Hello!
I installed a front camera on my B8 and I have an error on the camera and I can't figure it out!
I have attached the VCDS log:
I kept looking and it seems to be related to the ACC sensor.
The wiring I installed was taken from Aliexpress and did not come with a cable to the ACC sensor, so I connected 2 UTP wires from pin 1 and 8 of the camera to pins 5 and 6 of the ACC according to the wiring diagram.
Moreover, if I activate module 13 (ACC) byte 3 bit 6 (front camera), I have two errors there:
I checked the wiring, it's fine.
Can you help me?
Saturday,26,November,2022,15:59:56:44863
VCDS Version: 22.10.0.1 (x64) HEX-NET CB: 0.4623.4
VIN: WVWZZZ3CZGE015947 License Plate: CT01NLE
Gateway Installation List: 5Q0 907 530 AF
17-Instruments -- Status: Malfunction 0000
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 5F A5
VIN: WVWZZZ3CZGE015947 Mileage: 283689km-176276miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2.0l TDI H21 1990
Revision: B5H21--- CVN: 49FF1F44
Coding: 011D001A03641D083000
Shop #: WSC 36986 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
ROD: EV_ECM20TDI01104L906026FL.rod
VCID: 004CAB479BAC3C8D82-8054
VINID: 9E69EAAAA0D3A975400452441C362DCE2A
Part No SW: 0D9 300 041 A HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4801
Revision: 06253104 Serial number: TFK01505102026 CVN: 000098E9
Shop #: WSC 05311 115 00092
ROD: EV_TCMDQ250021.rod
VCID: 1660ED1FE928A23D48-8042
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61565000002471
Coding: 0FEC6A8F34210B710780060441CA49F0562CD0E0608292F11862F078C202
Shop #: WSC 00015 115 00001
VCID: 7AB8D9AFFD70665DCC-802E
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0709
Revision: 00026000 Serial number: 0370807116
Coding: 000F0F0703
Shop #: WSC 05311 115 00303
ROD: EV_KessyHellaMQBAB.rod
VCID: 393A06A3B8F6AD4585-806C
Part No SW: 5G0 907 044 BH HW: 5G0 907 044 BH
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020104204101011015504000101802
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 6E90E5FFB1383AFD60-803A
Air quality sensor:
Humidity sensor: exterior:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AJ HW: 5Q0 937 086 AJ
Revision: -------- Serial number: 86582005151061
Coding: 00011846C2C102FF4FE44004011407081C80000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 0248A14F95A02E9D94-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150516 042 0607
Serial number: 150527114929
Component: RLHS 037 0059
Serial number: S5Y15M06D07H23M29S24
Coding: 90A8DD
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 16 04 2015 00000057
Humidity sensor: interior:
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391514902917
Coding: 0071051811
VCID: 44C46757CF34E0ADE6-8010
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Coding: 3200670251FFC428949C804D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 342437979F94502D56-8060
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPB8XF6T
Coding: 88CCC000008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F4E28BBE6524375FB-802A
Subsystem 1 - Part No SW: ----------- HW: 454 002 305 15
Serial number: 3576U00000057599A41F
Subsystem 2 - Part No SW: ----------- HW: 454 002 005 15
Serial number: 3586U00000006699A41B
Subsystem 3 - Part No SW: ----------- HW: 454 803 105 15
Serial number: 3516RFFE22907000000K
Subsystem 4 - Part No SW: ----------- HW: 454 803 005 15
Serial number: 3526R2DF62907000000B
Subsystem 5 - Part No SW: ----------- HW: 454 801 605 15
Component: FrontSensor_D 114 0149
Serial number: 3556VF54456060000009
Part No SW: 5Q0 953 569 A HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: -------- Serial number: 20211110400079
Coding: 0410
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C341FB7B7C4986D9E-8068
Part No SW: 3G0 920 741 A HW: 3G0 920 741 A
Component: KOMBI 201 6421
Coding: 07A5091867800008008A7B0B1000000000000000
VCID: 2208C1CF3560CE9DB4-8076
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 E HW: 5Q0 963 272 E
Component: STH-MQB 007 0072
Coding: 9309
VCID: 383C03A783FCB44D7A-806C
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001144601
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 26051510800471
Coding: 0B0300045F017300FB0002581C0F00010001070000000000000000000000
GVL: 01543C0000000600408C80000004C80000000000000000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 75A2CA93D46E0925A1-8020
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 38150000024700025223
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 2251656503
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H54 0033
Serial number: 0076215
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000011581006
Coding: 0800000000000000
Shop #: WSC 00015 115 08193
ROD: EV_ELVMarquMQBB.rod
VCID: 71AAFE83A00625057D-8024
Component: TSG FS 020 0041
Serial number: 110515BCT18344
Coding: 00350B208000020000001000
VCID: 43C6644BCA3AE795DF-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001530717
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 203 2033
Revision: 00000000 Serial number: 0000256692
Coding: 01000011005000
Shop #: WSC 00015 115 00303
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
VCID: 3B361CABB2CA9F5597-806E
Component: TSG BFS 020 0041
Serial number: 130515BED02251
Coding: 003501208C00020000001000
VCID: 42C8614FD520EE9DD4-8016
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001539642
Coding: 090000
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0633
Coding: 02840201FF00000051110001000808031F0200D401200100CF
Shop #: WSC 05311 115 00018
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H52 1031
Serial number: VWZ8Z9REN002N1
Subsystem 2 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
7193 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 175
Mileage: 283683 km
Date: 2022.11.20
Time: 10:32:58
Voltage terminal 30: 14.0 V
BAP-BAP_Function_ID: 02
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 12071711K23740
Coding: 0004080200000401002413448140A90080000E010020
Shop #: WSC 33361 790 00165
1 Faults Found:
1122597 - Local Data Bus
U1169 00 [009] - Missing Message
[Timeout_RDR1_Header]
Reset counter: 135
Mileage: 283689 km
Date: 2022.11.20
Time: 15:58:57
Control Module temperature: 41 °C
Outside temperature: 16.5 °C
Vehicle speed: 0.00 km/h
System run time: 1798.6 s
Voltage terminal 15: 11.8 V
mid: 01 43
Status of camera: System malfunction
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
End----(Elapsed Time: 02:00, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
1236 - Databus
[FAULT_TIMEOUT_BV1_POSITION]
Reset counter: 135
Mileage: 283689 km
Date: 2022.11.20
Time: 15:16:12
Control Module temperature: 31 °C
Voltage terminal 15: 12.2 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
1232 - Databus
[FAULT_VIDEO_SIGNAL_LIST]
Reset counter: 135
Mileage: 283689 km
Date: 2022.11.20
Time: 15:16:12
Can you help me?
