2017 Jetta 1.4 - All kinds of malfunctions out of nowhere
HeliSwiss
C?ID=2629
Hello!
I am looking for some advice with issues with our 2017 Jetta 1.4.
Car was just fine on Friday, drove home from work, no issues at all.
Didn’t drive the car all weekend. Getting ready to go to work on Monday morning and had all kinds of fault indicators on the instrument cluster. Power-steering light on, ECS Malfunction, TPMS Malfunction, ABS Malfunction, all lit up that morning...
Any ideas would be greatly appreciated!
Monday,21,November,2022,15:12:50:36731
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: 3VWDB7AJ0HM396030   License Plate:
Mileage: 53950km-33522mi   Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 3C 44 5F 75
VIN: 3VWDB7AJ0HM396030   Mileage: 53950km-33522miles
04-Steering Angle -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CZTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AL    HW: 04E 907 309 AP
   Component: R4 1.4l TFS   H22 3669
   Revision: X5H22---    CVN: 3BBC5B28
   Coding: 011A0012232400001000
   Shop #: WSC 00066 790 00017
   ASAM Dataset: EV_ECM14TFS01104E906023AL 005004
   ROD: EV_ECM14TFS01104E906023AL.rod
   VCID: 6A8DCE681CF71EEB556-803F
   VINID: 0E69D448745A018743246003004C56DD20
7249 - No Communications with Steering Angle Sender (G85)
          U0126 00 [039] - -
                    Mileage: 53957 km
                    Date: 2022.11.15
                    Time: 09:54:59
                    Engine RPM: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 6 °C
                    Ambient air pressure: 770 mbar
                    Voltage terminal 30: 11.520 V
Readiness: 1110 0101
   Part No SW: 09G 927 158 BA    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3117
   CVN: EDA05DDC
   Coding: 010100000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 73B3D30C4B3DDF23E60-8027
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B400C492B0000850B02E7921900412010F01A
   Shop #: WSC 00066 790 00294
   VCID: 75B7ED1445C9C113C84-8021
                    Reset counter: 64
                    Mileage: 53956 km
                    Date: 2022.11.14
                    Time: 07:07:26
                    Count: 16384
                    Count: 12
                    Count: 29184
                    Count: 166
                    Count: 41472
                    Count: 65531
                    Count: 7168
                    Reset counter: 64
                    Mileage: 53956 km
                    Date: 2022.11.14
                    Time: 07:07:35
                    Count: 16386
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 52736
                    Count: 65531
                    Count: 10752
                    Reset counter: 64
                    Mileage: 53956 km
                    Date: 2022.11.14
                    Time: 07:07:26
                    Count: 16384
                    Count: 12
                    Count: 29184
                    Count: 8213
                    Count: 40960
                    Count: 65532
                    Count: 5120
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0438266369
   Coding: 032C0C
   VCID: 392F212429D16573ECC-806D
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 DA    HW: 5C0 820 047 DA
   Component: J301  Klimaanlage   0211
   Revision: 2001401S    Serial number: 00000004010145
   VCID: 629DA648E84746AB9D6-8037
   Part No SW: 7E0 937 190 B    HW: 7E0 937 190
   Component: BCM PQ25 Max3 H81 0744
   Revision: B8081001    Serial number: 88007140172072
   Coding: 7B994B9A08AB0B0008392080240884C54BC6722E600151F0B0A050032844
   Shop #: WSC 00066 000 00000
   VCID: 2B030B6CD30DC7E36E0-807F
   Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  022 1467
   Serial number: 14102743170406223832
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  022 1467
   Serial number: 14202742170410003300
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST001JM0HN00000
   Coding: 180000
   Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Serial number: 1101707465930471AD3B
   Coding: 280000
   Subsystem 5 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14202745170419170933
   Subsystem 6 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14202744170421152353
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0CUUF0
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 6393A34CFBDD4FA3960-8037
   Serial number: IBH00000000000763C7
   Coding: 303146
   Subsystem 2 - Part No SW: -----------    HW: 480 001 103 17
   Serial number: 35700000000B12B03224
   Subsystem 3 - Part No SW: -----------    HW: 480 001 103 17
   Serial number: 35800000000F231C422E
   Subsystem 4 - Part No SW: -----------    HW: 480 021 603 17
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001C325ACAB3766B
   Subsystem 5 - Part No SW: -----------    HW: 480 021 603 17
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001C325ACAB52322
   Subsystem 6 - Part No SW: -----------    HW: 480 021 304 17
   Component: FrontSensor_D  000 0189
   Serial number: 35500019B249E3C3E2CN
   Subsystem 7 - Part No SW: -----------    HW: 480 020 504 17
   Component: FrontSensor_P  000 0189
   Serial number: 3560001BD247FF90F37U
   Part No SW: 5C6 920 976 D    HW: 5C6 920 976 D
   Component: KOMBI         H02 1104
   Coding: 221A010000
   Shop #: WSC 00066 790 00320
   VCID: 3333130C0BBD9F23260-8067
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 64
                    Mileage: 53956 km
                    Date: 2022.11.14
                    Time: 07:07:27
   Part No SW: 7E0 909 901     HW: 7E0 937 190
   Component: GW-K-CAN TP20 H81 0744
   Revision: B8081001
   Coding: 102201
   VCID: 6889B460027B2CFB432-803D
                    Date: 2019.01.28
                    Time: 19:20:24
                    Reset counter: 64
                    Mileage: 53956 km
                    Date: 2022.11.14
                    Time: 07:07:25
                    Reset counter: 64
                    Mileage: 53956 km
                    Date: 2022.11.14
                    Time: 07:07:25
   Component: IMMO          H02 1104
   Coding: 000007
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 9 km
                    Date: 2017.07.03
                    Time: 04:00:58
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 17000096698002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 313F1904F1A1AD3354C-8065
   Serial number: 0433887747
   Coding: 01011101
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C21383026E3505BF7A-8069
   Serial number: 0434801229
   Coding: 010111
337296 - Databus
          [EPS ECU mLW_1 - no signal/no communication]
                    Reset counter: 64
                    Mileage: 53956 km
                    Date: 2022.11.14
                    Time: 07:07:25
Address 44: Steering Assist
   Part No SW: 5C0 035 200 B    HW: 5C0 035 200 B
   Component: MU-S-S-US     H31 0363
   Serial number: VWZAZ2T1238424
   Coding: 02630100AA00000051220001001808009F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 1471B0906EF3781B5FA-8041
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0160
   Serial number: 000003554140564
   Coding: 02630102C21632107F1606C00000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
End----(Elapsed Time: 01:24, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
HeliSwiss
C?ID=2629
Found it! Looks like a rodent chewed through a few wires of the wiring harness. Soldered them back together and everything is behaving.
