Carless for over 6 months ugh
cshae82
Illinois, USA
C?ID=533095
Hello all, I am hoping to get some help with getting my 2014 VW PASSAT 2.0 TDI SE to run again. In the middle of doing the Rawtek DEF,DPF,EGR delete and Malone Stage 2 upgrade, my car became a no crank, no start. I have been dealing with this issue since May after losing my fiancé due to cancer. I have since recently purchased the Ross Tech VCDS in hopes to get it on the road again. Every great once in a while I can get the car to start but when it does, i go to shift into reverse and it slams really hard then dies. Any help would be appreciated. Im very new to all of this and have a limited income so Im trying to avoid a dealership visit.
here is my auto=scan
Tuesday,22,November,2022,16:08:48:41203
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: 1VWBN7A32EC112667   License Plate:
Chassis Type: A3-VW41 (7N0)
          75 77
VIN: 1VWBN7A32EC112667   Mileage: 225590km-140175miles
02-Auto Trans -- Status: Cannot be reached 1100
   Component: R4 2.0l TDI   X24 9982
   Revision: 71X24---    Serial number:                CVN: D240C61F00000000
   Coding: 001D0012042400000000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B233B4F63EFAFE3FE0-806E
   VINID: 0669D27874430954C10421861C1215B2AB
4718 - No Communication with Transmission Control Module
          U0101 00 [039] - -
                    Mileage: 225597 km
                    Date: 2022.11.21
                    Time: 23:31:27
                    Engine RPM: 0.00 /min
                    Coolant temperature: 13 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 15.000 V
                    Requested transmission torque: 1000.0 Nm
                    Limitation: accelerator pedal: 220.0 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 44
                    selected gear-Bits 0-7: 0
                    Transmission torque intervention status-Bits 0-7: 16
                    Transmission torque intervention status-Bits 0-7: 128
                    Calculated reducing transmission intervention torque: 1000.0 Nm
Readiness: 0 0 0 X 1
Address 02: Auto Trans
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F5492300FCA31103EA92200042A1100012
   Shop #: WSC 09003 957 00200
   VCID: 7EA5F25B30FD7ACB99E-802A
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2017.04.13
                    Time: 23:06:25
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 16390
                    Count: 47104
                    Count: 1023
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2017.04.13
                    Time: 23:06:16
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 8195
                    Count: 47104
                    Count: 1023
   Part No SW: 561 907 426 E    HW: 561 907 426 E
   Component: AC Manuell    H02 0303
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1D67D5D7DD3BC1D3E04-8048
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0174
   Revision: BH122001
   Coding: EF200E1B902B08D4098800010600044800F1A08640801520648060000C70
   VCID: 73B3D36F0BBF27A3E60-8026
                    Fault Status: 00100001
                    Reset counter: 127
                    Mileage: 225597 km
                    Date: 2017.04.13
                    Time: 23:38:43
                        Term 15 Off
                    Voltage: 16.30 V
                    Fault Status: 01101000
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2017.04.13
                    Time: 23:23:13
                    Voltage: 13.65 V
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2017.04.13
                    Time: 23:06:25
                    Voltage: 13.10 V
   Serial number: 003MWM058VUO
   Coding: 00004D4A
   Shop #: WSC 36068 003 1048576
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B7ED77054B3993C84-8020
   Serial number: 6940000Y1400014Z410H
   Coding: 303044
   Serial number: 3572MSME14756A43ZZZX
   Serial number: 3582MSME380B4A44ZZZ
   Serial number: 3516KSME1016732CZZZL
   Serial number: 3526KSME5864732CZZZ.
   Serial number: 3556LSME024C012DZZZS
   Serial number: 3566LSME7943012DZZZY
   Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
   Revision: FF010042    Serial number: 20140315200164
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AFE14729535DF3ACC-802C
   Coding: E20000
0516 - Databus
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2022.11.21
                    Time: 23:06:36
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Coding: 231E01
   VCID: 1E65D2DBD03DDACBF9E-804A
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Getriebe: keine Kommunikation]
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2022.11.21
                    Time: 23:05:59
13893888 - Function Restricted due to Excessive Voltage
          U1401 00 [008] - -
                    Reset counter: 127
                    Mileage: 225597 km
                    Date: 2022.11.21
                    Time: 23:39:02
13636096 - Supply voltage
          U1012 00 [008] - Voltage too High
          [Supply voltage too high]
                    Reset counter: 127
                    Mileage: 225597 km
                    Date: 2022.11.22
                    Time: 00:42:48
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 17051403000099
   Coding: 461000
   VCID: 7BA3FB4F23EF6FE3BE0-802E
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2017.04.13
                    Time: 23:06:07
                    Reset counter: 127
                    Mileage: 225597 km
                    Date: 2017.04.14
                    Time: 00:39:04
Address 1C: Position Sensing
   VCID: 6A8DCE0B5CF5E66B556-803E
Address 2E: Media Player 3
   Revision: 13110009    Serial number: 0008318692
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE39BCF83AF8FE3DE0-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630140428202512
   Coding: 800000
65792 - Supply voltage
          [Front DCU overvoltage]
                    Reset counter: 127
                    Mileage: 225597 km
                    Date: 2022.11.21
                    Time: 23:39:12
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 290    3501
   Revision: 00H22000
   VCID: 392F214765539DF3ECC-806C
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 225597 km
                    Date: 2017.04.13
                    Time: 23:06:51
                    Battery Volts: 13.3 V
                        DD
                    Temperature: 14.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FBBDF1F67970343028-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011336003381
   Coding: 181100
   Revision: 15110009    Serial number: 0008321510
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE198D386A188DBD7A-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631140513143411
   Coding: 800000
                    Reset counter: 127
                    Mileage: 225597 km
                    Date: 2022.11.21
                    Time: 23:39:12
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H07 0009
   Revision: -----12S    Serial number: VWZ4Z7P3572796
   Coding: 0100044004000B
   VCID: 2B030B0F930F3F636E0-807E
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2017.04.13
                    Time: 23:07:08
                    Reset counter: 127
                    Mileage: 225597 km
                    Date: 2017.04.14
                    Time: 00:38:04
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140519
   Coding: 02140102C2163A007F1606C00000
   ROD: EV_OCULow_001.rod
   VCID: 53F373EFEB7F47A3060-8006
          U1401 00 [008] - -
          [restriction due to overvoltage]
                    Reset counter: 127
                    Mileage: 225597 km
                    Date: 2022.11.21
                    Time: 23:39:01
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 87
                    Mileage: 225597 km
                    Date: 2022.11.22
                    Time: 01:29:18
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007665646463
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E05021BA09D4A4B49E-807A
End----------(Elapsed Time: 01:04, VBatt start/end: 13.1V/13.4V)-----------
EuroX
Northern NJ USA
C?ID=208579
I would check wiring diagrams and fuses. It looks like nothing can talk to the transmission control module. I would start with that also under what circumstances did this car become a no crank no start?was it after a ecm reflash??
iichel
Eindhoven, NB, NL
C?ID=284912
Yep I agree. Engine is very unhappy about the missing TCM so chances are it does not see the car being in P or N and goes 'NOPE'.
Cars with DSG transmissions will simply refuse to start when they are in R or D/S.
PS, sorry for your loss. Hope you're getting over it.
siLc
Tallinn, Estonia
C?ID=330192
Many modules are complaining about overvoltage. That may have something to do with the TCU being offline. TCU fuses are usually in the engine bay fusebox - if those come back OK, then the TCU may be fried.
cshae82
Illinois, USA
C?ID=533095
My battery had died and I had to get a new one. Auto Zone said it was a bit bigger than my old one but they looked it up and says my Passat says it would work.
RGH0
Australia
C?ID=433612
The over voltage may have casued your battery to die and also be causing your other problems. The regulator in the alternator has probably failed causing the voer voltage and that needs to be fixed, nothing to do with battery size.
Whether that over voltage has caused permanent damage to the transmission control module is the next step to investigate once you check for blown fuses
cshae82
Illinois, USA
C?ID=533095
yes, it was after the reflash.
We have an A1 in today (posh Polo) and that has a dirty great 115 size (BBMA designation) battery in the boot, why such a big battery compared to the 096 in a Passat?
EuroX
Northern NJ USA
C?ID=208579
ECM reflash or TCM/Mech reflash? If either or I suspect bricked module or wrong software written to module. This would be after checking basics like power,ground and communication lines/wiring and fuses.
