00003 - Control Module 005 - No or Incorrect Basic Setting /Adaption Help
Ward360
South Florida, USA
C?ID=44489
Hello, first post, but am at a loss. Have a 2010 Golf GTI in the shop. It was diagnosed some time back as needing a new ABS module. I have done a couple of these before without a problem. The problem I am having is on Channel 026. No errors and able to use the brake pedal to match what the value the software is displaying. Was able to calibrate channel 025 in less than 5 mins. Have tried doing the calibration on Channel 026 multiple times without it ever completing. Today we ran the calibration for 20 mins without success. Below is the last Scan. No visible brake fluid leaks. Bled a second time and the rear pads are worn to the thickness of the pad backing plate. Waiting on the engine and ECU to cool again. I have seen where others have had this same problem, but no solutions I could find. Using a Ross Tech dongle and current VCDS software. Thank you for any assistance.
Friday,25,November,2022,10:38:25:34808
VCDS Version: 21.9.0.2 (x64)
VIN: WVWEV7AJ9AW271192   License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 65 77
VIN: WVWEV7AJ9AW271192   Mileage: 81210km-50461miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AM    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH11---    Serial number:
   Coding: 0403010A18070160
   VCID: 71E98C24682EE201BE-8024
   VINID: 9E69D598745A2519C21C104908CEB169CE
Readiness: 0000 0001
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H31 0107
   Revision: 00H31001
   Coding: 114B600C492900FB880C06ED921B0041300800
   VCID: 78FFB100CB54B34979-802C
                    Fault Status: 01100101
                    Reset counter: 128
                    Mileage: 81212 km
                    Date: 2017.04.17
                    Time: 10:35:02
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 143
                    Count: 43776
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75E1B834D446CE2162-8020
   Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
   Component: BCM PQ35  H+  103 0576
   Revision: 00103 AF
   Coding: 6D180A1A90272A0480080081700005C441010086534D8D60648020200000
   Shop #: WSC 05064 444 10367
   VCID: 356178349CC68E21A2-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 17120  21  0512
   Coding: 009795
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4D0A8L6Y
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 39797404B8DE6A4146-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0004YJGV00
   Serial number: 3572MSME432D004FZZZY
   Serial number: 3582MSME3679354EZZZ2
   Serial number: 3512QSME383F4477ZZZ%
   Serial number: 3522QSME3A284600ZZZP
   Serial number: 35527SME650B511FZZZK
   Serial number: 35627SME0C4B421FZZZQ
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78FFB1000B54B34979-802C
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5K6 920 970 H    HW: 5K6 920 970 H
   Component: KOMBI         H03 0305
   Coding: 270F00
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 050110F2000752
   Coding: E9801F07001612000000
   VCID: 69D9E44440FE1AC1F6-803C
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T76P904
   Coding: 0000002
   VCID: 7EF3A71829708D7933-802A
   Component: IMMO          H03 0305
   VCID: 6ADB9B488DF811D9FF-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667733962
   VCID: 2643AF785160F5B91B-8072
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2111
   Coding: 0001076
   VCID: 31694C24A8AEA201FE-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001076
   VCID: 326B4328ADA8991987-8066
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7J1139000
   Coding: 0100040004
   VCID: 61C9FC6478CE52812E-8034
                    Reset counter: 125
                    Mileage: 81203 km
                    Date: 2017.04.17
                    Time: 17:59:23
                    Reset counter: 125
                    Mileage: 81203 km
                    Date: 2017.04.17
                    Time: 17:59:23
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           103 0521
   Coding: 018705
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000329389176
   Coding: 412100
   VCID: 2A5B5B484578D1D93F-807E
End-------------------------(Elapsed Time: 02:16)--------------------------
Westbury, UK
It probably won't make any difference, but please clarify which Ross-Tech cable you are using (HEX-CAN, HEX-V2, HEX-NET,...) and the software you are using is actually a year old - the latest version is 22.10 (updates are free to registered users).
Ward360
South Florida, USA
C?ID=44489
Thank you for taking the time to reply. After posting yesterday, I bled the hydraulic brake system another time. Upgraded the software to the current version. To eliminate heat build up, used a vacuum pump to assist the booster so I could run the test without the engine running. Once again only 025 would complete. 20 mins for 026 and it never completed. It does seem to repeat 3 combinations after a point. I’ve also seen <000 000> but no “calibrated”. To eliminate the laptop and VCDS software, used our Alltel scanner. Same result. 025 calibrates. 026 never calibrates and is an endless loop. One more thing I noticed is the On/Off/Next button does not end the calibration routine after 025 completes. I have to exit. Shutdown the car. Restart the car. Security login and then basic settings 026 again. The On/Off/Next button works to start the calibration just as with 025. I did come across a note regarding this.
I’ll post which dongle I am using when I get in later this am. As far as the version, I’m often prompted to update, but don’t always have a vehicle to connect to to complete the install. Watching updates, it seems to delete existing files and install replacements. On more than one occasion I updated and sure enough the next vehicle doesn’t connect. It’s rare and we work on some vanagons with TDI conversions.
I’m leaning towards a problem with the new module. I did not install the new one. I was just asked to program it. I’m wondering if the correct module was ordered. Unfortunately I can’t see the part number label installed, but will compare the original ECU to the part number on the box. I’ll update what I find this am. I’ll also post a new auto scan. I’m also thinking about plugging in the original ECU and running auto scan again. Also bleeding the brakes, I noticed the rear pads are worn to the thickness of the brake pad backing. The owner tows this car behind a motorhome. He has a brake pedal actuator on the floor. The motor home has an ECU to operate a vacuum pump to assist the servo and operates the brake pedal under braking. It’s independent of the vehicle CAN system. Thanks again. Mark
Westbury, UK
You don't need to be connected to a vehicle to do an update, you just need an internet connection and the VCDS cable plugged into the PC - no need for it to be connected to a vehicle.
Ward360
South Florida, USA
C?ID=44489
Ok, the Dongle is Ross Tech HEX + CAN Dual -K CAN USB. After the software update, you are required to test and save the connection. So, the connection is to the dongle not the actual communication to the vehicle. I'll have to try that next time.
Still scratching my head and thinking outside the box. I did find one thing that was missed. The ECU was ordered by application. It was not ordered by part number. The original ECU part number is 1K0 907 379 AH. The replacement ECU part number on the box is 1K0 907 375 AH. I cannot see the module label with the ECU module installed. I am working between a laptop and posting on my workstation.
Google searching I don't see that that one supersedes the other. In fact, my experience the higher number would be the newer one. But here is where it gets confusing. I checked my original scan and then my last scan. For some reason, the ECU part number looks identical in both scans. Would long coding change the ECU part number? There does seem to be 2 different revision numbers in the two scans. We can remove the module and visually check the part number to be sure, but the owner needs to leave the beginning of next week and I doubt we could even get the correct ECU and if that is even going to fix the problem. Could there be a physical problem that would allow 025 to complete, but not 026?
First Scan with original ECU
Wednesday,23,November,2022,10:23:20:34808
VIN: WVWEV7AJ9AW271192   Mileage: 81200km-50455miles
               U1017 - 015 -
                    Fault Status: 01101111
                    Mileage: 80973 km
                    Date: 2017.04.15
                    Time: 16:36:39
                    RPM: 765 /min
                    Load: 21.6 %
                    Temperature: 60.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
               U1017 - 000 -  - Intermittent
                    Fault Frequency: 11
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 54.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.319 V
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
                    Reset counter: 124
                    Mileage: 80984 km
                    Date: 2017.04.15
                    Time: 10:05:10
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 128
                    Count: 42752
                    Count: 1024
                    Fault Status: 01101100
                    Reset counter: 84
                    Mileage: 80973 km
                    Date: 2017.04.15
                    Time: 16:49:21
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 64
                    Count: 49408
                    Count: 512
                    Reset counter: 84
                    Mileage: 80973 km
                    Date: 2017.04.15
                    Time: 16:49:21
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 48
                    Count: 49408
                    Count: 512
   Revision: 00009001
   Coding: 0000001002
   Revision: 00103 AF
   Coding: 009795
   Coding: 00003031
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 44
                    Reset counter: 124
                    Mileage: 80973 km
                    Date: 2022.11.23
                    Time: 16:36:00
   Coding: 0000532
   Coding: 00000130
   Coding: 270F00
   Coding: 0000002
   Coding: 0001076
   Revision: 00H17000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 84
                    Mileage: 80973 km
                    Date: 2017.04.15
                    Time: 16:49:21
                    Voltage: 13.75 V
                        DU
                    Temperature: 42.0°C
                    RPM: 845 /min
   Coding: 0001076
   Coding: 0100040004
                    Reset counter: 83
                    Mileage: 80973 km
                    Date: 2017.04.15
                    Time: 16:35:18
                    Reset counter: 83
                    Mileage: 80973 km
                    Date: 2017.04.15
                    Time: 16:35:18
   Coding: 018705
   Coding: 412100
End-------------------------(Elapsed Time: 02:19)--------------------------
Last Scan Today.
Saturday,26,November,2022,11:32:29:34808
VCDS Version: 22.10.0.1 (x64)
VIN: WVWEV7AJ9AW271192   Mileage: 81230km-50473miles
   VCID: 71E98C24682EE2057D-8024
   Revision: 00H31001
   VCID: 78FFB100CB54B34DBA-802C
                    Reset counter: 128
                    Mileage: 81223 km
                    Date: 2017.04.18
                    Time: 16:01:30
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 143
                    Count: 42240
   Revision: 00009001
   Coding: 0000001002
   VCID: 75E1B834D446CE25A1-8020
   Revision: 00103 AF
   VCID: 356178349CC68E2561-8060
   Coding: 009795
   Coding: 00003031
   VCID: 39797404B8DE6A4585-806C
   Coding: 0000532
   VCID: 78FFB1000B54B34DBA-802C
   Coding: 00000130
   Coding: 270F00
   VCID: 69D9E44440FE1AC535-803C
   Coding: 0000002
   VCID: 7EF3A71829708D7DF0-802A
   VCID: 6ADB9B488DF811DD3C-803E
   VCID: 2643AF785160F5BDD8-8072
   Coding: 0001076
   VCID: 31694C24A8AEA2053D-8064
   Revision: 00H17000
   Coding: 0001076
   VCID: 326B4328ADA8991D44-8066
   Coding: 0100040004
   VCID: 61C9FC6478CE5285ED-8034
                    Reset counter: 128
                    Mileage: 81212 km
                    Date: 2017.04.18
                    Time: 10:38:20
                    Reset counter: 128
                    Mileage: 81212 km
                    Date: 2017.04.18
                    Time: 10:38:20
   Coding: 018705
   Coding: 412100
   VCID: 2A5B5B484578D1DDFC-807E
Thank you for getting this far. Mark
Old:
Revision: 00H30001
New:
Revision: 00H31001
Both are 1K0 907 379 AH, but the new one is newer hardware revision: H31 vs H30 for the old.
Ward360
South Florida, USA
C?ID=44489
So, don't worry about the part numbers on the box? I'm drawing straws at this point. Looking for anything that may have been missed.
To clarify, I cannot complete the channel 026 calibration Hydraulic Unit Disconnecting Valves. I'm using this documentation for coding and setting ABS module. Brake Electronics I've also watched the Ross Tech YouTube video a few times. I'm open to suggestions at this point. Thank you. Mark
NEtech
Denmark
C?ID=56995
Where does MB 026 not complete, please post a screenshot.
What text or numbers are showed?
You are 100% sure, the brake tubes/pipes are not switched?
Ward360
South Florida, USA
C?ID=44489
Hello, 026 does not complete. No error. Have attempted to calibrate 5 times over 3 days. Have done each attempt for 20 mins. The software keeps offering pressure values to hit. After the value is hit with the pedal pressure, a new range is offered. After a long period of time, we notice it seems to offer the same 3 ranges.
I had the tech check that the pipes were in the correct ports. She took a picture before removing them.
I could post a screenshot, but it looks exactly like in the video. Where do I upload a photo to link? Don’t seem to have the option to insert a photo from my iPhone.
The problem is I don’t know enough about how it calibrates to mechanically find something wrong. I know it’s not the communication or the software because I replicated it with our Autell scope. Same result 025 completes. 026 would run all day. Seems from reading 5 mins should be adequate, but 20 min attempts to be sure.
Thankyou for trying.
NEtech
Denmark
C?ID=56995
Ward360
South Florida, USA
C?ID=44489
For pictures I could see they needed to be hosted offsite. Other forums don’t like when members link off site for photos. The links can break, which renders some threads useless.
On my phone, imgur doesn’t appear to be a photo storage. It looks like some sort of “feed” I’ll look for a solution this am.
As far as the actual problem. Ross tech has a how to video for basic settings channel 025 and 026. I’m seeing in my software exactly what is in the video with the exception of 2 problems. 026 never completes. 025 does complete. The other problem is the “on/off/next” button only turns the calibration on for either channel. It does not turn off when clicked after 025 completes.
EDIT: tried linking photo from Shutterfly and Google. Get an error image can not be loaded from the passed link. https://photos.app.goo.gl/aCmGjnPCPo9G7BfMA
Which just goes to prove that your iPhone is a poor substitute for a real computer. Why not do this from the computer you're using for VCDS? Alt+PrintScreen will copy the active window to the clipboard, from where you can past it straight into Imgur.
Copied to Imgur:
EuroX
Northern NJ USA
C?ID=208579
The correct part number of the ABS module that you need and what the vehicle should have is :1K0907375AH. What you have installed is 1K0907379AH. It is a direct replacement as far as I know. Are you sure your holding steady pressure with no leaks?? I have seen people cross thread the fittings on the abs block numerous times.
Ward360
South Florida, USA
C?ID=44489
The picture was taken by the phone, not for upload. The picture was for another reason. Thank you for moving and linking. I’ve been using VCDS for years. This was the first time I needed a login for the forum. So, I apologize for not being an expert out of the gate. Also. the owner wants their car back. It was supposed to be quick turn around. So I’m under pressure this time.
As far as brake fluid leaks. I checked the fittings and they are dry. I also inspected the underside to see if maybe ecu didn’t seal to the valve body. Nothing dripping. I also bled the brakes a second time so I could see that all air is removed. I didn’t install the module.
As far as the part number. The box had the label for 375 AH stuck over another label but the software was reporting 379 AH for both ECUs. I did not see the part number on the ECU before it was installed. From memory the ECU is ATE, but made in China. At this point I am suspect of the new part. While not happy, the owner is leaving with the car and will live with the traction control error light. They were more concerned that the airbags were disabled by the communication issue with the ABS. That seems to be resolved. I feel bad, but they live 5 hours away. I don’t like giving up on a problem. I’ve never let a vehicle beat me. We are going to look into a complete assembly tomorrow. The unbilled time would likely have covered the cost of a complete assembly. Thank you to those that did try to contribute.
EuroX
Northern NJ USA
C?ID=208579
Honestly if the old module had failed. I think your best bet would of been to send the original out for a rebuild. There is a few place that rebuild these units. Hell I used to rebuild them myself at one point. However I suspect its possible you have a ABS unit thats been reflashed with the correct part number for the vehicle but was originally a different unit possibly with different components inside.
Ward360
South Florida, USA
C?ID=44489
I was dragged in just to code the new one. Should have been an hour max. It was diagnosed back in July not by me the last time the car was in the area. The module had been ordered back then. Having the car down was just not an option at the time. They come to this area a few times a year. Basically a perfect storm brewing for 6 months. I don’t believe the replacement module came direct from VW. The original could be sent out now. I see rebuilders on the internet, but a recommendation of a good rebuilder would be helpful. If I can get one more day, I’d like to pull it back out. Note the number on the case, but separate it and check the valve movement. Also ensure all the seals seated correctly. It’s not easy to just walk away for me. Thanks for the information. Mark
Edit: Ran the car and exercised the ABS system. Under braking system is fine. Reran basic setting 025 logged in and it completed again. Logged back in and ran 026 calibration again. Never did complete. Was thinking maybe hammering the ABS might have put it in the mood. No luck.
Car left today with the traction control warning light on. No other issues and all the ECUs are communicating. Plan is to send the original out for refurb. Still open to recommendations. I’m sure there are many degrees of refreshed. Will install it next time the owner is in the area and will try to remember to update this thread. Thanks Mark
