What could be the reason for Address 17: Instruments Cannot be reached.
Do I need to a channel scan and upload for the Hex+ Net to be in a future update or is it an Instruments cluster fault.
Regards
Sunday,27,November,2022,16:08:38:62954
VCDS Version: 22.10.0.1 (x64) HEX-NET2 CB: 0.4623.4
VIN: WAUZZZF36P1006907 License Plate:
Mileage: 282km-175mi Repair Order:
Chassis Type: F3-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 23 42 44 4B 52 5F 61 6D 75 A5
CC D6 D7
VIN: WAUZZZF36P1006907 Mileage: 282km-175miles
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DFYA) Labels: None
Part No SW: 05E 906 018 CP HW: 05E 907 309 C
Component: R4 1.5l TFS H20 1317
Revision: 89H20000 CVN: B119B3E3
Coding: 0225003223240D0860086000000000000000000000000000
ASAM Dataset: EV_ECM15TFS01105E906018CP 004003
ROD: EV_ECM15TFS01105E906018CP.rod
VCID: 75BC89D3C54E6803C84-8020
VINID: 9D196AAAA5831A00400062401CF56EF42A
Radiator shutter:
Subsystem 1 - Part No SW: 95B 965 501 AA HW: 95B 965 501 AA
Component: V544KJS1 H13 0110
Serial number: 20220605060103050288
40446 - Generator
P065C 00 [032] - Mechanical Failure
Reset counter: 21
Mileage: 100 km
Date: 2022.11.16
Time: 12:46:56
Engine RPM: 141.00 /min
Vehicle speed: 44 km/h
Coolant temperature: 104 °C
Intake air temperature: 19 °C
Voltage terminal 30: 12.940 V
Unlearning counter according OBD: 21
Outside temperature: 9 °C
Absolute intake pressure: 96 kPa abs
Engine torque: 0.0 Nm
Fuel: tank fill level: 8.0 l
Oxygen sensor B1: sensor 1: specified value: 15.9998
Particulate filter: loading stage: 0
Overrun cut-off-Bits 0-7: 1
Part No SW: 0GC 300 048 K HW: 0GC 927 711 H
Component: GSG DQ381 H06 2809
Revision: 00H06V13 CVN: ED770DF6
ASAM Dataset: EV_TCMDQ381061 001001
ROD: EV_TCMDQ381061.rod
VCID: 343A74D78EB4310B3FA-8060
No subsystems:
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 HB HW: 5QM 614 517
Component: ESC H26 0157
Revision: 00000000 Serial number: 61182000001696 CVN: C63FFAEC
Coding: 15FFB27FA5203B728B800E006ACA48A84DA5DCD1705612FB12A1F574923D520B00622E64121A83902F35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100OMG 060015
ROD: EV_Brake1UDSContiMK100OMG_060_VW37.rod
VCID: 78A280E7D25C156BD32-802C
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 83A 820 043 AB HW: 83A 820 043 AB
Component: AC Automat H04 0070
Revision: 20026000 Serial number: 00000001052064
Coding: 071030040000000110010000000011040000000000000000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_AirCondiFrontVaAU326 001010
ROD: EV_AirCondiFrontVaAU326.rod
VCID: 6092C8876ACCFDAB8B2-8034
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H05 0010
Serial number: B2E58B7E00PAG0MUFU04
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 EA HW: 5Q0 937 084 EA
Component: BCM MQBAB MxL H44 0511
Serial number: 01102215400068
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
VCID: 7BA89FEBE36A3E73BE0-802E
Subsystem 1 - Part No SW: 83C 955 119 A HW: 83C 955 119
Component: J400FRWISCH 063 0050
Serial number: 890053F0402212300543
Coding: 5DC72F
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 43625023X81A955555B0
Coding: 00005D
Subsystem 3 - Part No SW: 4K2 941 501 R HW: 4K2 941 501 R
Component: E1 - LTM H06 0060
Serial number: 17S08.06.2200303288
Subsystem 4 - Part No SW: 5Q0 951 177 A HW: 5Q0 951 172 B
Component: Sensor, DWA 004 0403
Serial number: 000000000ZL221310A1Y
Serial number: 00000000000050847747
Steering Column Switch:
Subsystem 6 - Part No SW: 82A 953 521 MP HW: 5Q1 953 549 D
Component: J527 SMLS MQB 005 0080
Serial number: 00000004062220240290
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 H HW: 5QA 919 283
Component: PDC 4 Kanal H08 0073
Serial number: 000150059322140
Coding: 0601050011
ASAM Dataset: EV_EPHVA14AU3700000 009050
ROD: EV_EPHVA14AU3700000_009_AU37.rod
VCID: 4FF01B3B075272D3228-801A
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Coding: 520060C118FF8728747C63650050A700080000000000000044
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 73B8B7CBCB3A7633E60-8026
Part No SW: 5Q0 959 655 CC HW: 5Q0 959 655 CC
Component: AirbagVW21 010 0421
Serial number: 003J5R8H0PBT
Coding: 88CCF0C0002000005C5400DFC0C8005400C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
VCID: 0358E70B9B9A46B3F60-8056
Left seat belt tensioner:
Component: BeltPretRevFL 506 1062
Serial number: 83A857705G0159W00788
Coding: 802006
Right seat belt tensioner:
Component: BeltPretRevFR 506 1062
Serial number: 83A857706G0166W00280
Coding: 802006
Subsystem 3 - Part No SW: ----------- HW: 480 001 106 22
Serial number: 35700000000CB46C006N
Subsystem 4 - Part No SW: ----------- HW: 480 001 106 22
Serial number: 358000000000B46C006C
Subsystem 5 - Part No SW: ----------- HW: 480 401 406 22
Component: SideSensor_Dr 003 6149
Serial number: 35100019B09150B527A.
Subsystem 6 - Part No SW: ----------- HW: 480 401 006 22
Component: SideSensor_Pr 003 6149
Serial number: 3520001AB08E9FD1936O
Subsystem 7 - Part No SW: ----------- HW: 480 402 305 22
Component: FrontSensor_D 003 6149
Serial number: 3550001C906EE143C38E
Subsystem 8 - Part No SW: ----------- HW: 480 402 305 22
Component: FrontSensor_P 003 6149
Serial number: 3560001C906EE146E4CP
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 E
Component: GW MQB High 524 5502
Serial number: 02062210522264
Coding: 020100041F0810005B10224E1A0B00000001010000000000000003000000
GVL: 01463C0008000008408C80008000C80020000010000200000000000000000000
ROD: EV_GatewNF_VW37.rod (VIN: N/A)
VCID: 7F506BFBF7722253928-802A
Subsystem 1 - Part No SW: 4M8 951 523 HW: 4M8 951 523
Component: J453 MFL H07 0004
Serial number: 20220329195028 32475
Subsystem 2 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Component: J367-BDMHella H11 9070
Serial number: 7522089905
Address 23: Brake Booster (J539) Labels: None
Part No SW: 3Q0 909 059 AF HW: 3Q0 909 059 D
Component: EBKV H09 0209
Serial number: BPA085120622013
Coding: 4302C504300000C618638C31000049922449920400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
ROD: EV_BrakeBoostG2BoschVW48X_015.rod
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007VFF1416B
Coding: 00140A005001008000001002
ROD: EV_DCU2DriveSideMAXHKLO_AU37.rod
VCID: 4AC60A2FFC3057FB756-801E
Subsystem 1 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000061511502
Coding: 0D0000
Part No SW: 5TA 907 145 D HW: 5TA 907 145
Component: BASGEN1MQB37 502 1051
Serial number: 03428650
Coding: 01000000010000010001020101000100000001010100
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 009050
ROD: EV_SteerAssisBASGEN1MQB37_009.rod
VCID: 48C23027E23CA5EB632-801C
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 K
Component: FCM MQB Low 005 0367
Serial number: 21062211601262
Coding: 000000050900196E00102B03020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 372043DB9FC2DA131A8-8062
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007VF215818
Coding: 00140A005C01008000001000
ROD: EV_DCU2PasseSideMAXHKLO_AU37.rod
VCID: 49C43523F9365CE37CC-801C
Subsystem 1 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000061460309
Coding: 150000
Part No SW: 82A 035 043 B HW: 82A 035 043 A
Component: MU-TH-ND-EU 044 3801
Serial number: GRO-63321.09.22
Coding: 13260018804000000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU27.rod
VCID: 1C6ABC770624994B17A-8048
Multimedia System 1:
Subsystem 1 - Part No SW: 83A 919 605 C HW: 83A 919 605 C
Component: DU AU326 High H44 0137
Serial number: MA48X1AEB1465750
Subsystem 2 - Part No: V03 959 820 JP
Component: MIB3_EU_ 0860
Compact disc data bank:
Component: Gracenote2 1009
Volume Control 1:
Subsystem 4 - Part No SW: 83A 919 616 A HW: 83A 919 616
Component: LSR-D5/C8 H33 0110
Serial number: 00007522000107495016
Media socket:
1637 - Interface for External Media
U11B8 00 [008] - No Communications
[USB - communication error]
Reset counter: 53
Mileage: 31 km
Date: 2022.11.10
Time: 17:07:32
Voltage terminal 30: 12.6 V
Interface for external media: status: Open circuit
5529 - Secure Control Modules; Internal Communication
U15CA 00 [008] - Not Available
Reset counter: 83
Mileage: 17 km
Date: 2022.11.08
Time: 14:43:22
Voltage terminal 30: 12.1 V
Address 61: Battery Regul. (J1120) Labels: 4M0-915-105.clb
Part No SW: 5QF 915 105 HW: 5QF 915 105
Component: BMS_48V_LiIon H09 0410
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU37.rod
VCID: 0154ED03818654A3E4C-8054
Part No SW: 5WB 959 107 A HW: 5WB 959 107 A
Component: HDSG-Modul H05 0433
Revision: -------- Serial number: A2-C767-1200-8
Coding: 2900
ASAM Dataset: EV_DeckLidCONTIAU536 001002
ROD: EV_DeckLidCONTIAU536_VW38.rod
VCID: 4ECE063F00587BDB29E-801A
Part No SW: 5WA 035 284 G HW: 5WA 035 284 B
Component: OCUGen3High H20 0143
Serial number: 0000000205VIJH9
Coding: 013260101FE828009005460120010607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 C HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1302
Serial number: E80320002221680
Coding: 0004090821484020489E00001020000000010000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW41.rod
VCID: 353C49D385CE2803084-8060
Address CC: Starter-Generator (C29) Labels: None
Part No SW: 05E 903 018 F HW: 05E 903 018 F
Component: iBSG4U_000 H16 0123
Serial number: 5220614022525
ASAM Dataset: EV_SGCM600200005E903018F 002005
ROD: EV_SGCM600200005E903018F_002.rod
VCID: 251C9993356E5883B84-8070
Part No SW: 4K0 941 572 CC HW: 4K0 941 572 C
Component: LMS_MQB H06 0032
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 71B4BDC3B126442314C-8024
End----(Elapsed Time: 01:35, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Regards
