- Apr 24, 2022
- 27
- 0
- Boston, MA, USA
- C?ID=516305
I have retrofitted ACC and LKA, both of which are fully functional now. I have replaced the old steering wheel buttons for the ones with ACC and driver assistance. The controls for ACC such as speed and follow distance adjustment work, along with all the other buttons, except for the driver assist button.
Tuesday,01,November,2022,15:10:32:55940
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version 22.9.0.0 (arm64) HEX-V2 CB: 0.4623.4
VIN: 3VWCA7AU3FM515369 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 42 44 52 5F 6C 75 A5
VIN: 3VWCA7AU3FM515369 Mileage: 176868km-109900miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 022 N HW: 04L 907 309
Component: R4 2.0l TDI H23 9459
Revision: 85H23--- CVN: B5ADD45238D3FF82B866C2AD
Coding: 011D0012034410081000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM20TDI01104L997022N 004002
ROD: EV_ECM20TDI01104L997022N.rod
VCID: 3B23395723E80893F21-806F
VINID: 0E69D34474650D67450450C624EBB8C5E7
Readiness: 0 0 0 1 1
Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 05853104 Serial number: TFK01503163011 CVN: 0000EF4F
Shop #: WSC 00066 790 00218
ROD: EV_TCMDQ250021.rod
VCID: 2313E137BB585053DA1-8077
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 51085000000641
Coding: 04FA6AA124210971007A020681CC2520562490004081A4B21463F050C002
VCID: 47CB55A76F205C73669-8013
Revision: 00021000 Serial number: 0365009729
Coding: 030C0C
Shop #: WSC 12345 123 61029
VCID: 3A2D3C532CD2319BE97-806F
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 HW: 5GM 907 426
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020104202100000000000010000000
VCID: 05579FAF15AC8E63D45-8051
Part No SW: 5Q0 937 087 S HW: 5Q0 937 087 S
Revision: -------- Serial number: 8658061116000M
Coding: 00011A42404182F969E44000000403001800000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: 4BC369977348B813421-801F
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150327 043 0581
Serial number: 150518181529
Subsystem 2 - Part No SW: 5Q0 955 555 HW: 5Q0 955 555
Component: RLHSS 052 0122
Serial number: S7Y20M10D30H19M14S05
Coding: 00A8DD
Humidity sensor: interior:
540693 - Databus
Reset counter: 234
Mileage: 176868 km
Date: 2022.11.01
Time: 15:05:39
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 14.2 V
Outside temperature: 18.0 ∞C
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 R HW: 5Q0 907 572 J
Component: ACC BOSCH MQB H11 0771
Coding: 35007F418BEFC728949F81A761400000000000000099400000
ASAM Dataset: EV_ACCBOSCHVW416 003014
ROD: EV_ACCBOSCHVW416_003_VW37.rod
VCID: 46D558A3682A457B9DF-8013
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR01MTC-
Shop #: WSC 01383 790 50316
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150002Q8BT0I
Coding: 303138
Subsystem 2 - Part No SW: ----------- HW: 480 002 403 15
Serial number: 3570000000053D41831A
Subsystem 3 - Part No SW: ----------- HW: 480 002 403 15
Serial number: 35800000000870718318
Subsystem 4 - Part No SW: ----------- HW: 480 403 103 15
Serial number: 3510002C71941315012E
Subsystem 5 - Part No SW: ----------- HW: 480 403 103 15
Serial number: 3520002A31A87850C1E5
Subsystem 6 - Part No SW: ----------- HW: 480 402 603 15
Serial number: 3550002C3194131211EO
Subsystem 7 - Part No SW: ----------- HW: 480 402 603 15
Component: FrontSensor_P 001 6149
Serial number: 3560002C31941313D38Y
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150407400739
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 045182AB1E96B76BC3B-8051
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA5121A6580CF0502887E031000000000000000
Shop #: WSC 00046 123 12345
VCID: 6597BF2FF5EC6E63745-8031
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 01101410803011
Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
GVL: 01503C0000000600408C80008002C80000000000000000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72BDD473342289DBE17-8027
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 33180001093480031439
Coding: 2C0000
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0056486
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000072186002
Coding: 5D00000000000000
Shop #: WSC 00066 790 07030
ROD: EV_ELVMarquMQB.rod
VCID: 3431126B0EB6C7EB33B-8061
Component: TSG FS 020 0041
Serial number: 01071506050371
Coding: 003113205000040000000000
VCID: 43D341B75B187053BA1-8017
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001068099
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 1102
Component: TSG BFS 020 0041
Serial number: 141016060509XD
Coding: 003113205C00040000000000
VCID: 42DD44B34402795BB17-8017
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001127988
Coding: 091000
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Coding: 02730200FF00000051220001001808001F0100C40120010002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6C81CA0B16065F2B2BB-8039
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 252 8130
Serial number: VWZ6ZMW0235535
B11CF 53 [009] - Deactivated
Reset counter: 234
Mileage: 176868 km
Date: 2022.11.01
Time: 15:06:27
Voltage terminal 30: 14.1 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 137 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Component: RVC Compact H18 0231
Coding: 0100000260002013400060
VCID: 392F235F29D43A83E0D-806D
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 234
Mileage: 176868 km
Date: 2022.11.01
Time: 15:05:39
passive
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730202C2821A017F1E06000000
Shop #: WSC 00066 790 00322
ROD: EV_OCULowMQB.rod
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 04101711K22890
Coding: 0003060200010201002200448150890088000E010120
VCID: 3C213A4B26E60FABFBB-8069
End----------(Elapsed Time: 01:32, VBatt start/end: 14.2V/14.1V)-----------
