Request: NAR 2018 or 2019 Tiguan with LEDs 09 4B and 19 Adpmap
eurospekgarage
Houston, TX, USA
C?ID=314389
Hi all,
I am currently performing an LED headlight retrofit to my 2018 Tiguan. I have the wiring all situated and none of the relevant adpmaps here are working for my configuration - I am thinking this might be NAR Tiguan specific. Turn signals and high beams do not work. If possible, could you please provide the adpmaps for 09 (central electronics), 4B (headlight range/multifunction module), and 19 (CAN module) for a North American Tiguan with factory LEDs.
Thanks in advance!
eurospekgarage
Houston, TX, USA
C?ID=314389
Heres an auto scan for clarity
Thursday,24,November,2022,17:55:58:12942
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: 3VV2B7AX9JM201421   License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 29 2B 39 3C 42 44 4B 52
          5F 6C 75 D6 D7 D8 D9
VIN: 3VV2B7AX9JM201421   Mileage: 95774km-59511miles
29-Left Light -- Status: Cannot be reached 0100
39-Right Light -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100
D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 K    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0004
   Revision: 1DH31000    CVN: 95267501
   Coding: 012A00122426010F34000000000000000000000000000000
   Shop #: WSC 20149 444 00000
   ASAM Dataset: EV_ECM20TFS0115NA907115K 001004
   ROD: EV_ECM20TFS0115NA907115K.rod
   VCID: 46D65EB2A824C5DB91E-8012
   VINID: 0E698248746825A742001102044A052EA6
Readiness: 1110 1101
   Part No SW: 09G 927 158 DT    HW: 09G 927 158
   Component: AISIN AQ8     206 3698
   CVN: 2408AAFC
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00240
   ROD: EV_TCMAQ450031_VW32.rod
   VCID: 084A908AE2B013ABA32-805C
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 51618000000290
   Coding: 0BFA6BA454201B6DC57B0302A2C449D0D62AD8A3C045927C10415058C28A4200002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   VCID: 76B6EE729844155BC1E-8022
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0486231884
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E263652F0F49D1BD9E-806A
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00185779
   Coding: 0002000420011800100500001211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 4FF87B96475E0493228-801A
   Humidity sensor: exterior:
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:13:44
                    Outside temperature: 19.0 °C
                    Engine RPM: 0 /min
                    Temperature downstream of evaporator: 20.0 °C
                    Refrigerant pressure: 1.0 bar
   Part No SW: 5Q0 937 087 BG    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: C864150720042J
   Shop #: WSC 00066 790 00192
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 015C8DAEC18A22E3E4C-8054
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180614  034  0373
   Serial number: 18060522208330
   Humidity sensor: interior:
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07  0002
   Serial number: 71852681
9 Faults Found:
534549 - Databus
          [FLA_01 Datenbus fehlende Botschaft]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 20:19:14
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    last_wakeup: Pin A50 Drehfalle hinten links
                    Voltage: 12.4 V
                    Outside temperature: 20.5 °C
568836 - Databus
          [LWR AFS - Kein Signal/Kommunikation]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:05:27
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: Not operated
                    Voltage: 12.2 V
540693 - Databus
          [LWR_AFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:05:27
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
7687 - Reflector Actuator for Left Low Beam Headlamp
          B121B 11 [009] - Short to Ground
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 20:20:57
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
                    Outside temperature: 20.0 °C
7690 - Reflector Actuator for Left Low Beam Headlamp
          B121B 15 [008] - Open or Short to Plus
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 20:13:36
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.4 V
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [009] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 19:22:52
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: Not operated
                    Voltage: 12.9 V
65802 - Rear Vehicle Height/Level Sensor
          C114E 15 [009] - Open or Short to Plus
          [Geber für Fahrzeugniveau hinten Unterbrechung/Kurzschluss nach Plus]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:05:27
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
65800 - Rear Vehicle Height/Level Sensor
          C114E 29 [009] - Signal Implausible
          [Geber für Fahrzeugniveau hinten unplausibles Signal]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:05:28
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
65806 - Rear Vehicle Height/Level Sensor
          C114E 04 [009] - Internal System Fault
          [Geber für Fahrzeugniveau hinten defekt]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:05:28
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
   Component: ACCCONTIMQB   H03 0233
   Coding: 3200008110FF8728749C8145004097
   Shop #: WSC 00066 790 00452
          U1101 00 [009] - Active
          [FAULT_THP_EC_INVALID_IKA]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:13:05
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 65 °C
                    Longitudinal_acceleration_vehicle_reference: 0.09 m/s²
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM0A4Z75
   Coding: 8CCCFC00000000005000001AC20800000065
   VCID: 055499BED5A20EC3D84-8050
   Serial number: IBH000000000009Q2RE
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 003 006 18
   Serial number: 35700000000236CCB03L
   Subsystem 3 - Part No SW: -----------    HW: 480 000 207 18
   Serial number: 358000000003BA3CE03T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 005 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100010C2AE1266E3C6
   Subsystem 5 - Part No SW: -----------    HW: 480 401 805 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001C5299D271D6EI
   Subsystem 6 - Part No SW: -----------    HW: 480 400 506 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001C329B6AA285DJ
   Subsystem 7 - Part No SW: -----------    HW: 480 400 506 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001C729B6AA662AK
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:15:04
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 10051804401354
   Coding: 0410
   VCID: 074893B6EFAE1CD3AA8-8052
131108 - Databus
          U1121 00 [024] - Missing Message
          [Time-Out Gateway_71: Time-Out BSG]
                    Reset counter: 194
                    Operating time: 115200 min
                    Terminal 30 power supply: 12.8 V
                    Voltage at switch: 4.98 V
                    Terminal 15 status: not active
                    System status: 30
131140 - Databus
          [Time-Out Klemmen_Status_01: Time-Out Gateway]
                    Date: 2127.15.00
                    Time: 31:63:63
                    Operating time: 115226 min
                    Terminal 30 power supply: 13.2 V
                    System status: 30
   Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
   Component: KOMBI         380 0310
   Coding: 0BA40C1AA388CF0502882B0954000000A0000000
   Shop #: WSC 00066 790 00454
   Component: GW MQB High   518 5323
   Serial number: 30061800841360
   Coding: 030500347F085900FB0322481E0F00010001070000000000000000000000
   GVL: 01D03C0000000600404C80008002C80000000003000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 382A204AD2D0A32B132-806C
   Generator:
   Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
   Serial number: 1251812101600850BH2B
   Coding: 280000
   Serial number: 2275545900
131736 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x98]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:26:41
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: On
131737 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x99]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:26:41
                    Terminal 15: On
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:26:41
                    Terminal 15: On
   Serial number: HA1-00016.04.18
   Coding: 0101
   VCID: 4CC26C9AB6483F8B47A-8018
9 Faults Found:
16652 - Databus
          [Getriebe - TO -- Get_11]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
16654 - Databus
          [Kombi - TO -- Kombi_01]
                    Fault Priority: 8
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
17466 - Databus
          [Kombi - TO -- Kombi_02]
                    Fault Priority: 8
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
17473 - Databus
          [Motorsteuergerät - TO -- Mot_11]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
16657 - Databus
          [Motorsteuergerät - TO -- Mot_12]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
17474 - Databus
          [Motorsteuergerät - TO -- Mot_14]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
16727 - Databus
          [Motorsteuergerät - TO -- Mot_20]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
17475 - Databus
          [Motorsteuergerät - TO -- Mot_Code]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
16659 - Databus
          [Gateway - TO -- Sys_01]
                    Fault Priority: 8
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 01:01:00
Address 29: Left Light
   Serial number: 18000179707010
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33301766CBB64073260-8066
10 Faults Found:
12664832 - Databus
          [Timeout Message TSG_FT_01]
                    Reset counter: 194
                    Mileage: 95774 km
                    Result lock conditions: invalid
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Lock sensor: Not operated
                    Unlock sensor: operated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: On
                    Clamp 15: On
                    Clamp 15 Status: invalid
                    Remote Start: active
                    Driver door: For
                    Central locking locked external: locked
                    Central locking safed external: Vehicle secured
                    Clamp Request: Yes
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c timeout
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    Signature IMS OK: No
                    IMS responded: No
                    Positive authentification in current KL15 cycle: No
                    Lifestate: Immobilizer download obtained
                    Learn mode: Adapted
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 655.35 km/h
                    UBat internal: 12.2 V
                    UMotorBridge: 6.6 V
                    Lock condition engine speed: Condition not met
                    Lock condition clamp S: Condition not met
                    Lock condition clamp 15: Condition not met
                    Lock condition E2E clamp status: Condition not met
                    Lock condition timeout clamp status: Condition not met
                    Lock condition vehicle speed: Condition not met
                    Lock condition E2E vehicle speed: Condition not met
                    Lock condition timeout vehicle speed: Condition not met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition met
                    Lock condition selector lever position parking: Condition not met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition not met
                    Lock condition E2E distance pulse: Condition not met
                    Lock condition difference distance pulse: Condition not met
12665088 - Databus
          [Timeout Message Klemmen_Status_01]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 00:38:50
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Lock sensor: operated
                    Unlock sensor: Not operated
                    Clamp S: OFF
                    Clamp 15: OFF
                    Remote Start: not active
                    Driver door: For
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UBat internal: 12.3 V
                    UMotorBridge: 6.7 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition met
                    Lock condition clamp 15: Condition met
                    Lock condition selector lever position parking: Condition met
12665089 - Databus
          [Timeout Message ZV_02]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.23
                    Time: 00:38:51
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Clamp S: OFF
                    Clamp 15: OFF
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.7 V
12666369 - Databus
          [Timeout Message Motor_14]
                    Reset counter: 194
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Clamp 15 Status: valid
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UBat internal: 11.9 V
                    UMotorBridge: 6.5 V
                    Lock condition timeout clamp status: Condition met
12666370 - Databus
          [Timeout Message ESP_10]
                    Reset counter: 194
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UBat internal: 12.0 V
                    UMotorBridge: 6.5 V
12666372 - Databus
          [Timeout Message Gateway_73]
                    Reset counter: 194
                    Mileage: 95774 km
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Clamp S: OFF
                    Clamp 15: OFF
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.5 V
                    Lock condition E2E clamp status: Condition met
12666379 - Databus
          [Timeout Message ESP_21]
                    Reset counter: 194
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.5 V
12666380 - Databus
          [Timeout Message Diagnose_01]
                    Reset counter: 194
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: OFF
                    Clamp 15: OFF
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UBat internal: 12.1 V
                    UMotorBridge: 6.6 V
12666387 - Databus
          [Timeout Message WFS_01]
                    Reset counter: 194
                    Mileage: 95774 km
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Driver door: For
                    Clamp Request: Yes
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.7 V
13634048 - Databus
          [Timeout Message Kessy_04]
                    Reset counter: 194
                    Mileage: 95774 km
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Driver door: For
                    Clamp Request: Yes
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.7 V
Address 39: Right Light
   Serial number: 0483214428
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D24315EFDF28603C04-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0481529733
   Coding: 010111
512260 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
                    Reset counter: 194
   Serial number: 0000386565062
   Coding: 003013200000028000000000
   Shop #: WSC 57893 001 1048576
   VCID: 47C853B6AF2EDCD36A8-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000528473
   Coding: 011000
   Revision: 00000000    Serial number: 0002492197
   Coding: 01000010004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40DA48AA8A00EBEBAB2-8014
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 26111910520422
   Coding: 0000000608001D5200202100040000000000000000000000000000000000
   Shop #: WSC 00046 123 12345
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 37282376DFCEAC531A8-8062
13705478 - Databus
          [RLS_01 data bus missing message]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:22:37
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 8038820104093
   VCID: 44D244BA9E18F7CB8FA-8010
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000557476
   Coding: 091000
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.20
                    Time: 23:20:24
458752 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 194
458776 - Databus
          [Gateway_71 Datenbus fehlende Botschaft]
                    Reset counter: 194
458803 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 194
458809 - Databus
          [Systeminfo_01 Datenbus fehlende Botschaft]
                    Reset counter: 194
589843 - Window Regulator; Front Passenger Side
          B1320 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.22
                    Time: 13:39:25
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0867
   Coding: 02730600BE00000051220001001808001F0500C40120050002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2E06061220946D9B49E-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  252 8130
   Serial number: VWZ6ZMV1645182
          B11CF 53 [009] - Deactivated
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.24
                    Time: 05:10:58
                    Voltage terminal 30: 12.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 102 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Coding: 0123060120002017300040
   Shop #: WSC 37597 004 1048576
   VCID: 392C254EE9DABA23ECC-806C
   Component: OCULowMQBUS   009 0570
   Coding: 02230602C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   VCID: 43D047A69B16F0F3B60-8016
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
Address D8: LED HeadL. Pwr Left
Address D9: LED HeadL. Pwr Right
End----------(Elapsed Time: 01:51, VBatt start/end: 12.6V/12.5V)-----------
adpmap-09-5Q0-937-087-AS_3VV4B7AX8JM153175-20220720-2142.CSV
;SW:5Q0-937-087-AS   HW:5Q0-937-087-AP ---  Cent. Elect.
;Component:BCM PQ37BOSCH 034 0246, Coding:
;EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
;Wednesday,20,July,2022,21:42:36:07998
;VCDS Version: Beta 22.6.0 (x64)  Data version: 20220530 DS341.0
;VCID: 0C42AB3546CAA48BB7B-8058
IDE00001-ENG99061-Production mode-Access control,not active ,3,
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3,
IDE00001-ENG112304-Production mode-Heckwischer,not active ,3,
IDE00001-ENG98647-Production mode-Interior lights,not active ,3,
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active ,3,
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active ,3,
IDE00002-Transport mode,active ,1,
IDE00820-Activating and deactivating all development messages,not active ,1,
IDE01550-Service position,178.999822 °,2,
IDE02152-Characteristics in production mode,2000 ms,4,
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10,
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,10,
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10,
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10,
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10,
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10,
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10,
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active ,10,
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10,
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active ,10,
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10,
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10,
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10,
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10,
IDE02332-Deactivate production mode,0 ,3,
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen,not active ,8,
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen,not active ,8,
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8,
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8,
IDE02711-ENG112304-Rear wiper-Heckwischer,logikgesteuert ,8,
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf,not active ,8,
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck,active ,8,
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8,
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8,
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8,
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8,
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,active ,8,
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8,
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8,
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8,
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.3 °,16,
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.0 %/s,16,
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,both sides ,16,
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h,16,
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,16,
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 °C,16,
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,120 °,16,
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 °C,16,
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,80 °,16,
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,40.0 km/h,16,
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119 ,16,
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht,15 min,16,
IDE03787-Activate left/right hand drive switch-over,not active ,1,
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11,
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.0 °C,11,
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.0 °C,11,
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer,0 s,11,
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt,not installed ,11,
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus,not installed ,11,
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11,
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11,
IDE04927-ENG141955-Window heater-heizbare Heckscheibe,installed ,11,
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe,not installed ,11,
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11,
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11,
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11,
IDE04927-ENG154810-Window heater-window heating front activation time pause,0 s,11,
IDE04928-MAS01577-Anti-theft protection-Parking heater,not installed ,8,
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,8,
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8,
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,active ,8,
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8,
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,not_active ,8,
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8,
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8,
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,Horn_verbaut ,8,
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,not installed ,8,
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8,
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,not_active ,8,
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,not_active ,8,
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8,
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,No ,8,
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,1 Alarm ,8,
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,No ,8,
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,8,
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,8,
IDE05143-MAS02985-Writing parameter-Value,130 ,5,
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5,
IDE05144-Read parameter address,FE 00 00 ,3,
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 10 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 10 7F 00 00 00 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224,
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30,
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30,
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30,
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,21.00 °C,30,
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,20.00 °C,30,
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,21.00 °C,30,
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,20.00 °C,30,
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30,
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30,
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30,
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30,
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.00 °C,30,
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,30,
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.00 °C,30,
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,30,
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30,
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30,
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe,not installed ,30,
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30,
IDE06425-Dynamometer mode: functional,not active ,1,
IDE06507-MAS13125-Button in center console-Function of button 1,Start-stop ,8,
IDE06507-MAS13129-Button in center console-Function of button 2,not coded/not installed ,8,
IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8,
IDE06507-MAS13135-Button in center console-Function of button 4,not coded/not installed ,8,
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8,
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8,
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8,
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8,
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8,
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8,
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start,installed ,8,
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung,active ,8,
IDE07356-Position during interval mode,40.999959 °,2,
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6,
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6,
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6,
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,9,
IDE08786-ENG141956-Assistance light functions-Humidity sensor,installed ,9,
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,9,
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9,
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion,not active ,9,
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9,
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9,
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19,
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19,
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19,
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19,
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19,
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19,
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19,
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19,
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,19,
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,19,
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,30 %,19,
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19,
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,30 %,19,
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19,
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,30 %,19,
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,10 %,19,
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19,
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19,
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19,
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19,
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19,
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19,
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,19,
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht,not installed ,19,
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,19,
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,19,
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,19,
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel,not installed ,19,
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,19,
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19,
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19,
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19,
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5,
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5,
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5,
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5,
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,5,
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,5,
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5,
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5,
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,5,
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,5,
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,5,
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,5,
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active ,5,
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,5,
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,5,
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,5,
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17,
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17,
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17,
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17,
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17,
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17,
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17,
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17,
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17,
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17,
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17,
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17,
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17,
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17,
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik,not installed ,17,
IDE10298-Alternating park position 1,19.999980 °,2,
IDE10299-Alternating park position 2,34.999965 °,2,
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256,
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256,
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256,
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256,
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256,
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256,
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.40 ,256,
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256,
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000001  ,256,
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00110000  ,256,
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256,
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4,0 ,256,
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256,
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256,
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256,
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256,
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab,1 ,256,
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf,1 ,256,
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256,
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay,0 ,256,
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256,
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256,
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256,
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %,256,
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256,
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256,
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256,
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,70 %,256,
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256,
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256,
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256,
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256,
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %,256,
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256,
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256,
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256,
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,70 %,256,
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256,
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256,
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256,
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256,
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %,256,
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256,
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256,
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256,
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,70 %,256,
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256,
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256,
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256,
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256,
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %,256,
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256,
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256,
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256,
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,70 %,256,
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256,
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256,
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256,
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256,
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht,100 %,256,
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256,
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256,
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256,
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,70 %,256,
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256,
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256,
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256,
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256,
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht,100 %,256,
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256,
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256,
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256,
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,70 %,256,
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256,
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256,
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256,
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256,
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256,
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256,
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256,
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256,
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,70 %,256,
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256,
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256,
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256,
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256,
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256,
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256,
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256,
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256,
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,70 %,256,
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256,
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256,
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256,
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256,
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %,256,
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256,
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256,
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256,
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256,
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256,
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256,
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256,
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256,
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256,
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256,
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256,
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256,
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,70 %,256,
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256,
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256,
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256,
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256,
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256,
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256,
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256,
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256,
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,70 %,256,
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256,
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256,
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256,
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256,
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht,100 %,256,
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256,
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256,
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256,
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,70 %,256,
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256,
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256,
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256,
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256,
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256,
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256,
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256,
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256,
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,70 %,256,
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256,
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256,
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256,
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256,
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256,
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256,
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256,
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256,
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,70 %,256,
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256,
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256,
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256,
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256,
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256,
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256,
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256,
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256,
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,70 %,256,
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256,
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256,
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit,0.0 s,256,
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach,0.0 s,256,
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum,0.0 s,256,
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht,0.0 s,256,
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko,0.0 s,256,
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren,0.0 s,256,
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0.0 s,256,
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach,0.0 s,256,
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256,
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht,0.0 s,256,
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko,0.0 s,256,
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256,
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit,0.0 s,256,
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach,0.0 s,256,
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum,0.0 s,256,
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht,0.0 s,256,
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko,0.0 s,256,
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren,0.0 s,256,
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit,0.0 s,256,
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach,0.0 s,256,
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum,0.0 s,256,
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht,0.0 s,256,
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko,0.0 s,256,
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren,0.0 s,256,
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit,0.0 s,256,
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach,0.0 s,256,
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum,0.0 s,256,
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht,0.0 s,256,
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko,0.0 s,256,
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren,0.0 s,256,
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit,0.0 s,256,
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach,0.0 s,256,
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum,0.0 s,256,
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0.0 s,256,
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko,0.0 s,256,
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren,0.0 s,256,
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit,0.0 s,256,
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach,0.0 s,256,
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum,0.0 s,256,
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht,0.0 s,256,
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko,0.0 s,256,
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren,0.0 s,256,
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen,0 ,256,
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30,
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30,
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30,
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30,
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30,
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30,
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30,
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30,
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30,
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30,
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30,
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30,
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30,
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30,
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30,
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30,
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30,
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30,
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30,
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30,
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30,
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30,
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30,
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30,
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30,
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30,
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30,
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30,
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30,
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30,
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3,
IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3,
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen,not active ,3,
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3,
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3,
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3,
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30,
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin,0 ,30,
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30,
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30,
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30,
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30,
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30,
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30,
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30,
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30,
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30,
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30,
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30,
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30,
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30,
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30,
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30,
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30,
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30,
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30,
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30,
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30,
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30,
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30,
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30,
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30,
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30,
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30,
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30,
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30,
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung,active ,5,
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active ,5,
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug,not installed ,5,
MAS01490-ENG141950-Energy management-Hybrid vehicle,No ,5,
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement,not active ,5,
MAS01490-ENG141978-Energy management-Recuperation,active ,5,
MAS01490-ENG142037-Energy management-Zweitbatterie,not installed ,5,
MAS05055-lower turn position,42.999957 °,2,
MAS05056-upper turn position,178.999822 °,2,
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,1200 lx,24,
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,2200 lx,24,
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2512 lx,24,
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO,600 lx,24,
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten,1200 lx,24,
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten,2200 lx,24,
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24,
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24,
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway,not active ,24,
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain,not active ,24,
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,frueh ,24,
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF,not active ,24,
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe,not active ,24,
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24,
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24,
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24,
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke,0 lx,24,
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung,02 ,24,
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9,
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9,
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9,
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4,
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4,
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler,not installed ,4,
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60,
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60,
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60,
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60,
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60,
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60,
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60,
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60,
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60,
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60,
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60,
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60,
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60,
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60,
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60,
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60,
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60,
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60,
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60,
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60,
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60,
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60,
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60,
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60,
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60,
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60,
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60,
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60,
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60,
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60,
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60,
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60,
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60,
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60,
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60,
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60,
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60,
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60,
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60,
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60,
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60,
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60,
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60,
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60,
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60,
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60,
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60,
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60,
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60,
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60,
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60,
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60,
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60,
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60,
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60,
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60,
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60,
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60,
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60,
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60,
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60,
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60,
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60,
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60,
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60,
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60,
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60,
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60,
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60,
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60,
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60,
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60,
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60,
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60,
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60,
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60,
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60,
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60,
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60,
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60,
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60,
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60,
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60,
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60,
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60,
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60,
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60,
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60,
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60,
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60,
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60,
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60,
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60,
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60,
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60,
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60,
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60,
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60,
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60,
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60,
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60,
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60,
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60,
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60,
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60,
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60,
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60,
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60,
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60,
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60,
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60,
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60,
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60,
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60,
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60,
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60,
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60,
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60,
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60,
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60,
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30,
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30,
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30,
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30,
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30,
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30,
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30,
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30,
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30,
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30,
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30,
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30,
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30,
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30,
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30,
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30,
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30,
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30,
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30,
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30,
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30,
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30,
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30,
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30,
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,Panoramic roof ,30,
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30,
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30,
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30,
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30,
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30,
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed ,30,
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed ,30,
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed ,30,
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed ,30,
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed ,30,
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed ,30,
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed ,30,
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30,
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed ,30,
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed ,30,
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed ,30,
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed ,30,
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed ,30,
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed ,30,
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed ,30,
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0 ,60,
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60,
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0 ,60,
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0 ,60,
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0 ,60,
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0 ,60,
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0 ,60,
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0 ,60,
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0 ,60,
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0 ,60,
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0 ,60,
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60,
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0 ,60,
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60,
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60,
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0 ,60,
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0 ,60,
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0 ,60,
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0 ,60,
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0 ,60,
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60,
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0 ,60,
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0 ,60,
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0 ,60,
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0 ,60,
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0 ,60,
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0 ,60,
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0 ,60,
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0 ,60,
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0 ,60,
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0 ,60,
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60,
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0 ,60,
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60,
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60,
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0 ,60,
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0 ,60,
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0 ,60,
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0 ,60,
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0 ,60,
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60,
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed ,60,
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed ,60,
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed ,60,
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed ,60,
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed ,60,
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed ,60,
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed ,60,
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed ,60,
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed ,60,
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed ,60,
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60,
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed ,60,
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60,
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60,
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed ,60,
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed ,60,
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed ,60,
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed ,60,
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed ,60,
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23,
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23,
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23,
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23,
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23,
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23,
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23,
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23,
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23,
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23,
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23,
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23,
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23,
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23,
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23,
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23,
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23,
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10,
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken,active ,10,
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger,separte ,10,
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing,not active ,10,
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10,
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10,
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10,not active ,10,
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay,50 ms,10,
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken,not active ,10,
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10,
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken,active ,10,
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen,3 ,10,
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken,not active ,10,
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,not active ,10,
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10,
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10,
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10,
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10,
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10,
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10,
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10,
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10,
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10,
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10,
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10,
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10,
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10,
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9,
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9,
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9,
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag,Daytime running lamps ,9,
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9,
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9,
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9,
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9,
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9,
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9,
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9,
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9,
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9,
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9,
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte,not active ,9,
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,9,
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,9,
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9,
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,Yes ,5,
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5,
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5,
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,not active ,5,
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe,not installed ,5,
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light,not installed ,18,
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18,
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18,
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht,Aktive Begrenzung ,18,
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18,
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18,
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis,Driver door ,18,
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18,
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18,
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18,
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18,
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Sollspannungsanforderung 13.5 ,18,
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18,
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18,
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige,No ,18,
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18,
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18,
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL,Yes ,18,
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18,
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18,
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung,Yes ,18,
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus,Enabled ,18,
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18,
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,18,
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18,
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18,
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18,
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18,
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18,
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung,active ,18,
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP,active ,18,
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18,
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus,active ,18,
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18,
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,6 s,18,
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Sollspannungsanforderung 13.5 ,18,
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte,not active ,18,
ENG126647-ENG98399-debug_light_function-Activation,0 ,11,
ENG126647-ENG101417-debug_light_function-Adresse,0 ,11,
ENG126647-ENG126820-debug_light_function-Bitmask,0 ,11,
ENG126647-ENG126821-debug_light_function-Divisor,0 ,11,
ENG126647-ENG98827-debug_light_function-Offset,0 ,11,
ENG126647-ENG126822-debug_light_function-Polaritaet,0 ,11,
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0,0.0 %,6,
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1,50.0 %,6,
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2,100.0 %,6,
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0,0.0 %,6,
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1,50.0 %,6,
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2,100.0 %,6,
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP,present ,6,
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6,
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6,
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,not installed ,6,
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6,
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6,
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6,
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm,active ,6,
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6,
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6,
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,not active ,6,
ENG141682-ENG141966-Front_wiper-Frontwischertyp,LIN ,6,
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,6,
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,not active ,6,
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6,
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6,
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6,
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz,active ,6,
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6,
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6,
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant,not active ,6,
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,6,
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6,
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6,
ENG99457-ENG117394-Head area heater-blower_speed,1 ,2,
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2,
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid,installed ,8,
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8,
ENG141645-MAS00213-HW_Verbau-Insufficient coolant,installed ,8,
ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8,
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8,
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv,not active ,8,
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung,not installed ,8,
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor,installed ,8,
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube,installed ,8,
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8,
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer,not installed ,8,
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8,
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8,
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30,
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30,
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30,
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30,
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30,
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30,
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30,
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30,
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30,
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30,
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,64.0 %,30,
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,64.0 %,30,
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,64.0 %,30,
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,64.0 %,30,
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,57.0 %,30,
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30,
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,42.0 %,30,
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,27.0 %,30,
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,22.0 %,30,
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,15.0 %,30,
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize ,16,
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize ,16,
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize ,16,
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16,
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0 ,16,
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0 ,16,
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0 ,16,
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16,
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16,
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active ,16,
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always ,16,
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active ,16,
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active ,16,
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active ,16,
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active ,16,
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active ,16,
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active ,16,
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active ,16,
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active ,16,
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15,maximize ,16,
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15,maximize ,16,
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15,maximize ,16,
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15,100 ,16,
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15,0 ,16,
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15,0 ,16,
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15,100 ,16,
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16,
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15,00 ,16,
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16,
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15,Always ,16,
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16,
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15,not active ,16,
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15,not active ,16,
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15,not active ,16,
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15,not active ,16,
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15,not active ,16,
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15,Brake lamp ,16,
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15,not active ,16,
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize ,16,
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize ,16,
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize ,16,
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16,
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0 ,16,
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0 ,16,
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0 ,16,
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16,
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16,
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16,
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always ,16,
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16,
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active ,16,
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active ,16,
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active ,16,
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active ,16,
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active ,16,
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active ,16,
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active ,16,
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize ,16,
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize ,16,
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize ,16,
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,0 ,16,
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0 ,16,
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0 ,16,
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0 ,16,
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,16,
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00 ,16,
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,not active ,16,
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always ,16,
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active ,16,
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active ,16,
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active ,16,
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active ,16,
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active ,16,
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active ,16,
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active ,16,
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active ,16,
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize ,16,
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize ,16,
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize ,16,
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16,
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0 ,16,
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0 ,16,
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0 ,16,
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16,
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16,
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16,
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always ,16,
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16,
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16,
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active ,16,
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active ,16,
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active ,16,
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active ,16,
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active ,16,
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active ,16,
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize ,16,
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize ,16,
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize ,16,
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16,
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0 ,16,
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0 ,16,
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0 ,16,
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16,
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16,
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16,
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always ,16,
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16,
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16,
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active ,16,
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active ,16,
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active ,16,
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active ,16,
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active ,16,
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active ,16,
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize ,16,
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize ,16,
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize ,16,
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16,
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0 ,16,
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0 ,16,
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0 ,16,
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,48 ,16,
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16,
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16,
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16,
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active ,16,
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16,
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active ,16,
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active ,16,
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active ,16,
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active ,16,
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active ,16,
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize ,16,
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize ,16,
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize ,16,
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16,
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0 ,16,
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0 ,16,
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0 ,16,
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,47 ,16,
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16,
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16,
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16,
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active ,16,
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16,
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active ,16,
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active ,16,
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active ,16,
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active ,16,
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active ,16,
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize ,16,
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize ,16,
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize ,16,
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0 ,16,
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0 ,16,
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0 ,16,
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0 ,16,
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16,
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16,
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16,
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always ,16,
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active ,16,
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active ,16,
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16,
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active ,16,
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active ,16,
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active ,16,
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active ,16,
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active ,16,
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize ,16,
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize ,16,
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize ,16,
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0 ,16,
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0 ,16,
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0 ,16,
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0 ,16,
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16,
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16,
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16,
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always ,16,
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active ,16,
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active ,16,
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16,
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active ,16,
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active ,16,
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active ,16,
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active ,16,
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active ,16,
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize ,16,
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize ,16,
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize ,16,
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16,
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0 ,16,
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0 ,16,
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0 ,16,
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16,
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16,
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16,
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always ,16,
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16,
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active ,16,
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active ,16,
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active ,16,
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active ,16,
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active ,16,
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active ,16,
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active ,16,
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize ,16,
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize ,16,
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize ,16,
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16,
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0 ,16,
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,13 ,16,
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0 ,16,
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16,
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16,
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16,
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always ,16,
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16,
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16,
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase ,16,
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active ,16,
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,16,
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,16,
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,16,
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize ,16,
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize ,16,
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize ,16,
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16,
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0 ,16,
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,13 ,16,
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0 ,16,
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16,
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16,
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16,
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always ,16,
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16,
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16,
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase ,16,
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active ,16,
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,16,
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,16,
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,16,
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize ,16,
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize ,16,
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize ,16,
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16,
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0 ,16,
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0 ,16,
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0 ,16,
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,16,
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29 ,16,
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16,
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always ,16,
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake lamp ,16,
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16,
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active ,16,
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active ,16,
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active ,16,
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active ,16,
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active ,16,
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active ,16,
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize ,16,
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize ,16,
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize ,16,
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16,
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16,
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0 ,16,
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0 ,16,
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16,
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A ,16,
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16,
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16,
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16,
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16,
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16,
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,16,
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,16,
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,16,
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,16,
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize ,16,
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize ,16,
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize ,16,
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16,
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16,
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0 ,16,
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0 ,16,
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16,
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A ,16,
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16,
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16,
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16,
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16,
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16,
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,16,
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,16,
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,16,
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,16,
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize ,16,
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize ,16,
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize ,16,
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16,
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0 ,16,
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0 ,16,
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0 ,16,
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,16,
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28 ,16,
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED ,16,
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always ,16,
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16,
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active ,16,
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active ,16,
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active ,16,
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active ,16,
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active ,16,
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active ,16,
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize ,16,
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize ,16,
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize ,16,
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16,
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0 ,16,
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0 ,16,
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0 ,16,
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,54 ,16,
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16,
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16,
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16,
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,16,
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active ,16,
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active ,16,
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active ,16,
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,16,
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,16,
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,16,
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize ,16,
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize ,16,
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize ,16,
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16,
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0 ,16,
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0 ,16,
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0 ,16,
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16,
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16,
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16,
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always ,16,
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16,
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,16,
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active ,16,
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active ,16,
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active ,16,
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,16,
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,16,
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,16,
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize ,16,
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize ,16,
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize ,16,
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16,
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0 ,16,
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0 ,16,
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0 ,16,
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31 ,16,
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B ,16,
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16,
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16,
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht ,16,
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active ,16,
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active ,16,
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active ,16,
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active ,16,
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active ,16,
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active ,16,
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active ,16,
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize ,16,
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize ,16,
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize ,16,
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16,
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0 ,16,
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0 ,16,
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0 ,16,
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32 ,16,
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B ,16,
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16,
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16,
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht ,16,
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active ,16,
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active ,16,
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active ,16,
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active ,16,
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active ,16,
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active ,16,
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active ,16,
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize ,16,
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16,
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize ,16,
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16,
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16,
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16,
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0 ,16,
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16,
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16,
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16,
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always ,16,
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16,
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active ,16,
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16,
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16,
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16,
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16,
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active ,16,
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active ,16,
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize ,16,
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize ,16,
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize ,16,
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16,
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0 ,16,
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0 ,16,
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0 ,16,
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02 ,16,
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00 ,16,
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16,
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,16,
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell lamp ,16,
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active ,16,
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active ,16,
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active ,16,
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active ,16,
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active ,16,
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active ,16,
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active ,16,
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize ,16,
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize ,16,
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize ,16,
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16,
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0 ,16,
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0 ,16,
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0 ,16,
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16,
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00 ,16,
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active ,16,
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always ,16,
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16,
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active ,16,
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active ,16,
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active ,16,
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active ,16,
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active ,16,
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active ,16,
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active ,16,
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize ,16,
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize ,16,
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize ,16,
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16,
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0 ,16,
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0 ,16,
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0 ,16,
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16,
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00 ,16,
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active ,16,
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always ,16,
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16,
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active ,16,
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active ,16,
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active ,16,
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active ,16,
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active ,16,
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active ,16,
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active ,16,
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize ,16,
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize ,16,
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize ,16,
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16,
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0 ,16,
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0 ,16,
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0 ,16,
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16,
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00 ,16,
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active ,16,
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always ,16,
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16,
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active ,16,
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active ,16,
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active ,16,
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active ,16,
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active ,16,
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active ,16,
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active ,16,
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize ,16,
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize ,16,
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize ,16,
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16,
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0 ,16,
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0 ,16,
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0 ,16,
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16,
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00 ,16,
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active ,16,
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always ,16,
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16,
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active ,16,
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active ,16,
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active ,16,
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active ,16,
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active ,16,
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active ,16,
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active ,16,
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize ,16,
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16,
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize ,16,
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16,
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16,
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16,
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0 ,16,
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16,
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16,
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16,
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always ,16,
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16,
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active ,16,
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16,
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16,
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16,
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16,
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active ,16,
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active ,16,
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16,
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize ,16,
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize ,16,
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16,
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,0 ,16,
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16,
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0 ,16,
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16,
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16,
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16,
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always ,16,
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16,
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active ,16,
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16,
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active ,16,
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16,
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16,
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active ,16,
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active ,16,
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16,
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize ,16,
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize ,16,
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16,
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,0 ,16,
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16,
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0 ,16,
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16,
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16,
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16,
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always ,16,
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16,
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active ,16,
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16,
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active ,16,
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16,
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16,
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active ,16,
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active ,16,
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize ,16,
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize ,16,
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize ,16,
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16,
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16,
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0 ,16,
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0 ,16,
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A ,16,
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36 ,16,
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16,
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always ,16,
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links ,16,
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe bei bereits aktivem Abblendlicht oder bereits aktivem Dauerfahrlicht ,16,
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16,
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active ,16,
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active ,16,
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active ,16,
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active ,16,
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active ,16,
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize ,16,
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize ,16,
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize ,16,
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16,
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16,
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0 ,16,
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0 ,16,
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B ,16,
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40 ,16,
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16,
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always ,16,
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts ,16,
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe bei bereits aktivem Abblendlicht oder bereits aktivem Dauerfahrlicht ,16,
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16,
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active ,16,
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active ,16,
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active ,16,
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active ,16,
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active ,16,
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize ,16,
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize ,16,
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize ,16,
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16,
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16,
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0 ,16,
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0 ,16,
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4A ,16,
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16,
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16,
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always ,16,
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16,
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16,
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16,
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active ,16,
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active ,16,
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active ,16,
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active ,16,
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize ,16,
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize ,16,
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize ,16,
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16,
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16,
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0 ,16,
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0 ,16,
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16,
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16,
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16,
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always ,16,
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16,
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16,
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16,
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16,
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active ,16,
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active ,16,
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active ,16,
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active ,16,
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 08 00 0D 00 00 00 23 23 00 3E 18 04 64 05 00 80 08 00 0D 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192,
ENG141662-Leuchtenkonfiguration_Sonstiges,25 00 00 48 08 00 7F 00 00 00 00 00 00 00 00 00 25 00 00 47 08 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 18 00 64 ,128,
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR,1-Sensor_LWR ,62,
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62,
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62,
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62,
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62,
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62,
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz,15 %,62,
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe,10.0 s,62,
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62,
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62,
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62,
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62,
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62,
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62,
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62,
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62,
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62,
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62,
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62,
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62,
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62,
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62,
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62,
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62,
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62,
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle,95.0 %,62,
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62,
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62,
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr,100 Hz,62,
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62,
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62,
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62,
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62,
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62,
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62,
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62,
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62,
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62,
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62,
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,not active ,1,
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,not active ,1,
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,not active ,1,
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,not active ,1,
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,not active ,1,
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,not active ,1,
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,1,
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.0 %,12,
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12,
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12,
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12,
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12,
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12,
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %,12,
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %,12,
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %,12,
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %,12,
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %,12,
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %,12,
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20,
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20,
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20,
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20,
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20,
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20,
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20,
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20,
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20,
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20,
ENG122979-ENG141954-Networking-A/C electronics,installed ,8,
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,installed ,8,
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8,
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8,
ENG122979-ENG99457-Networking-Head area heater,not installed ,8,
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8,
ENG122979-ENG141969-Networking-UGDO,not installed ,8,
ENG124714-ENG142044-OCU-DWA_push,active ,8,
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8,
ENG124714-OCU-,installed ,8,
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8,
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8,
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8,
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8,
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8,
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16,
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16,
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung,not active ,16,
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16,
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16,
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16,
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16,
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16,
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16,
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16,
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,active ,16,
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4,not active ,16,
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5,
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,5,
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5,
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung,not active ,5,
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5,
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5,
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5,
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,5,
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5,
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,5,
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5,
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5,
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10,
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10,
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active ,10,
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10,
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10,
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10,
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10,
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,0 ms,10,
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10,
ENG141684-SFT271873-Slave_systems_identification-Wiper motor control module,Not available ,6,
ENG141684-SFT271874-Slave_systems_identification-Rain/Light Recognition Sensor,Not available ,6,
ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6,
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6,
ENG141684-SFT271877-Slave_systems_identification-Garage door opener control head,Not available ,6,
ENG141684-SFT271894-Slave_systems_identification-Anti-theft alarm system sensor,Not available ,6,
ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6,
ENG141684-SFT271904-Slave_systems_identification-Sunroof control module,Not available ,6,
ENG141684-SFT271910-Slave_systems_identification-Roof electronics control module,Not available ,6,
ENG141684-SFT271928-Slave_systems_identification-Roof shade control module,Not available ,6,
ENG141684-SFT271947-Slave_systems_identification-Humidity sensor: interior,Not available ,6,
ENG141684-SFT271966-Slave_systems_identification-Left head area heater,Not available ,6,
ENG141684-SFT271967-Slave_systems_identification-Right head area heater,Not available ,6,
ENG141684-SFT272065-Slave_systems_identification-Blower 1 for left front backrest,Not available ,6,
ENG141684-SFT272067-Slave_systems_identification-Blower 1 for left front seat cushion,Not available ,6,
ENG141684-SFT272069-Slave_systems_identification-Blower 1 for right front backrest,Not available ,6,
ENG141684-SFT272071-Slave_systems_identification-Blower 1 for right front seat cushion,Not available ,6,
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4,
ENG116588-Sonderfunktionen-,not enabled ,4,
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1,not installed ,4,
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5,
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5,
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5,
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5,
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5,
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5,
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung,active ,5,
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5,
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,active ,5,
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5,
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10,
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10,
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10,
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10,
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10,
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0,0.0 lx,10,
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1,8.0 lx,10,
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2,50.0 lx,10,
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3,80.0 lx,10,
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4,100.0 lx,10,
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0,6.0 ,10,
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1,6.0 ,10,
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2,20.0 ,10,
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3,50.0 ,10,
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4,100.0 ,10,
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0,0.0 lx,10,
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1,8.0 lx,10,
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2,50.0 lx,10,
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3,80.0 lx,10,
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4,100.0 lx,10,
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0,6.0 ,10,
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1,6.0 ,10,
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2,20.0 ,10,
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3,50.0 ,10,
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4,100.0 ,10,
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0,0 ms,22,
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22,
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22,
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22,
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22,
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22,
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22,
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22,
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22,
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22,
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22,
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0,100.0 %,22,
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22,
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10,0.0 %,22,
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22,
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22,
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22,
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22,
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22,
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22,
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22,
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22,
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.00 s,21,
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21,
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21,
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21,
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21,
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21,
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21,
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21,
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe,not active ,21,
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21,
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung,active ,21,
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21,
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21,
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21,
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi ,21,
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,21,
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21,
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21,
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0,0 ,22,
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1,50 ,22,
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10,0 ,22,
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2,100 ,22,
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3,200 ,22,
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4,253 ,22,
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5,0 ,22,
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6,0 ,22,
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7,0 ,22,
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8,0 ,22,
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9,0 ,22,
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0,0 lx,22,
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22,
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10,0 lx,22,
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22,
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22,
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 ,22,
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 ,22,
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6,0 lx,22,
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7,0 lx,22,
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8,0 lx,22,
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9,0 lx,22,
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0,0 ms,22,
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22,
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22,
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22,
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22,
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22,
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22,
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22,
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22,
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22,
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22,
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0,0.0 %,22,
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22,
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10,100.0 %,22,
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22,
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22,
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22,
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22,
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22,
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22,
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22,
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22,
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0,0 lx,8,
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1,8 lx,8,
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2,50 lx,8,
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3,500 lx,8,
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0,100.0 ,8,
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1,100.0 ,8,
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2,100.0 ,8,
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3,100.0 ,8,
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0,0 lx,8,
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1,8 lx,8,
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2,50 lx,8,
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8,
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0,6.0 ,8,
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1,6.0 ,8,
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2,100.0 ,8,
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3,100.0 ,8,
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 %,12,
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 %,12,
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 %,12,
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 %,12,
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 %,12,
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 %,12,
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0,10 ,12,
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1,10 ,12,
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2,100 ,12,
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3,150 ,12,
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4,220 ,12,
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5,253 ,12,
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0,0 lx,10,
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1,8 lx,10,
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2,200 lx,10,
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3,300 lx,10,
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4,500 lx,10,
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0,16.0 ,10,
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1,16.0 ,10,
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2,100.0 ,10,
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3,100.0 ,10,
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4,100.0 ,10,
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0,0 lx,10,
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,50 lx,10,
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2,220 lx,10,
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3,300 lx,10,
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4,500 lx,10,
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0,6.0 ,10,
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,16.0 ,10,
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,25.0 ,10,
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,30.0 ,10,
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10,
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0,0 ,12,
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1,10 ,12,
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12,
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12,
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4,220 ,12,
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5,253 ,12,
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12,
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12,
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12,
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12,
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12,
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5,100.0 %,12,
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0,0 lx,8,
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1,8 lx,8,
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2,50 lx,8,
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3,500 lx,8,
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0,6.0 ,8,
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1,6.0 ,8,
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2,100.0 ,8,
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3,100.0 ,8,
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0,0 lx,8,
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1,8 lx,8,
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2,50 lx,8,
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3,500 lx,8,
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0,100.0 ,8,
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1,100.0 ,8,
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2,100.0 ,8,
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3,100.0 ,8,
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 %,6,
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 %,6,
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 %,6,
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0,0.0 %,6,
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1,50.0 %,6,
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2,100.0 %,6,
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,12,
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12,
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12,
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12,
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,12,
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1020 lx,12,
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,12,
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12,
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12,
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12,
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12,
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,12,
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ms,10,
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,2000 ms,10,
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,3000 ms,10,
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,4000 ms,10,
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,5100 ms,10,
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,1.0 %,10,
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 ,10,
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 ,10,
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 ,10,
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 ,10,
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4,
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4,
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4,
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4,
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3,not installed ,4,
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4,
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4,
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,9,
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9,
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv,active ,9,
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9,
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9,
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9,
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9,
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9,
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9,
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9,
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9,
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9,
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9,
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,9,
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9,
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9,
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9,
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9,
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9,
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9,
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,active ,9,
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,active ,9,
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,installed ,9,
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 ,20,
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 ,20,
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 ,20,
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 ,20,
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,20,
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,20,
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,20,
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,20,
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,20,
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,20,
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,7,
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,not active ,7,
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,7,
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7,
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein,not active ,7,
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7,
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7,
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion,not active ,7,
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,7,
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7,
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung,not active ,7,
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7,
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7,
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,Freigabe_Softtouch ,7,
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7,
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7,
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck,active ,3,
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln,active ,3,
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,3,
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3,
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3,
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3,
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4,
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4,
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4,
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7,
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,7,
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,7,
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7,
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7,
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7,
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7,
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7,
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7,
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7,
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang,No ,7,
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel,active ,7,
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen,not active ,7,
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp,1 or 2 notch rear actuator ,7,
ENG141681-IDE02021-ZV Komfort-Comfort closing,active ,8,
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8,
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten,Yes ,8,
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8,
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8,
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit,600 s,8,
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus,active ,8,
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8,
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,not active ,8,
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8,
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global,active ,8,
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer,not active ,8,
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8,
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen,not active ,8,
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art,once ,8,
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus,not active ,8,
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8,
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8,
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5,
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal,nicht invertiert ,5,
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite,not installed ,5,
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite,not installed ,5,
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links,No ,5,
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts,No ,5,
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter,not installed ,5,
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM,Driver side ,5,
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,5,
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5,
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer,Yes ,5,
Elapsed Time: 01:58,,,
adpmap-4B-3Q0-907-338_3VV4B7AX8JM153175-20220720-2148.CSV
;SW:3Q0-907-338   HW:3Q0-907-338 ---  Multifunc. Module
;Component:FCM MQB Low   002 0286, Coding:0000000501001D5200210F01090000000000000000000000000000000000
;EV_MultiModulContiVW48X,001010,EV_MultiModulContiVW48X_001.rod
;Wednesday,20,July,2022,21:48:05:07998
;VCDS Version: Beta 22.6.0 (x64)  Data version: 20220530 DS341.0
;VCID: 72BED5CD442ED27BDD7-8026
IDE00001-Production mode,not active ,3,
IDE00820-Activating and deactivating all development messages,not active ,1,
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes ,1,
IDE01996-SFT00041-Installation list: specified installations-Left light control,Yes ,1,
IDE01996-SFT00057-Installation list: specified installations-Right light control,Yes ,1,
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,Yes ,1,
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1,
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1,
IDE02332-Deactivate production mode,0 ,3,
IDE03641-Presentation run dynamic AFS light,active ,1,
IDE03642-Presentation mode,not active ,1,
IDE03679-Adaptive light functions,active ,1,
IDE03787-Activate left/right hand drive switch-over,not active ,1,
IDE08418-Matrix light: total dimming,100 %,1,
IDE09156-Matrix headlamp: function at standstill,not active ,1,
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6,
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6,
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6,
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6,
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6,
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6,
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6,
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6,
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6,
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6,
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6,
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6,
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6,
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6,
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6,
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6,
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6,
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6,
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6,
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6,
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6,
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6,
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6,
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6,
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6,
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6,
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6,
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6,
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6,
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6,
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6,
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6,
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6,
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6,
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6,
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6,
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6,
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6,
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6,
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6,
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6,
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6,
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6,
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6,
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6,
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6,
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6,
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6,
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6,
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6,
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6,
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6,
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6,
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6,
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6,
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6,
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6,
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6,
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6,
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6,
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6,
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6,
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6,
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6,
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6,
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6,
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6,
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6,
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6,
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6,
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6,
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6,
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6,
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6,
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6,
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6,
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6,
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6,
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6,
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6,
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6,
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6,
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6,
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6,
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6,
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6,
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6,
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6,
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6,
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6,
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,0 %,12,
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,0 %,12,
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,0 %,12,
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,0 %,12,
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,0 %,12,
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,0 %,12,
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,0 %,12,
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,0 %,12,
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,0 %,12,
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,0 %,12,
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,0 %,12,
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,0 %,12,
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1,
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1,
ENG103979-Reference_Run_Start_Condition,Engine start ,1,
Elapsed Time: 00:08,,,
adpmap-19-3Q0-907-530-L_3VV4B7AX8JM153175-20220720-2134.CSV
;SW:3Q0-907-530-L   HW:3Q0-907-530-C ---  CAN Gateway
;Component:GW MQB High   518 5323, Coding:030500347F085900FB07225A1E0F00010001070000000000000000000000
;EV_GatewNF,013023,EV_GatewNF_VW37.rod
;Wednesday,20,July,2022,21:34:49:07998
;VCID: 382A27E562D2782B233-806C
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3,
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3,
IDE00002-Transport mode,not active ,1,
IDE00820-MAS01172-Activating and deactivating all development messages-Development messages,not active ,1,
IDE00820-ENG98891-Activating and deactivating all development messages-Reserved,0 ,1,
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2,
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2,
IDE01211-Static current measuring mode,not activated ,1,
IDE01457-Energy management deactivation stage,Mode not active ,1,
IDE01459-Energy management heat output control status,Mode not active ,1,
IDE01844-Increase idle speed request,Mode not active ,1,
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3,
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3,
IDE01860-Generator specified voltage value variable,10.6 V,1,
IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32,
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,coded ,32,
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32,
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32,
IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,coded ,32,
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32,
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32,
IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32,
IDE01996-SFT00019-Installation list: specified installations-Distance Regulation,coded ,32,
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,Not coded ,32,
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32,
IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems,coded ,32,
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32,
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32,
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32,
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32,
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32,
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32,
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,coded ,32,
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32,
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32,
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,coded ,32,
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32,
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32,
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,coded ,32,
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,coded ,32,
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32,
IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32,
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32,
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32,
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32,
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,coded ,32,
IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32,
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32,
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,Not coded ,32,
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32,
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32,
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32,
IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32,
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32,
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,coded ,32,
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32,
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,coded ,32,
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,coded ,32,
IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32,
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32,
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32,
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32,
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,coded ,32,
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32,
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32,
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,coded ,32,
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32,
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32,
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32,
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32,
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32,
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32,
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32,
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,Not coded ,32,
IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,coded ,32,
IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32,
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2,Not coded ,32,
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32,
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32,
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32,
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32,
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32,
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32,
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32,
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32,
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32,
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32,
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32,
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32,
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32,
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32,
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32,
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32,
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32,
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32,
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32,
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32,
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32,
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32,
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32,
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32,
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32,
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32,
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32,
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32,
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32,
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32,
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32,
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32,
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32,
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32,
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32,
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32,
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32,
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32,
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32,
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32,
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32,
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32,
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32,
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32,
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32,
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32,
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32,
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32,
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32,
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32,
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32,
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32,
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32,
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32,
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32,
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32,
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32,
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32,
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32,
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32,
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32,
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32,
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32,
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32,
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32,
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32,
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32,
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32,
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32,
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32,
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32,
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32,
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32,
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32,
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32,
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32,
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32,
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32,
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32,
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32,
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32,
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32,
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32,
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32,
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32,
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32,
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32,
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32,
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32,
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32,
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32,
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32,
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32,
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32,
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32,
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32,
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32,
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32,
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32,
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32,
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32,
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32,
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32,
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32,
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32,
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32,
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32,
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32,
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32,
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32,
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32,
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32,
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32,
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32,
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32,
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32,
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32,
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32,
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32,
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32,
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32,
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32,
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32,
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32,
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32,
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32,
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32,
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32,
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32,
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32,
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32,
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32,
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32,
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32,
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32,
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32,
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32,
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32,
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32,
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32,
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32,
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32,
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32,
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32,
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32,
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32,
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32,
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32,
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32,
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32,
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32,
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32,
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32,
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32,
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32,
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32,
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32,
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32,
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32,
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32,
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32,
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32,
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32,
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32,
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32,
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32,
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32,
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32,
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32,
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32,
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32,
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32,
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32,
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32,
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32,
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32,
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32,
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32,
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32,
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32,
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32,
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32,
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32,
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32,
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32,
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32,
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32,
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32,
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32,
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32,
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32,
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,69 Ah,15,
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15,
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15,
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15,
IDE03903-Production process data 1,00 00 ,2,
IDE04159-Deactivation of start/stop function,Mode not active ,1,
IDE04186-Battery terminal recognition,connected ,1,
IDE04330-Transfer of release code for a SWaP function,00 ,1,
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF ,4,
IDE06530-Distance left for deactivation of static current measuring mode,2 ,1,
IDE06541-Distance left for deactivation of transport mode,50 ,1,
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4,
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4,
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4,
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4,
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4,
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4,
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4,
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4,
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4,
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4,
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4,
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4,
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4,
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4,
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4,
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4,
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4,
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4,
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4,
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4,
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4,
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4,
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4,
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4,
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4,
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4,
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4,
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4,
IDE07838-Counter for inconsistent states,4 ,2,
IDE08348-Start/stop start voltage limit,12.0 V,1,
IDE08624-MKE Check box,activated ,1,
IDE10735-Number requests autonomous recharging,3 ,1,
IDE10736-Cyclization limitation request battery service,0 ,1,
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3,
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3,
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3,
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3,
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3,
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3,
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3,
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3,
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3,
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3,
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3,
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3,
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3,
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3,
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3,
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3,
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3,
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3,
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3,
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3,
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3,
IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3,
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,activated ,3,
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,activated ,3,
IDE11689-48V-System: locking,regular operation ,1,
MAS16372-Security version number,2 ,2,
SFT271921-IDE02583-Multifunction steering wheel control module-Steering wheel Tiptronic switch,not installed ,3,
SFT271921-MAS02311-Multifunction steering wheel control module-Steering wheel heating button,not active ,3,
SFT271921-MAS04733-Multifunction steering wheel control module-Two-stage,not active ,3,
SFT271921-MAS06614-Multifunction steering wheel control module-Variant,ACC ,3,
SFT271921-MAS09758-Multifunction steering wheel control module-Temperature sensor,installed ,3,
SFT271921-MAS13892-Multifunction steering wheel control module-Platform,MQB ,3,
SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,not active ,3,
SFT271921-ENG258379-Multifunction steering wheel control module-clamp behaviour,active with terminal 58 ,3,
SFT271921-ENG260738-Multifunction steering wheel control module-FoD ACC,automatic ,3,
SFT271921-ENG258784-Multifunction steering wheel control module-FoD Travel Assist,automatic ,3,
SFT271921-ENG262857-Multifunction steering wheel control module-Kombi_02_gueltig,not active ,3,
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12,
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12,
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12,
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12,
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12,
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12,
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12,
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12,
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,0 ms,12,
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms,12,
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4,
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4,
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4,
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4,
ENG137075-EM_heating_power_quota_adjustment,1000 W,1,
ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1,
ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1,
ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1,
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2,
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2,
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32,
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32,
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32,
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32,
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module,activated ,32,
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32,
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32,
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32,
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulation,activated ,32,
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32,
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32,
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systems,activated ,32,
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32,
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32,
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,activated ,32,
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32,
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32,
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32,
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32,
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32,
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32,
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32,
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32,
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32,
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32,
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32,
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32,
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32,
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32,
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32,
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32,
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32,
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32,
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32,
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32,
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32,
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32,
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32,
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32,
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32,
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32,
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32,
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32,
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32,
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32,
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32,
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32,
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32,
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems,activated ,32,
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32,
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32,
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32,
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32,
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32,
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32,
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32,
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32,
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32,
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32,
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32,
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32,
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32,
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,activated ,32,
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32,
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32,
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32,
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32,
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32,
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32,
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32,
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32,
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32,
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32,
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32,
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32,
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32,
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32,
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32,
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32,
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32,
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32,
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32,
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32,
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32,
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32,
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32,
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32,
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32,
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32,
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32,
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32,
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32,
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32,
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32,
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32,
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32,
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32,
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32,
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32,
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32,
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32,
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32,
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32,
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32,
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32,
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32,
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32,
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32,
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32,
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32,
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32,
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32,
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32,
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32,
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32,
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32,
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32,
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32,
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32,
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32,
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32,
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32,
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32,
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32,
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32,
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32,
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32,
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32,
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32,
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32,
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32,
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32,
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32,
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32,
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32,
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32,
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32,
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32,
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32,
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32,
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32,
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32,
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32,
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32,
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32,
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32,
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32,
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32,
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32,
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32,
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32,
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32,
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32,
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32,
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32,
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32,
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32,
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32,
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32,
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32,
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32,
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32,
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32,
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32,
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32,
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32,
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32,
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32,
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32,
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32,
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32,
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32,
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32,
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32,
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32,
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32,
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32,
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32,
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32,
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32,
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32,
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32,
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32,
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32,
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32,
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32,
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32,
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32,
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32,
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32,
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32,
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32,
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32,
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32,
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32,
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32,
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32,
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32,
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32,
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32,
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32,
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32,
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32,
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32,
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32,
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32,
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32,
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32,
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32,
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,activated ,32,
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,activated ,32,
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,activated ,32,
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,activated ,32,
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,activated ,32,
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,activated ,32,
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,activated ,32,
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,activated ,32,
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,activated ,32,
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,activated ,32,
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,activated ,32,
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,activated ,32,
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,activated ,32,
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,activated ,32,
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,activated ,32,
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,activated ,32,
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,activated ,32,
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,activated ,32,
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,activated ,32,
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,activated ,32,
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,activated ,32,
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,activated ,32,
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,activated ,32,
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,activated ,32,
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,activated ,32,
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,activated ,32,
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,activated ,32,
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,activated ,32,
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,activated ,32,
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,activated ,32,
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,activated ,32,
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,activated ,32,
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,activated ,32,
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,activated ,32,
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,activated ,32,
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,activated ,32,
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,activated ,32,
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,activated ,32,
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,activated ,32,
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,activated ,32,
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,activated ,32,
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,activated ,32,
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,activated ,32,
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,activated ,32,
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,activated ,32,
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,activated ,32,
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Powertrain data bus ,2,
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2,
ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1,
ENG137850-MVK_Warning,regular operation ,1,
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1,
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1,
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8,
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8,
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,10 ,8,
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,120 min,8,
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8,
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8,
Elapsed Time: 00:24,,,
That's a 2018 SEL Premium, "Annie". Those were from last July, testing DS341. I have maps of all the modules made then, but I do not have access to that vehicle at this time.
eurospekgarage
Houston, TX, USA
C?ID=314389
Thanks Uwe! I will give these a try and see what happens. Hope you had a pleasant Thanksgiving!
