Diesel 1.6 Audi A3 that very intermittently cuts out when driving, Code set was
7078 - Supply Voltage for Fuel Injector Group A
P2147 00 [104] - Short to Ground
[Fuel Injector Group "A" Supply Voltage Circuit Low]
Engine RPM: 1774.50 /min
Voltage terminal 30: 12.085 V
Did the usual checks, 500v insulation test on the injectors, wiggled the injector wires, tapped the ecu etc. Noted that the Terminal 30 voltage at time of fault was 12.08v but the engine was apparently still at 1700 RPM -
Is the ECU reporting voltage downstream of the Main relay or from it's permanent battery supply or is it on the network ? If that's relay output then that gives me direction.
Unfortunately that was the only code set so no voltages to compare
Obligatory scan
Obligatory scan
Thursday,01,December,2022,10:25:06:34176
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Dealer/Shop Name:
VIN: TRUZZZ8P9A1007968 License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 47 52 56 61 62 72
VIN: TRUZZZ8P9A1007968 Mileage: 149730km-93037miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: R4 1.6l TDI H23 9979
Revision: --H23--- Serial number: AUX7Z0J1FNH01T CVN: 4F2DF892
Coding: 00114034032501080000
Shop #: WSC 00497 210 88415
ASAM Dataset: EV_ECM16TDI02103L906023M 003017
ROD: EV_ECM16TDI02103L906023JK_003.rod
VCID: 30391D723AAB0B8B5B2-8064
VINID: 92296AAAA220251040007246203ADFFB01
Fault Frequency: 14
Mileage: 149728 km
Date: 2022.11.22
Time: 22:53:36
Normed load value: 60.0 %
Vehicle speed: 29 km/h
Coolant temperature: 49 °C
Intake air temperature: 16 °C
Error information regarding selected piezo output stage-LF_STATE_PPS_SPI[0]: 2
Injection valve 1: voltage-V_INJ_MAIN[0]: 127.21 V
Injection valve 2: voltage-V_INJ_MAIN[1]: 124.06 V
Supply voltage of analog output 1-VCC_1: 5.03 V
Supply voltage of analog output 2-VCC_2: 5.00 V
Injection valve 3: voltage-V_INJ_MAIN[2]: 126.48 V
Injection valve 4: voltage-V_INJ_MAIN[3]: 126.25 V
Readiness: 0 1 0 0 0
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 1342201249220001C81404EA92210091380800
Shop #: WSC 55729 003 1048576
VCID: 7AADFF5AACD701DBA56-802E
Address 08: Auto HVAC Labels: 8P0-820-047.clb
Part No SW: 8P0 820 047 D HW: 8P0 820 047 D
Component: J255 Klima Man H08 0060
Revision: 00H08004 Serial number: 00000000000000
VCID: 313F18763D21028354C-8064
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A0FB205F140207060E00100004C53725CAA0020C122E4008F000055
Shop #: WSC 01236 758 00200
VCID: 323D177A3427399B2D6-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Subsystem 3 - Part No: 8P7 951 177
Component: DWA-Sensor H0 H03 0040
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93641004402386
VCID: 42DD47BA8487891BBD6-8016
Address 15: Airbags Labels: 8P7-959-655.clb
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SR Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS000WTGX
Coding: 0021330
Shop #: WSC 01236 785 00200
VCID: 06559BAAE42F753BD1E-8052
Subsystem 1 - Serial number: 6332DRB409AB880C+
Subsystem 2 - Serial number: 6342DRB409AB0F33Z
Subsystem 3 - Serial number: 63747RB40557BDC1.
Subsystem 4 - Serial number: 63847RB40557BD2D/
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0002041
VCID: 46D55BAAA4AFB53B91E-8012
Component: E0221 H02 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2241J005019554
Coding: 0004428
VCID: 40D94DB2868B9B0BAB2-8014
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J102040BA1
Coding: E9A07F26100202049101
VCID: 6B83CA1EDF8DA8532E0-803E
Revision: D0H03005 Serial number: AUX7Z0J1FNH01T
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255 B
Component: VSG AUDI A3 H14 0130
VCID: 44D141A29293872B8FA-8010
Address 42: Door Elect, Driver Labels: None
Part No SW: 8P7 959 801 D HW: 8P7 959 801 D
Component: Tuer-SG H04 0100
Coding: 0131764
VCID: 43D342BE979D8013B60-8016
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P7 035 382 C HW: 8P7 035 382 C
Component: AB2 SUBWOOFERBOXH04 0160
Revision: 00003 Serial number: 92159949691792
VCID: 372B266ED345DCB31A8-8062
Part No SW: 8P7 959 802 F HW: 8P7 959 802 F
Component: Tuer-SG H04 0103
Coding: 0131764
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 S HW: 8P0 035 186 S
Component: R Concert2+ H03 0280
Revision: 00H03000 Serial number: AUZ1Z3K6011420
Coding: 0330211
VCID: 42DD47BA8887891BBD6-8016
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J102040BA1
Coding: 0303085A
VCID: 6889B512C27B834B432-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002791011196
Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
Component: Tuer-SG H01 0050
Coding: 0131216
Shop #: WSC 01236 785 1012552
Part No SW: 8P7 959 812 B HW: 8P7 959 812 B
Coding: 0131216
End----------(Elapsed Time: 01:24, VBatt start/end: 12.3V/12.1V)-----------
