Audi Q7, P0088 Fuel rail/system pressure too high
Any reason why the fuel pressure cannot be regulated fast enough to specified fuel pressure?
  • High press fuel pump faulty?
    Votes: 0 0.0%
  • Fuel high pressure switch faulty?
    Votes: 0 0.0%
  • Total voters
RyMar
South Africa
C?ID=133909
Q7 sent to us from another workshop.
Aftermarket airmass meter replaced by another workshop.
We replaced the SCV fuel press regulator solenoid valve with a genuine Bosch regulator with the same part number.
Thursday,24,November,2022,16:22:53:19741
VCDS Version: 22.9.0.0 (x64)  HEX-NET2 CB: 0.4623.4
VIN: WAUZZZ4LXBD018584   License Plate: Q7 2
Mileage: 295930km-183882mi   Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 18 19 42 46 4F 52 55 56 5F 62
          69 6D 6F 72 76
VIN: WAUZZZ4LXBD018584   Mileage: 295930km-183882miles
Address 01: Engine (J623-CJGA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L1 910 401 H    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  X37 0006
   Revision: 53X37---    Serial number:                CVN: 186ECDE6
   Coding: 2A2A4012A53701020000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM30TDI0114L1910401H 001011
   ROD: EV_ECM30TDI0114L1910401H.rod
   VCID: 2802930C3277CA9B8F3-807C
   VINID: 9D196AAAA11CA12500048148102145178C
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [039] - -
          [Data bus on board diagnostic interface -J533please read DTC]
                    Mileage: 295931 km
                    Date: 2022.11.24
                    Time: 15:29:42
                    Engine RPM: 1079.00 /min
                    Normed load value: 35.7 %
                    Vehicle speed: 24 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 47 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 13.840 V
                    ACC specified acceleration: 0.000 m/s²
                    ACC control module: received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: -0.033 m/s²
                    Engine status: COENG_RUNNING
5213 - Fuel Rail/System Pressure
          P0088 00 [167] - Too High
                    Mileage: 295932 km
                    Date: 2022.11.24
                    Time: 16:17:06
                    Engine RPM: 1911.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 28 km/h
                    Coolant temperature: 80 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 13.500 V
                    Unlearning counter according OBD: 80
                    Fuel temperature: 51.5 °C
                    Mean injection quantity: 39.04 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 5
                    Fuel high-pressure: actual value: 2014500 hPa
                    High fuel pressure: specified value: 1296600 hPa
                    Pressure control valve adaptation factor: 1.1173
                    Fuel level: 26.00 l
4795 - Mass Air Flow Sensor (G70)
          P0101 00 [039] - Implausible Signal
                    Mileage: 295933 km
                    Date: 2022.11.24
                    Time: 16:17:48
                    Engine RPM: 1377.50 /min
                    Vehicle speed: 31 km/h
                    Coolant temperature: 79 °C
                    Intake air temperature: 56 °C
                    Voltage terminal 30: 13.620 V
                    Mean injection quantity: 0.00 mg/stroke
                    Control Module temperature: 58.9 °C
                    EGR_governor_deviation: 112.5 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Mass_air_flow_sensor_drift: 0.1465
                    Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 131.9 kg/h
                    Actual charge pressure: 1064 hPa
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [039] - Intermittent
                    Mileage: 295931 km
                    Date: 2022.11.24
                    Time: 15:29:43
                    Engine RPM: 1099.00 /min
                    Normed load value: 40.8 %
                    Mean injection quantity: 21.66 mg/stroke
                    Control Module temperature: 55.9 °C
                    EGR_governor_deviation: -2644.3 mg/stroke
                    Inj Ctl q Curr: 21.64 mg/stroke
                    Mass_air_flow_sensor_drift: 0.1243
                    Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 865.7 kg/h
                    Actual charge pressure: 1104 hPa
   Part No SW: 0C8 927 750 AE    HW: 0C8 927 750 AE
   Component: AL1000 AISIN  001 1815
   Serial number:                CVN: EEB03BAC
   Coding: 0001F8
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_AU56.rod
   VCID: 6FB0B810D719DDA30E9-803A
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 2196577
   Shop #: WSC 31414 790 00001
   VCID: 343A777CF23FBE7B33B-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10602901694648
   Coding: 0000147
   VCID: 251C9A3849E5D7F3B45-8070
   Subsystem 1 - Part No: 4F0 910 132 A
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220
   Component: FBSAUDIC6 IDG   H01 0054
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AD
   Component: KLIMA 4 ZONEN H13 0060
   Revision: 00---022    Serial number: 00000000256567
   Coding: 01009416
   VCID: 251C9A3845E5D7F3B45-8070
02989 - Reduced Fresh Airflow due to Critical Power Supply Condition
                    Reset counter: 183
                    Mileage: 295932 km
                    Date: 2022.11.24
                    Time: 16:14:59
                    Voltage: 12.10 V
                    Temperature: 42.0°C
                    RPM: 840 /min
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H29 0390
   Coding: 0033122
   VCID: 6FB0B810DB99DDA30E9-803A
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 157CAAF895854773245-8040
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D07AK3V
   Coding: 0014128
   VCID: 2E0E65141C1394AB45F-807A
   Subsystem 1 - Serial number: 6332QSME1D7B0D20M
   Subsystem 2 - Serial number: 6342QSME1F7B3D00Q
   Subsystem 3 - Serial number: 6352QSME1D7B180AS
   Subsystem 4 - Serial number: 6362QSME427A4622F
   Subsystem 5 - Serial number: 63734SME4F7349101
   Subsystem 6 - Serial number: 63834SME19714906$
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026103030524
   Coding: 0102142
   VCID: 2700903033E9C5E3869-8072
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 932 J    HW: 4L0 920 932 J
   Component: KOMBIINSTR.   H10 0209
   Revision: 00000000    Serial number: FLL22E9CA
   Coding: 2F56630400000008010800
   VCID: 33387460FB31B9432A1-8066
Address 18: Aux. Heat        Labels: 4L0-910-105.clb
   Part No SW: 4L0 910 105     HW: 4L0 815 071 G
   Component: Heizgeraet      H09 0140
   Revision: 0000000C    Serial number: 00000009021078
   Coding: 0000101
   VCID: 6092CB2C164772DB873-8034
   Part No SW: 4F0 907 468 P    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0047
   Revision: LB200032    Serial number: 3200L10A240173
   Coding: 00CF07
   VCID: 3C2A5F5CD66F763BFBB-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790446831
   Serial number: 10306000118021200181
02252 - Generator
                    Reset counter: 183
                    Mileage: 295920 km
                    Date: 2022.11.24
                    Time: 14:56:29
                    Bin. Bits:    11111
                    Voltage: 12.10 V
                    Count: 7
                    Bin. Bits:    10011
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0008000110034
   Coding: 011F02205041440004
   VCID: 48C2338C92B72A9B6F3-801C
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 223
                    Mileage: 295920 km
                    Date: 2022.11.24
                    Time: 14:57:39
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01378796450000
   Coding: 3285241
   VCID: 353C4A78F945A773045-8060
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000192577
   Coding: 0011101
   VCID: 5EEEF5D42C33442BB5F-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0008000110957
   VCID: 47C030B09FA925E3669-8012
   Part No: 8P0 907 357 H
   Coding: 0000007
   VCID: 3FD02850CB796D23DE9-806A
   Part No SW: 4G0 035 056     HW: 4G0 035 056
   Component: Radio U STD   H52 0051
   Revision: AB001007    Serial number: 469K80A7607808
   Coding: 060003020100000000
   VCID: 5EEEF5D42033442BB5F-800A
   Part No SW: 4L0 035 646 B    HW: 4L0 035 646
   Component: B-B-ER        H48 0140
   Revision: --------    Serial number: 312JO0AB000138
   Coding: 010001060004C3ED01002305EF6300030200
   VCID: 2A0669042CFBF88B997-807E
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0084
   Serial number: 9465JJ0A0223101
   Subsystem 2 - Part No SW: 4L0 910 609     HW: 4L0 919 611
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001711277
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0361
   Revision:             Serial number: 0008000112529
   Coding: 010E00204041230004
   VCID: 46DE3DB498A33CEB9DF-8012
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4L0 907 383 D    HW: 4L0 907 383 D
   Component: Anhaenger     H08 0100
   Revision: 2C001001    Serial number: 00000135961685
   Coding: 0101010000000000
   VCID: 32367164042BB04B217-8066
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H55 0500
   Revision: --H55001    Serial number: E5030000B
   Shop #: WSC 01439 996 90519
   VCID: 6C8AAF1CEA8F26BB2BB-8038
   Subsystem 3 - Serial number: RD11.11.10--H55001001C0274ÿ
   Subsystem 4 - Serial number: 1C0274ÿ
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H05 0070
   Revision: AAH05061    Serial number: 108811351-----
   Coding: 0000001
   VCID: 659CDA38096517F3745-8030
   Component: TSG HR        H11 0361
   Revision:             Serial number: 0008000112526
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H03 0500
   Revision: 00H03000    Serial number: 37331031100262
   Coding: 0211066
   VCID: 2A06690420FBF88B997-807E
End----------(Elapsed Time: 01:44, VBatt start/end: 14.0V/14.0V)-----------
