.0,94.85,33.0,94.85,52.0,94.85,33.0,,,,,,,,,,,,,,,,,
,95.05,32.0,95.05,33.0,95.05,39.0,95.05,33.0,,,,,,,,,,,,,,,,,
,95.28,33.0,95.28,33.0,95.28,39.0,95.28,33.0,,,,,,,,,,,,,,,,,
,95.46,33.0,95.46,33.0,95.46,50.0,95.46,33.0,,,,,,,,,,,,,,,,,
,95.67,33.0,95.67,33.0,95.67,50.0,95.67,33.0,,,,,,,,,,,,,,,,,
,95.87,33.0,95.87,33.0,95.87,47.0,95.87,33.0,,,,,,,,,,,,,,,,,
,96.08,33.0,96.08,33.0,96.08,51.0,96.08,33.0,,,,,,,,,,,,,,,,,
,96.29,34.0,96.29,33.0,96.29,47.0,96.29,33.0,,,,,,,,,,,,,,,,,
,96.49,33.0,96.49,33.0,96.49,51.0,96.49,33.0,,,,,,,,,,,,,,,,,
,96.69,33.0,96.69,33.0,96.69,47.0,96.69,33.0,,,,,,,,,,,,,,,,,
,96.90,33.0,96.90,33.0,96.90,50.0,96.90,33.0,,,,,,,,,,,,,,,,,
,97.10,33.0,97.10,33.0,97.10,36.0,97.10,33.0,,,,,,,,,,,,,,,,,
,97.31,33.0,97.31,33.0,97.31,41.0,97.31,33.0,,,,,,,,,,,,,,,,,
,97.51,33.0,97.51,33.0,97.51,49.0,97.51,33.0,,,,,,,,,,,,,,,,,
,97.72,33.0,97.72,33.0,97.72,33.0,97.72,33.0,,,,,,,,,,,,,,,,,
,97.92,33.0,97.92,33.0,97.92,50.0,97.92,33.0,,,,,,,,,,,,,,,,,
,98.13,33.0,98.13,33.0,98.13,37.0,98.13,33.0,,,,,,,,,,,,,,,,,
,98.33,33.0,98.33,33.0,98.33,50.0,98.33,33.0,,,,,,,,,,,,,,,,,
,98.54,33.0,98.54,33.0,98.54,48.0,98.54,33.0,,,,,,,,,,,,,,,,,
,98.74,33.0,98.74,33.0,98.74,50.0,98.74,33.0,,,,,,,,,,,,,,,,,
,98.95,34.0,98.95,33.0,98.95,50.0,98.95,33.0,,,,,,,,,,,,,,,,,
,99.15,33.0,99.15,33.0,99.15,50.0,99.15,33.0,,,,,,,,,,,,,,,,,
,99.36,34.0,99.36,33.0,99.36,50.0,99.36,33.0,,,,,,,,,,,,,,,,,
,99.56,33.0,99.56,34.0,99.56,50.0,99.56,33.0,,,,,,,,,,,,,,,,,
,99.77,34.0,99.77,33.0,99.77,37.0,99.77,34.0,,,,,,,,,,,,,,,,,
,99.97,34.0,99.97,34.0,99.97,51.0,99.97,34.0,,,,,,,,,,,,,,,,,
,100.18,34.0,100.18,34.0,100.18,51.0,100.18,34.0,,,,,,,,,,,,,,,,,
,100.38,34.0,100.38,34.0,100.38,52.0,100.38,34.0,,,,,,,,,,,,,,,,,
,100.59,35.0,100.59,35.0,100.59,46.0,100.59,34.0,,,,,,,,,,,,,,,,,
,100.79,35.0,100.79,35.0,100.79,50.0,100.79,35.0,,,,,,,,,,,,,,,,,
,101.00,35.0,101.00,35.0,101.00,35.0,101.00,35.0,,,,,,,,,,,,,,,,,
,101.20,35.0,101.20,35.0,101.20,36.0,101.20,35.0,,,,,,,,,,,,,,,,,
,101.41,35.0,101.41,35.0,101.41,36.0,101.41,35.0,,,,,,,,,,,,,,,,,
,101.61,35.0,101.61,35.0,101.61,37.0,101.61,35.0,,,,,,,,,,,,,,,,,
,101.82,35.0,101.82,35.0,101.82,35.0,101.82,35.0,,,,,,,,,,,,,,,,,
,102.02,35.0,102.02,35.0,102.02,35.0,102.02,35.0,,,,,,,,,,,,,,,,,
,102.23,35.0,102.23,35.0,102.23,54.0,102.23,35.0,,,,,,,,,,,,,,,,,
,102.43,35.0,102.43,35.0,102.43,52.0,102.43,34.0,,,,,,,,,,,,,,,,,
,102.64,34.0,102.64,34.0,102.64,34.0,102.64,34.0,,,,,,,,,,,,,,,,,
,102.84,34.0,102.84,34.0,102.84,34.0,102.84,34.0,,,,,,,,,,,,,,,,,
,103.05,34.0,103.05,34.0,103.05,34.0,103.05,34.0,,,,,,,,,,,,,,,,,
,103.25,34.0,103.25,34.0,103.25,34.0,103.25,33.0,,,,,,,,,,,,,,,,,
,103.46,34.0,103.46,33.0,103.46,33.0,103.46,33.0,,,,,,,,,,,,,,,,,
,103.66,33.0,103.66,33.0,103.66,33.0,103.66,33.0,,,,,,,,,,,,,,,,,
,103.87,33.0,103.87,33.0,103.87,33.0,103.87,33.0,,,,,,,,,,,,,,,,,
,104.07,33.0,104.07,33.0,104.07,33.0,104.07,33.0,,,,,,,,,,,,,,,,,
,104.28,32.0,104.28,32.0,104.28,32.0,104.28,32.0,,,,,,,,,,,,,,,,,
,104.48,32.0,104.48,32.0,104.48,32.0,104.48,32.0,,,,,,,,,,,,,,,,,
,104.69,31.0,104.69,31.0,104.69,47.0,104.69,31.0,,,,,,,,,,,,,,,,,
,104.89,30.0,104.89,31.0,104.89,31.0,104.89,31.0,,,,,,,,,,,,,,,,,
,105.10,30.0,105.10,30.0,105.10,29.0,105.10,30.0,,,,,,,,,,,,,,,,,
,105.30,30.0,105.30,30.0,105.30,31.0,105.30,30.0,,,,,,,,,,,,,,,,,
,105.51,29.0,105.51,29.0,105.51,47.0,105.51,29.0,,,,,,,,,,,,,,,,,
,105.71,28.0,105.71,29.0,105.71,32.0,105.71,29.0,,,,,,,,,,,,,,,,,
,105.92,28.0,105.92,28.0,105.92,28.0,105.92,29.0,,,,,,,,,,,,,,,,,
,106.12,28.0,106.12,28.0,106.12,28.0,106.12,28.0,,,,,,,,,,,,,,,,,
,106.35,27.0,106.35,27.0,106.35,28.0,106.35,27.0,,,,,,,,,,,,,,,,,
,106.53,27.0,106.53,27.0,106.53,27.0,106.53,27.0,,,,,,,,,,,,,,,,,
,106.74,26.0,106.74,26.0,106.74,28.0,106.74,26.0,,,,,,,,,,,,,,,,,
,106.94,26.0,106.94,26.0,106.94,35.0,106.94,25.0,,,,,,,,,,,,,,,,,
,107.15,25.0,107.15,25.0,107.15,25.0,107.15,25.0,,,,,,,,,,,,,,,,,
,107.37,25.0,107.37,25.0,107.37,27.0,107.37,24.0,,,,,,,,,,,,,,,,,
,107.56,24.0,107.56,24.0,107.56,22.0,107.56,24.0,,,,,,,,,,,,,,,,,
,107.76,24.0,107.76,24.0,107.76,36.0,107.76,24.0,,,,,,,,,,,,,,,,,
,107.97,23.0,107.97,23.0,107.97,23.0,107.97,23.0,,,,,,,,,,,,,,,,,
,108.17,22.0,108.17,22.0,108.17,23.0,108.17,22.0,,,,,,,,,,,,,,,,,
,108.40,21.0,108.40,21.0,108.40,32.0,108.40,21.0,,,,,,,,,,,,,,,,,
,108.58,20.0,108.58,20.0,108.58,20.0,108.58,20.0,,,,,,,,,,,,,,,,,
,108.79,19.0,108.79,19.0,108.79,19.0,108.79,19.0,,,,,,,,,,,,,,,,,
,108.99,19.0,108.99,19.0,108.99,19.0,108.99,18.0,,,,,,,,,,,,,,,,,
,109.20,18.0,109.20,18.0,109.20,18.0,109.20,17.0,,,,,,,,,,,,,,,,,
,109.42,17.0,109.42,16.0,109.42,16.0,109.42,16.0,,,,,,,,,,,,,,,,,
,109.61,16.0,109.61,15.0,109.61,16.0,109.61,15.0,,,,,,,,,,,,,,,,,
,109.81,15.0,109.81,14.0,109.81,15.0,109.81,14.0,,,,,,,,,,,,,,,,,
,110.02,13.0,110.02,13.0,110.02,14.0,110.02,13.0,,,,,,,,,,,,,,,,,
,110.22,13.0,110.22,12.0,110.22,12.0,110.22,12.0,,,,,,,,,,,,,,,,,
,110.45,13.0,110.45,12.0,110.45,13.0,110.45,11.0,,,,,,,,,,,,,,,,,
,110.63,12.0,110.63,11.0,110.63,14.0,110.63,11.0,,,,,,,,,,,,,,,,,
,110.84,12.0,110.84,11.0,110.84,12.0,110.84,11.0,,,,,,,,,,,,,,,,,
,111.04,12.0,111.04,10.0,111.04,23.0,111.04,10.0,,,,,,,,,,,,,,,,,
,111.25,12.0,111.25,10.0,111.25,21.0,111.25,10.0,,,,,,,,,,,,,,,,,
,111.47,11.0,111.47,10.0,111.47,11.0,111.47,9.0,,,,,,,,,,,,,,,,,
,111.66,11.0,111.66,10.0,111.66,13.0,111.66,9.0,,,,,,,,,,,,,,,,,
,111.86,11.0,111.86,10.0,111.86,22.0,111.86,9.0,,,,,,,,,,,,,,,,,
,112.07,11.0,112.07,9.0,112.07,10.0,112.07,9.0,,,,,,,,,,,,,,,,,
,112.27,11.0,112.27,9.0,112.27,22.0,112.27,9.0,,,,,,,,,,,,,,,,,
,112.50,11.0,112.50,9.0,112.50,20.0,112.50,9.0,,,,,,,,,,,,,,,,,
,112.68,11.0,112.68,9.0,112.68,10.0,112.68,8.0,,,,,,,,,,,,,,,,,
,112.89,10.0,112.89,9.0,112.89,17.0,112.89,8.0,,,,,,,,,,,,,,,,,
,113.09,10.0,113.09,8.0,113.09,9.0,113.09,7.0,,,,,,,,,,,,,,,,,
,113.30,9.0,113.30,8.0,113.30,9.0,113.30,8.0,,,,,,,,,,,,,,,,,
,113.51,9.0,113.51,7.0,113.51,9.0,113.51,7.0,,,,,,,,,,,,,,,,,
,113.71,7.0,113.71,7.0,113.71,6.0,113.71,6.0,,,,,,,,,,,,,,,,,
,113.91,7.0,113.91,6.0,113.91,7.0,113.91,6.0,,,,,,,,,,,,,,,,,
,114.12,6.0,114.12,5.0,114.12,6.0,114.12,5.0,,,,,,,,,,,,,,,,,
,114.32,6.0,114.32,5.0,114.32,6.0,114.32,5.0,,,,,,,,,,,,,,,,,
,114.53,5.0,114.53,5.0,114.53,21.0,114.53,5.0,,,,,,,,,,,,,,,,,
,114.73,5.0,114.73,5.0,114.73,6.0,114.73,5.0,,,,,,,,,,,,,,,,,
,114.94,5.0,114.94,5.0,114.94,5.0,114.94,5.0,,,,,,,,,,,,,,,,,
,115.14,5.0,115.14,5.0,115.14,5.0,115.14,5.0,,,,,,,,,,,,,,,,,
,115.35,5.0,115.35,5.0,115.35,5.0,115.35,5.0,,,,,,,,,,,,,,,,,
,115.55,5.0,115.55,6.0,115.55,5.0,115.55,6.0,,,,,,,,,,,,,,,,,
,115.76,5.0,115.76,6.0,115.76,11.0,115.76,6.0,,,,,,,,,,,,,,,,,
,115.96,6.0,115.96,6.0,115.96,6.0,115.96,6.0,,,,,,,,,,,,,,,,,
,116.17,6.0,116.17,6.0,116.17,5.0,116.17,6.0,,,,,,,,,,,,,,,,,
,116.37,6.0,116.37,7.0,116.37,10.0,116.37,6.0,,,,,,,,,,,,,,,,,
,116.58,6.0,116.58,7.0,116.58,6.0,116.58,7.0,,,,,,,,,,,,,,,,,
,116.78,6.0,116.78,7.0,116.78,5.0,116.78,7.0,,,,,,,,,,,,,,,,,
,116.99,6.0,116.99,7.0,116.99,5.0,116.99,7.0,,,,,,,,,,,,,,,,,
,117.19,6.0,117.19,7.0,117.19,5.0,117.19,7.0,,,,,,,,,,,,,,,,,
,117.40,6.0,117.40,7.0,117.40,5.0,117.40,7.0,,,,,,,,,,,,,,,,,
,117.60,6.0,117.60,7.0,117.60,5.0,117.60,7.0,,,,,,,,,,,,,,,,,
,117.81,6.0,117.81,7.0,117.81,5.0,117.81,7.0,,,,,,,,,,,,,,,,,
,118.01,6.0,118.01,7.0,118.01,5.0,118.01,7.0,,,,,,,,,,,,,,,,,
,118.22,6.0,118.22,7.0,118.22,6.0,118.22,7.0,,,,,,,,,,,,,,,,,
,118.42,6.0,118.42,7.0,118.42,5.0,118.42,7.0,,,,,,,,,,,,,,,,,
,118.63,6.0,118.63,7.0,118.63,5.0,118.63,7.0,,,,,,,,,,,,,,,,,
,118.83,6.0,118.83,7.0,118.83,5.0,118.83,7.0,,,,,,,,,,,,,,,,,
,119.04,6.0,119.04,7.0,119.04,6.0,119.04,7.0,,,,,,,,,,,,,,,,,
,119.24,6.0,119.24,7.0,119.24,6.0,119.24,7.0,,,,,,,,,,,,,,,,,
,119.45,6.0,119.45,7.0,119.45,6.0,119.45,7.0,,,,,,,,,,,,,,,,,
,119.65,6.0,119.65,7.0,119.65,6.0,119.65,7.0,,,,,,,,,,,,,,,,,
,119.86,6.0,119.86,7.0,119.86,8.0,119.86,7.0,,,,,,,,,,,,,,,,,
,120.06,7.0,120.06,7.0,120.06,6.0,120.06,7.0,,,,,,,,,,,,,,,,,
,120.27,7.0,120.27,8.0,120.27,7.0,120.27,8.0,,,,,,,,,,,,,,,,,
,120.47,8.0,120.47,8.0,120.47,15.0,120.47,8.0,,,,,,,,,,,,,,,,,
,120.68,8.0,120.68,8.0,120.68,7.0,120.68,8.0,,,,,,,,,,,,,,,,,
,120.88,8.0,120.88,8.0,120.88,8.0,120.88,9.0,,,,,,,,,,,,,,,,,
,121.09,9.0,121.09,9.0,121.09,8.0,121.09,9.0,,,,,,,,,,,,,,,,,
,121.29,9.0,121.29,9.0,121.29,18.0,121.29,9.0,,,,,,,,,,,,,,,,,
,121.50,9.0,121.50,9.0,121.50,9.0,121.50,9.0,,,,,,,,,,,,,,,,,
,121.70,9.0,121.70,9.0,121.70,9.0,121.70,9.0,,,,,,,,,,,,,,,,,
,121.91,9.0,121.91,9.0,121.91,9.0,121.91,9.0,,,,,,,,,,,,,,,,,
,122.11,9.0,122.11,9.0,122.11,9.0,122.11,9.0,,,,,,,,,,,,,,,,,
,122.32,9.0,122.32,9.0,122.32,9.0,122.32,9.0,,,,,,,,,,,,,,,,,
,122.52,9.0,122.52,9.0,122.52,9.0,122.52,9.0,,,,,,,,,,,,,,,,,
,122.73,9.0,122.73,9.0,122.73,11.0,122.73,9.0,,,,,,,,,,,,,,,,,
,122.93,9.0,122.93,9.0,122.93,9.0,122.93,9.0,,,,,,,,,,,,,,,,,
,123.14,9.0,123.14,9.0,123.14,9.0,123.14,9.0,,,,,,,,,,,,,,,,,
,123.34,9.0,123.34,9.0,123.34,9.0,123.34,9.0,,,,,,,,,,,,,,,,,
,123.57,9.0,123.57,9.0,123.57,9.0,123.57,9.0,,,,,,,,,,,,,,,,,
,123.75,9.0,123.75,9.0,123.75,18.0,123.75,9.0,,,,,,,,,,,,,,,,,
,123.96,8.0,123.96,8.0,123.96,9.0,123.96,8.0,,,,,,,,,,,,,,,,,
,124.16,8.0,124.16,8.0,124.16,8.0,124.16,8.0,,,,,,,,,,,,,,,,,
,124.37,8.0,124.37,8.0,124.37,8.0,124.37,8.0,,,,,,,,,,,,,,,,,
,124.59,8.0,124.59,7.0,124.59,8.0,124.59,7.0,,,,,,,,,,,,,,,,,
,124.78,8.0,124.78,7.0,124.78,8.0,124.78,7.0,,,,,,,,,,,,,,,,,
,124.98,8.0,124.98,7.0,124.98,9.0,124.98,7.0,,,,,,,,,,,,,,,,,
,125.19,8.0,125.19,7.0,125.19,9.0,125.19,7.0,,,,,,,,,,,,,,,,,
,125.39,8.0,125.39,6.0,125.39,9.0,125.39,6.0,,,,,,,,,,,,,,,,,
,125.62,7.0,125.62,6.0,125.62,7.0,125.62,6.0,,,,,,,,,,,,,,,,,
,125.81,7.0,125.81,6.0,125.81,14.0,125.81,5.0,,,,,,,,,,,,,,,,,
,126.01,7.0,126.01,6.0,126.01,12.0,126.01,5.0,,,,,,,,,,,,,,,,,
,126.21,7.0,126.21,6.0,126.21,7.0,126.21,5.0,,,,,,,,,,,,,,,,,
,126.42,7.0,126.42,5.0,126.42,6.0,126.42,5.0,,,,,,,,,,,,,,,,,
,126.65,7.0,126.65,5.0,126.65,7.0,126.65,5.0,,,,,,,,,,,,,,,,,
,126.83,6.0,126.83,5.0,126.83,6.0,126.83,4.0,,,,,,,,,,,,,,,,,
,127.03,6.0,127.03,5.0,127.03,6.0,127.03,4.0,,,,,,,,,,,,,,,,,
,127.24,5.0,127.24,4.0,127.24,5.0,127.24,3.0,,,,,,,,,,,,,,,,,
,127.45,4.0,127.45,3.0,127.45,4.0,127.45,3.0,,,,,,,,,,,,,,,,,
,127.67,3.0,127.67,3.0,127.67,3.0,127.67,2.0,,,,,,,,,,,,,,,,,
,127.85,2.0,127.85,2.0,127.85,2.0,127.85,2.0,,,,,,,,,,,,,,,,,
,128.06,2.0,128.06,1.0,128.06,2.0,128.06,1.0,,,,,,,,,,,,,,,,,
,128.27,1.0,128.27,1.0,128.27,1.0,128.27,1.0,,,,,,,,,,,,,,,,,
,128.47,1.0,128.47,0.0,128.47,1.0,128.47,0.0,,,,,,,,,,,,,,,,,
,128.70,0.0,128.70,0.0,128.70,0.0,128.70,0.0,,,,,,,,,,,,,,,,,
,128.88,0.0,128.88,0.0,128.88,0.0,128.88,0.0,,,,,,,,,,,,,,,,,
,129.09,0.0,129.09,0.0,129.09,0.0,129.09,0.0,,,,,,,,,,,,,,,,,
,129.29,0.0,129.29,0.0,129.29,0.0,129.29,0.0,,,,,,,,,,,,,,,,,
,129.50,0.0,129.50,0.0,129.50,0.0,129.50,0.0,,,,,,,,,,,,,,,,,
,129.71,0.0,129.71,0.0,129.71,0.0,129.71,0.0,,,,,,,,,,,,,,,,,
,129.91,0.0,129.91,0.0,129.91,0.0,129.91,0.0,,,,,,,,,,,,,,,,,
,130.11,0.0,130.11,0.0,130.11,0.0,130.11,0.0,,,,,,,,,,,,,,,,,
,130.32,0.0,130.32,0.0,130.32,0.0,130.32,0.0,,,,,,,,,,,,,,,,,
,130.52,0.0,130.52,0.0,130.52,0.0,130.52,0.0,,,,,,,,,,,,,,,,,
,130.74,0.0,130.74,0.0,130.74,0.0,130.74,0.0,,,,,,,,,,,,,,,,,
,130.93,0.0,130.93,0.0,130.93,0.0,130.93,0.0,,,,,,,,,,,,,,,,,
,131.13,0.0,131.13,0.0,131.13,0.0,131.13,0.0,,,,,,,,,,,,,,,,,
,131.34,0.0,131.34,0.0,131.34,0.0,131.34,0.0,,,,,,,,,,,,,,,,,
,131.55,0.0,131.55,0.0,131.55,0.0,131.55,0.0,,,,,,,,,,,,,,,,,
,131.75,0.0,131.75,0.0,131.75,0.0,131.75,0.0,,,,,,,,,,,,,,,,,
,131.95,0.0,131.95,0.0,131.95,0.0,131.95,0.0,,,,,,,,,,,,,,,,,
,132.16,0.0,132.16,0.0,132.16,0.0,132.16,0.0,,,,,,,,,,,,,,,,,
,132.37,0.0,132.37,0.0,132.37,0.0,132.37,0.0,,,,,,,,,,,,,,,,,
,132.57,0.0,132.57,0.0,132.57,0.0,132.57,0.0,,,,,,,,,,,,,,,,,
,132.77,0.0,132.77,0.0,132.77,0.0,132.77,0.0,,,,,,,,,,,,,,,,,
,132.98,0.0,132.98,0.0,132.98,0.0,132.98,0.0,,,,,,,,,,,,,,,,,
,133.19,0.0,133.19,0.0,133.19,0.0,133.19,0.0,,,,,,,,,,,,,,,,,
,133.39,0.0,133.39,0.0,133.39,0.0,133.39,0.0,,,,,,,,,,,,,,,,,
,133.59,0.0,133.59,0.0,133.59,0.0,133.59,0.0,,,,,,,,,,,,,,,,,
,133.80,0.0,133.80,0.0,133.80,0.0,133.80,0.0,,,,,,,,,,,,,,,,,
,134.01,0.0,134.01,0.0,134.01,0.0,134.01,0.0,,,,,,,,,,,,,,,,,
,134.21,0.0,134.21,0.0,134.21,0.0,134.21,0.0,,,,,,,,,,,,,,,,,
,134.41,0.0,134.41,0.0,134.41,0.0,134.41,0.0,,,,,,,,,,,,,,,,,
,134.62,0.0,134.62,0.0,134.62,0.0,134.62,0.0,,,,,,,,,,,,,,,,,
,134.83,0.0,134.83,0.0,134.83,0.0,134.83,0.0,,,,,,,,,,,,,,,,,
,135.03,0.0,135.03,0.0,135.03,0.0,135.03,0.0,,,,,,,,,,,,,,,,,
,135.24,0.0,135.24,0.0,135.24,0.0,135.24,0.0,,,,,,,,,,,,,,,,,
,135.44,0.0,135.44,0.0,135.44,0.0,135.44,0.0,,,,,,,,,,,,,,,,,
,135.65,0.0,135.65,0.0,135.65,0.0,135.65,0.0,,,,,,,,,,,,,,,,,
,135.85,0.0,135.85,0.0,135.85,0.0,135.85,0.0,,,,,,,,,,,,,,,,,
,136.06,0.0,136.06,0.0,136.06,0.0,136.06,0.0,,,,,,,,,,,,,,,,,
,136.26,0.0,136.26,0.0,136.26,0.0,136.26,0.0,,,,,,,,,,,,,,,,,
,136.47,0.0,136.47,0.0,136.47,0.0,136.47,0.0,,,,,,,,,,,,,,,,,
,136.67,0.0,136.67,0.0,136.67,0.0,136.67,0.0,,,,,,,,,,,,,,,,,
,136.88,0.0,136.88,0.0,136.88,0.0,136.88,0.0,,,,,,,,,,,,,,,,,
,137.08,0.0,137.08,0.0,137.08,0.0,137.08,0.0,,,,,,,,,,,,,,,,,
,137.29,0.0,137.29,0.0,137.29,0.0,137.29,0.0,,,,,,,,,,,,,,,,,
,137.49,0.0,137.49,0.0,137.49,0.0,137.49,0.0,,,,,,,,,,,,,,,,,
,137.70,0.0,137.70,0.0,137.70,0.0,137.70,0.0,,,,,,,,,,,,,,,,,
,137.90,0.0,137.90,0.0,137.90,0.0,137.90,0.0,,,,,,,,,,,,,,,,,
,138.11,0.0,138.11,0.0,138.11,0.0,138.11,0.0,,,,,,,,,,,,,,,,,
,138.31,0.0,138.31,0.0,138.31,0.0,138.31,0.0,,,,,,,,,,,,,,,,,
,138.52,0.0,138.52,0.0,138.52,0.0,138.52,0.0,,,,,,,,,,,,,,,,,
,138.72,0.0,138.72,0.0,138.72,0.0,138.72,0.0,,,,,,,,,,,,,,,,,
,138.93,0.0,138.93,0.0,138.93,0.0,138.93,0.0,,,,,,,,,,,,,,,,,
,139.13,0.0,139.13,0.0,139.13,0.0,139.13,0.0,,,,,,,,,,,,,,,,,
,139.34,0.0,139.34,0.0,139.34,0.0,139.34,0.0,,,,,,,,,,,,,,,,,
,139.54,0.0,139.54,0.0,139.54,0.0,139.54,0.0,,,,,,,,,,,,,,,,,
,139.77,0.0,139.77,0.0,139.77,0.0,139.77,0.0,,,,,,,,,,,,,,,,,
,139.95,0.0,139.95,0.0,139.95,0.0,139.95,0.0,,,,,,,,,,,,,,,,,
,140.16,0.0,140.16,0.0,140.16,0.0,140.16,0.0,,,,,,,,,,,,,,,,,
,140.36,0.0,140.36,0.0,140.36,0.0,140.36,0.0,,,,,,,,,,,,,,,,,
,140.57,0.0,140.57,0.0,140.57,0.0,140.57,0.0,,,,,,,,,,,,,,,,,
,140.79,0.0,140.79,0.0,140.79,0.0,140.79,0.0,,,,,,,,,,,,,,,,,
,140.98,0.0,140.98,0.0,140.98,0.0,140.98,0.0,,,,,,,,,,,,,,,,,
,141.18,0.0,141.18,0.0,141.18,0.0,141.18,0.0,,,,,,,,,,,,,,,,,
,141.39,0.0,141.39,0.0,141.39,0.0,141.39,0.0,,,,,,,,,,,,,,,,,
,141.59,0.0,141.59,0.0,141.59,0.0,141.59,0.0,,,,,,,,,,,,,,,,,
,141.82,0.0,141.82,0.0,141.82,0.0,141.82,0.0,,,,,,,,,,,,,,,,,
,142.00,0.0,142.00,0.0,142.00,0.0,142.00,0.0,,,,,,,,,,,,,,,,,
,142.21,0.0,142.21,0.0,142.21,0.0,142.21,0.0,,,,,,,,,,,,,,,,,
,142.41,0.0,142.41,0.0,142.41,0.0,142.41,0.0,,,,,,,,,,,,,,,,,
,142.62,0.0,142.62,0.0,142.62,0.0,142.62,0.0,,,,,,,,,,,,,,,,,
,142.84,0.0,142.84,0.0,142.84,0.0,142.84,0.0,,,,,,,,,,,,,,,,,
,143.03,0.0,143.03,0.0,143.03,0.0,143.03,0.0,,,,,,,,,,,,,,,,,
,143.23,0.0,143.23,0.0,143.23,0.0,143.23,0.0,,,,,,,,,,,,,,,,,
,143.44,0.0,143.44,0.0,143.44,0.0,143.44,0.0,,,,,,,,,,,,,,,,,
,143.64,0.0,143.64,0.0,143.64,0.0,143.64,0.0,,,,,,,,,,,,,,,,,
,143.87,0.0,143.87,0.0,143.87,0.0,143.87,0.0,,,,,,,,,,,,,,,,,
,144.05,0.0,144.05,0.0,144.05,0.0,144.05,0.0,,,,,,,,,,,,,,,,,
,144.26,0.0,144.26,0.0,144.26,0.0,144.26,0.0,,,,,,,,,,,,,,,,,
,144.46,0.0,144.46,0.0,144.46,0.0,144.46,0.0,,,,,,,,,,,,,,,,,
,144.67,0.0,144.67,0.0,144.67,0.0,144.67,0.0,,,,,,,,,,,,,,,,,
,144.89,0.0,144.89,1.0,144.89,0.0,144.89,0.0,,,,,,,,,,,,,,,,,
,145.08,0.0,145.08,1.0,145.08,0.0,145.08,0.0,,,,,,,,,,,,,,,,,
,145.28,0.0,145.28,1.0,145.28,0.0,145.28,1.0,,,,,,,,,,,,,,,,,
,145.49,0.0,145.49,1.0,145.49,0.0,145.49,1.0,,,,,,,,,,,,,,,,,
,145.69,1.0,145.69,1.0,145.69,0.0,145.69,1.0,,,,,,,,,,,,,,,,,
,145.92,1.0,145.92,1.0,145.92,0.0,145.92,1.0,,,,,,,,,,,,,,,,,
,146.10,1.0,146.10,1.0,146.10,2.0,146.10,1.0,,,,,,,,,,,,,,,,,
,146.31,1.0,146.31,2.0,146.31,1.0,146.31,1.0,,,,,,,,,,,,,,,,,
,146.51,1.0,146.51,2.0,146.51,1.0,146.51,1.0,,,,,,,,,,,,,,,,,
,146.72,1.0,146.72,2.0,146.72,1.0,146.72,2.0,,,,,,,,,,,,,,,,,
,146.93,1.0,146.93,2.0,146.93,1.0,146.93,2.0,,,,,,,,,,,,,,,,,
,147.13,2.0,147.13,2.0,147.13,1.0,147.13,2.0,,,,,,,,,,,,,,,,,
,147.33,2.0,147.33,2.0,147.33,1.0,147.33,2.0,,,,,,,,,,,,,,,,,
,147.54,2.0,147.54,2.0,147.54,1.0,147.54,2.0,,,,,,,,,,,,,,,,,
,147.74,1.0,147.74,2.0,147.74,1.0,147.74,1.0,,,,,,,,,,,,,,,,,
,147.96,1.0,147.96,1.0,147.96,1.0,147.96,1.0,,,,,,,,,,,,,,,,,
,148.15,1.0,148.15,1.0,148.15,1.0,148.15,1.0,,,,,,,,,,,,,,,,,
,148.36,0.0,148.36,1.0,148.36,0.0,148.36,0.0,,,,,,,,,,,,,,,,,
,148.56,0.0,148.56,0.0,148.56,0.0,148.56,0.0,,,,,,,,,,,,,,,,,
,148.77,0.0,148.77,0.0,148.77,0.0,148.77,0.0,,,,,,,,,,,,,,,,,
,148.97,0.0,148.97,0.0,148.97,1.0,148.97,0.0,,,,,,,,,,,,,,,,,
,149.18,0.0,149.18,0.0,149.18,0.0,149.18,0.0,,,,,,,,,,,,,,,,,
,149.38,0.0,149.38,0.0,149.38,0.0,149.38,0.0,,,,,,,,,,,,,,,,,
,149.59,0.0,149.59,1.0,149.59,0.0,149.59,0.0,,,,,,,,,,,,,,,,,
,149.79,0.0,149.79,1.0,149.79,2.0,149.79,1.0,,,,,,,,,,,,,,,,,
,150.00,0.0,150.00,1.0,150.00,0.0,150.00,0.0,,,,,,,,,,,,,,,,,
,150.20,0.0,150.20,0.0,150.20,0.0,150.20,0.0,,,,,,,,,,,,,,,,,
,150.41,0.0,150.41,0.0,150.41,1.0,150.41,0.0,,,,,,,,,,,,,,,,,
,150.61,0.0,150.61,0.0,150.61,0.0,150.61,0.0,,,,,,,,,,,,,,,,,
,150.82,0.0,150.82,1.0,150.82,0.0,150.82,1.0,,,,,,,,,,,,,,,,,
,151.02,0.0,151.02,1.0,151.02,0.0,151.02,1.0,,,,,,,,,,,,,,,,,
,151.23,0.0,151.23,0.0,151.23,0.0,151.23,0.0,,,,,,,,,,,,,,,,,
,151.43,0.0,151.43,0.0,151.43,0.0,151.43,0.0,,,,,,,,,,,,,,,,,
,151.64,0.0,151.64,0.0,151.64,0.0,151.64,0.0,,,,,,,,,,,,,,,,,
,151.84,0.0,151.84,0.0,151.84,0.0,151.84,0.0,,,,,,,,,,,,,,,,,
,152.05,0.0,152.05,0.0,152.05,0.0,152.05,0.0,,,,,,,,,,,,,,,,,
,152.25,0.0,152.25,0.0,152.25,0.0,152.25,0.0,,,,,,,,,,,,,,,,,
,152.46,0.0,152.46,0.0,152.46,0.0,152.46,0.0,,,,,,,,,,,,,,,,,
,152.66,0.0,152.66,0.0,152.66,0.0,152.66,0.0,,,,,,,,,,,,,,,,,
,152.87,0.0,152.87,0.0,152.87,0.0,152.87,0.0,,,,,,,,,,,,,,,,,
,153.28,0.0,153.28,0.0,153.28,0.0,153.28,0.0,,,,,,,,,,,,,,,,,
,153.48,0.0,153.48,0.0,153.48,0.0,153.48,0.0,,,,,,,,,,,,,,,,,
,153.69,0.0,153.69,0.0,153.69,0.0,153.69,0.0,,,,,,,,,,,,,,,,,
,153.89,1.0,153.89,0.0,153.89,0.0,153.89,0.0,,,,,,,,,,,,,,,,,
,154.10,1.0,154.10,1.0,154.10,1.0,154.10,0.0,,,,,,,,,,,,,,,,,
,154.30,1.0,154.30,1.0,154.30,1.0,154.30,1.0,,,,,,,,,,,,,,,,,
,154.51,2.0,154.51,1.0,154.51,1.0,154.51,1.0,,,,,,,,,,,,,,,,,
,154.71,2.0,154.71,2.0,154.71,2.0,154.71,1.0,,,,,,,,,,,,,,,,,
,154.92,2.0,154.92,2.0,154.92,6.0,154.92,2.0,,,,,,,,,,,,,,,,,
,155.12,2.0,155.12,2.0,155.12,2.0,155.12,2.0,,,,,,,,,,,,,,,,,
,155.33,3.0,155.33,2.0,155.33,3.0,155.33,2.0,,,,,,,,,,,,,,,,,
,155.53,3.0,155.53,2.0,155.53,3.0,155.53,2.0,,,,,,,,,,,,,,,,,
,155.74,3.0,155.74,2.0,155.74,3.0,155.74,2.0,,,,,,,,,,,,,,,,,
,155.94,2.0,155.94,2.0,155.94,2.0,155.94,2.0,,,,,,,,,,,,,,,,,
,156.15,2.0,156.15,2.0,156.15,2.0,156.15,2.0,,,,,,,,,,,,,,,,,
,156.35,2.0,156.35,2.0,156.35,2.0,156.35,2.0,,,,,,,,,,,,,,,,,
,156.56,2.0,156.56,2.0,156.56,2.0,156.56,2.0,,,,,,,,,,,,,,,,,
,156.76,2.0,156.76,2.0,156.76,2.0,156.76,2.0,,,,,,,,,,,,,,,,,
,156.99,2.0,156.99,2.0,156.99,2.0,156.99,2.0,,,,,,,,,,,,,,,,,
,157.17,2.0,157.17,2.0,157.17,2.0,157.17,2.0,,,,,,,,,,,,,,,,,
,157.38,2.0,157.38,2.0,157.38,5.0,157.38,2.0,,,,,,,,,,,,,,,,,
,157.58,3.0,157.58,3.0,157.58,2.0,157.58,3.0,,,,,,,,,,,,,,,,,
,157.79,3.0,157.79,3.0,157.79,3.0,157.79,3.0,,,,,,,,,,,,,,,,,
,158.01,3.0,158.01,3.0,158.01,3.0,158.01,3.0,,,,,,,,,,,,,,,,,
,158.20,3.0,158.20,3.0,158.20,4.0,158.20,3.0,,,,,,,,,,,,,,,,,
,158.40,3.0,158.40,3.0,158.40,3.0,158.40,3.0,,,,,,,,,,,,,,,,,
,158.61,3.0,158.61,3.0,158.61,3.0,158.61,3.0,,,,,,,,,,,,,,,,,
,158.81,3.0,158.81,3.0,158.81,3.0,158.81,3.0,,,,,,,,,,,,,,,,,
,159.04,3.0,159.04,3.0,159.04,3.0,159.04,3.0,,,,,,,,,,,,,,,,,
,159.22,3.0,159.22,3.0,159.22,3.0,159.22,3.0,,,,,,,,,,,,,,,,,
,159.43,3.0,159.43,3.0,159.43,7.0,159.43,3.0,,,,,,,,,,,,,,,,,
,159.63,3.0,159.63,3.0,159.63,3.0,159.63,3.0,,,,,,,,,,,,,,,,,
,159.84,3.0,159.84,3.0,159.84,3.0,159.84,3.0,,,,,,,,,,,,,,,,,
,160.06,3.0,160.06,3.0,160.06,3.0,160.06,3.0,,,,,,,,,,,,,,,,,
,160.25,3.0,160.25,3.0,160.25,3.0,160.25,3.0,,,,,,,,,,,,,,,,,
,160.45,2.0,160.45,3.0,160.45,2.0,160.45,3.0,,,,,,,,,,,,,,,,,
,160.66,2.0,160.66,2.0,160.66,2.0,160.66,2.0,,,,,,,,,,,,,,,,,
,160.86,2.0,160.86,2.0,160.86,2.0,160.86,2.0,,,,,,,,,,,,,,,,,
,161.09,2.0,161.09,2.0,161.09,1.0,161.09,2.0,,,,,,,,,,,,,,,,,
,161.27,2.0,161.27,2.0,161.27,1.0,161.27,2.0,,,,,,,,,,,,,,,,,
,161.48,2.0,161.48,2.0,161.48,1.0,161.48,2.0,,,,,,,,,,,,,,,,,
,161.68,2.0,161.68,2.0,161.68,3.0,161.68,2.0,,,,,,,,,,,,,,,,,
,161.89,2.0,161.89,3.0,161.89,2.0,161.89,2.0,,,,,,,,,,,,,,,,,
,162.11,2.0,162.11,3.0,162.11,3.0,162.11,2.0,,,,,,,,,,,,,,,,,
,162.30,2.0,162.30,3.0,162.30,6.0,162.30,3.0,,,,,,,,,,,,,,,,,
,162.50,2.0,162.50,3.0,162.50,2.0,162.50,3.0,,,,,,,,,,,,,,,,,
,162.71,2.0,162.71,3.0,162.71,2.0,162.71,2.0,,,,,,,,,,,,,,,,,
,162.91,2.0,162.91,3.0,162.91,2.0,162.91,2.0,,,,,,,,,,,,,,,,,
,163.14,2.0,163.14,3.0,163.14,1.0,163.14,2.0,,,,,,,,,,,,,,,,,
,163.32,2.0,163.32,2.0,163.32,1.0,163.32,2.0,,,,,,,,,,,,,,,,,
,163.53,1.0,163.53,2.0,163.53,1.0,163.53,2.0,,,,,,,,,,,,,,,,,
,163.73,1.0,163.73,2.0,163.73,2.0,163.73,2.0,,,,,,,,,,,,,,,,,
,163.94,1.0,163.94,2.0,163.94,1.0,163.94,2.0,,,,,,,,,,,,,,,,,
,164.15,1.0,164.15,2.0,164.15,1.0,164.15,2.0,,,,,,,,,,,,,,,,,
,164.35,1.0,164.35,2.0,164.35,1.0,164.35,2.0,,,,,,,,,,,,,,,,,
,164.55,1.0,164.55,2.0,164.55,1.0,164.55,2.0,,,,,,,,,,,,,,,,,
,164.76,1.0,164.76,2.0,164.76,1.0,164.76,2.0,,,,,,,,,,,,,,,,,
,164.96,1.0,164.96,2.0,164.96,1.0,164.96,2.0,,,,,,,,,,,,,,,,,
,165.18,1.0,165.18,2.0,165.18,1.0,165.18,2.0,,,,,,,,,,,,,,,,,
,165.37,1.0,165.37,2.0,165.37,1.0,165.37,1.0,,,,,,,,,,,,,,,,,
,165.58,1.0,165.58,2.0,165.58,3.0,165.58,1.0,,,,,,,,,,,,,,,,,
,165.78,1.0,165.78,2.0,165.78,1.0,165.78,2.0,,,,,,,,,,,,,,,,,
,165.99,1.0,165.99,2.0,165.99,1.0,165.99,2.0,,,,,,,,,,,,,,,,,
,166.19,1.0,166.19,2.0,166.19,2.0,166.19,2.0,,,,,,,,,,,,,,,,,
,166.40,1.0,166.40,2.0,166.40,5.0,166.40,2.0,,,,,,,,,,,,,,,,,
,166.60,1.0,166.60,2.0,166.60,2.0,166.60,1.0,,,,,,,,,,,,,,,,,
,166.81,1.0,166.81,1.0,166.81,1.0,166.81,1.0,,,,,,,,,,,,,,,,,
,167.01,1.0,167.01,1.0,167.01,1.0,167.01,1.0,,,,,,,,,,,,,,,,,
,167.22,1.0,167.22,1.0,167.22,1.0,167.22,1.0,,,,,,,,,,,,,,,,,
,167.42,1.0,167.42,1.0,167.42,1.0,167.42,1.0,,,,,,,,,,,,,,,,,
,167.63,1.0,167.63,1.0,167.63,1.0,167.63,1.0,,,,,,,,,,,,,,,,,
,167.83,1.0,167.83,1.0,167.83,0.0,167.83,1.0,,,,,,,,,,,,,,,,,
,168.04,0.0,168.04,1.0,168.04,0.0,168.04,0.0,,,,,,,,,,,,,,,,,
,168.24,0.0,168.24,1.0,168.24,0.0,168.24,0.0,,,,,,,,,,,,,,,,,
,168.45,0.0,168.45,1.0,168.45,0.0,168.45,1.0,,,,,,,,,,,,,,,,,
,168.65,1.0,168.65,1.0,168.65,0.0,168.65,1.0,,,,,,,,,,,,,,,,,
,168.86,1.0,168.86,1.0,168.86,1.0,168.86,1.0,,,,,,,,,,,,,,,,,
,169.06,1.0,169.06,1.0,169.06,1.0,169.06,1.0,,,,,,,,,,,,,,,,,
,169.27,1.0,169.27,1.0,169.27,0.0,169.27,1.0,,,,,,,,,,,,,,,,,
,169.47,0.0,169.47,1.0,169.47,0.0,169.47,1.0,,,,,,,,,,,,,,,,,
,169.68,0.0,169.68,1.0,169.68,0.0,169.68,0.0,,,,,,,,,,,,,,,,,
,169.88,0.0,169.88,0.0,169.88,0.0,169.88,0.0,,,,,,,,,,,,,,,,,
,170.09,0.0,170.09,0.0,170.09,0.0,170.09,0.0,,,,,,,,,,,,,,,,,
,170.29,0.0,170.29,0.0,170.29,0.0,170.29,0.0,,,,,,,,,,,,,,,,,
,170.50,0.0,170.50,0.0,170.50,0.0,170.50,0.0,,,,,,,,,,,,,,,,,
,170.70,0.0,170.70,0.0,170.70,0.0,170.70,0.0,,,,,,,,,,,,,,,,,
,170.91,0.0,170.91,0.0,170.91,0.0,170.91,0.0,,,,,,,,,,,,,,,,,
,171.11,0.0,171.11,0.0,171.11,0.0,171.11,0.0,,,,,,,,,,,,,,,,,
,171.32,0.0,171.32,0.0,171.32,0.0,171.32,0.0,,,,,,,,,,,,,,,,,
,171.52,0.0,171.52,0.0,171.52,0.0,171.52,0.0,,,,,,,,,,,,,,,,,
,171.73,0.0,171.73,0.0,171.73,0.0,171.73,0.0,,,,,,,,,,,,,,,,,
,171.93,0.0,171.93,0.0,171.93,0.0,171.93,0.0,,,,,,,,,,,,,,,,,
,172.14,0.0,172.14,0.0,172.14,0.0,172.14,0.0,,,,,,,,,,,,,,,,,
,172.34,0.0,172.34,0.0,172.34,0.0,172.34,0.0,,,,,,,,,,,,,,,,,
,172.55,0.0,172.55,0.0,172.55,0.0,172.55,0.0,,,,,,,,,,,,,,,,,
,172.75,0.0,172.75,0.0,172.75,0.0,172.75,0.0,,,,,,,,,,,,,,,,,
,172.96,0.0,172.96,0.0,172.96,0.0,172.96,0.0,,,,,,,,,,,,,,,,,
,173.16,0.0,173.16,0.0,173.16,0.0,173.16,0.0,,,,,,,,,,,,,,,,,
,173.37,0.0,173.37,0.0,173.37,0.0,173.37,0.0,,,,,,,,,,,,,,,,,
,173.57,0.0,173.57,0.0,173.57,0.0,173.57,0.0,,,,,,,,,,,,,,,,,
,173.78,0.0,173.78,0.0,173.78,0.0,173.78,0.0,,,,,,,,,,,,,,,,,
,173.98,0.0,173.98,0.0,173.98,0.0,173.98,0.0,,,,,,,,,,,,,,,,,
,174.21,0.0,174.21,0.0,174.21,0.0,174.21,0.0,,,,,,,,,,,,,,,,,
,174.39,0.0,174.39,0.0,174.39,0.0,174.39,0.0,,,,,,,,,,,,,,,,,
,174.60,0.0,174.60,0.0,174.60,0.0,174.60,0.0,,,,,,,,,,,,,,,,,
,174.80,0.0,174.80,0.0,174.80,0.0,174.80,0.0,,,,,,,,,,,,,,,,,
,175.01,0.0,175.01,0.0,175.01,0.0,175.01,0.0,,,,,,,,,,,,,,,,,
,175.23,0.0,175.23,0.0,175.23,0.0,175.23,0.0,,,,,,,,,,,,,,,,,
,175.42,0.0,175.42,0.0,175.42,0.0,175.42,0.0,,,,,,,,,,,,,,,,,
,175.62,0.0,175.62,0.0,175.62,0.0,175.62,0.0,,,,,,,,,,,,,,,,,
,175.82,0.0,175.82,0.0,175.83,0.0,175.83,0.0,,,,,,,,,,,,,,,,,
,176.02,0.0,176.02,0.0,176.02,0.0,176.03,0.0,,,,,,,,,,,,,,,,,
,176.26,0.0,176.26,0.0,176.26,0.0,176.26,0.0,,,,,,,,,,,,,,,,,
,176.44,0.0,176.44,0.0,176.44,0.0,176.44,0.0,,,,,,,,,,,,,,,,,
,176.65,0.0,176.65,0.0,176.65,0.0,176.65,0.0,,,,,,,,,,,,,,,,,
,176.85,0.0,176.85,0.0,176.85,0.0,176.85,0.0,,,,,,,,,,,,,,,,,
,177.06,0.0,177.06,0.0,177.06,0.0,177.06,0.0,,,,,,,,,,,,,,,,,
,177.28,0.0,177.28,0.0,177.28,0.0,177.28,0.0,,,,,,,,,,,,,,,,,
,177.46,0.0,177.46,0.0,177.46,0.0,177.46,0.0,,,,,,,,,,,,,,,,,
Definitely looks like something wonky with the left rear. Unclear whether it's the bearing, the encoder ring, or the sensor:
Souriau
Newry, NI
C?ID=86928
I fitted a new wheel bearing on the rear left.
The reluctor ring was badly rusted.
A short drive and lock-to-lock steering, hey presto, all warning lights are out. Happy day.
steering assist is back to mormal.
Monday,30,January,2023,20:03:32:46973
VCDS Version: 22.10.0.1  HEX-NET CB: 0.4623.4
Workshop Code: 000 18261 018261
VIN: WVWZZZ1KZ7W199812   License Plate:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ7W199812   Mileage: 320030km-198857miles
Address 01: Engine        Labels: 03G-906-016-BDJ.clb
   Part No SW: 03G 906 016 LD    HW: 03G 906 016 LD
   Component: R4 2,0L EDC 0000SG  0544
   Revision: 12345678    Serial number: VWZ7Z0G8049553
   Coding: 0000071
   Shop #: WSC 01279 785 00200
   VCID: F0AC999DE314EE0DF2-80A4
   VINID: 9E69EAAAA05BA879C1249201089DF6C72A
   Revision: 00H11001
   Coding: 0021121
   Part No: 1K0 820 047 GK
   Component: Climatic PQ35   120 0606
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006685161
   Coding: 00890F2700041500471400001400000000087B075C0001
   Shop #: WSC 01287 785 00200
   VCID: EB968EF1CA320DD5C7-80BE
   Component: Wischer 060207 020  0501
   Coding: 00038805
   Shop #: WSC 01287
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD11L860
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: BD3270A9E4C6536529-80E8
   Subsystem 1 - Serial number: 6332MSME16525957B
   Subsystem 2 - Serial number: 6342MSME16520F4DI
   Subsystem 3 - Serial number: 6352QSME21512C112
   Subsystem 4 - Serial number: 6362QSME21193835A
   Part No SW: 1K0 953 549 BB    HW: 1K0 953 549 BB
   Component: Lenksäulenmodul 036 0070
   Coding: 0000002
   Part No SW: 1K0 920 953 N    HW: 1K0 920 953 N
   Revision: V0003000    Serial number: VWZ7Z0G8049553
   Coding: 0003403
   Shop #: WSC 18261 785 18261
   VCID: B6206F85C1F0803DE8-80E2
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 120207F1002033
   Coding: 3D0F034007000001
   Shop #: WSC 18261 000 18261
   VCID: AF2E5AE13EAAB1F5AB-80FA
   Component: IMMO            VDD 1610
   Component: Tuer-SG         005 0984
   Coding: 0000564
   VCID: B83C61BDCBE4764DFA-80EC
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 18261 028 18261
   Part No: 1K0 959 433 AJ
   Coding: 00C802087F2D8405485A038010CC
   VCID: F8BCA1BD8B64B64D3A-80AC
   Coding: 0000564
   VCID: B93A64B9F0EE6F4505-80EC
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G4498166
   Coding: 0020200
   VCID: B73E6281C6FA7935F3-80E2
End----------(Elapsed Time: 01:15, VBatt start/end: 12.5V/12.5V)-----------
Souriau
Newry, NI
C?ID=86928
Update on the logging
Thu,Feb,02,2023,10:17:10 -VCID:73A94CCF4AAB38ADE693FB-8026,VCDS Mobile: 0.4623
,0.00,11.0,0.00,10.0,0.00,11.0,0.00,10.0,,,,,,,,,,,,,,,,,
,0.24,10.0,0.24,10.0,0.24,10.0,0.24,10.0,,,,,,,,,,,,,,,,,
,0.47,10.0,0.47,10.0,0.47,10.0,0.47,10.0,,,,,,,,,,,,,,,,,
,0.65,10.0,0.65,10.0,0.65,10.0,0.65,10.0,,,,,,,,,,,,,,,,,
,0.86,10.0,0.86,9.0,0.86,9.0,0.86,10.0,,,,,,,,,,,,,,,,,
,1.06,9.0,1.06,9.0,1.06,9.0,1.06,9.0,,,,,,,,,,,,,,,,,
,1.27,9.0,1.27,9.0,1.27,9.0,1.27,9.0,,,,,,,,,,,,,,,,,
,1.49,9.0,1.49,9.0,1.49,9.0,1.49,9.0,,,,,,,,,,,,,,,,,
,1.68,9.0,1.68,9.0,1.68,9.0,1.68,9.0,,,,,,,,,,,,,,,,,
,1.88,9.0,1.88,9.0,1.88,9.0,1.88,9.0,,,,,,,,,,,,,,,,,
,2.09,9.0,2.09,9.0,2.09,9.0,2.09,9.0,,,,,,,,,,,,,,,,,
,2.29,9.0,2.29,9.0,2.29,9.0,2.29,9.0,,,,,,,,,,,,,,,,,
,2.52,10.0,2.52,10.0,2.52,10.0,2.52,10.0,,,,,,,,,,,,,,,,,
,2.70,11.0,2.70,11.0,2.70,11.0,2.70,10.0,,,,,,,,,,,,,,,,,
,2.91,11.0,2.91,11.0,2.91,11.0,2.91,11.0,,,,,,,,,,,,,,,,,
,3.11,12.0,3.11,12.0,3.11,12.0,3.11,12.0,,,,,,,,,,,,,,,,,
,3.32,12.0,3.32,12.0,3.32,12.0,3.32,12.0,,,,,,,,,,,,,,,,,
,3.54,13.0,3.54,13.0,3.54,13.0,3.54,13.0,,,,,,,,,,,,,,,,,
,3.73,13.0,3.73,13.0,3.73,13.0,3.73,13.0,,,,,,,,,,,,,,,,,
,3.93,13.0,3.93,13.0,3.93,13.0,3.93,13.0,,,,,,,,,,,,,,,,,
,4.14,13.0,4.14,13.0,4.14,13.0,4.14,13.0,,,,,,,,,,,,,,,,,
,4.34,14.0,4.34,14.0,4.34,14.0,4.34,14.0,,,,,,,,,,,,,,,,,
,4.57,14.0,4.57,14.0,4.57,14.0,4.57,14.0,,,,,,,,,,,,,,,,,
,4.75,14.0,4.75,14.0,4.75,14.0,4.75,14.0,,,,,,,,,,,,,,,,,
,4.96,14.0,4.96,14.0,4.96,14.0,4.96,14.0,,,,,,,,,,,,,,,,,
,5.16,15.0,5.16,14.0,5.16,15.0,5.16,14.0,,,,,,,,,,,,,,,,,
,5.37,15.0,5.37,14.0,5.37,15.0,5.37,14.0,,,,,,,,,,,,,,,,,
,5.59,15.0,5.59,15.0,5.59,14.0,5.59,14.0,,,,,,,,,,,,,,,,,
,5.78,15.0,5.78,14.0,5.78,15.0,5.78,14.0,,,,,,,,,,,,,,,,,
,5.98,14.0,5.98,14.0,5.98,15.0,5.98,14.0,,,,,,,,,,,,,,,,,
,6.19,14.0,6.19,14.0,6.19,14.0,6.19,14.0,,,,,,,,,,,,,,,,,
,6.39,14.0,6.39,14.0,6.39,14.0,6.39,14.0,,,,,,,,,,,,,,,,,
,6.62,13.0,6.62,13.0,6.62,13.0,6.62,13.0,,,,,,,,,,,,,,,,,
,6.80,13.0,6.80,13.0,6.80,13.0,6.80,13.0,,,,,,,,,,,,,,,,,
,7.01,12.0,7.01,13.0,7.01,13.0,7.01,13.0,,,,,,,,,,,,,,,,,
,7.21,12.0,7.21,12.0,7.21,12.0,7.21,12.0,,,,,,,,,,,,,,,,,
,7.42,12.0,7.42,12.0,7.42,12.0,7.42,12.0,,,,,,,,,,,,,,,,,
,7.63,12.0,7.63,12.0,7.63,12.0,7.63,12.0,,,,,,,,,,,,,,,,,
,7.83,12.0,7.83,12.0,7.83,12.0,7.83,12.0,,,,,,,,,,,,,,,,,
,8.03,12.0,8.03,12.0,8.03,12.0,8.03,12.0,,,,,,,,,,,,,,,,,
,8.24,12.0,8.24,13.0,8.24,12.0,8.24,13.0,,,,,,,,,,,,,,,,,
,8.44,12.0,8.44,13.0,8.44,12.0,8.44,13.0,,,,,,,,,,,,,,,,,
,8.65,12.0,8.65,12.0,8.65,12.0,8.65,13.0,,,,,,,,,,,,,,,,,
,8.85,12.0,8.85,12.0,8.85,12.0,8.85,12.0,,,,,,,,,,,,,,,,,
,9.06,12.0,9.06,12.0,9.06,11.0,9.06,12.0,,,,,,,,,,,,,,,,,
,9.26,11.0,9.26,11.0,9.26,11.0,9.26,12.0,,,,,,,,,,,,,,,,,
,9.47,11.0,9.47,11.0,9.47,11.0,9.47,11.0,,,,,,,,,,,,,,,,,
,9.67,11.0,9.67,11.0,9.67,10.0,9.67,10.0,,,,,,,,,,,,,,,,,
,9.88,10.0,9.88,11.0,9.88,10.0,9.88,11.0,,,,,,,,,,,,,,,,,
,10.08,11.0,10.08,11.0,10.08,10.0,10.08,11.0,,,,,,,,,,,,,,,,,
,10.29,11.0,10.29,12.0,10.29,10.0,10.29,12.0,,,,,,,,,,,,,,,,,
,10.49,10.0,10.49,12.0,10.49,10.0,10.49,11.0,,,,,,,,,,,,,,,,,
,10.70,10.0,10.70,11.0,10.70,9.0,10.70,11.0,,,,,,,,,,,,,,,,,
,10.90,9.0,10.90,11.0,10.90,9.0,10.90,10.0,,,,,,,,,,,,,,,,,
,11.11,9.0,11.11,11.0,11.11,8.0,11.11,11.0,,,,,,,,,,,,,,,,,
,11.31,9.0,11.31,11.0,11.31,8.0,11.31,10.0,,,,,,,,,,,,,,,,,
,11.52,9.0,11.52,11.0,11.52,8.0,11.52,10.0,,,,,,,,,,,,,,,,,
,11.72,9.0,11.72,11.0,11.72,8.0,11.72,11.0,,,,,,,,,,,,,,,,,
,11.93,9.0,11.93,11.0,11.93,8.0,11.93,10.0,,,,,,,,,,,,,,,,,
,12.13,8.0,12.13,10.0,12.13,7.0,12.13,9.0,,,,,,,,,,,,,,,,,
,12.34,7.0,12.34,9.0,12.34,6.0,12.34,8.0,,,,,,,,,,,,,,,,,
,12.54,6.0,12.54,7.0,12.54,5.0,12.54,7.0,,,,,,,,,,,,,,,,,
,12.75,5.0,12.75,6.0,12.75,4.0,12.75,5.0,,,,,,,,,,,,,,,,,
,12.95,4.0,12.95,4.0,12.95,3.0,12.95,4.0,,,,,,,,,,,,,,,,,
,13.16,2.0,13.16,3.0,13.16,2.0,13.16,3.0,,,,,,,,,,,,,,,,,
,13.36,1.0,13.36,2.0,13.36,1.0,13.36,2.0,,,,,,,,,,,,,,,,,
,13.57,0.0,13.57,1.0,13.57,0.0,13.57,1.0,,,,,,,,,,,,,,,,,
,13.77,0.0,13.77,0.0,13.77,0.0,13.77,0.0,,,,,,,,,,,,,,,,,
,13.98,0.0,13.98,0.0,13.98,0.0,13.98,0.0,,,,,,,,,,,,,,,,,
,14.18,0.0,14.18,0.0,14.18,0.0,14.18,0.0,,,,,,,,,,,,,,,,,
,14.39,0.0,14.39,0.0,14.39,0.0,14.39,0.0,,,,,,,,,,,,,,,,,
