VW T5
senna1
C?ID=231631
Here is a log of T5 2013 It has many faults as you can see & i am about to start checking out the faults, apart from the obvious
is there anything jumping out at you as it it has been quoted New OEM Engine Ecu and instrument Cluster & J519 bcm, which i did not install
the vehicle is as per the log The company who installed the new modules said they coded all the new modules ? They said they couldent do the key,
I have just oredered new interface.
Thursday,24,November,2022,13:30:43:44675
VCDS Version: 22.10.0.1 (x64)
VIN: WV1ZZZ7HZEH037985   License Plate:
Mileage: 20km-12mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 56 61
VIN: WV1ZZZ7HZEH037985   Mileage: 20km-12miles
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAAD)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FH    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 6293
   Revision: 22H38---    Serial number: 00000000000000 CVN: 13593D87
   Coding: 00000000000000000000
   Shop #: WSC 07051 005 1048576
   ASAM Dataset: EV_ECM20TDI01103L906019FH 003007
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 76E8035FC969BE3DA8-8022
   VINID: 9E606AAAA1D8A956000C724814F66D2210
8 Faults Found:
4881 - EGR Valve (N18)
          P1440 00 [036] - Open Circuit
                    Mileage: 26 km
                    Date: 2022.11.24
                    Time: 12:52:28
                    Engine RPM: 0.00 /min
                    Coolant temperature: 7 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 12.400 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 99.28 %
                    EGR valve: offset closed: 0.60 %
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 2
                    Actuator for high pressure EGR: status-Bits 0-7: 3
                    High press EGR actuator: actual unconditioned volt val: 704.6 mV
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:17:44
                    Coolant temperature: 58 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.240 V
                    Longitudinal acceleration: raw value: 32.767 m/s²
                    Vehicle inclination acceleration angle: raw value: 0.000 m/s²
                    Status: incline angle-Bits 0-7: 1
                    Longitudinal acceleration: 0.000 m/s²
                    Longitudinal acceleration sensor: status-Bits 0-7: 1
                    Vehicle lateral acceleration: raw value: 0.00 g
                    Vehicle lateral acceleration: 0.00 g
4729 - Steering Effort Control Module
          U0130 00 [039] - No Communications
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:17:44
                    Limitation: accelerator pedal: 92.5 Nm
                    selected gear-Bits 0-7: 0
5046 - Fuel Injector #1 (N30)
          P0263 00 [167] - Contribution/Balance Fault
                    Mileage: 26 km
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Allowed number of injections-Bits 0-7: 0
                    Injection release status-Bits 0-7: 0
                    Desired injection characteristic-Bits 0-7: 0
                    Mean injection quantity: 0.00 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 0
                    Fuel high-pressure: actual value: 0 hPa
                    Control Module temperature: 150.0 °C
5044 - Fuel Injector #3 (N32)
          P0269 00 [167] - Contribution/Balance Fault
                    Mileage: 26 km
5047 - Fuel Injector #4 (N33)
          P0272 00 [167] - Contribution/Balance Fault
                    Mileage: 26 km
5043 - Fuel Injector #2 (N31)
          P0266 00 [167] - Contribution/Balance Fault
                    Mileage: 26 km
10529 - Engine Control Module Incorrectly Coded
          P1612 00 [167] - -
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9C24AB9179B96390
   Shop #: WSC 07051 005 49152
   VCID: 3A70D76FB5F11A5D8C-806E
                    Fault Status: 01100101
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:17:49
                    Count: 16512
                    Count: 768
                    Count: 212
                    Count: 766
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:17:49
                    Count: 16512
                    Count: 768
                    Count: 8214
                    Count: 766
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:17:49
                    Count: 16512
                    Count: 768
                    Count: 8226
                    Count: 766
Address 08: Auto HVAC
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 342200003
   Coding: 24982BBB0C610000000000302E4B0C800F00400F60040850200000000000
   Shop #: WSC 00000 288 27091
   VCID: 68D45D279BDD58CD2A-803C
8 Faults Found:
00329 - Control Circuit for Unlocking Rear Lid
                    Fault Status: 00101011
                    Reset counter: 44
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:21:09
03297 - Switch in Lock Cylinder; Driver Side
                    Reset counter: 44
00893 - Switch for Trunk Handle (E234)
                    Fault Status: 01101000
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:20:27
03303 - Response Closing Status of Rear Left Door
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.20
                    Time: 11:39:59
03304 - Response Closing Status of Rear Right Door
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.20
                    Time: 11:39:59
00975 - Heated Rear Window (Z1)
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:20:29
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:20:27
                    Reset counter: 44
                    Mileage: 26 km
                    Date: 2022.11.24
                    Time: 12:52:26
Address 15: Airbags
   Part No SW: 7E0 920 960 JX    HW: 7E0 920 960 JX
   Component: KOMBI         H04 0709
   Coding: 460201
   VCID: 08147DA7B39DB8CDCA-805C
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:17:58
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042300
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:18:03
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:18:04
                    Reset counter: 4
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:18:04
   Component: IMMO          H04 0709
   VCID: 6AD0272F8DD16ADD3C-803E
Address 56: Radio        Labels: None
   Part No SW: 3TD 035 156     HW: 3TD 035 156
   Component: RadioSK46MID  006 0010
   Coding: 01000424041000
   Shop #: WSC 00078 790 00000
   VCID: 7F06E67BEE53FF75FB-802A
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: F2001800
   Shop #: WSC 01693 210 00002
   Subsystem 1 - Part No SW: 7E0 915 181 B    HW: 7E0 915 181 B
   Component: J367-BDM  H08 0181
   Serial number: 50238G45562221010723
                    Mileage: 26 km
                    Date: 2022.11.19
                    Time: 14:18:08
End-------------------------(Elapsed Time: 02:02)--------------------------
JMR
Romania
C?ID=432218
Will you be kind and erase all faults and repost a fresh scan ? Many of the codes are intermittent and i have a hard time trying to understand what is it that you need help with. Thanks
senna1
C?ID=231631
Here is a scan With new Version of VCDS HEX- NET
This vehicle has many faults basically nothing works, My concerns are The Engine ecu,(01) the J519 Bcm,(9) Instrument cluster (17) Gateway (19) address
The Gateway Module & the other modules mentioned for Coding for all these modules would be a starting point, The company that bought these OEM parts new installed and Coded them ? The log shows many no signal/communication, or incorrectly coded,, The wiring on the vehicle for components i'm working on seem correct power/ Gnd including motors and switches, Vcds can output some of the items such as central locking, Electric windows are not recognised, can you take a look at this new scan after delete as ask for, and advise coding or basic setting required.
just one other thing,, this vehicle has stop start feature, & as far as i know the Gateway is intergrated in the Bcm. as it is after may 2012.
One other point is the Owner has bought a new Battery, Manufacturer yuasa, Which is not on the recommended VCDS menu, the Battery has a label serial number 10 Digits, so that should go in,, the only other Digits are YBX9096 i know the Vendor is usually 3 digits, so lets say i use YBX, That leaves 9096 Can i use this for the pt number, or is it no good at all, The invoice part number has ZGBYBX9096.
 Friday,09,December,2022,16:24:18:51242
VCDS Version: 22.10.0.1 (x64)  HEX-NET2 CB: 0.4623.4
VIN: WV1ZZZ7HZEH037985   License Plate: T5 SCAN DELETE NEW VCDS
Scan: 01 03 04 08 09 0D 15 17 19 25 56 61 0B
0D-Slide Door, Left -- Status: OK 0000
   VCID: 76BE8932E84BBF1BC1E-8022
10 Faults Found:
16703 - Gear Reconition Sensor
          P181C 00 [039] - Implausbile Signal
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:27
                    Coolant temperature: 1 °C
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 12.080 V
                    Neutral position sensor: current transmission angle: 20.00 °
                    Neutral position sensor: adapted transmission angle: -0.65 °
                    Adaptation status of neutral position sensor-Bits 0-7: 60
                    Transmission neutral position sensor voltage: 0 mV
                    Neutral position sensor: upper adaptation value: 3360 mV
                    Neutral position sensor: lower adaptation value: 1580 mV
          P1440 00 [038] - Open Circuit
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:30:18
                    Intake air temperature: 3 °C
                    Voltage terminal 30: 11.880 V
                    EGR Solen.val.: actual value: 99.51 %
                    EGR valve: offset closed: 0.84 %
                    High press EGR actuator: actual unconditioned volt val: 687.0 mV
          U1113 00 [039] - -
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:27
10092 - Neutral Gear Sensor
          P15A0 00 [039] - Electrical Malfunction
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:27
                    Neutral position sensor: current transmission angle: -14.00 °
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:27
                    Mileage: 27 km
                    Mileage: 27 km
                    Mileage: 27 km
                    Mileage: 27 km
          P1612 00 [167] - -
   Revision: 00H43001
   VCID: 3A265D029C531B7BE56-806E
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:24
                    Count: 16384
                    Count: 256
                    Count: 212
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:25
                    Count: 16384
                    Count: 8214
                    Count: 766
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:25
                    Count: 16384
                    Count: 256
                    Count: 8226
                    Count: 766
   Shop #: WSC 12345 288 27091
   VCID: 6882D74AB27F59EB432-803C
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU006041660975355
   Coding: 1400B0
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:25
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:27
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:25
Address 0D: Slide Door, Left
Address 15: Airbags
   Coding: 460201
   VCID: 0842F7CA92BFB9EBA32-805C
          U1111 00 [009] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:26
   Revision: B9080001
   Coding: 042300
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:24
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:24
                    Reset counter: 4
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:24
   VCID: 6A86AD42ACF36BFB556-803E
   VCID: 55FCEEBE1C0DD403E84-FFFE
   Coding: F2001800
                    Mileage: 27 km
                    Date: 2022.12.09
                    Time: 02:28:24
End----------(Elapsed Time: 01:17, VBatt start/end: 12.0V/12.1V)-----------
Regards
Does the van have start/stop? What type of battery is installed?
Try coding the 61-Battery Regul. module with: F3051800
As to why the Airbags and HVAC controller are off-line, you'll have to chase that with a wiring diagram and multimeter.
senna1
C?ID=231631
The battery in it when bought could be off anything, so decided to get new battery Of what VCDS vendor recommends, but owner bought
the battery described, Can you make anything of the Digits i have listed,
What do you think of the coding of the Bcm etc and do they need coding, if i need to do coding for the Bcm j519 For 2012/13 T5 do you have a link for the procedure,
this is my main concern at the moment and the Battery, The vehicle is i'm told by VW parts it is STOP/START type
2kaa52
Ceska Republica, Praha
C?ID=319193
Seems Modul 01 and 09 are Not correct ones for that car
senna1
C?ID=231631
Hi
The Ecu is as far as i know replaced by another company Brand new with cluster & Bcm for this vehicle engine code should be
CAAD so correct based on vin, The Bcm i think has issues, i am trying to clarify inc the gateway as nothing works really regarding coding
senna1
C?ID=231631
2kaa52
C?ID=319193
Hi
Why replaced ,ecu, Cluster and BCM at Same time ?
Ecu and Cluster replace at Same time IS (official) Not possible.
2kaa52
C?ID=319193
Why do you dont let VW do the coding by ODIS online,so you can be Sure the coding IS correct
senna1
C?ID=231631
Its a Feeling when i See your VIN and the partnumbers.
I can Check this monday If correct or not
Hi i'm told it all the new modules mentioned were done with ODIS i would if you could check On monday and let me know your findings
to clear it up, as far as i'm aware the modules inc coding were best part of 3k,,, and the van is a mess, it has been to other company's and the
problems still exist, i'm beginning to think it has Communication issues net work, as today had my kit on it NOT vcds and i have signal and chassis Gnd
Can L only i will be doing resistance etc checks next, VW i quoted the Pt number on the new BCM and one guy said not stop start/ then His colleague
said it is def Stop start elsawin says the Gateway was not in the bcm depending on type of vehicle but only till may 2012, this is sept 2012 i think
you will know by Vin. The company NOT vw used ODIS as you know you can buy it.
2kaa52
C?ID=319193
01-ECU correct for this Car
09-BCM Not correct for this Car
senna1
C?ID=231631
Hi thankyou can you give me the reason why not correct BCM as it is brand new so i need to correct it,
Is it a part number issue because we have been told the original pt number has been superseded
I need to get to the bottom of it as you can imagine the problems if the wrong BCM.
2kaa52
C?ID=319193
Hi why do you think wrong BCM as per 2Kaa52
Because there has to be another one in your Car. ( Another partnumber)
So online coding for BCM at the Moment Not possible.
2kaa52
C?ID=319193
Your Engine ECU IS correct,but Not complete adapted
senna1
C?ID=231631
This is getting confusing , elsawin diagrams for J519, & J533 stop/start with and without, my findings by elsawin says j519 has intergrated j533 gateway
Without Stop Start System,) And WITH stop start, Databus interface j533 is Red 20 pin connector images looks like it is above the throttle/ brake pedal although it says behind dash panel near relay carrier cockpit which is to the right of the throttle pedal, it quotes 1-3 Models with Stop Start only & valid until may 2012, then another option quotes 2-4-5, which are for models says vehicles With Stop Start & without special purpose vehicle control j608,, 4, valid from 2012, 5, will be cancelled after oct 2012, so i thought right this vehicle should have a separate j533 gateway on its own above the pedals , BUT nothing is there only clutch switch , throttle pedal motor FBW, i thought this is the problem if it had 2 gateways ? wrong BCM,,, so phone vw and they say part number superseded and is for stop start,,? although the first guy said it is not stop/start vehicle, so you can see, can you be clearer as your reply say
Because there has to be another one in your Car,
can you explain, another part number ? do you mean there is a separate j533 and the J519 Bcm
I have seen the invoice for the new Engine Ecu the cluster & the BCM and told it was coded using ODIS ££ to server ? i listed the log as a lot of signal/comms problems and also modules that are supposed to be coded listed as not coded correctly.
My thoughts are if this vehicle were stop start then it should have a separate j533 as it is i think registered sept 2013. and the elsawin info points that way, yet vw say the bcm is for stop start which if i cant see a separate j533 it must be in the Bcm but elsawin quotes stop start vehicles j533 already mentioned the location 20 pin red connector too october 2012 if no j608,
