- Nov 22, 2022
- 5
- 1
- Maryland, USA
- C?ID=214173
Greetings everyone, longtime VCDS owner, first time doing coding... having some issues.
Thank you in advance and sorry for the long long long first time post.
Here is the story: Wife's 2014 Tiguan
R Line (FWD) DSG with steering controls for phone/radio/up & downshift.
Steering controls & horn stopped working
Airbag light on
TPMS light on
Search seems to point to clockspring issue.
Original clockspring is 5K0953569L
New clockspring is 5K0953569AL (search states this is a successor)
Scan results before replacement:
Replaced clockspring - airbag light went off.
Horn works
Controls work for radio
New issues that I noticed:
-TPMS pressures will not save no matter how many times I try to save.
-Steering wheel icon comes up
Did a search and came up with https://forums.ross-tech.com/index.php?threads/6715
I just dont understand exactly WHAT I am supposed to do in the above thread.
I just don't know if my steering angle sensor is broken or how to calibrate it properly.
Also the stability control module light is on as well. I am hoping someone can help me and translate all this stuff in a way that someone with an IQ of 50 can understand because I seem to be that person.
Here is a scan of the Tiguan after the new clockspring
Airbag light on
TPMS light on
Monday,21,November,2022,16:22:35:17941
VCDS Version: 22.10.0.1 (x64)
VIN: WVGAV3AX3EW011447 License Plate:
Mileage: 127370km-79144mi Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4C
4F 52 53 55 56 62 6C 72 75 77
VIN: WVGAV3AX3EW011447 Mileage: 127370km-79144miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 997 027 N HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 06 0397
Revision: P3H07--- Serial number:
Coding: 0423010A19070160
Shop #: WSC 04876 002 1048576
VCID: 408F512A13C5D68DC2-8014
VINID: 9E65D19834680D59C00411041CDDD611F1
P0300 - 000 -
Mileage: 127373 km
Date: 2017.04.13
Time: 19:17:46
RPM: 1086 /min
Load: 33.3 %
Temperature: 6.0°C
Temperature: 7.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected
Mileage: 127373 km
Date: 2017.04.13
Time: 19:17:46
RPM: 1086 /min
Load: 33.3 %
Temperature: 6.0°C
Temperature: 7.0°C
Voltage: 14.224 V
Part No SW: 09G 927 750 NK HW: 09G 927 750 NK
Component: AQ 250 6F 2253
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 071D8A36766B21B5C3-8052
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BD HW: 5N0 614 109 BD
Component: J104 C6 450M VDEB 0011
Revision: --H07--- Serial number: 00000007150859
Coding: 0005158
VCID: 6ED3DF9279D110FD60-803A
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 235
Mileage: 127373 km
Date: 2017.04.07
Time: 16:44:44
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.00 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0193671748
Coding: 030C0C
VCID: 34670DFA9F7D7A2D56-8060
Part No SW: 3AA 907 044 BH HW: 3AA 907 044 BH
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 0010019002
VCID: 77FDFAF6CE8B5135B3-8022
Part No SW: 5K0 937 086 R HW: 5K0 937 086 R
Component: BCM PQ35 M 122 0173
Revision: BJ122001
Coding: EF180A1B88232EC4018800C134000D4448D50006576D8DB0E4840000A040
VCID: 43855E26C2D3CD95DF-8016
Subsystem 1 - Part No SW: 5N1 955 119 C HW: 5N1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 14051 10 0603
Coding: 009795
Component: RLS 100613 05 54 0403
Coding: 02304D
Reset counter: 19
Mileage: 127269 km
Date: 2017.04.04
Time: 12:37:39
Term 15 Off
Voltage: 12.35 V
01501 - Bulb for Blinkers; Rear Left (M6)
Fault Status: 00101010
Reset counter: 20
Mileage: 127373 km
Date: 2017.04.12
Time: 16:30:16
Term 15 Off
Voltage: 11.90 V
Reset counter: 20
Mileage: 120863 km
Date: 2016.09.17
Time: 12:30:54
Voltage: 14.50 V
Part No SW: 5N0 959 655 AD HW: 5N0 959 655 AD
Component: J234__207 VW10 HI 2318
Revision: 27019000 Serial number: 003N4PBURXXH
Coding: 0012343
VCID: 7F0D12D62EBB6975FB-802A
Subsystem 1 - Part No: 5N0 959 339 B
Subsystem 2 - Serial number: 0000000000CL70
Subsystem 3 - Serial number: 0022.01.130000300000850057ÿ†63
Subsystem 4 - Serial number: 850057ÿ†6332MTS617051513-ÿ†63
Subsystem 5 - Serial number: 51513-ÿ†6342MTS634181513/ÿ†63
Subsystem 6 - Serial number: 81513/ÿ†6351HTS6RPRS1CKJ$ÿ†63
Subsystem 7 - Serial number: S1CKJ$ÿ†6361HTS65KPR1CKRIÿ†63
Subsystem 8 - Serial number: R1CKRIÿ†63727TS6D6FH0CKJIÿ†63
Subsystem 9 - Serial number: H0CKJIÿ†63827TS66BFH0CKJHÿ
Subsystem 10 - Serial number: H0CKJHÿ
Fault Status: 11100001
Mileage: 127373 km
Date: 2017.04.07
Time: 16:44:32
Part No SW: 5K0 953 501 BL HW: 5K0 953 569 L
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130612300783
Coding: 111A140000
VCID: 75E1F0FED4872325A1-8020
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Reset counter: 234
Mileage: 127285 km
Date: 2022.11.12
Time: 14:58:11
Part No SW: 5N0 920 973 E HW: 5N0 920 973 E
Component: KOMBI H04 0811
Coding: 211F01
VCID: 366337F28901683D68-8062
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 050613F1000641
Coding: 356002
VCID: 7BF5E6C6FAA37555D7-802E
Component: IMMO H04 0811
Coding: 000007
VCID: 6ADBD3828D39FCDD3C-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000107384005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 306F01EA6B65460D32-8064
Address 2E: Media Player 3
Part No SW: 561 959 760 A HW: 561 959 760 A
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000058028029
Coding: 00581B0000000000000001010101202020202121202020
VCID: 2149F4AE388FFF85AD-8074
Part No SW: 1K0 035 274 F HW: 1K0 035 274 F
Component: RNS315-NAR H70 0409
Serial number: VWZAZ2N0320391
Coding: 0409002101000C0000008000
ROD: EV_RNS315NARV2UDS_VW32.rod
VCID: 275DEAB65EAB01B5E3-8072
Component: NAR_V4 0041
B11CF 53 [009] - Deactivated
Reset counter: 5
Mileage: 31692 km
Date: 2016.12.17
Time: 14:43:41
Part No SW: 5N0 959 701 G HW: 3C0 959 793 C
Component: TUER-SG FT 002 0503
Revision: 12110009 Serial number: 0007035411
Coding: 0015BE
VCID: 39793CCEB81F874585-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1504
Serial number: 00000007745461
Coding: 000490
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.286 1202
Revision: 1BH04839 Serial number: 00131570058901
Coding: 0000258
VCID: 3F8D52D66E3BA975BB-806A
Part No: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0045965
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
VCID: 2643E7B259A118BDD8-8072
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 050B0500
VCID: 6FEDC296BEDB19F56B-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB14 H05 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB14 H05 0220
Part No SW: 5N0 959 702 G HW: 3C0 959 792 C
Component: TUER-SG BT 002 0503
Revision: 14110009 Serial number: 0007025112
Coding: 0015BE
VCID: 3A7B23C2BD198C5D8C-806E
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1504
Serial number: 00000007787525
Coding: 000490
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000001115044
Coding: 0026156
VCID: 366337F24101683D68-8062
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 041200010B000400
VCID: 377D3AF68E0B913573-8062
Subsystem 1 - Part No: 4H0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 4H0 941 329 Labels: 3D0-941-329.CLB
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 A HW: 5N0 907 441 A
Component: J772__Rearview 0030
Revision: 00H12000 Serial number: 525PA8-J35F180
Coding: 0100010
VCID: 2D51189EB4572BE519-8078
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0078
Serial number: 000003554140500
Coding: 02130602C2423A107F1606000000
ROD: EV_OCULow_001.rod
VCID: 53A56E663AB35D156F-8006
12670464 - Databus
Fault Frequency: 17
Reset counter: 18
Mileage: 119630 km
Date: 2022.03.29
Time: 19:29:52
0035 - Databus
Fault Frequency: 33
Reset counter: 18
Mileage: 116200 km
Date: 2022.01.27
Time: 10:32:23
2103041 - Control Module
Fault Priority: 8
Reset counter: 235
Mileage: 127373 km
Date: 2022.11.21
Time: 19:22:02
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666902494
Coding: 0A100300A0010110
Shop #: WSC 04881 002 1048576
ROD: EV_UHVUMI.rod
VCID: 326B0BE26569741D44-8066
End-------------------------(Elapsed Time: 04:04)--------------------------
Address 01: DTCs clearedTuesday,22,November,2022,12:00:30:17941
Readiness: 1110 0101
Coding: 0000840
Component: J104 C6 450M VDEC 0011
Coding: 0005158
Fault Frequency: 9
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.08
Time: 16:44:44
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.14
Time: 00:00:30
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011110
Count: 191
Hex Value: 0x0000
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.14
Time: 00:00:30
Coding: 030C0C
Revision: 00001K01
Coding: 0010019002
Revision: BJ122001
Coding: 009795
Coding: 02304D
Reset counter: 19
Mileage: 127269 km
Date: 2017.04.05
Time: 12:37:39
Term 15 Off
Voltage: 12.35 V
Reset counter: 20
Mileage: 127373 km
Date: 2017.04.13
Time: 16:30:16
Term 15 Off
Voltage: 11.90 V
Reset counter: 20
Mileage: 120863 km
Date: 2016.09.18
Time: 12:30:54
Voltage: 14.50 V
Coding: 0012343
001 - Upper Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100001
Mileage: 127373 km
Date: 2017.04.08
Time: 16:44:32
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20221019201020
Coding: 111A140000
Shop #: WSC 01286 386 08256
VCID: 020B9B229549049D94-8056
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0032
Serial number: 0149813
Coding: 830000
14 Faults Found:
147462 - Terminal 15
B1148 12 [009] - Short to Plus
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
Reset counter: 236
226827 - Turn Signal Switch
B1144 13 [008] - Open Circuit
226839 - Turn Signal Switch
B1144 11 [008] - Short to Ground
Reset counter: 21
227334 - Windshield Wiper Switch
B1145 12 [008] - Short to Plus
227339 - Windshield Wiper Switch
B1145 13 [008] - Open Circuit
B1149 13 [008] - Open Circuit
Reset counter: 21
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
229147 - Cruise Control Switch
B1154 13 [009] - Open Circuit
332660 - Databus
Reset counter: 21
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
U108E 00 [008] - No Communications
617736 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
1140738 - Steering angle sensor
UBat: 13.70 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Coding: 211F01
Coding: 356002
Coding: 000007
Reset counter: 5
Mileage: 31692 km
Date: 2016.12.18
Time: 14:43:41
Coding: 0015BE
Slave Driver:
Coding: 000490
Coding: 0000258
02546 - Steering Limit Stop
Fault Status: 11100101
Reset counter: 236
(no units): 4.0
Voltage: 12.20 V
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.14
Time: 00:00:22
(no units): 7.0
Steering Angle: 0.00°
Not OK
(no units): 15
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K 6813
Coding: 050B0500
Coding: 0015BE
Slave Passenger:
Coding: 000490
Coding: 0026156
Coding: 0100010
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.14
Time: 00:00:20
Reverse OFF
Count: 3
12670464 - Databus
Fault Frequency: 17
Reset counter: 18
Mileage: 119630 km
Date: 2022.03.30
Time: 19:29:52
0035 - Databus
Fault Frequency: 33
Reset counter: 18
Mileage: 116200 km
Date: 2022.01.28
Time: 10:32:23
Fault Priority: 8
Reset counter: 236
Mileage: 127373 km
Date: 2022.11.22
Time: 00:04:58
ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 04:06)--------------------------
Horn works
Tuesday,22,November,2022,12:09:39:17941
Coding: 0000840
Coding: 0005158
Fault Frequency: 9
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.08
Time: 16:44:44
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.14
Time: 00:00:30
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011110
Count: 191
Hex Value: 0x0000
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.14
Time: 00:00:30
Coding: 030C0C
Revision: 00001K01
Coding: 0010019002
Revision: BJ122001
Coding: 009795
Coding: 02304D
Reset counter: 19
Mileage: 127269 km
Date: 2017.04.05
Time: 12:37:39
Term 15 Off
Voltage: 12.35 V
Reset counter: 20
Mileage: 127373 km
Date: 2017.04.13
Time: 16:30:16
Term 15 Off
Voltage: 11.90 V
Reset counter: 20
Mileage: 120863 km
Date: 2016.09.18
Time: 12:30:54
Voltage: 14.50 V
Coding: 0012343
Mileage: 127373 km
Date: 2017.04.08
Time: 16:44:32
Coding: 111A140000
Coding: 830000
14 Faults Found:
Reset counter: 236
Reset counter: 21
Reset counter: 21
332660 - Databus
Reset counter: 21
UBat: 13.70 V
Coding: 211F01
Coding: 356002
Coding: 000007
Reset counter: 5
Mileage: 31692 km
Date: 2016.12.18
Time: 14:43:41
Coding: 0015BE
Slave Driver:
Coding: 000490
Coding: 0000258
Reset counter: 236
(no units): 4.0
Voltage: 12.20 V
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.14
Time: 00:00:22
(no units): 7.0
Not OK
(no units): 15
Coding: 050B0500
Coding: 0015BE
Slave Passenger:
Coding: 000490
Coding: 0026156
Coding: 0100010
Reset counter: 236
Mileage: 127373 km
Date: 2017.04.14
Time: 00:00:20
Reverse OFF
Count: 3
12670464 - Databus
Fault Frequency: 17
Reset counter: 18
Mileage: 119630 km
Date: 2022.03.30
Time: 19:29:52
0035 - Databus
Fault Frequency: 33
Reset counter: 18
Mileage: 116200 km
Date: 2022.01.28
Time: 10:32:23
Fault Priority: 8
Reset counter: 236
Mileage: 127373 km
Date: 2022.11.22
Time: 00:04:58
ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 03:54)--------------------------
