Hello to All:
I just started using my newly acquired Ross-Tech scanner. I am delighted at how extensive the data is! Does anyone here have personal experience with figuring out the meaning of the ff scan result?
Meantime, the ff lights are lit up always on: ABS, Steering angle, Traction Control
The TPMS sensor is blinking.
1) My initial impression is my right rear wheel ABS sensor isn't sending data, i need to check on the cable connections and the sensor itself, maybe do a swap from left and right rear wheel? Will the sensors fit? I have a screenshot of data from the live data showing that right rear speed sensor data is ZERO, not showing the speed while running, but I don't know how to share a picture here.
2) The data also shows a fault code pointing at the ABS module...do I take this seriously a forsee that I need to send out the ABS module for repair?
The local VW dealer shop not surprisingly recommended a new ABS module be installed at a cost of approx USD 2,100...yikes! So given my past 10 year experience fixing our old Opel using OP-Com, I decided I better verify using VCDS.
3) There is fault in the Multifunction steering wheel control module:
4) So the raw data is below:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0766139
Coding: 820000
147462 - Terminal 15
B1148 12 [008] - Short to Plus
Component: GSG DSG AG6 531 4010
Revision: 05653104 Serial number: 00001501310472
VCID: 1471B1538273DFCB5FA-8040
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Fault Frequency: 26
Reset counter: 1
Mileage: 48569 km
Date: 2017.04.21
Time: 18:16:32
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 323B401609290EFC4C0B02E4901D7042A1000023
VCID: 04518113FE134F4BCFA-8050
7 Faults Found:
Reset counter: 28
Mileage: 48487 km
Date: 2017.04.13
Time: 22:36:46
Count: 1088
Count: 4608
Count: 81
Count: 49943
Count: 64501
Count: 64252
Fault Status: 00100011
Reset counter: 33
Mileage: 48651 km
Date: 2017.04.23
Time: 16:23:17
Count: 4608
Count: 83
Count: 48910
Count: 65535
Count: 259
Fault Status: 00101100
Reset counter: 36
Mileage: 48363 km
Date: 2017.04.07
Time: 12:16:46
Count: 4608
Count: 107
Count: 49943
Count: 512
03842 - RPM Sensor Rear Right: Incorrect Signal
Reset counter: 36
Mileage: 48458 km
Date: 2017.04.11
Time: 16:22:52
Count: 14
Count: 12800
Count: 87
Count: 43008
Count: 256
Count: 65535
Reset counter: 251
Mileage: 48501 km
Date: 2017.04.15
Time: 10:57:10
Count: 3
Count: 14
Count: 4096
Count: 128
Count: 43776
Count: 255
Fault Frequency: 9
Reset counter: 251
Mileage: 48364 km
Date: 2017.04.07
Time: 12:26:03
Count: 3
Count: 14
Count: 12800
Count: 16390
Count: 48896
Count: 65280
Count: 510
Fault Status: 01101100
Fault Frequency: 11
Reset counter: 251
Mileage: 48375 km
Date: 2017.04.07
Time: 16:53:14
Count: 32768
Count: 4608
Count: 4198
Count: 49165
Count: 256
Part No SW: 5K0 953 501 CQ HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20150306301767
Coding: 1982140000
VCID: 7BA3FAEF836D30B3BE0-802E
Coding: 820000
Reset counter: 17
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.294 1401
Revision: 1BH04739 Serial number: 00150560006401
Coding: 0000258
VCID: 41DF4807AD819A63A4C-8014
Fault Status: 00101101
Fault Frequency: 63
Reset counter: 36
Mileage: 48375 km
Date: 2017.04.07
Time: 16:53:15
RPM: 1008 /min
Speed: 11.0 km/h
(no units): 7.0
Voltage: 13.30 V
