Here the guide I have : http://forum.xhorse.pl/viewtopic.php?t=357&sid=405a2a4aaf5a55d749ab36d5e3493c84
I buy a CH SWCM, right now I have a RCD340 in the car too and solder the module from XHorse. Change from highline to lowline.
What I need to do with the lbl file they give here : http://forum.xhorse.pl/viewtopic.php?t=240&sid=30ec43e21f96932c7925fe480479b66d
Right now I only have the RED led on, no flashing white led. No buttons work on the SW and no horn. Airbag light on on the dash and steering wheel too
Can you help me with that please ?
Here the log :
Here the log :
Sunday,27,November,2022,13:35:34:49884
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: WVWKC71K98W054141 License Plate:
Mileage: 145760km-90571mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 3D 42 44 46 47 52 55 56
VIN: WVWKC71K98W054141 Mileage: 145760km-90571miles
3D-Special Function -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 KR HW: 022 906 032 GP
Component: R32-DQ-LEV2 G 1098
Revision: 1QH02--- Serial number: VWX7Z0G53NT7Q7
Coding: 0000178
Shop #: WSC 66565 257 00032
VCID: 65974C7F796DEBE3784-8030
VINID: 9E69DB4C705B2489C01440440447D8DA39
012313 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit
RPM: 835 /min
Load: 63.1 %
Temperature: 23.0°C
Temperature: 16.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.303 V
049412 - No Communication with Cruise Control Module
U0104 - 008 - - Intermittent
Mileage: 144932 km
Temperature: 8.0°C
Temperature: 11.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 10.033 V
U0155 - 008 - - Intermittent
Mileage: 144932 km
Temperature: 8.0°C
Temperature: 11.0°C
Voltage: 10.033 V
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 -
Fault Status: 01100001
Temperature: 26.0°C
Temperature: 22.0°C
Voltage: 11.684 V
Readiness: 0110 0100
Part No SW: 02E 300 011 CC HW: 02E 927 770 AE
Component: GSG DSG 082 1405
Revision: 04808020 Serial number: 00000802130110
Shop #: WSC 01035 444 52584
VCID: 52FD87A318E36C5B0D6-8006
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
Shop #: WSC 01269 785 00200
VCID: 72BD2723B8A30C5BED6-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 79AF100FE5D57F03ACC-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007318295
Coding: E68F8F2140041500470A00000A00000000097B0F5C000100000000000000
Shop #: WSC 94825 999 52571
VCID: 71BF282FBDA5374314C-8024
Component: Wischer 040707 021 0501
Coding: 00040853
Shop #: WSC 94825
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 070707 046 0204
Coding: 00469790
Shop #: WSC 94825
00380 - Special Vehicle Control Module (J608)
Reset counter: 15
Mileage: 145765 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.05 V
Reset counter: 15
Mileage: 145765 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.05 V
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
Reset counter: 15
Mileage: 145765 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.80 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0098611
VCID: 2E05F3536C1B68BB49E-807A
Fault Frequency: 21
Reset counter: 87
Mileage: 142547 km
Time: 03:16:45
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6T AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D091GGW
Coding: 0013908
VCID: 6C81395B9A87DAAB27A-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME1C184906C
Subsystem 3 - Serial number: 6342MSME1B6C5849S
Subsystem 4 - Serial number: 6352QSME2E36247DS
Subsystem 5 - Serial number: 6362QSME3150327DC
Subsystem 6 - Serial number: 63727SME0D470166/
Subsystem 7 - Serial number: 63827SME0D47004E3
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 055 0111
Coding: 0000132
VCID: 7AAD0F03E0D3741BA56-802E
00895 - Cruise Control Switch (E45)
014 - Defective
01426 - Controls in Steering Wheel (E221)
00888 - Wiper Switch for Intermittent Operation (E22)
Part No SW: 1K6 920 974 D HW: 1K6 920 974 D
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G53NT7Q7
Coding: 0007203
Shop #: WSC 01287 067 57207
VCID: 3537DC3F894D5B63084-8060
Reset counter: 15
Mileage: 145765 km
Time: 00:36:28
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 020707F1000022
Coding: FF0F036307000000
VCID: 2F3BEE576B1161B3428-807A
Fault Status: 00110100
Reset counter: 14
Mileage: 145765 km
Time: 00:36:29
Reset counter: 14
Mileage: 145765 km
Time: 00:36:29
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 3635DB33944B507B01E-8062
Component: IMMO VDD 1216
Address 3D: Special Function Labels:. 1F9-909-919.lbl
Part No SW: 1F9 909 919 B HW: 1F9 909 919 B
Component: MultifunctionDevice 0072
Revision: 00H03000 Serial number: 00000000000765
Coding: 21807B
VCID: 372BD6379341A9731A8-8062
Subsystem 1 - Part No: Unknown
Component: Slave HW Part
02071 - Local Databus
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120A
Coding: 0001077
Shop #: WSC 01279 785 00200
VCID: 3829D50B9E5FA60B132-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.141 H08 1901
Shop #: WSC 00000 028 00001
02546 - Steering Limit Stop
Temperature: 8.0°C
Voltage: 12.00 V
Voltage: 11.80 V
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 1B900E885103483F2D02058FB0080A0488BC00
Shop #: WSC 01287 785 00200
VCID: 045171FB921732EBCFA-8050
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 230
Mileage: 145765 km
Time: 00:07:46
Reset counter: 15
Mileage: 145765 km
Time: 00:36:29
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000137236
VCID: 2A0DFF4350F3049B956-807E
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 392FD00FA555BF03ECC-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000004
VCID: 74B1213BC2B7026BFFA-8020
Part No SW: 6RD 035 187 B HW: 6RD 035 187 A
Component: Radio 541 5614
Revision: -------- Serial number: VWZZZ4Q5103558
Coding: 0E000400040005
Shop #: WSC 00046 123 12345
VCID: 46D5ABF3E8ABC0FB91E-8012
Fault Status: 00111011
Reset counter: 230
Mileage: 145765 km
Time: 00:06:50
00875 - Treble Speaker Front Right (R22)
Reset counter: 230
Mileage: 145765 km
Time: 00:06:50
Reset counter: 230
Mileage: 145765 km
Time: 00:06:50
00877 - Treble Speaker Rear Right (R16)
Reset counter: 230
Mileage: 145765 km
Time: 00:06:50
Reset counter: 230
Mileage: 145765 km
Time: 00:06:47
Reset counter: 230
Mileage: 145765 km
Time: 00:20:37
End----(Elapsed Time: 01:28, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
