- Apr 3, 2022
- 18
- 2
- Rochester, NY, USA
- C?ID=514497
Hi All,
A follow up to my NTA / PRU Transmission question...
Our powertrain swap went smoothly. We thought we might be OK as far as coding issues went because we used the same PCM. All the sensors were the same, so we just flopped the 2015 harness back on top of the 2013 Engine and transmission. The car started right up, with no leaks. We ran it on the lift idling and occasionally at a high idle for about an hour. The bumper cover and lights are still off of it, but everything is intact from the core support back.
Then we discovered the transmission would not go into any gear (the shifter moves, but the wheels would not turn at all).
Then we got out the VAG-COM.
The most concerning to me is the transmission controller saying it is LOCKED. I find on this forum that there is nothing I can do with VAG-COM to make it work?
Even if I have to take it to Audi for a complete fix, I was hoping to at least be able to drive it onto the trailer!
The scan after I reset all codes. Car had not been restarted.
I'm sure you can see lots of other interesting things in there too.
Thanks!
Thanks!
Wednesday,23,November,2022,20:46:03:30451
VCDS Version: 22.3.0.1 (x64) HEX-NET2 CB: 0.4615.4
Data version: 20220225 DS336.1
VIN: WAUFFAFL2FN011025 License Plate:
Mileage: 176430km-109628mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
6C 72
VIN: WAUFFAFL2FN011025 Mileage: 176430km-109628miles
Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 N HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09--- CVN: FE64ECCA
Coding: 4A2A0013242600062000
Shop #: WSC 51623 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
ROD: EV_ECM20TFS0118K5907115N.rod
VCID: 3D2C505B7DF6C1D3E44-8068
VINID: 9D195659159C096780041002141F5E45B1
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [100] - -
Mileage: 176436 km
Date: 2022.11.23
Time: 15:46:33
Engine RPM: 2178.50 /min
Normed load value: 8.2 %
Coolant temperature: 95 °C
Intake air temperature: 22 °C
Voltage terminal 30: 14.559 V
Unlearning counter according OBD: 76
Engine status: COENG_RUNNING
10593 - Cylinder 3
P0303 00 [100] - Misfire Detected
Mileage: 176436 km
Date: 2022.11.23
Time: 15:46:33
10592 - Cylinder 2
P0302 00 [100] - Misfire Detected
Mileage: 176436 km
Date: 2022.11.23
Time: 15:46:33
Voltage terminal 30: 14.536 V
7786 - Sensor for Ambient Air Temperature (G17)
P0070 00 [175] - Malfunction
Mileage: 176436 km
Date: 2022.11.23
Time: 15:33:58
Engine RPM: 798.50 /min
Normed load value: 22.7 %
Coolant temperature: 49 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.442 V
Readiness: 1110 0101
Part No SW: 8K0 927 158 T HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1003
Revision: --H16--- CVN: 17DA5374
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002020
VCID: 47C032B32F2A9B034E8-8012
2543 - Transmission Control Unit
P1701 00 [175] - Locked
Mileage: 176436 km
Date: 2022.11.23
Time: 15:33:57
Voltage terminal 30: 14.533 V
Immobilizer Snapshot 1-Param 0: 11
Immobilizer Snapshot 1-Param 1: 11
Immobilizer Snapshot 1-Param 2: 8A
Immobilizer Snapshot 1-Param 3: 1F
Immobilizer Snapshot 1-Param 4: 00
Immobilizer Snapshot 1-Param 5: 00
Status data bus communication diagnostic interface-State Deashboard received: not received
Status data bus communication diagnostic interface-State ECM received: not received
Status data bus communication diagnostic interface-State ESP received: not received
Status data bus communication diagnostic interface-State Gateway received: not received
Status data bus communication diagnostic interface-State Parking Brake received: not received
Status data bus communication diagnostic interface-State Steering Angle received: not received
Status data bus communication diagnostic interface-State Steering Assist received: not received
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Coding: 2D1D1801
Shop #: WSC 02391 785 00200
VCID: 0944F48B793E2D7398C-805C
11 Faults Found:
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:57:04
Hex Value: 0x0000
Hex Value: 0x1002
Hex Value: 0x0023
Hex Value: 0x0264
Hex Value: 0x0000
Fault Frequency: 12
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:57:48
Hex Value: 0x0000
Hex Value: 0x1002
Hex Value: 0x0032
Hex Value: 0x2461
Hex Value: 0x0000
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 17
Reset counter: 196
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:35
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0022
Hex Value: 0x339B
Hex Value: 0x0000
Fault Status: 00101101
Reset counter: 235
Mileage: 176436 km
Date: 2022.10.29
Time: 19:51:30
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x021A
Hex Value: 0x0296
Hex Value: 0x0000
012 - Electrical Fault in Circuit - Intermittent - MIL ON
Fault Status: 10101100
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:02
Hex Value: 0x0000
Hex Value: 0x0780
Hex Value: 0x0048
Hex Value: 0xB0A1
Hex Value: 0x0000
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:02
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x002F
Hex Value: 0x7AA1
Hex Value: 0x0000
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:03
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x0012
Hex Value: 0xB9A1
Hex Value: 0x0000
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:03
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x000D
Hex Value: 0x85A1
Hex Value: 0x0000
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:03
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x000C
Hex Value: 0xE3A1
Hex Value: 0x0000
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:03
Hex Value: 0x0000
Hex Value: 0x2780
Hex Value: 0x001F
Hex Value: 0x40A1
Hex Value: 0x0000
01119 - Gear Recognition Signal
Reset counter: 236
Mileage: 176436 km
Date: 2022.11.23
Time: 15:23:30
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x000D
Hex Value: 0x2792
Hex Value: 0x0000
Part No SW: 8K0 907 064 JM HW: 8K0 907 064 JM
Component: BCM2 2.0 H14 0650
Coding: 0D814040000000000000
VCID: 045AE5BF5E1C701BEBA-8050
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Serial number: 0514000112790019
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000151237013
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:33:33
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:33:37
Fault Frequency: 28
Reset counter: 196
Mileage: 176435 km
Date: 2022.10.25
Time: 21:55:56
00955 - Key 1
Fault Status: 01100010
Reset counter: 195
Mileage: 176436 km
Date: 2022.11.11
Time: 21:12:49
02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted
Reset counter: 195
Mileage: 176436 km
Date: 2022.11.23
Time: 15:23:18
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01200820140651
Coding: 6480208000
VCID: 77A082731FCA2B83FE8-8022
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:54:45
Voltage: 8.40 V
Temperature: 19.0°C
Reset counter: 195
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:31
Reset counter: 235
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:36
Temperature: 11.0°C
Fault Status: 01101000
Fault Frequency: 8
Reset counter: 196
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:39
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000875583302
Coding: 26000091863CAFC00000480300003D0D0F1C5308A2090221000008004000030100000030000000
VCID: 78A2814F12D424FBF72-802C
Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B Labels: 1KX-955-119.CLB
Component: MITSUBA090714 H18 0461
Serial number: 1407040603896
Coding: 004577
Component: G397_RLFS H06 0002
Serial number: 22945220
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002307140698
Component: USHL4.2 H30 0030
Serial number: 0000002274555R8V3103
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: C279CD37000000000001
17 Faults Found:
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:33:32
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:56:21
Fault Status: 01101100
Fault Frequency: 22
Reset counter: 196
Mileage: 176436 km
Date: 2022.10.29
Time: 17:31:46
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Reset counter: 195
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:34
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 195
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:34
Reset counter: 235
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:36
02258 - Door Opener Transmitter
Reset counter: 235
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:36
00908 - Control Module for Wiper Motor
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:03
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:07
03188 - Bulb for Side Marker Light; Front Left
Reset counter: 195
Mileage: 176436 km
Date: 2022.11.23
Time: 15:31:35
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 195
Mileage: 176436 km
Date: 2022.11.23
Time: 15:31:35
Reset counter: 195
Mileage: 176436 km
Date: 2022.11.23
Time: 15:31:37
Reset counter: 195
Mileage: 176436 km
Date: 2022.11.23
Time: 15:31:37
Reset counter: 196
Mileage: 176436 km
Date: 2022.11.23
Time: 15:48:52
Reset counter: 196
Mileage: 176436 km
Date: 2022.11.23
Time: 15:48:52
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 196
Mileage: 176436 km
Date: 2022.11.23
Time: 16:02:26
Reset counter: 196
Mileage: 176436 km
Date: 2022.11.23
Time: 16:02:26
Part No SW: 8K0 959 655 Q HW: 8K0 959 655 Q
Component: AirbagVW-AU10 H51 0812
Serial number: 003NDD12A66Y
Coding: 303844354730383131304A55304C384B3053
Shop #: WSC 12298 002 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4BC80E8333427F636A0-801E
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000L9RN
Serial number: 6334MSME483B6F54T
Serial number: 6344MSME473B7273I
Serial number: 6352QSME0645407EH
Serial number: 6362QSME324314623
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:33
9444115 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:33
13635840 - Supply voltage
[Powersupply lower threshold fall short of]
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:33:46
B10B4 00 [008] - Function Restriction due to Undervoltage
[Bladder Mat: functional restriction because of low voltage]
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:33:02
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NGV000DU
Coding: 000016
VCID: 48C2318F22B4947B472-801C
Fault Frequency: 11
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:33:42
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:57:58
Part No SW: 8K0 920 983 F HW: 8K0 920 983 F
Component: KOMBIINSTR. H35 0564
Revision: 00100000 Serial number: ZAA79GT7F
Coding: 8BB609000301D705020000
VCID: 3822414F5254E4FB372-806C
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:55:16
Fault Frequency: 23
Reset counter: 196
Mileage: 176436 km
Date: 2022.10.29
Time: 17:31:48
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z14802035E
Coding: 80C303FF00
VCID: 4CCA0D9F36CC785B63A-8018
Serial number: 8579144103
Fault Frequency: 24
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.14
Time: 14:07:12
Bin. Bits: 10111
Voltage: 10.90 V
Count: 6
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:56:48
Bin. Bits: 00111
Voltage: 8.10 V
Count: 6
02252 - Generator
Fault Status: 00101100
Reset counter: 235
Mileage: 176436 km
Date: 2022.10.26
Time: 08:11:42
Bin. Bits: 00101
Voltage: 4.60 V
Count: 6
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0077
Revision: AA000000 Serial number: 00000110841572
Coding: 00581B00000000000000
VCID: 3B285E436362CFE3DA0-806E
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:55:51
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0341774971
Coding: 010211
VCID: 3FD02A5377FAD3C3F68-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0341513383
Coding: 010211
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C13204E00410001
VCID: 56FEEFF7F800328BC5E-8002
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:55:04
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0003021346
Coding: 100000000001
ROD: EV_RCEPSAU48X_008.rod
VCID: 343A757F4EBC009B1BA-8060
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
[Lenkungsendanschläge nicht angelernt]
Fault Frequency: 31
Reset counter: 196
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:16
Write only channel
Revision: 00002001 Serial number: 0342930070
Coding: 0106023A00FA400580B0013200000000
Component: GTO BF H01 0080
Serial number: 00000000000000870396
7 Faults Found:
01512 - Control Module for Sliding Roof
Reset counter: 195
Mileage: 176435 km
Date: 2022.09.21
Time: 13:07:43
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 195
Mileage: 176435 km
Date: 2022.09.21
Time: 13:11:12
02616 - Fuel Tank Cap; Unlock
Reset counter: 195
Mileage: 176435 km
Date: 2022.09.21
Time: 13:11:31
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:55:56
Reset counter: 235
Mileage: 176436 km
Date: 2022.10.26
Time: 00:00:17
Fault Frequency: 22
Reset counter: 196
Mileage: 176436 km
Date: 2022.10.29
Time: 17:32:13
03305 - Wire for Engine Start Request
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 21:13:30
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
VCID: 55FCE8FBE5063993CC4-8000
02111 - Motor for Window Regulator
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:33:50
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:55:05
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000409837
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A265B476CD8F6EBC16-806E
10554390 - Supply voltage
[FC_LOW_V_BATT]
Reset counter: 195
Mileage: 176435 km
Date: 2022.10.25
Time: 21:54:35
Voltage terminal 30: 8.9 V
Internal Fault ID: 40
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: Open
Status ParkingBrake right: Open
461568 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[FC_SIGNAL_KBI_AUSSEN_TEMP_GEF_ERROR_VALUE]
Fault Frequency: 8
Reset counter: 196
Mileage: 176436 km
Date: 2022.10.29
Time: 19:13:39
Voltage terminal 30: 12.4 V
Internal Fault ID: 147
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Revision: AB001007 Serial number: 156H+0E8050882
Coding: 020007020100000001
VCID: 241A853FFEDC901B8BA-8070
Part No SW: 8R1 035 746 F HW: 8R1 035 746 D
Component: H-BNT-NA H41 0812
Revision: -------- Serial number: 204HW0EB018143
Coding: 0F0200000006A1EF51028B5E00000403140000000000000000
VCID: 3A265B476C58F6EBC16-806E
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Component: DU7 High H42 0104
Serial number: A130GG0E3100317
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001944445
Component: CD-Database 5950
Reset counter: 235
Mileage: 176436 km
Date: 2022.11.11
Time: 00:00:10
Bin. Bits: 00000000 00000000
Bin. Bits: 00000100 00000000
03367 - Supply Voltage for Display Module
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:56:48
Voltage: 8.10 V
01524 - Antenna for Telephone
Fault Status: 00101011
Reset counter: 228
Mileage: 176029 km
Date: 2022.08.19
Time: 12:21:21
Voltage: 14.50 V
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0305
Coding: 010C13204000210001
VCID: 59E4E4CB891E1DF3E8C-800C
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:55:05
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-J47917C
Coding: 1000006
VCID: 3822414F5E54E4FB372-806C
Fault Frequency: 8
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:33:35
Reverse OFF
Count: 3
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:56:25
Reverse OFF
Count: 3
Component: TSG HR H07 0305
Reset counter: 235
Mileage: 176435 km
Date: 2022.10.25
Time: 21:55:07
End----------(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.0V)-----------
