VW Beetle ABS and ASP light on
Crofter
Scotland
C?ID=508845
Sunday,04,December,2022,13:05:26:07161
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN:    License Plate: G3BUG
Mileage: 46170km-28688mi   Repair Order:
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
   Mileage: 46170km-28688miles
Address 01: Engine        Labels: 06A-906-018-AQY.lbl
   Part No: 06A 906 018 EJ
   Component: 2.0l R4/2V  MOTR HS V04
   Coding: 00031
   Shop #: WSC 00066
   VCID: 6E85C1647986BAEB09E-4B1E
18057 - Powertrain Data Bus
            P1649 - 35-00 - Missing Message from ABS Controller
16556 - Fuel Trim; Bank 1
            P0172 - 35-00 - System Too Rich
Readiness: 0010 1001
Address 03: ABS Brakes        Labels: 1J0-907-37x-ESP-F.clb
   Part No: 1C0 907 379
   Component: ESP     20    CAN  V005
   Coding: 18433
   Shop #: WSC 00066
   VCID: 678BB440567C6BA34A8-4B1E
            00-00 - -
            49-00 - No Communications
   Part No: 6Q0 909 605 A
   Component: 0S AIRBAG VW5       0004
   Coding: 12371
   Shop #: WSC 00066
   VCID: 35372E085C50C933084-4B3C
Address 17: Instruments        Labels: 1C0-920-xx0.lbl
   Part No: 1C0 920 900 C
   Component: KOMBI+WEGFAHRS. M73 V07
   Coding: 01442
   VCID: 1B63D8B0DAB47F431E0-4B1E
   Subsystem 1 - Part No: Ident
   Component: Nr. Wegfahrs.:VWZ5Z0Y4032169
   Ident.-Nr. Wegfahrs.:VWZ5Z0Y4032169
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V072
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9DF1C63B2AC1B1B2-4B1E
   Part No: 1J0 959 799 AH
   Component: 6P Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 00066
   VCID: 045183CC470AA0BBCFA-4B1E
   Subsystem 1 - Part No: 1J1959801C
   Component: 6P Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 6P Tõrsteuerger. BF0002r
            36-10 - Open Circuit - Intermittent
Address 56: Radio        Labels: 1J0-035-18x-56.clb
   Part No: 1C0 035 186
   Component:  Radio BNO         0004
   Coding: 00401
   Shop #: WSC 00066
   VCID: 5BE398B09A343F43DE0-4B00
00852 - Loudspeaker(s); Front
            36-00 - Open Circuit
00853 - Loudspeaker(s); Rear
End----------(Elapsed Time: 03:40, VBatt start/end: 14.0V/14.0V)-----------
Hi all,
As it says the ABS and ESP lights are on I've attached the scan (hopefully). Anyone got any pointers for what my course of action should be?
Alan M
Why leave out the VIN (none GDPR data) and leave the reg which is personal data? The VIN to help the others is WVWZZZ9CZYM649353
You need a new ABS unit which I get as being VAG part number 8N0 698 517 but these are now obsolete from VAG UK but usefully it also fits the A3 and TT.
Sometimes they can be repaired but the only company I trust is AC Tronics and even they let me down on a Mk20 pump a few months back, charging me £50 for the privilege of telling me they could not repair it when I had sent it to them because they said they could! Also ACT only deal with the trade.
65535 - Internal Control Module Memory Error 00-00 - -
VWCoach
Philippines
C?ID=519119
My Touran has an ABS module that may need repair, do you know about ECU Testing Ltd in the UK? Are they reputable?
ECU testing are about 3 miles from where I am sitting… in the local area they are notorious and I would rather send and ECU to Mars than them, utter charlatans.
VWCoach
Philippines
C?ID=519119
Oh dear...good I asked you people in this forum! Many thanks for your support. Who then is reputable? I have read about BB Reman? However, I just read posts on BB Reman in the USA with news about legal problems and complaints? Where can we get proper repair work for an ABS module?
BBA in the UK did some good work but expanded too quickly and suffered but they have done some good work for me.
  • Informative
EuroX
Northern NJ USA
C?ID=208579
Replace module or rebuild.
VWCoach
Philippines
C?ID=519119
I see, what work turned out good? ON what type of controller? Most importantly, do they honor their promise of doing a good job by admitting need to rework if needed?
VWCoach
Philippines
C?ID=519119
The local VW dealer is quoting me usd 2,300 to install a new ABS Module...ouch! that is why i am looking for a lower cost option to repair
JMR
Romania
C?ID=432218
What , are you kidding ? Those are under 100 bucks around here , albeit they are most for the LHD cars( perhaps they could be coded for RHD or it might not matter ) but they cannot exceed maybe 200 pounds in UK at a wrecker ..
VWCoach
Philippines
C?ID=519119
What country or language is this? I need to try use google translate to understand it
JMR
Romania
C?ID=432218
This is on a romanian wrecker site where all wreckers post their wares , warranty and refund guaranteed. You need to be a registered member to buy and sell and i am happy to announce that i am one buyer with a perfect 100 % satisfaction rating ( given and received ) and 25 stars ( perfect score ) :). However , the prices are in romanian Lei or RON , you can do the parity . So , you need to look ip the part number and find a wrecker site in or near your country.
I doubt there are very many VWs in the Philippines, which means used parts will be difficult to find there.
JMR
Romania
C?ID=432218
@Uwe , for some reason i thought the OP was from UK . The op is from Scotland , is he not?? I m getting confused here lol
Yep, post #1 is from a guy in Scotland. But he was last seen on the forum on Monday and since then the discussion is with someone from the Philippines. :)
