- Apr 20, 2022
- 12
- 1
- Kiel, Germany
- C?ID=511575
after I retrofitted ACC and the front camera I would like to replace my monochrom cluster to colour.
Is anyone here who did this before?
I´m a bit scared that I choose the wrong instrument cluster because there are so many different kinds. (is the immobilizer the same generation?)
In the autoscan you can see my actual one. Can someone tell me the right part number?
Is the coding the same as in the actual one? And is the plug the same?
Thanks for your help!
Saturday,26,November,2022,16:21:49:20476
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: WAUZZZ8V4H1040179 License Plate:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 52 55 5F 6C A5 BB
BC D6 D7
VIN: WAUZZZ8V4H1040179 Mileage: 53155km-33028miles
Address 01: Engine (J623-CHZD) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 AB HW: 04C 907 309 AE
Component: R3 1.0l TFS H25 3494
Revision: W1H25--- CVN: 0F777929
Coding: 02190032234401082000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_ECM10TFS01104C906026AB 002006
ROD: EV_ECM10TFS01104C906026AB_002.rod
VCID: 619EA65C41CD55C384C-8034
VINID: 9D196AAAA226118040100047246D029FBF
Part No SW: 5Q0 614 517 AR HW: 5Q0 614 517 AG
Component: ESC H62 0642
Revision: 00000000 Serial number: 63046000001108
Coding: 13F16AA22424126C4B780E0740CC25C8562448D27002A4731443F0788028420000000012121212B835351919323200
VCID: 015E86DCA18DF5C3E4C-8054
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001084545
Coding: 03000003000000001000000000001000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
VCID: 40D843D8EA073CCBAB2-8014
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 0D99C65800PAG0MUFU03
328964 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator Stuck
Reset counter: 248
Mileage: 53026 km
Date: 2022.11.21
Time: 14:23:10
Voltage terminal 30: 14.8 V
Inside temperature: 23.8 °C
Outside temperature: 2 °C
Front air distribution flap: actual value: 0
Front air distribution flap: actual value: 96.0 %
Air distribution door front - Specified value: 96
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001629601059
ROD: EV_BCMBOSCH_017.rod
VCID: 7EA4FD20D0738A3B99E-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160829 043 0585
Serial number: 160905190931
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62394955
Coding: 03006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 17 08 2016 00001391
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Component: PDC 8 KanalH08 0044
Serial number: 000150058321054
Coding: 0470551801
VCID: 4BC264F4D341EF934E0-801E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 R HW: 5Q0 907 572 J
Component: ACC BOSCH MQB H11 0771
Coding: 2D1978E2D7FFCF08979F812561402400000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 003014
VCID: 46D455C0C82312FB91E-8012
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2AMNGG
Coding: 98CCC0000C0000005C5400CA004800000065
VCID: 1078B398FAE78C4B7B2-8044
Subsystem 1 - Part No SW: ----------- HW: 480 002 810 16
Serial number: 357000000009D375DE1.
Subsystem 2 - Part No SW: ----------- HW: 480 002 810 16
Serial number: 35800000000EC375DE1%
Subsystem 3 - Part No SW: ----------- HW: 480 402 710 16
Serial number: 3510001AF2280CC633DA
Subsystem 4 - Part No SW: ----------- HW: 480 402 710 16
Serial number: 3520001A522BF354B755
Subsystem 5 - Part No SW: ----------- HW: 480 401 810 16
Serial number: 35500029D22E8E126077
Subsystem 6 - Part No SW: ----------- HW: 480 402 010 16
Component: PedP_Sensor_D 000 6149
Serial number: 22800019B229A9E42559
Subsystem 7 - Part No SW: ----------- HW: 480 402 010 16
Component: PedP_Sensor_P 000 6149
Serial number: 22900019B229A9E6738I
Subsystem 8 - Part No SW: ----------- HW: 480 001 310 16
Serial number: I0M00000000A18893A14
Subsystem 9 - Part No SW: ----------- HW: 480 001 310 16
Serial number: I0N00000000528893A11
Part No SW: 8V0 953 521 JD HW: 5Q0 953 549 E
Revision: -------- Serial number: 05111604400520
Coding: E008
VCID: 055692CCB5A5D9E3D84-8050
Part No SW: 8V0 920 861 C HW: 8V0 920 861 C
Component: KOMBI H03 8316
Coding: 07C51A006F8400080080EF031000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 3B22343483E15F13FE0-806E
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 515 5286
Serial number: 02111610522301
Coding: 030100043F0857005B000258000B00000001010000000000000000000000
GVL: 01543C0000000000408C90000002480000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F3A10644799B3B3428-807A
Generator:
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0003
Serial number: 20161102043903 20575
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001611032193
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H06 0016
ASAM Dataset: EV_LCMLeftCONTIAU426 001008
VCID: 42DC49D0E40B2EDBBD6-8016
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001008
Component: TSG FS 020 0041
Serial number: 131016EJD22377
Coding: 001C8B205000040000001003
VCID: 43D24CD4FB1127D3B60-8016
Component: EPS_MQB_ZFLS 129 1072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D652CCF52519E3984-8010
Component: TSG BFS 020 0041
Serial number: 241016EJN02356
Coding: 001C83205C00040000001003
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V1.clb
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Coding: 0ECA00102B230200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E243D2090F34A3BD9E-806A
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGS2.clb
Part No SW: 81A 035 192 B HW: 81A 035 192
Component: MU-HS-LND-EU 045 0170
Coding: 01730101FF0A000011111101000A00102F002A4401F00100CE
ROD: EV_MUHigScl6C3DELP.rod
VCID: 2018E3580A471CCBCB2-8074
Subsystem 1 - Part No SW: V03 959 803 PP HW: -----------
Component: ECE 2022/2023 --- 0061
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY208B86
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL120101600010407
Component: RVC Compact H18 0231
Coding: 0273000102002001400040
VCID: 392E2E3C89DD6D03ECC-806C
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 211
Mileage: 53060 km
Date: 2022.11.22
Time: 17:20:00
passive
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H13 0610
Serial number: 17022011K24851
Coding: 040307030000040101221344804E850098000E20002000
ROD: EV_MFKBoschMQBB_002.rod
Component: TSG HFS 020 0041
Serial number: 181016EJH14568
Coding: 000C83204000040000001003
Component: TSG HBFS 020 0041
Serial number: 181016EJH14566
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176AC884DF095B733A8-8042
Component: LED1R H09 0008
End----(Elapsed Time: 01:37, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
