VW T5
   #81
Unsure if we covered before but .... if the new BCM was in Factory Mode is may unlock the doors but not lock them. If this happens with used BCMs I'm probably way off here but make sure channel 099 is off (0 = Factory Mode inactive) in the new unit.
   #82
senna1
C?ID=231631
Hi Dana anything is worth looking at as it should otherwise be working i tested the Central lock switch seems like it is ok i think it does have a resistor to know when unlock/lock and on the one test just straight contact the other shows resistance approx 650 ohms, and all continuity is correct,
i assume when you say 099 Channel is Off that is in MVB & if it is not correct can i edit it Coding regards
   #83
That's going to be under the Adaptation-10 (not MVBs) function after you connect to the BCM. The screen will look like this:
... but you are reading channel 99 instead of 01 per that exact example. After you get a read on channel 99 make sure it is set to 0. If it isn't change it to 0 and Test/Save.
senna1
C?ID=231631
Thankyou i will take a look tomorrow, I have tried the two other BCM we have it was the same but you never know,
   #85
senna1
C?ID=231631
Hi Dana
I took a look 09 then 10 adaption then channel 99 it was on 1 = factory mode active so i put it to 0 = factory mode inactive
and tried the central lock to Lock NO Joy it says something in the pop up once it's being deactivated it can not be
reactivated again i put it back to 1, should i put it to 0 = Factory mode inactive i have tried everything and no joy the continuity
all checks as good and VCDS can unlock and lock the Front Doors, i will see if direct at T73a/11 if any power when the E150 sw is opereated to Lock
function , but continuity is all good inc the Gnd, and unlock works same Gnd same input but on unlock it is T73a/12
the Drivers door has a new V56 motor do they have to be Coded
   #86
Yeah, you want that set to 0 = Factory mode inactive otherwise various BCM functions will not work. Also note, Address 19 could be in Transport Mode (since it is new as well/part of J519). You may want to click the [De-activate Transport Mode] button located on the Applications screen as well.
If that doesn't help please post another current condition scan so we can see the overall condition at this point in time.
Replacement door latches (i.e. V56/F220) would be plug and play. No coding or diagnostic steps would be required.
   #87
senna1
C?ID=231631
when you say address 19 is that channel 19 in adaption to click de activate transport mode
   #90
senna1
C?ID=231631
Hi Dan Ref #87
for BCM You say set to 0 = Factory mode inactive otherwise various BCM functions will not work. Also note, Address 19 could be in Transport Mode (since it is new as well/part of J519). You may want to click the [De-activate Transport Mode] button located on the Applications screen as well.
I set this to 0 = factory mode, Then in 19 gateway the only area i saw anything regarding Transport Deactivation was in MVB 02 It is already in Deactivate Mode unlearn counter 4.0 MB Group 02 but i could not edit it even if i wanted too, or once it is change maybe you cant go back .
Also i noticed under 19 Gateway I went through from 0 to 240 channels I stopped at 240 as every channel had error not available.
The N/S sliding door previously was not on The scan when scanned, i plugged another second hand door Lock assembly into the harness and now you
can see it on the scan But i still cant under 09 get any communication with controller, also with both SIDE door lock assemblys in MVB it shows Door status
when the Doors are closed, the Side door shows on MB 05 the opposite to what it is , if The door is Open, the MB shows closed and vice versa
And And unlocked status for F222 it is unlocked Door closed, when door open it shows Safe ? when on MBV 07
I have traced previously the side door harness from the B post strip contact F10 to the side Door contact strip all good,
Here is todays scan after changes and deletes,
There are some new DTC's as the bumper is removed and some lightsl
REGARDING the new side Door lock assembly it is plug and play But does any coding need to be done as you said no.
The central locking will still only UNLOCK, no Locking on any Doors only possible with output test VCDS
Thursday,23,February,2023,12:57:08:51242
VCDS Version: 22.10.0.1 (x64)  HEX-NET2 CB: 0.4623.4
VIN: WV1ZZZ7HZEH037985   License Plate: NEW FULL SCAN 23-2-23
Mileage: 20km-12mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 0D 15 17 19 25 56 61 0B
VIN: WV1ZZZ7HZEH037985   Mileage: 20km-12miles
04-Steering Angle -- Status: Cannot be reached 1100
0D-Slide Door, Left -- Status: OK 0000
15-Airbags -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAAD)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FH    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 6293
   Revision: 22H38---    Serial number: 00000000000000 CVN: 13593D87
   Coding: 0111401A232401080000
   Shop #: WSC 07051 005 104857
   ASAM Dataset: EV_ECM20TDI01103L906019FH 003007
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 76BE8932E84BBF1BC1E-8022
   VINID: 9E606AAAA1D8A956000C724814F66D2210
11 Faults Found:
16703 - Gear Reconition Sensor
          P181C 00 [039] - Implausbile Signal
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:50
                    Engine RPM: 0.00 /min
                    Coolant temperature: 6 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 12.180 V
                    Neutral position sensor: current transmission angle: 20.00 °
                    Neutral position sensor: adapted transmission angle: 0.00 °
                    Adaptation status of neutral position sensor-Bits 0-7: 4
                    Transmission neutral position sensor voltage: 0 mV
                    Neutral position sensor: upper adaptation value: 0 mV
                    Neutral position sensor: lower adaptation value: 0 mV
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [039] - Signal too High
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:51
                    Voltage terminal 30: 12.160 V
                    Exhaust gas temperature sensor 1: 10.4 °C
                    Exhaust gas temperature sensor 2: -0.0 °C
                    Exhaust gas temperature sensor 3: 10.4 °C
                    Exhaust gas temperature sensor 4: 18.0 °C
                    Shut-off timer: last engine shut-off time: 2224 s
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:51
                    Longitudinal acceleration: raw value: 32.767 m/s²
                    Vehicle inclination acceleration angle: raw value: 0.000 m/s²
                    Status: incline angle-Bits 0-7: 1
                    Longitudinal acceleration: 0.000 m/s²
                    Longitudinal acceleration sensor: status-Bits 0-7: 1
                    Vehicle lateral acceleration: raw value: 0.00 g
                    Vehicle lateral acceleration: 0.00 g
10092 - Neutral Gear Sensor
          P15A0 00 [039] - Electrical Malfunction
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:51
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:51
                    Limitation: accelerator pedal: 92.5 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    selected gear-Bits 0-7: 0
4710 - No Communications with Airbag Control Module
          U0151 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:51
4729 - Steering Effort Control Module
          U0130 00 [039] - No Communications
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:51
5046 - Fuel Injector #1 (N30)
          P0263 00 [167] - Contribution/Balance Fault
                    Mileage: 27 km
                    Vehicle speed: 255 km/h
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 12.280 V
                    Allowed number of injections-Bits 0-7: 0
                    Injection release status-Bits 0-7: 0
                    Desired injection characteristic-Bits 0-7: 0
                    Mean injection quantity: 0.00 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 0
                    Fuel high-pressure: actual value: 0 hPa
                    Control Module temperature: 150.0 °C
5044 - Fuel Injector #3 (N32)
          P0269 00 [167] - Contribution/Balance Fault
                    Mileage: 27 km
5047 - Fuel Injector #4 (N33)
          P0272 00 [167] - Contribution/Balance Fault
                    Mileage: 27 km
5043 - Fuel Injector #2 (N31)
          P0266 00 [167] - Contribution/Balance Fault
                    Mileage: 27 km
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9C24AB9179B96390
   Shop #: WSC 07051 005 49152
   VCID: 3A265D029C531B7BE56-806E
                    Fault Status: 01100101
                    Reset counter: 4
                    Date: 2023.02.23
                    Time: 00:37:47
                    Count: 16384
                    Count: 4352
                    Count: 212
                    Count: 766
                    Reset counter: 4
                    Date: 2023.02.23
                    Time: 00:37:47
                    Count: 16384
                    Count: 4352
                    Count: 279
                    Count: 766
                    Reset counter: 4
                    Date: 2023.02.23
                    Time: 00:37:47
                    Count: 16384
                    Count: 4352
                    Count: 270
                    Count: 766
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 4
                    Date: 2023.02.23
                    Time: 00:37:47
                    Count: 16384
                    Count: 4352
                    Count: 8193
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:49
                    Count: 16384
                    Count: 4352
                    Count: 8214
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:49
                    Count: 16384
                    Count: 4352
                    Count: 8226
                    Count: 766
Address 08: Auto HVAC
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 342200003
   Coding: A0A0303A0A612431802849702E2B8C540780610F60064C41320000020000
   Shop #: WSC 12345 288 27091
   VCID: 6882D74AB27F59EB432-803C
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU006041660975355
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU029051551498270
   Coding: 0000A0
00967 - Left Turn Signals
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
03431 - Activation of Left Parking Light
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
03442 - Return Message Closing Status of Rear Lid
                    Fault Status: 01101000
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:43:42
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
Address 0D: Slide Door, Left
Address 15: Airbags
   Part No SW: 7E0 920 960 JX    HW: 7E0 920 960 JX
   Component: KOMBI         H04 0709
   Coding: 460201
   Shop #: WSC 07051 005 1048576
   VCID: 0842F7CA92BFB9EBA32-805C
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042300
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.23
                    Time: 00:37:48
   Component: IMMO          H04 0709
   VCID: 6A86AD42ACF36BFB556-803E
Address 56: Radio
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 230B1A73
   Shop #: WSC 01693 210 00002
   Subsystem 1 - Part No SW: 7E0 915 181 B    HW: 7E0 915 181 B
   Component: J367-BDM  H08 0181
   Serial number: 50238G45562221010723
End----------(Elapsed Time: 01:05, VBatt start/end: 11.5V/12.2V)-----------
senna1
C?ID=231631
Hi Dana
what do think of my last report & Scan , and what is VCDS doing for regarding when using output test as IT can lock the Doors using this, compared to the operation of the Std Central locking switch, as i said my wiring,, everything checks out especially T73a/11 outup but there is NO output coming from the J519 for T73a/11 so my central locking LOCK function is never going to work.
   #92
I don't have any additional suggestions but did you click the [De-activate Transport Mode] button located on the Applications screen? It would look like this:
Ross-Tech: VCDS Tour - Applications
   #93
VWT6
Finland
C?ID=295527
Try changing BCM byte 26 byte 0 = "1" supposedly to enable CAN communications (for left sliding door)
Try changing BCM byte 10 bit 6 = "0" supposedly to reverse open/closed statuses for sliding doors.
senna1
C?ID=231631
Hi) I did try the otherday Byte 26 signal for canbus side loading door NO difference no change, but i notice the problem side loading door staus shows closed when it is actually open the opposite to what it is, if i change the coding byte of 26 the status changes to NO COMMUNICATION so i put it back to what it was, i have not tried ( Try changing BCM byte 10 bit 6 = "0" supposedly to reverse open/closed statuses for sliding doors. ) i will try that,Thanks
also one of the fault codes 01336
Possible Cause:
Data Bus Comfort working in Single-Wire Mode. if i have my break out box connected to check canbus H-L only pin 14 L is showing any communication
nothing on pin 6 Can h
I am going to disconnect T73a/11 wire about 6 inches from the j519 as there is a heatshrink join there, although i have continuity for all the doors etc for the wire, as it joins for them routed by B215 & via other connectors and Door strip contact just incase there is any interference Not much left i can do all the checks regarding the modules for canbus all check out yet i have the Dtc of 01336 i have another Bcm i have coded and no difference here is that full scan.
Tuesday,28,February,2023,13:53:38:51242
VIN: WV1ZZZ7HZEH037985   License Plate: FULL SCAN DONA MODULE
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 0D 10 15 17 19 25 2E 44 56 61 77 0B
10-Park/Steer Assist -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
14 Faults Found:
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
                    Coolant temperature: 5 °C
                    Intake air temperature: 7 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 12.340 V
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:20
                    Voltage terminal 30: 12.320 V
                    Exhaust gas temperature sensor 1: 8.5 °C
                    Exhaust gas temperature sensor 3: 8.5 °C
                    Exhaust gas temperature sensor 4: 16.1 °C
                    Shut-off timer: last engine shut-off time: 945 s
8623 - Sensor for Ambient Air Temperature (G17)
          P0071 00 [036] - Implausible Signal
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:19:33
                    Voltage terminal 30: 10.200 V
                    Shut-off timer: last engine shut-off time: 1155 s
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 27 km
                    Coolant temperature: 4 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 10.640 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 193
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4881 - EGR Valve (N18)
          P1440 00 [036] - Open Circuit
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:28:58
                    Voltage terminal 30: 11.900 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 99.38 %
                    EGR valve: offset closed: 0.84 %
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 2
                    Actuator for high pressure EGR: status-Bits 0-7: 3
                    High press EGR actuator: actual unconditioned volt val: 691.8 mV
          U1113 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
                    Voltage terminal 30: 12.300 V
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
          U0164 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:20
          U0151 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
                    Mileage: 27 km
                    Voltage terminal 30: 12.080 V
                    Mileage: 27 km
                    Mileage: 27 km
                    Mileage: 27 km
   Revision: 00H43001
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:16
                    Count: 16384
                    Count: 4352
                    Count: 212
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:16
                    Count: 16384
                    Count: 4352
                    Count: 279
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:16
                    Count: 16384
                    Count: 4352
                    Count: 270
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:16
                    Count: 16384
                    Count: 4352
                    Count: 8193
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:17
                    Count: 16384
                    Count: 4352
                    Count: 8214
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:18
                    Count: 16384
                    Count: 4352
                    Count: 8226
                    Count: 766
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 326133020
   Coding: A0A0303A0A612431802849702E2B8C540780610F7E064C41320000020000
   Shop #: WSC 73430 790 00121
   VCID: 2D0C665E5D1DBCC3704-8078
   Coding: 1400B0
   Coding: 0000A0
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:36
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:36
01326 - Control Module for Multi-Function Steering Wheel (J453)
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:39
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:35
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:35
Address 10: Park/Steer Assist
Address 15: Airbags
   Coding: 460201
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:17
          U1111 00 [009] - -
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:17
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:00:15
13654544 - Databus
          [Steuergerät für Telefon keine Kommunikation]
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:00:42
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 322300
   VCID: 70B2BF2A8AAF912B1B2-8024
                    Fault Frequency: 11
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:43
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:43
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:43
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:43
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:44
Address 2E: Media Player 3
Address 44: Steering Assist
Address 56: Radio
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 030B1A5A
   VCID: 6B88A846A38972F32E0-803E
Address 77: Telephone
End----------(Elapsed Time: 04:03, VBatt start/end: 12.2V/12.2V)-----------
senna1
C?ID=231631
Hi Dana i did look again went into applications tab then i could see Deactivate Transport mode selected it but it is already shows group 2 MB transport mode unlearn counter 4.0 then next box Deactivated transport mode value here is a full scan with a Dona J519 using the same coding as per the new J519, thanks for your help.
14 Faults Found:
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:20
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:19:33
          U1113 00 [039] - -
                    Mileage: 27 km
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:28:58
          U1113 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
          U0164 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:20
          U0151 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:19
                    Mileage: 27 km
                    Mileage: 27 km
                    Mileage: 27 km
                    Mileage: 27 km
   Revision: 00H43001
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:16
                    Count: 16384
                    Count: 4352
                    Count: 212
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:16
                    Count: 16384
                    Count: 4352
                    Count: 279
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:16
                    Count: 16384
                    Count: 4352
                    Count: 270
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:16
                    Count: 16384
                    Count: 4352
                    Count: 8193
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:17
                    Count: 16384
                    Count: 4352
                    Count: 8214
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:18
                    Count: 16384
                    Count: 4352
                    Count: 8226
                    Count: 766
   Coding: 1400B0
   Coding: 0000A0
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:36
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:36
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:39
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:35
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:40:35
Address 15: Airbags
   Coding: 460201
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:17
          U1111 00 [009] - -
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:16:17
          U1111 00 [009] - -
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:00:15
13654544 - Databus
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:00:42
   Revision: B9074001
   Coding: 322300
                    Fault Frequency: 11
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:43
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:43
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:43
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:43
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.02.28
                    Time: 00:33:44
Address 56: Radio
   Coding: 030B1A5A
senna1
C?ID=231631
also To add both electric window door control units j386 j387 have been changed
   #97
senna1
C?ID=231631
Doors status as you can see the side sliding door although it is closed it shows Open yet it shows Locked as per the other doors
Saturday,25,February,2023,12:55:06:51242
VIN: WV1ZZZ7HZEH037985 License Plate: DOOR TESTS STATUS LOCKED
Address 09: Cent. Elect. (7E0 937 090 )
12:54:17
Door Closed Driver Door Door Contact (F2)
Door Closed Passenger Door Door Contact (F3)
Door Open Rear Left Door Door Contact (F10)
Locked Driver Door Status (F220)
Locked Passenger Door Status (F221)
Locked Rear Left Door Status (F222)
Not Installed Rear Right Door Status (F223)
   #98
VWT6
Finland
C?ID=295527
Just to doublecheck - does the van actually have fully electrically operated sliding door - thus buttons on dash and on remote controller to open/close the door? This wasn't clear to me from build sheet on post #22.
   #99
senna1
C?ID=231631
Hi
The door is just a regular side sliding door it is manual operation as far as i can see it just has the door control module with safe lock
and the key fob just like a regular fob which has not been coded.
BE slide door rear left , do you know if this should be ticked in Gateway installation List i tried it but no joy, but wondered should it be ticked and saved.
   #100
VWT6
Finland
C?ID=295527
Hi
Ahhh, I see. Remove the sliding door controller 0D from the installation list. There is no controller on CANbus for the sliding door.
Also the mentioned BCM byte 26 byte 0 must be "0" then.
However, changing BCM byte 10 bit 6 = "0" should reverse open/closed status for sliding doors.
