For some reason the HEX-NET Interface doesn't communicate with the transmission control module on my 2012 Audi R8 V10.
Here was a scan using my HEX-V2 which I no longer own:
Here is a scan with the Hex-Net Every time I try to communicate it doesn't work.
It seems like the old Hex-V2 worked just fine but the Hex-Net doesn't. Has anyone run into this issue before? My Hex-Net is up to date as well as my VCDS
Tuesday,21,December,2021,12:53:49:37984
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WUAENAFG1CN000875 License Plate:
Mileage: 20730km-12881mi Repair Order:
Chassis Type: FG-AU35 (7N0)
Scan: 01 02 03 08 09 0F 10 11 31 14 15 16 17 19 25 2E 37 42 46 47
52 56 61 65 6C 77 A6
VIN: WUAENAFG1CN000875 Mileage: 20730km-12881miles
02-Auto Trans -- Status: Sporadic communication error 1000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
A6-Microphone -- Status: Malfunction 0010
Address 01: Engine (BUJ) Labels:. 07L-910-552-BUJ1.clb
Part No SW: 424 910 552 M HW: 420 907 552 B
Component: 5.2L V10HDZ/4V F ™0010
Revision: F5H09--- Serial number: AUX7Z0K6FNM0CS
Coding: 011000091B0F0120
Shop #: WSC 09382 002 1048576
VCID: 1D67D112B1B888E3AC7-8048
VINID: 9E5455791597053780000207142B93000D
Temperature: -40.0∞C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005386 - Engine Off Timer Performance
P150A - 002 - - Intermittent
Mileage: 19299 km
Temperature: 22.0∞C
Temperature: 24.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Mileage: 19328 km
Date: 2021.07.31
Time: 22:41:55
Temperature: 31.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 12.319 V
000369 - Fuel Trim; Bank 1
P0171 - 001 - System Too Lean
Fault Status: 01100001
Mileage: 20723 km
Date: 2021.12.17
Time: 13:12:42
RPM: 2752 /min
Load: 20.8 %
Speed: 23.0 km/h
Temperature: 92.0∞C
Temperature: 38.0∞C
Voltage: 13.716 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 20731 km
Date: 2021.12.21
Time: 15:53:39
Temperature: 16.0∞C
Temperature: 18.0∞C
Voltage: 11.811 V
Readiness: 0000 0001
Address 02: Auto Trans Labels: 420-910-156-V2.clb
Part No SW: 420 910 156 M HW: 420 927 156
Component: SL600 5.2L FSI HDZ 0040
Revision: SBH04001 Serial number: 9P2NA4U6L
Coding: 0000001
Shop #: WSC 66565 257 00032
VCID: 196FC502A590F4C340F-804C
Subsystem 1 - Part No: 420 713 041 C
Component: A11 C02 20.05.11 0A11
Address 03: ABS Brakes Labels: None
Part No SW: 420 907 379 HW: 420 614 517 D
Component: ESP8 quattro H01 0200
Coding: 0000267
Shop #: WSC 02197 785 00200
VCID: 59EF8502E51034C380F-800C
Fault Frequency: 11
Reset counter: 203
Mileage: 19798 km
Date: 2021.09.04
Time: 00:02:12
Hex Value: 0x00C0
Hex Value: 0x4222
Hex Value: 0x0023
Hex Value: 0x0192
Hex Value: 0x0000
Reset counter: 202
Mileage: 20612 km
Date: 2021.11.06
Time: 00:34:32
Hex Value: 0x0000
Hex Value: 0x4022
Hex Value: 0x0013
Hex Value: 0x4496
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 420-820-043.clb
Part No SW: 420 820 043 G HW: 420 820 043 G
Component: J255 Klima 1 Zone 0100
Revision: 00H06007 Serial number: 00000001193068
Coding: 1572906
VCID: 0E45A65E6C5E237B25D-805A
Reset counter: 203
Mileage: 19798 km
Date: 2021.09.04
Time: 00:02:12
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 S HW: 8P0 907 063 S
Component: BCM PQ35 H 110 0665
Revision: 00110 AD
Coding: 6E000A00A8933624207444E02920004950F26A001120C92ADC080E1C0045
Shop #: WSC 02391 823 56573
VCID: 44D144767E92992BC39-8010
Subsystem 1 - Part No SW: 423 955 113 HW: 423 955 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiR H23 0040
Coding: 005912
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 025B32
03134 - Motor for Rear Spoiler Movememt (V54)
Fault Status: 01101100
Reset counter: 132
Mileage: 19299 km
Date: 2021.07.30
Time: 13:55:56
Term 15 Off
Voltage: 12.25 V
Term 50 Off
03132 - Limit Switch for Rear Spoiler Movement (F135/F136)
Reset counter: 132
Mileage: 19299 km
Date: 2021.07.30
Time: 13:55:57
Term 15 Off
Voltage: 12.30 V
Term 50 Off
Reset counter: 202
Mileage: 20612 km
Date: 2021.11.06
Time: 00:34:33
Voltage: 12.25 V
Term 50 On
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7L0602109
Coding: 0000100
VCID: 36352EBE344E3BBB4DD-8062
Reset counter: 132
Mileage: 19299 km
Date: 2021.07.30
Time: 13:54:58
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X2.clb
Part No SW: 8P0 919 475 N HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0140
Revision: 11001001 Serial number: 12561119500239
Coding: 30010C
VCID: 49CF554259B0444330F-801C
Reset counter: 202
Mileage: 20612 km
Date: 2021.11.06
Time: 00:34:32
Temperature: 11.0∞C
Address 11: Engine II Labels:. 07L-910-552-BUJ2.clb
Voltage: 0.000 V
Mileage: 19299 km
Temperature: 22.0∞C
Temperature: 24.0∞C
Voltage: 11.938 V
P0300 - 008 - - Intermittent
Mileage: 19328 km
Date: 2021.08.01
Time: 05:52:29
RPM: 1277 /min
Load: 39.2 %
Temperature: 47.0∞C
Temperature: 32.0∞C
Voltage: 12.319 V
000372 - Fuel Trim; Bank 2
P0174 - 001 - System Too Lean - MIL ON
Fault Status: 11100001
Mileage: 20722 km
Date: 2021.12.17
Time: 12:17:29
RPM: 2044 /min
Load: 29.8 %
Speed: 16.0 km/h
Temperature: 101.0∞C
Temperature: 48.0∞C
Voltage: 14.224 V
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 420 910 376 A HW: 420 907 376 A
Component: J250 Raddaempfung 0170
Revision: --H16--- Serial number: 190DPH 1166047
Coding: 0000052
VCID: 117FBD227D603C8338F-8044
Address 15: Airbags Labels: 420-959-655.lbl
Part No SW: 420 959 655 HW: 420 959 655
Component: SN Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 003B8000EPX8
Coding: 0021326
VCID: 5DE79112F138C8E3EC7-8008
Subsystem 1 - Part No: 8J0 910 339 A
Component: BF-Gewichtsens. H02 0030
Subsystem 2 - Serial number: 05MRT
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ˇÜ63
Subsystem 4 - Serial number: 000000ˇÜ63328RB406320306+ˇÜ63
Subsystem 5 - Serial number: 20306+ˇÜ63428RB4063202FCJˇÜ63
Subsystem 6 - Serial number: 202FCJˇÜ63747RB40642B266KˇÜ63
Subsystem 7 - Serial number: 2B266KˇÜ63847RB40642B2C2Nˇ
Subsystem 8 - Serial number: 2B2C2Nˇ
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H37 0070
Coding: 0004141
VCID: 41DF4D626D808C03E8F-8014
Component: E0221 H06 0030
Address 17: Instruments Labels: 420-920-xxx-17.clb
Part No SW: 420 920 981 L HW: 420 920 981 L
Component: KOMBIINSTR. VDO H02 0650
Revision: D0H02002 Serial number: 2246K002000067
Coding: 0081286
Shop #: WSC 35850 004 1048576
VCID: 1F1BEB1ABBB49AF3BEB-804A
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 150711F2003023
Coding: 354100
VCID: 372B23BA3F44C2B356B-8062
Fault Status: 00110100
Reset counter: 202
Mileage: 20612 km
Date: 2021.11.06
Time: 00:34:33
Revision: D0H02002 Serial number: AUX7Z0K6FNM0CS
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 420 035 785 HW: 420 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020302
VCID: 52FD722EB4E6079B415-8006
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 423 035 192 H HW: 423 035 192 H
Component: RNS-E PU US H06 0210
Revision: 0000013S Serial number: AUZBZ7L7200872
Coding: 0730645
Shop #: WSC 25106 444 05016
VCID: 1577C9324988D0A3647-8040
Reset counter: 189
Mileage: 19905 km
Date: 2021.09.25
Time: 18:26:40
Bin. Bits: 00000000 00000000
Bin. Bits: 10000000 00000000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 420 959 801 H HW: 420 959 801 H
Component: Tuer-SG H04 0103
Coding: 0005245
VCID: 1E65D61EBCBE93FBB5D-804A
Address 47: Sound System Labels: 420-035-223.lbl
Part No SW: 420 035 223 D HW: 420 035 223 A
Component: J525 Amp High H14 0230
Revision: 00H14001 Serial number: 34844001236406
Coding: 0246111
VCID: 094F954215300443F0F-805C
Part No SW: 420 959 802 H HW: 420 959 802 H
Coding: 0005245
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0730645
Reset counter: 189
Mileage: 19905 km
Date: 2021.09.25
Time: 18:26:40
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: F3220148
VCID: 71BFDDA211A05C8358F-8024
Subsystem 1 - Part No SW: 420 915 181 HW: 420 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650224924
Address 65: Tire Pressure Labels: None
Part No SW: 420 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0040
Revision: 00050040 Serial number: 00000700007660
Coding: 0462426
VCID: 0D47A15261581863DC7-8058
Address 6C: Back-up Cam. Labels: 420-910-441.clb
Part No SW: 420 910 441 A HW: 7L6 907 441 C
Component: J772__Rearview 0010
Revision: --H13--- Serial number: 525PA8-J1560AL
Coding: 1020412
VCID: 0A4DAA4E10360F5BF95-805E
Part No SW: 8P1 862 336 A HW: 8P1 862 336
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005155414
Coding: 0011477
Shop #: WSC 02556 785 00200
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 HW: 420 907 394
Component: BELTMICBOX H09 0060
Coding: 0100010202
Shop #: WSC 02197 785 00000
ASAM Dataset: EV_BeltMicAU715 002011
ROD: EV_BeltMicAU715_002.rod
VCID: 56F58E3E988E1BBBADD-8002
0032 - Microphone 1 for Passenver Side
B1206 13 [009] - Open Circuit
[BeltMicCoDriverMic1Open]
0048 - Microphone 2 for Passenver Side
B1207 13 [009] - Open Circuit
[BeltMicCoDriverMic2Open]
0064 - Microphone 3 for Passenver Side
B1208 13 [009] - Open Circuit
[BeltMicCoDriverMic3Open]
0080 - Microphone 1 for Drivers Side
B1203 13 [009] - Open Circuit
[BeltMicDriverMic1Open]
0096 - Microphone 2 for Drivers Side
B1204 13 [009] - Open Circuit
[BeltMicDriverMic2Open]
0112 - Microphone 3 for Drivers Side
B1205 13 [009] - Open Circuit
[BeltMicDriverMic3Open]
End----(Elapsed Time: 01:45, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Sunday,09,October,2022,12:06:46:01516
VCDS Version: 22.9.0.0 (x64) HEX-NET2 CB: 0.4623.4
Mileage: 21290km-13228mi Repair Order:
VIN: WUAENAFG1CN000875 Mileage: 21290km-13228miles
VCID: 9D6C365601B110236C5-80C8
P1923 - 008 -
Mileage: 21295 km
Date: 2022.10.09
Time: 11:45:11
Temperature: 21.0∞C
Temperature: 23.0∞C
Voltage: 11.684 V
Address 03: ABS Brakes Labels: 420-910-517.lbl
Coding: 0000267
VCID: D9E462465519AC0340D-808C
Coding: 1572906
VCID: 8E4E411ADC57BBBBE5F-80DA
Revision: 00110 AD
VCID: C4DAA332CE9B01EB03B-8090
Coding: 005912
Coding: 025B32
Coding: 0000100
VCID: B63EC9FA8447A37B8DF-80E2
Reset counter: 233
Mileage: 21127 km
Date: 2022.06.19
Time: 21:07:26
Coding: 30010C
VCID: C9C4B206E9B9DC83F0D-809C
Mileage: 21012 km
Date: 2022.05.16
Time: 12:29:34
RPM: 1366 /min
Load: 57.6 %
Temperature: 28.0∞C
Temperature: 25.0∞C
Voltage: 13.843 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent
Mileage: 21012 km
Date: 2022.05.16
Time: 12:30:03
RPM: 878 /min
Load: 22.3 %
Temperature: 40.0∞C
Temperature: 26.0∞C
Voltage: 14.351 V
000773 - Cylinder 5
P0305 - 008 - Misfire Detected - Intermittent
Mileage: 21012 km
Date: 2022.05.16
Time: 12:30:03
RPM: 878 /min
Load: 22.3 %
Temperature: 40.0∞C
Temperature: 26.0∞C
Voltage: 14.351 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent
Mileage: 21012 km
Date: 2022.05.16
Time: 12:30:03
RPM: 878 /min
Load: 22.3 %
Temperature: 40.0∞C
Temperature: 26.0∞C
Voltage: 14.351 V
000775 - Cylinder 7
P0307 - 008 - Misfire Detected - Intermittent
Mileage: 21012 km
Date: 2022.05.16
Time: 12:30:03
RPM: 878 /min
Load: 22.3 %
Temperature: 40.0∞C
Temperature: 26.0∞C
Voltage: 14.351 V
Coding: 0000052
VCID: 91745A66CD69A443F8D-80C4
Coding: 0021326
VCID: DDEC7656413150232C5-8088
Coding: 0004141
VCID: C1D4AA26DD8914C328D-8094
Coding: 0081286
VCID: 9F100C5E0BBD02337E9-80CA
Coding: 354100
VCID: B720C4FE8F4D5A73969-80E2
Revision: 00000000
Coding: 020302
VCID: D2F6956A04EF9F5B817-8086
Coding: 0730645
VCID: 957C2E76F9814863A45-80C0
Reset counter: 31
Mileage: 21253 km
Date: 2022.09.18
Time: 14:29:27
Coding: 0005245
VCID: 9E6E315A0CB70B3B75F-80CA
Coding: 0246111
VCID: 89447206A5399C8330D-80DC
00875 - Treble Speaker Front Right (R22)
Fault Status: 00101011
Reset counter: 1
Mileage: 21019 km
Date: 2022.05.16
Time: 14:51:19
Coding: 0005245
Coding: 0730645
Reset counter: 31
Mileage: 21253 km
Date: 2022.09.18
Time: 14:29:27
Coding: F3220148
VCID: F1B43AE6A1A9C44398D-80A4
Coding: 0462426
VCID: 8D4C4616D15180A31C5-80D8
Coding: 1020412
VCID: 8A464D0AA03F979B397-80DE
Coding: 0011477
Coding: 0100010202
VCID: D6FE697A2887837B6DF-8082
End----------(Elapsed Time: 02:05, VBatt start/end: 14.3V/14.3V)-----------
