Disable HSA on VW transporter T5
andlan
Norway
C?ID=185485
Does anyone know how to disable HSA (Hill Start Assistant) on a VW Transporter T5, or if it's even possible?
I tried to enter into «03-ABS Brakes» and «coding-07» but I don’t seem to get any checkboxes on any of the bytes.
Below is a full autoscan of the vehicle.
Friday,10,July,2015,22:52:33:23081
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN:                     License Plate:
Mileage: 54780km-34038mi   Repair Order:
Chassis Type: 7H (6N0)
Scan: 01 03 08 09 15 17 18 19 22 25 56 69 6E 0B
VIN: WV1ZZZ7HZCH030569   Mileage: 54780km-34038miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DK    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9135
   Revision: 26H43---    Serial number: 00000000000000
   Coding: 0119401A231600080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019DK 002007
   ROD: EV_ECM20TDI01103L906019DK.rod
   VCID: 77FDA708CE976D995F5-8022
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 708724AD91A70E9524A78977696710
   Shop #: WSC 02736 790 49152
   VCID: 377D67088617AD999F5-8062
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E5 907 047 AS    HW: 7E5 907 047 AS
   Component: Climatic-T5   H19 0404
   Revision: 00001008
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 000FCCD49B592A216EF-8055
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 086 H    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0251
   Revision: BM047001    Serial number: 0428 229110495
   Coding: A0A0393A0E212013002008102C2B8CD40010430F60060000300000000000
   Shop #: WSC 02736 790 00000
   VCID: 387F64348B09A2E196F-806D
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  002 3311
   Component: VW10Airbag003 H06 0013
   Revision: --------    Serial number: 003HL007183H
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_SK12.rod
   VCID: 35616D00941B5F898D9-8060
   Part No SW: 7E0 920 860 E    HW: 7E0 920 860 E
   Component: KOMBI         H04 0305
   Coding: 160000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 2A5B4E7C4DA5007110B-807F
   Coding: 160000
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 819 008 D
   Component: J737__Standheizung  0605
   Revision: 00084000    Serial number: 09019169F00000
   Coding: 0001322
   Shop #: WSC 15695 000 1048576
   VCID: 2A5B4E7C85A5007110B-807F
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 H47 0251
   Revision: BM047001
   Coding: 042200
   VCID: 70EF9C14A3F93AA19EF-8025
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000009
   VCID: 377D67084617AD999F5-8062
   Component: IMMO          H04 0305
   VCID: 6ADB8E7C8D25C071D0B-803F
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  032 0079
   Revision: 01000001    Serial number: VWZ1Z2L3477879
   Coding: 05000200020014
   Shop #: WSC 02734 790 00000
   VCID: 33655318926F41B9A3D-8066
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Revision: 3A001001    Serial number: 00000154793578
   Coding: 410D000100000000
   VCID: 306F5C1463797AA1DEF-8065
Address 6E: Ctrl Head Roof (J702)       Labels: None
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0175
   Revision: 10100010    Serial number: 213999
   Coding: 000203
   VCID: 35616D009C1B5F898D9-8060
End-------------------------(Elapsed Time: 02:05)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
Out of curiosity....Why would anyone want to disable it?
andlan
Norway
C?ID=185485
Your guess is as good as mine :-P
It's a colleague's car, and he think it's really annoying when he tries to park in hill.. He says that when he backs up uphill he can't get a smooth start, when he releases the clutch the brakes hold it back and suddenly release causing the car to jerk backwords..
So I thought I'd help him out if possible
NZDubNurd
New Zealand
C?ID=230482
This is true - our 2013 4motion biturbo is like that - it can be really awkward at times, and a proper hill start is often easier! The results are quite variable you never really know how much it will hold, and doesn't seem to be based on how hard you push the brake either.
NEtech
Denmark
C?ID=56995
Have you tried Adaptation channels 058 (059), with latest VCDS beta ?
andlan
Norway
C?ID=185485
sorry, went on vacation just after posting this..
Will try this tomorrow, I'll keep you updated
