[Suggestion] Include parameter information in autoscan
Mwell
EU
C?ID=439106
Please include the following critically important control unit parameter/dataset information in the autoscan logs by default:
Advanced Identification:
Misc.
Equipment/PR Code: 000000000000000000000014
Dataset Number: 4G9909510E
Dataset Version: 0006
When e.g. changing control units or doing retrofits, this information is vital and would greatly increase the value of VCDS autoscans.
This should be a simple change that can be implemented in the upcoming VCDS software update.
If it is possible to implement, it would be also useful if the scan could show "Dataset Number: N/A" or just omit the lines for those control units that don't utilize parameters at all (e.g. control units that use the .sgo flash file type/KWP2000 protocol) and "Dataset Number: Dataset Missing!" if the control unit is currently missing parameters (which causes a DTC such as "No end-of-line programming" or "Data Set Implausible").
(As of now parameter information is not included either in the "Controller Channel Map" scan under VCDS Applications.)
Thank you!
Mwell
EU
C?ID=439106
I'm very glad to see you have implemented this and the latest VCDS shows "Dataset Number: 4G9909510E 0006" in the scan !
However, the parameter information is not complete unless the "Equipment/PR Code: 000000000000000000000014" data is included as well.
All three components of the parameter information must be present to verify you have 100% correct parameter in your control module.
This is because options (=Equipment/PR codes) of the car affect the contents of parameter files.
For example the above B&O audio dataset, PR such as body style (avant vs sedan) and sunroof slightly affect the audio parameter and if you don't have the 100% correct parameter file with the right Equipment/PR code, your sound will not be optimal, and what's worse in many cases you will not get the "Data Set Implausible/Invalid Data Set" DTC to be aware of the problem.
The Equipment/PR Code is always 24 digits (12 bytes as 2-digit hex number) but you may choose to omit the leading zeros to make the autoscan file more compact, e.g.:
Dataset: 4G9909510E Version: 0006 PR: 14
