Volkswagen Telematics powered by Ross-Tech
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Wife called me today to tell me her Tiguan's MIL was on. Because (too much typing), we are together on weekends but usually on opposite ends of Ohio during the week. Being somewhat experienced at both marriage and Volkswagen ownership, I keep a HEX-NET in her center console programmed to associate to our home WiFi up there, and our home WiFi networks are VPN linked.
I don't know if anyone else uses it this way regularly, but this particular Auto-Scan was done with VCDS running on my laptop with the HEX-NET and vehicle 235 miles away, just as if it was in my driveway, no issues. :) Was nice to be able to verify it's safe to drive home this weekend. Checked running terminal 30 voltage and it's in a normal range, so was just something left on in the car over the weekend before she went to work on Monday. (the rest of the codes are mainly transient stuff triggered by openpilot)
Monday,05,December,2022,19:32:16:18483
VCDS Version: 22.10.0.1 (x64)  HEX-NET CB: 0.4623.4
VIN: 3VV4B7AX4LM074301   License Plate:
                Address 01: Engine       Labels: 06L-907-115-V1.clb
Control Module Part Number: 83A 907 115 B    HW: 06L 907 309 B
  Component and/or Version: R4 2.0l TFS   H31 0005
           Software Coding: 012A00122466012FB4000000000000000000000000000000
            Work Shop Code: WSC 03207 444 00000
              ASAM Dataset: EV_ECM20TFS01183A907115B 001006 (VW37)
                       ROD: EV_ECM20TFS01183A907115B.rod
                      VCID: A502B7B9A4A9B5A551-80F0
40571 - Voltage Supply 1 for Control Module
          U3501 00 [168] - Too Low
                    Mileage: 55412 km
                    Date: 2022.11.09
                    Time: 16:58:06
                    Engine RPM: 1082.50 /min
                    Normed load value: 30.6 %
                    Coolant temperature: 23 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 10.940 V
                    Engine status: COENG_RUNNING
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [032] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
23765 - Control unit for information electronics 1
          U1054 00 [032] - No Communication
          [Information electronics control module 1No Communication]
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 36 39 3C 42 44 47 4B
          52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN: 3VV4B7AX4LM074301   Mileage: 57409km-35672miles
29-Left Light -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115 B    HW: 06L 907 309 B
   Component: R4 2.0l TFS   H31 0005
   Revision: 1DH31000    CVN: BDBE2D29
   Shop #: WSC 03207 444 00000
   VINID: 0E698448746811C7401C40C004F05615FD
                    Mileage: 55412 km
                    Date: 2022.11.09
                    Time: 16:58:06
          U0235 00 [032] - -
   Part No SW: 09G 927 158 DT    HW: 09G 927 158
   Component: AISIN AQ8     206 3698
   CVN: 2408AAFC
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00439
   ROD: EV_TCMAQ450031_VW32.rod
   VCID: 885CDE0D337B88CD4A-80DC
   Part No SW: 5Q0 614 517 FE    HW: 5Q0 614 517 BP
   Component: ESC           H35 0191
   Revision: 00000000    Serial number: 52979000000369
   Coding: 0BFA6BA450271B70C57A0300A2C449D0D60AD8A3C045927438415058D2AA4A0B00402F641A1B13111435351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: F9BAABC97891E14545-80AC
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0527017560
   Coding: 132C2C0723
   Shop #: WSC 00066 790 00217
   ROD: EV_KessyHellaMQBAB.rod
   VCID: C5C2173944E955A571-8090
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11997800
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NN 907 044 AA    HW: 5NN 907 044 AA
   Component: AC Automat    H36 4803
   Revision: 20K03000    Serial number: 00000D00484106
   Coding: 00020024200118001104010C1211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002027
   VCID: 8B56E101220DE3D567-80DE
   Part No SW: 5Q0 937 087 BG    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: C86412111901L9
   Shop #: WSC 00066 790 00276
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 814AC3291041B9850D-80D4
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 191021  034  0373
   Serial number: 19101821075430
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: S4Y19M09D06H11M21S34
   Coding: 0008DD
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23  0170
   Serial number: 0300011120190C200388
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000259540119314
   Coding: 0471255811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   VCID: D0EC366D8BAB800DD2-8084
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 320007D258FF8728749C810530409700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: C3C609214ADD6B955F-8096
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
                    Reset counter: 87
                    Mileage: 55440 km
                    Date: 2022.11.10
                    Time: 08:25:53
                    Voltage terminal 15: 14.6 V
                    Vehicle speed: 11.80 m/s
                    Longitudinal acceleration: 0.34 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 86
                    Mileage: 55826 km
                    Date: 2022.11.13
                    Time: 17:31:23
                    Voltage terminal 15: 14.8 V
                    Control Module temperature: 10 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.56 m/s²
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    008 0403
   Serial number: 003FGM06LRF$
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 8C54E21D2703E4ED6E-80D8
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000CIDYKE
   Coding: 303352
   Subsystem 2 - Part No SW: -----------    HW: 480 002 509 19
   Serial number: 3570000000079029814C
   Subsystem 3 - Part No SW: -----------    HW: 480 002 409 19
   Serial number: 358000000004EB39C04U
   Subsystem 4 - Part No SW: -----------    HW: 480 402 009 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B8F2FD200B719
   Subsystem 5 - Part No SW: -----------    HW: 480 402 009 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B2F322723B5F3
   Subsystem 6 - Part No SW: -----------    HW: 480 401 610 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B4F2F5557C6CR
   Subsystem 7 - Part No SW: -----------    HW: 480 401 610 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001B4F2F5557C37K
   Part No SW: 3G0 920 890 E    HW: 3G0 920 890 E
   Component: KOMBI         503 4192
   Coding: 08A42008EF88CF050288634B10010000A0000F07
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: AB164181C24D83D587-80FE
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 13111900841378
   Coding: 030500347F085900FB03225A1E0F00010001070000000000000000000000
   GVL: 01C63C000800040040DC80008002C80010000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: F0AC96ED2BEBA00DF2-80A4
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H06 0025
   Serial number: 0362014593801442FG2B
   Coding: 2E0000
   Serial number: 3818756900
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 252
                    Reset counter: 121
                    Mileage: 39660 km
                    Date: 2022.05.07
                    Time: 05:07:32
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00005.08.19
   Coding: 0101
   VCID: CCD4221D6783A4EDAE-8098
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 88
                    Mileage: 55426 km
                    Date: 2022.11.09
                    Time: 17:17:11
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007SI739837
   Coding: 0010000000000500018280808080000000008101000000F400
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: BFCE05D126350F753B-80EA
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0148
   Serial number: 11230018969676
   Coding: 52954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: B93A6BC93811214505-80EC
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0148
   Serial number: 11230018983817
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 12058931400686
   Coding: 003F1B205200048000000000
   VCID: CDD22F199C99ADE5B9-8098
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000004632516
   Coding: 011000
196665 - Switch for Central Locking
          B122D 29 [009] - Signal Implausible
                    Reset counter: 152
                    Mileage: 46490 km
                    Date: 2022.07.26
                    Time: 08:06:45
   Part No SW: 5QM 909 144 C    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1082
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: D1EA336980A18905DD-8084
21760 - Databus
          [HCA_01 Botschaft - CAN-Timeout]
                    Reset counter: 30
                    Mileage: 51468 km
                    Date: 2022.09.30
                    Time: 16:59:51
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 13.25 V
                    Temperature: 56.0 °C
                    KFC: 55
                    KFA: 00 00
                    Freeze frame conditions: 20
                    uioUdNotFilt_xdu16: 13.30 V
                    uAdSensI_SwitchedKl30_xdu16: 13.21 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD0692ZY
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: AE104895F15FF6FDA0-80FA
Address 4B: Multifunc. Module (J745)       Labels:. 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 FCM MQB Low   003 03670367
   Serial number: 11111900840711
   Coding: 0000000509001D52002103010B0000000000000000000000000000000000
   ROD: N/A
   VCID: B73E6DF10E053735F3-80E2
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 13058931100723
   Coding: 003F13205E00048000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000004642112
   Coding: 091000
   Part No SW: 2GM 035 876 B    HW: 2GM 035 876 B
   Component: MU-S-NS-US    854 0520
   Coding: 027306020000000051220002001808211F0506E401200405C6
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  254 8130
   Serial number: VWZ6ZMW3175626
   Subsystem 2 - Part No SW: 5NA 919 866 P    HW: -----------
   Component: NAR 2019/20  --- 0910
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG061956
   Coding: 01230601A20F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C758-8680-4
   Coding: 0A28
   VCID: C8DC1E0D73FB48CD8A-809C
   Part No SW: 5WA 035 283     HW: 5WA 035 283
   Component: OCUGen3Low    H10 0295
   Serial number: 0000000909NVCL4
   Coding: 0232602019682C208005461160100607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW37.rod
   VCID: 8248CC251547A29D14-80D6
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 20081915K25557
   Coding: 0003070601020201002213468150490084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: C0CC062D5BCB708D42-8094
1122 - Camera Interference
          C1104 00 [008] - -
          [Daddy detected a CRC error on Zynq_0]
                    Reset counter: 5
                    Mileage: 53128 km
                    Date: 2022.10.07
                    Time: 07:22:18
                    Control Module temperature: 32 °C
                    Outside temperature: 10.5 °C
                    Vehicle speed: 31.47 km/h
                    System run time: 1043.9 s
                    Voltage terminal 15: 14.1 V
                    mid: 02 4B
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
1275 - Front Sensors for Driver Assist
          B182E F0 [008] - Function Restriction due to Environmental Influences
                    Reset counter: 81
                    Mileage: 43522 km
                    Date: 2022.06.07
                    Time: 08:03:04
                    Control Module temperature: 38 °C
                    Outside temperature: 18.0 °C
                    Vehicle speed: 25.84 km/h
                    System run time: 6.6 s
                    Voltage terminal 15: 13.1 V
                    mid: 01 63
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: F5A2A7F95489852521-80A0
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 804CC62D1B4BB08D02-80D4
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 02:52, VBatt start/end: 14.7V/14.7V)-----------
                    Mileage: 55412 km
                    Date: 2022.11.09
                    Time: 16:58:06
          U0235 00 [032] - -
                    Mileage: 55412 km
                    Date: 2022.11.09
                    Time: 16:58:06
          U0235 00 [032] - -
   CVN: 2408AAFC
   Coding: 132C2C0723
   Coding: 0008DD
   Coding: 0471255811
1236 - Databus
                    Reset counter: 87
                    Mileage: 55440 km
                    Date: 2022.11.10
                    Time: 08:25:53
0836 - Databus
                    Reset counter: 86
                    Mileage: 55826 km
                    Date: 2022.11.13
                    Time: 17:31:23
   Coding: 303352
   Generator:
   Coding: 2E0000
                    Reset counter: 121
                    Mileage: 39660 km
                    Date: 2022.05.07
                    Time: 05:07:32
                    Terminal 15: OFF
   Coding: 0101
                    Reset counter: 88
                    Mileage: 55426 km
                    Date: 2022.11.09
                    Time: 17:17:11
   Coding: 52954640
   Coding: 011000
                    Reset counter: 152
                    Mileage: 46490 km
                    Date: 2022.07.26
                    Time: 08:06:45
   Coding: 911F0000
21760 - Databus
                    Reset counter: 30
                    Mileage: 51468 km
                    Date: 2022.09.30
                    Time: 16:59:51
                    Motor status: 02
                    KFC: 55
                    KFA: 00 00
   ROD: N/A
   Coding: 091000
   Coding: 0A28
          C1104 00 [008] - -
                    Reset counter: 5
                    Mileage: 53128 km
                    Date: 2022.10.07
                    Time: 07:22:18
                    mid: 02 4B
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
                    Reset counter: 81
                    Mileage: 43522 km
                    Date: 2022.06.07
                    Time: 08:03:04
                    mid: 01 63
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
VPNs rock!
Way back when, it was on the roadmap to come up with a way to allow remote access to it without benefit of a VPN, but we've never gotten to implementing that.
JMR
Romania
C?ID=432218
maaaan..i think you 're spying :)) But yes, cool setup
Engine RPM: 1082.50 /min Normed load value: 30.6 % Vehicle speed: 0 km/h Coolant temperature: 23 °C Intake air temperature: 20 °C Ambient air pressure: 980 mbar Voltage terminal 30: 10.940 V
how is this normal ??
