VW Touareg Mk 3 2018 Tow Bar ACC issues
collinstott
Nottingham, UK
C?ID=524837
Hello, I'm looking for advice and or information on how to resolve a problem, having fitted an ECS tow bar wiring loom I understood that the loom would require coding.
But since the loom has been fitted I'm having ACC unavailable warnings. I have attached the VCDS report.
Tuesday,29,November,2022,14:21:57:21227
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVGZZZCRZJD008716   License Plate:  UKH
Mileage: 71122km-44193mi   Repair Order: 001
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 09 13 15 16 17 19 2B 42 44 46 52 5F 69 6C 6D 81 A5
          AC BB BC CA D6 D7 DE
VIN: WVGZZZCRZJD008716   Mileage: 71122km-44193miles
69-Trailer -- Status: Not registered 0001
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DENA)       Labels: None
   Part No SW: 760 907 401 N    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---    CVN: 9CCCCE8FFA9EEAC7755A2113755A211300000000D6C3ECFE
   Coding: 292A40320366050334180000000400000000000000000000
   Shop #: WSC 00166 210 00000
   ASAM Dataset: EV_ECM30TDI011760907401N 001002
   ROD: EV_ECM30TDI011760907401M.rod
   VCID: 2019EDA8EA46CDBBCB2-8074
   VINID: 9E65EAAAA4E2A9A5000081C118CE8A248B
17156 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 11
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:01:00
                    Engine RPM: 651.00 /min
                    Normed load value: 27.5 %
                    Coolant temperature: 55 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.660 V
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_RUNNING
   Part No SW: 760 927 158 B    HW: 0D5 927 156 N
   Component: 0D5  30TDIRdW H05 1003
   Revision: --H05---    CVN: 4559B166
   Coding: 100000
   Shop #: WSC 31414 035 00001
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 1F1BEE54D738F243F28-804A
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M6 907 379 N    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0850
   CVN: 7A85C135
   Coding: 1DA731B730A20B9E9EA54892008352E2E93AE1B88C0CD07912004A47975C87
   ROD: EV_ESP9BOSCHCMP_VW53.rod
   VCID: 48C955082236D5FB632-801C
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 DG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0652
   Coding: 07501143E1180009074D97085BAE8041830B31100040009301100A0079045A011BC500BB02B606140000010000D1201B1802000045010104000000000000000000
   Shop #: WSC 31414 050 00001
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 76B5EBF01842130BC1E-8022
   Subsystem 1 - Part No SW: 762 955 113     HW: 762 955 113
   Component: WIPER 190518  010 0380
   Serial number: VZ1SKA 0100109919051
   Serial number: 21442513X81A955555A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 762 941 633     HW: 762 941 633
   Component: E1 - LTM  H06 0054
   Serial number: 13S09.05.1800140587
   Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
   Serial number: GX1CE113011820910053
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 760 947 105 S    HW: 760 947 105 S
   Component: Dachelektroni  H32 0057
   Serial number: 00000149330000000000
393607 - Motor for Fresh Air / Recirculated Air Flap
          B11AF 07 [009] - Mechanical Failure
                    Reset counter: 15
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:27:13
                    average_Voltage_terminals: 12.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: 12.50 °C
                    interior_temperature: 21.00 °C
                    Vehicle speed: 0.00 km/h
393731 - Motor for Recirculation Flap
          B1092 07 [009] - Mechanical Failure
                    Reset counter: 15
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:27:11
   Part No SW: 760 907 561 B    HW: 760 907 561 A
   Component: LRR4R         H04 0330
   Coding: 32657FC358000400000020A000000010051246484401009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002022
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 1B63DA44C320EE631E0-804E
2345 - Databus
          [FAULT_CAMERA_ERROR]
                    Reset counter: 15
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:28:16
                    Voltage terminal 15: 12.7 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
                    Steering_angle-Data: 17.400 °
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: OFF
                    Misalignment angle: horiz: -0.005 °
                    Misalignment angle: horiz: fast algorithm: 0.124 °
                    Congestion pilot: status: OFF
                    Outside temperature: 12.00 °C
                    Sensor blindness: radar: no blindness detected
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 15
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:28:16
   Part No SW: 4M0 959 655 J    HW: 4M0 959 655 J
   Component: AirbagVW31    H07 2710
   Serial number: 003YQM009KRC
   Coding: 88CCC0C00C800000585400EF308D41A80065
   Shop #: WSC 31414 031 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 42DD4720040AFFABBD6-8016
   Subsystem 1 - Part No SW: -----------    HW: 480 002 505 18
   Serial number: 357000000002C779FF2+
   Subsystem 2 - Part No SW: -----------    HW: 480 002 605 18
   Serial number: 35800000000384D4BE2W
   Subsystem 3 - Part No SW: -----------    HW: 480 032 905 18
   Serial number: 351001C108A891C0FD9M
   Subsystem 4 - Part No SW: -----------    HW: 480 032 405 18
   Serial number: 352001C10ED609112AE8
   Subsystem 5 - Part No SW: -----------    HW: 480 031 804 18
   Component: FrontSensor_D  002 0189
   Serial number: 355001C0C73B71C01E9H
   Subsystem 6 - Part No SW: -----------    HW: 480 031 804 18
   Component: FrontSensor_P  002 0189
   Serial number: 356001C0C73BB1115ECJ
   Subsystem 7 - Part No SW: -----------    HW: 480 030 205 18
   Component: PedP_Sensor_D  002 014A
   Serial number: 228001C106ADC4711E3B
   Subsystem 8 - Part No SW: -----------    HW: 480 030 205 18
   Component: PedP_Sensor_P  002 014A
   Serial number: 229001C106A0854029C/
   Subsystem 9 - Part No SW: -----------    HW: 480 030 805 18
   Component: PedP_Sensor_C  002 014A
   Serial number: 230001C106A384A0CF9A
   Subsystem 10 - Part No SW: -----------    HW: 480 000 405 18
   Serial number: I0M00000000581B48EAF
   Subsystem 11 - Part No SW: -----------    HW: 480 000 405 18
   Serial number: I0N00000000481B48EAF
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 760 953 507 B    HW: 760 953 507 B
   Component: Lenks.Modul   H03 0006
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 1C61D958C62EE95B17A-8048
   Part No SW: 760 920 971     HW: 760 920 971
   Component: TDieUK------- H04 0320
   Coding: A5A631C06F94260001886322B0804808E4000080
   ASAM Dataset: EV_DashBoardAU65X 001011
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 59EF804C899C5C73CCC-800C
   Subsystem 1 - Part No SW: 760 927 531 F    HW: 760 927 531 F
   Component: E881 BedieFPA  001 0460
          U1014 00 [009] - -
          [ECU incorrectly coded]
                    Fault Frequency: 11
                    Reset counter: 18
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:29:19
   Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 AB
   Component: Gateway       H14 0036
   Revision: 8P020004    Serial number: 0488P053318525
   Coding: 0301000300008E407F07000000DB0532581E000700000000037D078E10000100
   GVL: 71503C0008040200008C88000002C80010080000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_VW53.rod
   VCID: 79AFE0CC295C7C73ACC-802C
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180000798600018195
   Coding: 2FFFFF
   Serial number: 7320647804
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [Data_Bus_Commponent_List_detected]
                    Fault Frequency: 29
                    Reset counter: 18
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:30:05
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 18000159728006
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323D17E0B4AA4F2B2D6-8066
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS001 0187
   Serial number: YE007RC51334B
   Coding: 003F9A00D001040000013082
   ROD: EV_DCU2DriveSideMAXHKLO_VW53.rod
   VCID: 3E2533D070F29B4BD9E-806A
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H20 0504
   Coding: B4110101000100
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313F18ECB1AC743354C-8064
   Part No SW: 4N0 907 064 BP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H14 0144
   Coding: 013500002FB000487329A0047C00080203020000004704502F0400000508803F001F31C4010001
   ASAM Dataset: EV_BCM2CONTIAU651 008007
   ROD: EV_BCM2CONTIAU651_008.rod
   VCID: 7EA5F3D030725B4B99E-802A
   ID - sensor:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY180872LAN
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0006
   Serial number: 00000000000000071429
   Rear spoiler control module:
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS001 0187
   Serial number: YE007REF1127C
   Coding: 003F9A00DC01040000013080
   ROD: EV_DCU2PasseSideMAXHKLO_VW53.rod
   VCID: 3D2734DC7DF48053C04-8068
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 760 035 154     HW: 760 035 154
   Component: MU-H-LND-EU   046 2481
   Coding: 02350601FF00000043110101C08808301F0106E601A004009F
   ROD: EV_MUHigGen2pALPI_VW53.rod
   VCID: 4FFB7E14C75802C3228-801A
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV1230693
   Subsystem 2 - Part No: V03 959 805 HA
   Component: MIB2P_EU_Q317  0240
   Compact disc data bank:
   Component: Gracenote2  1008
   Media socket:
   Subsystem 4 - Part No SW: 5G0 035 953 D    HW: 0
H08 0014
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789670392
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3B233AC463E08E63FE0-806E
   Component: RVC Compact   H12 0250
   Coding: 0135060122002011000040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 333312E44BB04623260-8066
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0166
   Revision: --------    Serial number: 31952095300000
   Coding: 1758
0037 - Load Space Cover
          B12EF 07 [008] - Mechanical Failure
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:24:59
   Part No SW: 762 713 041 A    HW: 4M2 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 18050747241639
   ROD: EV_GSMWaehlZFAU736_VW53.rod
   VCID: 1079BD681AE65D3B7B2-8044
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0291
   Coding: 04C2860000000000000806000090042C18075300000000000000000000000000000000000000000000000000000000000000000000000000000040000000000000001000000000700000004000000000008040000020
   ASAM Dataset: EV_ZFASAU516 001005
   ROD: EV_ZFASAU516_001.rod
   VCID: 7F5B0ED437785243928-802A
221201 - Front Camera for Driver-Assist Systems
          C12B3 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 15
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:31:06
                    Front camera: status of current initial calibration: not completed successfully
                    Front camera: details of current initial calibration-Year: 2000
                    Front camera: details of current initial calibration-Month: 0
                    Front camera: details of current initial calibration-Day: 0
                    Front camera: details of current initial calibration-Hours: 0
                    Front camera: details of current initial calibration-Minutes: 0
                    Front camera: details of current initial calibration-Seconds: 0
                    Front camera: details of current initial calibration-Odometer reading: 41964 km
                    Front camera: details of current initial calibration-Status: Calibration not yet performed
                    Front camera: details of current initial calibration-Vehicle Identification Number (VIN): WVGZZZCRZJD0
                    Front camera: details of current initial calibration-Focal length: 0
                    Front camera: details of current initial calibration-Calibration marks: line 1: 00111111
                    Front camera: details of current initial calibration-Calibration marks: line 2: 00111111
                    Front camera: details of current initial calibration-Calibration marks: line 3: 00111111
                    Front camera: details of current initial calibration-Calibration marks: line 4: 00111111
                    Front camera: details of current initial calibration-Calibration marks: line 5: 00111111
                    Front camera: details of current initial calibration-Main point of the camera: X coordinate: 640
                    Front camera: details of current initial calibration-Main point of the camera: Y coordinate: 480
                    Front camera: yaw angle (initial calibration)-Front_camera_yaw_angle_initial_calibration: -0.49 °
                    Front camera: pitch angle (initial calibration)-Front_camera_pitch_angle_initial_calibration: -0.46 °
                    Front camera: sway angle (initial calibration)-Front_camera_roll_angle_initial_calibration: 0.07 °
                    Front camera: camera height (initial calibration)-Front_camera_height_initial_calibration: 1553 mm
                    Front camera: calibration result (static calibration end of line)-Yaw angle: -0.32 °
                    Front camera: calibration result (static calibration end of line)-Pitch angle: -0.67 °
                    Front camera: calibration result (static calibration end of line)-Roll angle: 0.05 °
                    Front camera: calibration result (static calibration end of line)-Camera height: 1575 mm
                    Front camera: calibration results (end of line initial dynamic calibration)-Yaw angle: -8.85 °
                    Front camera: calibration results (end of line initial dynamic calibration)-Pitch angle: -5.67 °
                    Front camera: calibration results (end of line initial dynamic calibration)-Roll angle: -5.73 °
                    Front camera: calibration results (end of line initial dynamic calibration)-Camera height: 0 mm
                    Front camera: type of latest end of line calibration: static
                    Front camera: end of line calibration: adjustment: only static calibration
                    Initial online calibration status: not active
                    Initial online calibration: suitable single images: 0
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: -40 °C
4108 - Databus
          [irreversibler_Fehler_im_ACC_System]
                    Fault Frequency: 11
                    Reset counter: 18
                    Mileage: 71085 km
                    Date: 2022.11.28
                    Time: 12:31:06
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_VW53.rod
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS002 0187
   Serial number: YE007REM22417
   Coding: 003E92000000040000013080
   VCID: 40D94D280A06EDBBAB2-8014
   Component: TSG HBFS002 0187
   Serial number: YE007REM22157
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 588040753602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3A2D3FC06CDAB76BE56-806E
   Part No SW: 7P5 941 591 BD    HW: 7P5 941 591 B
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Component: WLC Front     H10 0057
   Coding: 400000
   VCID: 221DE7A0E44ADFABDD6-8076
End----(Elapsed Time: 02:04, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Byte 3, bit 3 should be: "Control_module_for_towing _sensor - installed" and needs to be set in the ACC module.
PS: Please Get Verified.
collinstott
Nottingham, UK
C?ID=524837
Thanks for taking the time to respond, I'm more of an old HGV mechanic from the 70's and as you can imagine not that up on the latest tech.
I thought a tow bar would be straight forward so had a go and bought the VDCS cable and software thinking it would be straight forward.
Would it be possible to point me in the direction of where its possible to learn the Byte 3, bit 3 terminology? I could do with a basic youtube video if you could point me to a link. the kit I used to work on had stop cables lol.
Re the verified I did click on the email link?
Once again thanks for taking the time
I don't think we have a video for that.
Step-by-step:
[Select]
[13-Auto Dist. Reg]
[Coding]
[Long Coding Helper]
At that point, VCDS will likely warn you that only "Experimental" coding is available for this module and ask you whether you wish to use that data. Click [Yes].
You'll see a window that looks something like this:
The big '2' there is the byte number. You'll probably have a '0' there. Use the little up/down arrows next to that box to get to Byte 3. At that point you should see some of the bits in that byte defined. Bit 3 should be "Control_module_for_towing _sensor - installed". Put a check-mark next to it. Then close the Long Coding Helper.
Your new coding will be transferred to the appropriate box back in VCDS, where you'll have to click [Do It!]
collinstott
Nottingham, UK
C?ID=524837
Thank you for your help your a star
collinstott
Nottingham, UK
C?ID=524837
Hello again I completed the towing module 69 and the Byte 3, bit 3 which has removed the lane error fault, however I'm still having issue's
with VW Touareg 2018 MK3 be grateful for any insights
2345 - Databus
U1014 00 [009] - -
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Wednesday,30,November,2022,12:54:49:21227
Mileage: 71125km-44195mi   Repair Order:
VIN: WVGZZZCRZJD008716   Mileage: 71125km-44195miles
   Coding: 100000
   CVN: 7A85C135
   Coding: 02006D
   Coding: 030000
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:30:34
                    average_Voltage_terminals: 12.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 9.00 °C
                    interior_temperature: 18.50 °C
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:30:34
   Coding: 32657FCB58000400000020A000000010051246484401009E00
2345 - Databus
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:31:09
                    Voltage terminal 15: 12.0 V
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: 6.700 °
                    adjustment_calculation: On
                    Outside temperature: 9.00 °C
   Control head driving profile:
          U1014 00 [009] - -
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:31:39
   GVL: 71503C0008040200808C88000002C80010080000000000000000000000000000
   Coding: 2FFFFF
   ID - sensor:
   Media socket:
H08 0014
   Coding: 1758
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:32:20
4107 - Databus
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:32:20
   Coding: 400000
End----(Elapsed Time: 01:52, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
2345 - Databus
Likely because the Camera isn't calibrated.
U1014 00 [009] - -
Instrument Cluster, Coding, Byte 14, Bit 5.
Camera calibration requires specialized targets and measuring equipment. Here is an example of how it's done.
4107 - Databus
Looks like the camera is upset that the ACC is upset that camera is upset. :banghead:
collinstott
Nottingham, UK
C?ID=524837
That's great very helpful, thank you any idea what would cause the camera to need calibrating nothings has been changed?
Thanks again
PS now I've invested in the lead and software is there an easy way to disable the stop start function?
Regards
Collin
No, not really. Let's get rid of as many other faults as possible first and see what happens.
Not that I am aware of on that vehicle.
collinstott
Nottingham, UK
C?ID=524837
Thank you, Ill sort the control module in the morning and see how I get on.
Thanks again
Vdub
C?ID=57533
Thanks again
Regards
Collin
Sometimes its enough to just take care off the proper codings.
StartStop isn't possible to disable with VCDS, there is another similar tool that can do it or a tuner can do it in the ECU.
For a quick disable(with error-notification) you can pull the small connector of the MINUS from the battery.
collinstott
Nottingham, UK
C?ID=524837
Hell again Ive managed to clear
U1014 00 [009] - -
But Im still stuck with the ACC limited function and Lane assist unavailable be grateful if you could review the data again
Thursday,01,December,2022,14:25:15:21227
Mileage: 71125km-44195mi   Repair Order: 01.12.22
   Coding: 100000
   CVN: 7A85C135
   Coding: 02006D
   Coding: 030000
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:30:34
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:30:34
2345 - Databus
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:31:09
   Coding: A5A631C06F94260001886322B0806808E4000080
   Coding: 2FFFFF
   ID - sensor:
   Media socket:
H08 0014
   Coding: 1758
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:32:20
4107 - Databus
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.11.30
                    Time: 12:32:20
   Coding: 400000
End----------(Elapsed Time: 01:53, VBatt start/end: 15.1V/15.1V)-----------
Address 13: DTCs cleared
Address A5: DTCs cleared
   Coding: 100000
   CVN: 7A85C135
   Coding: 02006D
   Coding: 030000
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.12.01
                    Time: 14:35:00
                    average_Voltage_terminals: 14.90 V
                    Outside air temperature sensor-Outside air temperature on CAN: 7.50 °C
                    interior_temperature: 17.50 °C
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.12.01
                    Time: 14:35:25
                    average_Voltage_terminals: 14.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: 8.00 °C
2345 - Databus
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.12.01
                    Time: 14:33:24
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.8 V
                    Steering_angle-Data: -0.700 °
                    Yaw_rate-Data: -0.011 rad/s
                    Outside temperature: 7.50 °C
   Coding: 2FFFFF
   ID - sensor:
   Media socket:
H08 0014
   Coding: 1758
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.12.01
                    Time: 14:33:24
4107 - Databus
                    Reset counter: 18
                    Mileage: 71125 km
                    Date: 2022.12.01
                    Time: 14:33:24
   Coding: 400000
End----------(Elapsed Time: 01:52, VBatt start/end: 15.0V/15.0V)-----------
Vdub
C?ID=57533
maybe try to do a ACC basic setting
collinstott
Nottingham, UK
C?ID=524837
Hi and thanks for the suggestion, I'm afraid I don't understand how, could you supply more information please
collinstott
Nottingham, UK
C?ID=524837
I was hoping to shed some light on this on going issue, the car is currently with Vertu motors a VW main dealer.
There saying they cannot recalibrate the lane assist as it has a towbar fitted which is not a VW part.
The car was bought from this dealer with the same tow fitted and the lane assist was working fine.
The car developed the fault before I replaced the loom as it was not operating the fridge etc. (hence the reason for the change)
There fitter is saying its not possible to calibrate the the lane assist with the non OE part VW tow bar.
I suspect there lying but I could do with a little more of an understanding before I challenge them, the car is under an extended warranty, there advise is to remove the towbar. The car was bought with the towbar fitted and it all worked fine.
Be grateful for a little insight.
