i need bcm coding please ,someone have make wrong coding before the car to arrive to me,the high beam it wont stay on,no interior blower,no rear wiper working
Thursday,24,November,2022,11:33:07:28383
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: WVWZZZ1KZBM618165 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZBM618165 Mileage: 264780km-164526miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 997 557 R HW: 03L 906 023 A
Component: R4 1.6l TDI H23 9984
Revision: --H23--- Serial number: 00000000000000 CVN: 20E9CECC
Coding: 00114014030401080000
Shop #: WSC 00066 000 00085
ASAM Dataset: EV_ECM16TDI02103L997557R 003004
ROD: EV_ECM16TDI02103L997557Q.rod
VCID: 4BC39B020343FDA34E0-801E
VINID: 9E69EAAAA05BA92746048046142E050A9F
10165 - Glow Plug Module 1; Glow Plug Circuit
P0670 00 [175] - Electrical Malfunction
Mileage: 264773 km
Date: 2022.11.20
Time: 18:21:15
Engine RPM: 959.25 /min
Normed load value: 18.4 %
Coolant temperature: 8 °C
Intake air temperature: 9 °C
Voltage terminal 30: 11.294 V
Glow status-STATE_GLOW: 176
Fuel temperature-TFU: 7 °C
Sensor for engine block temperature: raw value-Coolant temperature: 9 °C
10123 - ECM Power Relay Control Circuit
P0685 00 [032] - Open Circuit
Mileage: 264774 km
Date: 2022.11.23
Time: 13:49:52
Engine RPM: 0.00 /min
Coolant temperature: 53 °C
Intake air temperature: 16 °C
Voltage terminal 30: 0.000 V
Battery voltage: 0.0 V
Voltage terminal 15-V_IGK: 11.7 V
Starter control: Start interruption status-Binary 16 Bit: 00011001 00000000
Fuel pressure regulator valve actual value-CFB_PCV_MES: 0.067 A
Valve for fuel metering: feedback value measured-CFB_VCV_MES: 0.060 A
10454 - Output for Starter Relay
P0616 00 [038] - Short to Ground
Mileage: 264782 km
Date: 2022.11.24
Time: 21:07:24
Engine RPM: 783.00 /min
Normed load value: 12.2 %
Coolant temperature: 44 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.005 V
Engine RPM: 782 /min
Battery voltage: 14.0 V
Starter activation: status-FRF_ST_RL: 1
Sensor for engine block temperature: raw value-Coolant temperature: 44 °C
Number of resets of main unit-CTR_RST_MC: 0
10453 - Output for Starter Relay
P0615 00 [038] - Open Circuit
Mileage: 264782 km
Date: 2022.11.24
Time: 21:05:33
Engine RPM: 778.25 /min
Normed load value: 14.9 %
Coolant temperature: 39 °C
Intake air temperature: 10 °C
Voltage terminal 30: 14.344 V
Engine RPM: 781 /min
Battery voltage: 14.3 V
Readiness: 1 1 0 0 1
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 113B200D09230002880C04EA901E0051310000
Shop #: WSC 00066 000 00000
VCID: 0451703E6E1DF2DBCFA-8050
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000003
Shop #: WSC 00066 000 00149
ROD: EV_ClimaBasis_VW36.rod
VCID: 6D87359A5D171393304-8038
Part No SW: 5K0 937 086 F HW: 5K0 937 086 F
Component: BCM PQ35 M 011 0035
Revision: BC011001
Coding: 07180EBA983F02C040000080350081E403610287425D8160648003000041
Shop #: WSC 00011 888 77253
VCID: 372BD7F26F4B69431A8-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 15081 21 0512
Coding: 009795
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 183
Mileage: 264782 km
Date: 2022.11.24
Time: 21:16:14
Voltage: 14.25 V
02391 - Terminal 30 Reference
Reset counter: 183
Mileage: 264782 km
Date: 2022.11.24
Time: 21:16:11
Voltage: 13.95 V
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA9YDKM
Coding: 00003137
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B23CBC253E34D23FE0-806E
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME646E3555ZZZ+
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME5B357153ZZZY
Serial number: 3511HSME71336322ZZZ8
Serial number: 3521HSME74136422ZZZB
Part No SW: 5K0 953 507 AS HW: 5K0 953 549 C
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JFT0009I
Coding: 5080040000
Shop #: WSC 00066 000 00187
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 015F792A718FE7F3E4C-8054
Part No SW: 5K0 920 861 A HW: 5K0 920 861 A
Component: KOMBI H21 0204
Revision: X0021007 Serial number:
Coding: 171918
Shop #: WSC 00066 123 00187
ASAM Dataset: EV_KombiUDSMM9RM10 A04203
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 2B03FB82A383DDA36E0-807E
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 09081001200417
Coding: E9807F0640020204002002
VCID: 2E05F2969C11A88B49E-807A
Part No SW: 5K0 953 234 HW: 5K0 920 861 A
Component: IMMO H21 0204
ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
VCID: 6A8D3E866CF904AB556-803E
Address 37: Navigation (J794) Labels:| 3C0-035-270.clb
Part No SW: 3C0 035 270 B HW: 3C0 035 270
Component: RNS310 H15 0351
Revision: 10000000 Serial number: VWZ1Z2K6283330
Coding: 000004010400000000000000
Shop #: WSC 01383 790 50316
ASAM Dataset: VW_RNS310 A02007
ROD: EV_VWRNS310UDS.rod
VCID: 196F314AF91F5F330CC-804C
1048577 - Supply voltage
U1012 00 [008] - Voltage too High
[supply voltage upper limit exceeded]
Reset counter: 223
Mileage: 264774 km
Date: 2022.11.23
Time: 00:13:04
1048579 - Function Restricted due to Excessive Voltage
U1401 00 [008] - -
[restriction due to overvoltage]
Reset counter: 223
Mileage: 264774 km
Date: 2022.11.23
Time: 00:13:04
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001257528
Coding: 0210B4
ROD: EV_DCU42BroseDriveSide_VW32.rod
VCID: 270B07B2BF6BF9C38A8-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005185246
Coding: 000090
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 182
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 313FE9EA8D2FB77354C-8064
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001268156
Coding: 0200B4
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 2809048EB275F6BB832-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005130194
Coding: 000090
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H25 5603
Coding: 030B185A
VCID: 71BF29EA41AFF77314C-8024
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 182
Mileage: 264774 km
Date: 2022.11.23
Time: 00:51:56
End----------(Elapsed Time: 01:25, VBatt start/end: 14.0V/13.9V)-----------
