Newbie user with P2006 issue
Jaymz77
Sydney, Australia
C?ID=522258
Hi folks,
as the title suggest i am a newbie at this and was hoping for some help.
I have a 2021 Amarok that has has some upgrades done to it. One of them is the elimination of the intake manifold butterfly/ swirl flap.
This has resulted in error codes (P2006 00 [039]) in my VCDS scans and the "check engine" light on the dash. My tuner is having issues resolving this for me.
I was hoping for some instruction on how to turn the butterfly off in the coding so i no longer get errors and lights on the dash.
Cheers
Westbury, UK
The butterfly is an integral part of the engine control systems, so the likelihood of being able to eliminate it by a coding change is IMHO vanishingly small and the tuner will have to make changes too the firmware in the engine ECU to remove it.
Please post an Auto-Scan to confirm my thoughts.
  • Agree
Jaymz77
Sydney, Australia
C?ID=522258
Thanks for your reply.
The car runs perfectly well without the butterfly in place, it just throws error codes.
Initially when auto scanned it returned this error message:
28486 - Intake Manifold Flap Position Sensor
          U11F9 00 [039] - No Communications
          [Sensor for intake manifold flap position/runner controlNo communication]
                    Mileage: 34201 km
                    Date: 2022.11.20
                    Time: 00:35:47
                    Engine RPM: 0.00 /min
                    Coolant temperature: 26 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 12.200 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Intake manifold Runner Control (IMRC): activation: 100.00 %
                    Intake manifold Runner Control (IMRC): acknowledgment: -23.41 %
                    Potentiometer for intake manifold flap: digit. value-Bits 0-7: 0
                    Charge air pressure: actual value: 991.95 hPa
                    Actuator for intake manifold runner control: status-Bits 0-7: 0
                    Actuator for intake manifold runner control: status-Bits 0-7: 7
                    Actuator for intake manifold runner control: status-Bits 0-7: 4
Readiness: 0 0 0 0 X
I reported the above to the tuner who did make some unknown change to the map.
It must have made some difference because then on the second attempt, the warning light on the dash was no longer present but i got the following code in the follow up auto scan:
9129 - Intake Manifold Flap; Bank 1
          P2006 00 [039] - Stuck Closed
                    Mileage: 34406 km
                    Date: 2022.11.23
                    Time: 07:09:38
                    Coolant temperature: 17 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 12.020 V
                    Charge air pressure: actual value: 1006.95 hPa
                    Actuator for intake manifold runner control: status-Bits 0-7: 69
Your help is appreciated.
This is not something that can be done with a scan tool; it has to be done by modifying the firmware in the ECU. If the tuner you're currently using can't do it, then you'll have to find one who can.
Then again, if what he's done doesn't trigger the Check Engine light and with the DTC being "Not Confirmed", you might consider just living with it as is.
Jaymz77
Sydney, Australia
C?ID=522258
It got to a point where it was throwing error codes but the check engine light was not on. That i could live with.
But not the check engine light is back on and a) it annoys me, and b) i wont know if there are ever any other engine issues if it is always on.
Any suggestions what i may be able to do myself to get rid of the light?
(My tuner has been great but this is all being done remotely and is starting to become a bit tedious. I just want it done and dusted)
Cheers.
Westbury, UK
I think Uwe has already given you the answer - find a local tuner since no scan tool can fix it.
