Fitting aftermarket LED headlight and taillights - VW Amarok
kubalfc
Sydney, Australia
C?ID=309564
Hi all,
Total newb here posting for the first time needing some assistance with errors and warning lights appearing after fitting aftermarket headlight and taillight assemblies to my 2013 VW Amarok. These are not LED bulbs but complete headlight and taillight units. These products were listed as plug and play, and i naively believed this claim so wired them up and got some errors. I have inserted the scan below.
I had searched other threads online and someone suggested the errors i am getting on the parking and back up lamps could be a resistance issue.
Any and all help is greatly apppreciated.
Cheers.
Kuba
Wednesday,23,November,2022,08:20:08:40269
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: WV1ZZZ2HZDA051591 License Plate:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 32 56 6C
VIN: WV1ZZZ2HZDA051591 Mileage: 148150km-92056miles
56-Radio -- Status: Not registered 0011
6C-Back-up Cam. -- Status: Not registered 0001
Address 01: Engine (J623-CSHA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 012 AF HW: 03L 907 309 AC
Component: R4 2,0L EDC H24 7092
Revision: 74H24--- Serial number: 00000000000000 CVN: 3A6008F80000000000000000
Coding: 012A4012232600080001
Shop #: WSC 11738 002 1048576
ASAM Dataset: EV_ECM20BTD01103L906012AF 001010
ROD: EV_ECM20BTD01103L906012AF_001.rod
VCID: 688AB0AF12FA0F9B432-803C
VINID: 9E606AAAA098A94440141149043FECCDAB
Address 02: Auto Trans (J217) Labels:| 0CM-325-025.clb
Part No SW: 2H0 927 158 B HW: 0CM 325 025
Component: 2H0 20RTDIRdW H16 3009
Revision: --H16--- CVN: BB651686
ASAM Dataset: EV_TCMAL450211 002011
ROD: EV_TCMAL450211_002_VN81.rod
VCID: 2C020CBFC682E3BB67A-8078
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 L HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0110
Revision: 00H44001
Coding: C07324B69999039624A799ACAF5190
Shop #: WSC 07456 790 49164
VCID: 392C25EB39504613ECC-806C
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 2H0 907 040 E HW: 2H0 907 040 E
Component: ClimatronicT5 H19 0406
Revision: 00001003
Coding: 0000000002
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis_VN81.rod
VCID: 2310E783AB5C2CC3D60-8076
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 M HW: 6R7 937 087 M
Component: PQ25 BCM H30 0555
Revision: -1------ Serial number: --------------
Coding: 3C0002380C610400923808102C4B84C50080410E60000000300000000003
Shop #: WSC 20072 959 132160
VCID: 4EC6663790DEF1AB29E-801A
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3323
Coding: 050000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3323
Coding: 050000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 001 001 0103
Component: LIN BACKUP HORN H11 H11 9005
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Serial number: 0540954
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3323
Subsystem 8 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3323
Reset counter: 25
Mileage: 147969 km
Date: 2017.04.10
Time: 00:31:51
03432 - Activation of Right Parking Light
Fault Status: 00110111
Reset counter: 78
Mileage: 147969 km
Date: 2017.04.10
Time: 00:41:52
00901 - Back-Up Lamps
Fault Status: 00111010
Reset counter: 38
Mileage: 148155 km
Date: 2017.04.14
Time: 21:02:12
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261304201511
Coding: 308103
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 392C25EB39D04613ECC-806C
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00H H07 0013
Revision: -------- Serial number: 003HN00BTHU1
Coding: 000000000000000000000000000000003048
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 333017C31BBCBC43260-8066
Serial number: 3495RRB400I50FFEH1EH
Serial number: 3505RRB400Q50FFE90LF
Serial number: 3555YRB40044UPLGDHV/
Serial number: 3565YRB40024UPLG91TH
Part No SW: 2H0 920 863 C HW: 2H0 920 863 C
Component: KOMBI H05 0605
Coding: 150A00
VCID: 290CF5ABC970F6939CC-807C
Part No SW: 6N0 909 901 HW: 6R7 937 087 M
Component: GW-K-CAN TP20 H30 0555
Revision: -1------
Coding: 742300
Shop #: WSC 07462 000 09999
VCID: 70BAD8CF2AAAC75B1B2-8024
Reset counter: 25
Mileage: 147969 km
Date: 2017.04.10
Time: 00:31:51
Component: IMMO H05 0605
VCID: 6A8ECAA70CF63D8B556-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 10.09.12 00
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
Address 56: Radio
Address 6C: Back-up Cam.
End----------(Elapsed Time: 01:30, VBatt start/end: 11.9V/12.1V)-----------
GolfswagenVolk
Belgium
C?ID=401717
Have you taught the vehicle that it has LED headlights installed?
As the CAN gateway tells you, Control Module Incorrectly Coded
kamold
Australia
C?ID=241363
The faults in 09 are intermittent.
If you clear them to they return?
Do all lighting functions work?
19 faults appear to be due to incorrectly adding RVC address 6C to installation list, as well as an aftermarket radio at 56 which does not repond to diagnostics.
You can safely ignore these faults or remove 56 and 6c from 19 installation list.
Perhaps you could post a link to these items or a Picture of the description / box etc. ; That way other forum members will have some idea of what you are dealing with.
kubalfc
Sydney, Australia
C?ID=309564
I haven't taught it anything, but i believe this error was appearing in older scnas before i installed the headlights, so i'm not sure if they are related. How would i check for this?
kubalfc
Sydney, Australia
C?ID=309564
If i clear them, they still return.
On the rear lights they function normally, but the light bulb warning light pops up when i shift into reverse only, although the reverse light also functions as intended.
The front lights on the left handside function normally without error, but the right hand side one does not. The lights are setup such that by turning on the park lights this turns on the daytime running light function on the headlights. When i switch the park lights on, the right headlight turns the DRL on and off and cycles through this. The blinker and high and low beams function without a problem.
The wiring harness on the car has 9 active pins (1 - 6, 8-10) on the connector for the headlights, however the aftermarket light only has 5 active pins on its connection (5,6, 8-10).
With regard to the reverse camera and headunit i assumed these were not important so i had ignored them.
kubalfc
Sydney, Australia
C?ID=309564
HI Stefdds;
Below are the links for the lights i had purchased. I will also take a photo of the connections on each light when i'm at home;
The lights came with no instructions or paperwork included in the box for either the front or rear lights.
GolfswagenVolk
Belgium
C?ID=401717
All your auto-scans are automatically saved to your computer.
This computer -> Windows (C:)drive -> Ross-Tech -> VCDS -> Scans
I'm pretty sure the new lights need coding (I mean the control unit ofcourse)
Maybe the old control unit doesn't support coding for the new lights?
Take a look in 09 Centr. Elec. -> coding -> long coding helper
That's where my lighting functions are stored.
Don't just change stuff there as it can break the module. Also make a copy of your original coding before making any changes.
iichel
Eindhoven, NB, NL
C?ID=284912
yes but that is due to the 6C camera module not registered.
3C0002380C610400923808C02C4B84C5F08041F060000000300000000003
try this coding for your bcm please, clear all errors and then cycle ignition, start engine and move the light switch from 0 to parking lights, wait a few seconds, brake, wait a few seconds, from parking lights to low beam, what a little while, turn on high beam, wait a bit, turn on reverse, wait a bit, and rear fog. And finallly left and right indicator. Tell us when any warning light comes on and the behaviour of the lights.
