2016 Mk3 Fabia - enable dual rear fog lights
Maligator
C?ID=508928
Hello all,
I am trying to activate both rear fogs for a friend who has a 2016 Skoda Fabia Mk3, I can see that the fogs are duel filament halogen bulbs.
Due to a back injury and issues bending I am unable to check if there is wiring on the rear left to support the activation of both and don't have a wiring diagram of the car but having looked initially at the car it seems almost the same as my 2016 Octavia in terms of what needs to be changed but upon changing: LEUCHTE27 KL58XS C67-LIGHT_FUNCTION_A_27 to Nebelschlusslichtwennkeinanhnagergesteckt the rear left fog light did not come on so I assume that it does not have the wiring as the right hand side 26NSL was already set to Nebelschlusslichtwennkeinanhnagergesteckt.
Am I on the right track?
Please see the scan for reference.
Wednesday,23,November,2022,17:21:01:34356
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: TMBFN6NJ1HZ183335   License Plate: AW54SAM
Mileage: 103667km-64415mi   Repair Order:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: TMBFN6NJ1HZ183335   Mileage: 103667km-64415miles
Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 LJ    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H24 3856
   Revision: R4H24---    CVN: 0539D1EB
   Coding: 0119003223241D080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM12TFS01104E906027LJ 001001
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 77AAE9D12F4527F3DA8-8022
   VINID: 91D49678679A058A812030C314B75F3929
21742 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
          P0219 00 [096] - -)
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
10592 - Cylinder 2
          P0302 00 [096] - Misfire Detected
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 ESP9.0i       H04 00060006
   Serial number: 08504223170419
   Coding: 43F5487D492B33C30917106C0056C21292CC9008000DCAF98F00
   Shop #: WSC 13765 031 00000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: N/A
   VCID: 3E243CF540FFD6BBD9E-806A
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 C    HW: 6V0 820 045 C
   Component: AC Manuell    H01 0204
   Serial number:  1703221B-0656
   Coding: 100000001100100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 323C18C584A702DB2D6-8066
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H10 0094
   Serial number: 006308504019
   Coding: 0F0008404205005B03A04080B10703080000D900D6013500000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_VW26.rod
   VCID: 313E17C981A139C354C-8064
   Subsystem 1 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1708013AH
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000037718443
233224 - Turn Signal Lever Limiter
          B1824 F1 [008] - Implausible Position
                    Mileage: 66412 km
                    Date: 2021.05.23
                    Time: 19:37:03
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    Stoerschutzzaehler: 19
                    Voltage: 14.7 V
                    Outside temperature: 10.0 °C
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0054
   Revision: --------    Serial number: 39261710107138
   Coding: 0001050001
   ROD: EV_EPHVA14AU3700000_SK26.rod
   VCID: 3C2036FD56E3C4ABF7A-8068
   Part No SW: 5Q0 907 572 K    HW: 5Q0 907 572 K
   Component: ACC Bosch MQB H05 0402
   Serial number: 06041703212107
   Coding: 00000000FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3FDA41F147F5DFB3D28-806A
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag74D 002 0380
   Revision: --------    Serial number: 003TJ00CMBMW
   Coding: 88CCC000000000005C5400CF008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B2235E153EDC393FE0-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 820 604 17
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00022A4D4E3A31H
   Subsystem 2 - Part No SW: -----------    HW: 410 820 604 17
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H003229E428121CC
   Subsystem 3 - Part No SW: -----------    HW: 442 150 804 17
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A009921C1D82743B
   Subsystem 4 - Part No SW: -----------    HW: 442 150 804 17
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A325D117470B5
   Part No SW: 6V0 920 946 B    HW: 6V0 920 946 B
   Component: KOMBI         202 2310
   Coding: 272401002180A60001882A011000000000000000
   ROD: EV_DashBoardVDDMQBAB_SK26.rod
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 46
                    Reset counter: 231
                    Mileage: 88899 km
                    Date: 2022.04.16
                    Time: 19:43:12
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H10 0094
   Revision: --------    Serial number: 006308504019
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   GVL: 01443C0000000000400080000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 2614F495B86F6E7BB1E-8072
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000D2425040417
   Subsystem 2 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
   Serial number: 9848863604
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AJ    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  323 3242
   Serial number: CH4B1078
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 71BED7C9412179C314C-8024
   Part No SW: 5Q0 035 842 B    HW: 5Q0 035 842 B
   Component: MU-S-D-ER     H30 0363
   Serial number: SKZAZ2T5173026
   Coding: 03620000BE00000011111204008808002F0107C60120010002
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2E040CB5909F263B49E-807A
   Subsystem 1 - Part No SW: 6V0 919 604 B    HW: 6V0 919 604 B
   Component: ABTm_Std2  H42 1041
   Serial number: SKZ8Z9TLX01DX4
End----(Elapsed Time: 01:37, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
Do you know why there is only one fog light on many cars? In Germany I think it may even be a TUV failure.
Maligator
C?ID=508928
I certainly do know why, braking and the ease of distinguishing.
I can also confirm that having two is not a TUV failure, I guess it may be if you don't have the third centre high rise brake light but this and most cars that have both fogs enabled do have this and also pass TUV with flying colours.
It is also fine for MOT's too.
langers2k
C?ID=224085
You might want to add an adaption map from 09 too...
Westbury, UK
That's a red herring which keeps getting posted on the interent.
For over 20 years vehicles have had 3 brake lights - so anyone who cannot tell the difference between 2 rear fog lights and 3 brake lights has such poor vision that they should not be driving.
