VW T5
senna1
C?ID=231631
Just another Test:
- What do you measure of resistance between CAN-H and CAN-L when ignition is off (wait 60 Seconds after off).
- On my 2013 T5 with everythig possible retrofitted on engine can, i get 59 Ohm
- In My Table Setup with 01 03 09 15 i get 63 Ohm
I think i will measure resistance at B383 B390 where they join up, as the modules are on the same Route. i could also at the OBD connection.
with all modules connected,
I think the issue is on the Can - H side as no fuction on 6 of my Breakout box only Can - L and later do a test with reconnect the Eco 01 & leave ABS removed and see what info is then shown,
   #62
senna1
C?ID=231631
I think MQB started in MY 2013, but the Transporters have always been a bit different and not on the same upgrade cycle. In fact, the electronics in this one most resemble a PQ25 Polo.
pity because i could of confirmed if loom or modules on my test rig,
   #63
dnoermann
C?ID=358118
where are you measuring from for Engine Can is it at the ecu connected or on the harness pins ecu disconnected
you say In My Table Setup with 01 03 09 15 i get 63 Ohm is that with them connected and where are you then measuring from
I measured between B383 B390 (on Bench really on that Point, and in Car i installed a Y Cable at the Cable comming from B383 B390 to BCM, to measure)
In my Car and on Bench
01 was both times connected
   #64
dnoermann
C?ID=358118
That makes no Sence.
OBD Can is dedicted and goes only from ODB Connector to Gateway inside BCM
   #65
senna1
C?ID=231631
I will measure with all modules reconnected at B383 & B390 as you know they are still or should be at the BCM T73b/18 & 19,
Do you know where the J341 is located Headlight control module my drawings for stop/start type vehicle should be up by the clutch pedals
approx , The motors are going all the time when the headlights connectors are connected, so i thought check the module if i can find it ?
   #66
senna1
C?ID=231631
At OBD port i can check with my breakout box pin 6 Can h and Can -L pin 14 for activity and resistance & voltage at 6 to pin 4/5 gnd and 14,
i can see all activity for chassis and signal ground, power supply pin 16 etc, but not per module,
   #67
senna1
C?ID=231631
dnoermann
I had all modules connected and i coded in 2 Dona J519 & ohms at B383 B390 were approx 69 ohms including the new J519 ALSO 69, ohms
Here is a upto date full scan from one of the Dona Module j519
Tuesday,10,January,2023,16:19:09:51242
VCDS Version: 22.10.0.1 (x64)  HEX-NET2 CB: 0.4623.4
VIN: WV1ZZZ7HZEH037985   License Plate: DONA 2 J519 FULL SCAN AFTER CODING
Mileage: 20km-12mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 0D 10 15 17 19 25 2E 44 56 61 77 0B
VIN: WV1ZZZ7HZEH037985   Mileage: 20km-12miles
04-Steering Angle -- Status: Cannot be reached 1100
0D-Slide Door, Left -- Status: OK 0000
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAAD)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FH    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 6293
   Revision: 22H38---    Serial number: 00000000000000 CVN: 13593D87
   Coding: 0111401A232401080000
   Shop #: WSC 07051 005 104857
   ASAM Dataset: EV_ECM20TDI01103L906019FH 003007
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 76BE8932E84BBF1BC1E-8022
   VINID: 9E606AAAA1D8A956000C724814F66D2210
10 Faults Found:
16703 - Gear Reconition Sensor
          P181C 00 [039] - Implausbile Signal
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:07
                    Engine RPM: 0.00 /min
                    Coolant temperature: 10 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 12.940 V
                    Neutral position sensor: current transmission angle: 20.00 °
                    Neutral position sensor: adapted transmission angle: 0.00 °
                    Adaptation status of neutral position sensor-Bits 0-7: 4
                    Transmission neutral position sensor voltage: 0 mV
                    Neutral position sensor: upper adaptation value: 0 mV
                    Neutral position sensor: lower adaptation value: 0 mV
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [039] - Signal too High
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:08
                    Exhaust gas temperature sensor 1: 14.2 °C
                    Exhaust gas temperature sensor 2: -0.0 °C
                    Exhaust gas temperature sensor 3: 14.2 °C
                    Exhaust gas temperature sensor 4: 23.8 °C
                    Shut-off timer: last engine shut-off time: 1479 s
4481 - Cruise Control Switch (E45)
          P0568 00 [039] - Implausible Signal
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:07
                    Voltage terminal 30: 12.920 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 192
                    Cruise Control System (CCS): status-Bits 0-7: 200
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4482 - Function Restriction due to Implausible Message(s)
          U1112 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:07
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:07
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:08
                    Longitudinal acceleration: raw value: 32.767 m/s²
                    Vehicle inclination acceleration angle: raw value: 0.000 m/s²
                    Status: incline angle-Bits 0-7: 1
                    Longitudinal acceleration: 0.000 m/s²
                    Longitudinal acceleration sensor: status-Bits 0-7: 1
                    Vehicle lateral acceleration: raw value: 0.00 g
                    Vehicle lateral acceleration: 0.00 g
10092 - Neutral Gear Sensor
          P15A0 00 [039] - Electrical Malfunction
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:07
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:08
                    Limitation: accelerator pedal: 92.5 Nm
                    selected gear-Bits 0-7: 0
4710 - No Communications with Airbag Control Module
          U0151 00 [039] - -
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:07
4729 - Steering Effort Control Module
          U0130 00 [039] - No Communications
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:07
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9C24AB9179B96390
   Shop #: WSC 07051 005 49152
   VCID: 3A265D029C531B7BE56-806E
                    Fault Status: 01100101
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:04
                    Count: 16384
                    Count: 4352
                    Count: 212
                    Count: 766
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:04
                    Count: 16384
                    Count: 4352
                    Count: 279
                    Count: 766
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:04
                    Count: 16384
                    Count: 4352
                    Count: 270
                    Count: 766
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:04
                    Count: 16384
                    Count: 4352
                    Count: 8193
                    Count: 766
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
                    Count: 16384
                    Count: 4352
                    Count: 8214
                    Count: 766
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:06
                    Count: 16384
                    Count: 4352
                    Count: 8226
                    Count: 766
Address 08: Auto HVAC
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 326133020
   Coding: A0A0303A0A612431802849702E2B8C540780610F7E064C41320000020000
   Shop #: WSC 73430 790 00121
   VCID: 2D0C665E5D1DBCC3704-8078
8 Faults Found:
00329 - Control Circuit for Unlocking Rear Lid
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
00975 - Heated Rear Window (Z1)
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:06
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:09
01326 - Control Module for Multi-Function Steering Wheel (J453)
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:09
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:28:02
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:28:02
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
Address 0D: Slide Door, Left
Address 10: Park/Steer Assist
Address 15: Airbags
   Part No SW: 7E0 920 960 JX    HW: 7E0 920 960 JX
   Component: KOMBI         H04 0709
   Coding: 460201
   Shop #: WSC 07051 005 1048576
   VCID: 0842F7CA92BFB9EBA32-805C
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:06
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:06
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:06
13654544 - Databus
          [Steuergerät für Telefon keine Kommunikation]
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:06
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 322300
   VCID: 70B2BF2A8AAF912B1B2-8024
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 59
                    Mileage: 27 km
                    Date: 2023.01.10
                    Time: 00:25:05
   Component: IMMO          H04 0709
   VCID: 6A86AD42ACF36BFB556-803E
Address 2E: Media Player 3
Address 44: Steering Assist
Address 56: Radio
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 030B1A5A
   VCID: 6B88A846A38972F32E0-803E
   Subsystem 1 - Part No SW: 7E0 915 181 B    HW: 7E0 915 181 B
   Component: J367-BDM  H08 0181
   Serial number: 50238G45562221010723
Address 77: Telephone
End----------(Elapsed Time: 03:48, VBatt start/end: 13.0V/13.0V)-----------
senna1
C?ID=231631
I don't think that's a bug. The Gateway thinks it was able to talk to these modules, but for some reason, VCDS cannot. I'm not sure how real-time that Gateway status is. In other words, was the Gateway really able to talk to those modules at the time VCDS wasn't? Check MVBs 125 and 126 in the GW.
The vehicle is clearly broken somehow as evidenced by the faults in the Gateway.
Hi
all modules connected 125 and 126 for ABS 03 & 19 Gateway,
MVB for 19 Gateway 126 = steering angle 0 & Airbag 0
MVB for 19 Gateway 125 = Engine 1 & ABS 1 & instruments 1
MVB for 03 ABS 126 instruments 1 Gateway 1, immob 1
MVB for ABS 125 engine 1 & steering angle 0
Does 1 mean ok or fault,
   #69
senna1
C?ID=231631
Dash j285 fuse SB13 ok,, all Can H & L continuity all good to J519 J285 ohms at harness disconnected 67,ohms so no issues,
Connected to Cluster 65, ohms all good, T32/16 brown is GND to 636 floor 1.5mm to 4.mm checked OK
The only strange thing last time i tested the voltage for Can - H 3.12v. today it was 269v
& Can - L was 1.8v today 237v ?
All J234 Airbag module checks most checks ok,, except finding the GND im not 100% sure if it is 605 if it is there is no continuity
at the steering column, Ohms test at the harness disconnected was 68 ohms, Connected to the J285 It was 2.5 K, ohms
dnoermann What are you seeing on your bench Loom, not expecting 2.5 K
The Gnd If T50/46 To a 376 in Harness ) which it cant be as Left hand drive etc, and in the connector it is Blank no pin, DNOERMANN is it 605 AT COLUMN.? On your loom,
I'm doing the same checks for ABS etc
   #71
senna1
C?ID=231631
1 Means Connection OK
Ok Thanks, do you know where the J431 module is located, its supposed to be above the Pedals support area, ive not found it Black 26 pin connecter
   #72
senna1
C?ID=231631
Page 35/2 for Airbag from August 2009 The page shows j234 unit , My question is the Gnd you can see it has no pin number at the J234
It is a black thin line to 13 location, But I cant identify it at the j234 Connector , i have not seen this illustration , not sure if it means
cable connection detachable ? Or it relies on the module to body for Gnd,? I cant see any cables at the j234 only the ones in the Connecter 1 to 50, there is a Gnd on some vehicles with different extras T50/46, My connector for this is empty no 46. do you know ?
dnoermann
C?ID=358118
Airbag ECU gets GND from Chassis via the Mounting Screw
   #75
senna1
C?ID=231631
Any news, good or bad ?
Hi ive not been on here for a while, No not done anymore with airbag i will try when i get back to it clean the Gnd and re check coding.
i have the electric windows working & Have been working on the central locking as many problems with it,
I have a question for you Regarding the Central Locking Front Doors although some of the wiring linked to side Door & Rear Lid
My question is The J519 T73a/11 Violet colour wire i have no power coming out of it, When i operate the E150 switch to v56 Motor to LOCK say Drivers Door
pin 1 Bl/Yl of T73a/12 at J519 works as it should, But pin 2 Vi to B215 tree into J519 T73a/11 to the V56 motor NO power If i use vcds i have power
The only fuses i can see if anything Is sc20 sc28 which if removed dont effect the central locking so they are not for it and SF55 is for windows.
The j519 is Brand New i also have here 2 others but no joy, All continuity test are good to the J519, and the connectors in between to the F220 V56 Etc
and to N/s Door including the connectors in the A post
Can you see on your test loom any voltage when operating the central locking to LOCK T73a/11 output
Regards
   #76
Based on the "Connector assignment of onboard supply control unit -J519-" section "73-pin connector -T73a-" I think the BCM input for cent locks might be T73a/16 via Fuse 8 on fuse holder B -SB8- (Terminal 30 central locking). The output is labeled T73a/11 to the following components as you describe:
Contact strip in right sliding door -F352-​
Contact strip in left sliding door -F353-​
Driver door central locking motor -V56-​
Front passenger door central locking motor -V57-​
Rear right door central locking motor -V97-​
Rear left door central locking motor -V115-​
Rear lid locking motor -V120-​
If you are working with one of those massive PDF diagrams from erWin check the bottom of it to see if there's a section that has the terminal assignment of both BCM connectors. I think that will make your life a lot easier since mine shows the Input versus Output of each labeled terminal.
If you are working with the older XML/HTML type of individual wiring diagrams check the one labeled "Convenience system From November 2012" (diagram number 158) for hyperlinks that may offer that BCM connector view.
   #77
senna1
C?ID=231631
Hi Dana
I am working with Elsawin i also have a Pdf from dnoermann but it is German, working with Convenience system From November 2012 my J519 pins for 73a connector T73a/16 via Fuse 8 on fuse holder B -SB8- (Terminal 30 central locking) i had also checked the yellow wire T73a/25 from E150 which i think is input for the J519 i will re look SB8 do you have a screen shot of the diagram that SB 8 covers or page number i had checked all fuses SB & Sc one by one but if i go back to SB 8 i can trace that if any issues there,, other than that it makes me wonder if the central locking switch is faulty although i have checked it and it should work i also had a spare one i checked should be ok, so i cant see it being switch, i have access to another one which i know is 100% good i just need to lend it to confirm Switch or not as it sends signal to get input for output , the only fuses suspect but not related to Central lock is SB 21 starter moter etc & 25 fresh air blower NO power at the fuse location,,, fuses are good, the blower Works ? as does the starter motor ? i know someone has played with the starter motor side ive not yet investigated that, one step at a time, regards
   #78
senna1
C?ID=231631
Dana forget the screen shot i have just traced SB 8, 15amp Diagram page ) power from SA9 so at least if any power issues to Fuse or to J519 T73a/16 i something to work with.
   #79
Sounds good. Also, in Elsawin look for:
-Fitting locations: control units
That should pull up diagram Transporter Fitting Locations No. 801 / 1.
Roughly 1/3 of the way into the document there is a very nice J519 terminal assignment for this particular vehicle. You still need to search for those fuses/components in each diagram but those charts are very helpful to narrow down the J519 inputs versus outputs.
   #80
senna1
C?ID=231631
Yes that is what i do , i have had Elsawin for a while, i thought yesterday if the unlock is working the Fuse SB8 should be good as T73a/25 YL is like a duel wire at E150 pin 3 used to input Unlock and Lock I checked today and yes it is all good, continuity & Power so doesn't make sense it should unlock Via T73a/11 12 is unlock, the only thing regarding the Switch E150 as it only uses T73/a 25 Yl wire Pin 3 on E150 how does the Function know it is told to unlock or Lock
it is hard to tell 100% but i think in the Switch there is a Resistor which would make sense for the input to the J519 for Unlock no resistor to lock resistor.
do you have any views opinons on that because that is all that is left as sherlock holmes would say lol
