[A6 C6] ABS module coding after replacement - Faults: 01314 and 18055
Szogun
Poland
C?ID=403301
I'm asking You for help with coding ABS module in Audi A6 4F - BOSCH 8.0.
ABS control module has been changed to another one (used), and I think the new one is still has coding from previous car.
Unfortunately mechanics didn't check previous ABS coding.
I succesfully made G85 adaptaion, and system function test.
Thursday,24,November,2022,19:32:17:16626
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WAUZZZ4F45N089076   License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
          61 62 72
VIN: WAUZZZ4F45N089076   Mileage: 362940km-225520miles
Address 01: Engine (BDW)       Labels:. 06E-910-552-BDW.clb
   Part No SW: 4F0 910 552 R    HW: 4F0 907 552 D
   Component: 2.4l V6 MPI         0010
   Revision: --H17---    Serial number:
   Coding: 0105000302070020
   Shop #: WSC 00100 259 06641
   VCID: 323D1FE5B82B6EBB217-8066
   VINID: 9D196AAAA11610578020900718A70373FC
Readiness: 0010 1001
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F0 910 155 M    HW: 01J 927 156 HT
   Component: V30 01J 2.4l 4V RdW 0040
   Revision: 00000006    Serial number: 00000000844671
   Coding: 0000001
   Shop #: WSC 26080 048 01796
   VCID: 2C01019D9A0F384B6BB-8078
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
   Component: ESP 8.0 front   H05 0090
   Coding: 0020856
   Shop #: WSC 12345 777 89765
                    Fault Status: 11100000
                    Reset counter: 76
                    Mileage: 362944 km
                    Date: 2022.11.24
                    Time: 19:30:46
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0014
                    Hex Value: 0x3194
                    Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Reset counter: 76
                    Mileage: 362944 km
                    Date: 2022.11.24
                    Time: 19:30:46
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0014
                    Hex Value: 0x2194
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0160
   Revision: 27100401    Serial number: 10600300115408
   Coding: 0000002
   Shop #: WSC 02323 785 00200
   VCID: 6393AAA1B751B7339A1-8036
   Subsystem 1 - Part No: 4F0 910 131 A
   Component: FBSAUDIC6 EZS   H43 0070
   Subsystem 2 - Part No: 4F0 910 220
   Component: FBSAUDIC6 IDG   H36 0040
                    Reset counter: 76
                    Mileage: 362944 km
                    Date: 2022.11.24
                    Time: 19:02:55
01049 - Supply Voltage Term 50
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 76
                    Mileage: 362944 km
                    Date: 2022.11.24
                    Time: 19:07:50
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4F0 910 729 H    HW: 4F0 035 729 C
   Component: MMI Cockpit     H15 0040
   Revision: C51100CE    Serial number: AUZ6Z2DC6E2982
   Coding: 0114021
   Shop #: WSC 02327 785 00200
   VCID: 2E050B95AC134A5B45F-807A
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H07 0010
   Subsystem 2 - Serial number: 00000000092195
   Subsystem 3 - Serial number: 0113.12.040000000100010129˙
   Subsystem 4 - Serial number: 010129˙
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 F
   Component: KLIMABETAETIGUNGH04 0110
   Revision: 00000023    Serial number: 00000000097312
   Coding: 0000006
   VCID: 5BE392418F218FF3D21-800E
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0012122
   Shop #: WSC 02335 785 00200
   VCID: 6695B3B54463C21B7DF-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
Address 0E: Media Player 1        Labels: Redir Fail!
   Coding: 0114021
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 D    HW: 4F0 959 655 B
   Component: 33 AIRBAG AUDI8RH29 0250
   Revision: 05H29000    Serial number: 0037LD052TA4
   Coding: 0013107
   VCID: 2809FD8D8EF7146B8F3-807C
   Subsystem 1 - Serial number: 6332CSME0818735B4
   Subsystem 2 - Serial number: 6342CSME081F0D313
   Subsystem 3 - Serial number: 6351HSME055A0D5DI
   Subsystem 4 - Serial number: 6361HSME055A0F73D
   Subsystem 5 - Serial number: 6371VSME05385A4DV
   Subsystem 6 - Serial number: 6381VSME04791761J
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026043500078
   Coding: 0002011
   Component: Lenkradmodul    H06 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 900 M
   Component: KOMBIINSTR. M73 H10 0630
   Revision: 00200000    Serial number: 4R4709HD4
   Coding: 0256143
   Shop #: WSC 80093 222 69422
   VCID: 1E65DB55DCB3DADBF5F-804A
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
   Component: Gateway         H09 0030
   Revision: 09          Serial number: 0800804C160298
   Coding: 6CFE73C41B0104
   Shop #: WSC 02325 785 00200
   VCID: 270BFEB183E91B13869-8072
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H10 0020
   Revision: 00000000    Serial number: ‘E9
   Coding: 0000618
   VCID: 290FF88995FD2D6390D-807C
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H14 0090
   Revision: 00900014    Serial number: 01002174110000
   Coding: 0139505
   Component: LIN BACKUP HORN H02 1301
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
                    Fault Status: 01101100
                    Reset counter: 76
                    Mileage: 346141 km
                    Date: 2005.02.01
                    Time: 12:00:54
Address 47: Sound System        Labels: 4F0-910-7xx-47.lbl
   Coding: 0114021
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H09 0050
   Revision:             Serial number: 00000000055483
   Coding: 0001104
   VCID: 5EE59B559C339ADBB5F-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H10 0020
   Revision: 00000000    Serial number: „6
   Coding: 0000618
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0002031
   Shop #: WSC 02334 785 00200
   VCID: 5DE79C59913581C3AC5-8008
                    Fault Status: 00101101
                    Reset counter: 116
                    Mileage: 362944 km
                    Date: 2022.11.24
                    Time: 19:14:08
                    Voltage: 12.94 V
                    Count: 236
   Part No: 8P0 907 357 C
   Coding: 0000003
   VCID: 3A2D37C5605B96FBE97-806E
Address 56: Radio        Labels: Redir Fail!
   Coding: 0114021
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000000130
   VCID: 2313EAA1F7D1F733DA1-8076
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  595402080
   Coding: 344630393135313035432056413035393534303230383020
   Shop #: WSC 00011 888 06946
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 A    HW: 4F0 959 795 A
   Component: TSG HL          H09 0010
   Coding: 0000042
   VCID: 2A0D078590FB267B997-807E
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 A    HW: 4F0 959 794 A
   Component: TSG HR          H09 0010
   Coding: 0000042
End----------(Elapsed Time: 01:35, VBatt start/end: 12.0V/12.0V)-----------
Try: 0021330
