Monday,28,November,2022,14:59:09:01862
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 22.10.0.1 (x64)
VIN: 3VWDT81K16M746502 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 56 62 72 7D
VIN: 3VWDT81K16M746502 Mileage: 516340km-320838miles
03- Brakes -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E3111505
Coding: 0050071
Shop #: 66565 257 00032
VCID: 63EB6714A252FE95FF-8036
VINID: 0E69D490805B0467471061400844DDDCD6
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Mileage: 516342 km
Time: 17:07:24
RPM: 1596 /min
Speed: 40.0 km/h
Temperature: 27.0°C
(no units): 1032.0
Mass Flow: 21.33 g/s
(no units): 2.59
Temperature: 70.2°C
Address 03: Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021122
Shop #: 00066 000 00000
VCID: 71C71D5C68AE5C057D-8024
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
Shop #: 00000 000 00000
VCID: 6BFB0F344A82B6D547-803E
00229 - Refrigerant Pressure
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000237219
Coding: 04018E234004180000140000001400000028770B5C
Shop #: 22599 444 57643
VCID: 2B7BCF348A0276D507-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: 22599
Fault Status: 00101100
Fault Frequency: 238
Reset counter: 52
Mileage: 479937 km
Voltage: 13.50 V
Fault Frequency: 13
Reset counter: 67
Mileage: 516015 km
Voltage: 14.10 V
Fault Status: 00101010
Reset counter: 52
Mileage: 516019 km
Voltage: 14.15 V
Reset counter: 52
Mileage: 516015 km
Voltage: 14.20 V
Reset counter: 69
Mileage: 516015 km
Voltage: 12.80 V
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E1040423
Reset counter: 52
Mileage: 384057 km
Time: 22:54:00
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 38 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD03BBN1
Coding: 0013112
VCID: 3957E57C705ED44585-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0D00157A7
Subsystem 3 - Serial number: 6342MSME0C590471A
Subsystem 4 - Serial number: 6351HSME086F5D0AO
Subsystem 5 - Serial number: 6361HSME087B61135
Subsystem 6 - Serial number: 63727SME0843547F6
Subsystem 7 - Serial number: 63827SME084A1409/
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01218 - Side Airbag Igniter; Passenger Side (N200)
002 - Lower Limit Exceeded - Intermittent - MIL ON
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002021
VCID: 7AD53A7035D81F5DCC-802E
Component: E0221 007 0050
015 - Cannot Be Tested at this Time - MIL ON
Part No: 1K0 920 972 L
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: 22599 444 59177
VCID: 354FE94C5C46302561-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105B0686AE
Coding: 3D7F0B600F1002
VCID: 2A75CA3085F86FDDFC-807E
Reset counter: 69
Mileage: 516015 km
Time: 00:46:35
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T0L1G01
Coding: 0000003
Component: IMMO 3HL 4312
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C79CC288F0C71ED0E-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 364DEE4041403B3D68-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3245D250AD28271D44-8066
Mileage: 6000 km
Temperature: 17.0°C
Voltage: 12.70 V
Voltage: 12.50 V
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 12900E880106083F2904058FB0080F0680A540
VCID: 022542905D08579D94-8056
Reset counter: 205
Mileage: 411423 km
Time: 05:26:22
Address 52: Door Elect, Pass.
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio DE2 011 0014
Revision: 00011000 Serial number: VWZ4Z7E2035994
Coding: 0010400
VCID: 20612818F3C4A58DA2-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 3147DD5CA82E1C053D-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Component: -Element 0404
VCID: 2D7FC12CB41678E519-8078
End-------------------------(Elapsed Time: 01:25)--------------------------
