Controller refused to send a seed!
rs38
C?ID=519578
After having good success with different MLBEvo based ECUs in the unsupported Porsche, I am trying to add Homelink functions to the MIB3 based ECU, before installing the actual physical stuff.
Error 12: Sub-function not supported or invalid format
some Info from the controller:
   Part No SW: 9J1 035 070 BC    HW: 9J1 035 070 AC
   Component: MU-TP-ND-EU   042 3793
   Serial number: GRO-63326.11.20
   Coding: 75130030808000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: N/A (VIN: N/A)
   VCID: 6888B9C2F2F9AFBB432-803C
   Subsystem 1 - Part No SW: 9J1 919 597 M    HW: 9J1 919 597 M
   Component: A01LG_Prem     H09 0220
   Serial number: LG5LGH30092000010205
   Subsystem 2 - Part No: V03 959 817 J
   Component: MIB3_EU_       0860
   Component: Gracenote2     1006
   Subsystem 4 - Part No SW: 9J1 919 610 K    HW: 9J1 919 610 K
   Component: System DU2     H10 1250
   Serial number: 00000000000000048974
No ASAM data for: "EV_MUTI" ()
Advanced Identification/FAZIT
     Identification: GRO-633
     Date: 26.11.20
     Manufacturer number: 1802
     Test stand number: 0124
Flash Status
     Programming Attempts(application): 1/3/1/3/1/1/0/4/3/3/3/0/0/1/1/1/1/1/1/1/1
     Flash Date: 00.01.01
Misc.
     Hardware number: 9J1 035 070 AC
     Workshop System Name: J794
     Dataset Number: 9J1909545AH
     Dataset Version: 0001
     ASAM Dataset Revision: 001010
Car Info
     Chassis Number: WP0ZZZxxx
VCDS Info:
       VCID: 6888B9C2F2F9AFBB67F-803C
in VCDS controller menu I get a popup and I can chosse from diff. RODs:
e.g.
EV_MUTI_AU37.rod,
EV_MUTI_AU49.rod,
EV_MUTI_AU65.rod*
they all work fine and they result in correct measurement and adaption querys, e.g. channel
>IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo, not activated
but setting security access is not possible as well as setting the channel without SA.
Is the ECU somehow locked that it does not accept SA?
the same is true, when I try to talk to the ECU on my own with an ELM device:
Q: 773|27 05
A: 7DD|7F 27 12
any idea?
rs38
C?ID=519578
is it possible that a diagnostic firewall is enabled and therefore the strange seed refusal?
I compared the above procedure with an Audi 2022 Q5 with MIB3 infotainment and I was able to read all adaption channels without any "secure access" warnings after disabling the firewall.
rs38
C?ID=519578
I retried with open front hood but still the same error with seed refusal.
It's a Porsche part number. We have no info on what Porsche does with these.
rs38
C?ID=519578
it's an Aptiv MIB3 Premium device J794 under the hood having the same bugs and behaviors like Audi, when they introduced it in the A4 2019
Is the refusal of a seed really unknown in the rest of the supported VAG world?
AINils
Germany (AIB)
C?ID=56975
MIB3 Premium (Aptiv) have SFD option, but not sure if J1 Platform have SFD.
But without ROD Files it will be hard to support deeper mods in these cars
rs38
C?ID=519578
this is my main goal: to understand why is MIB3 saying "Controller refused to send a seed" Err:12.
If you google it, it's quite common for ABS access and other ECUs, but it has been fixed somehow or the error subcode wasn't 12.
If it's clearly pointing to a SFD* topic okay, I would accept, and not dig further.
but my best guess is: it's already been solved for similar Audi cars, and does not work out of the box because part numbers don't match.
*if the reason is SFD I's expect a different error code than 12:
rs38
C?ID=519578
here you go:
Sunday,04,September,2022,12:49:53:42831
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4622.4
Chassis Type: Y1-N/A (9J1)
Scan: 01 03 06 08 09 13 15 16 17 19 23 32 36 3C 42 44 46 47 51 52
          5F 65 6B 6C 6D 74 75 81 8C A5 BB BC C0 C5 C6 CE CF D6 D7 DB
          DC DE 8104 8114
VIN: WP0ZZZY1ZMSA12345
6B-Aerodynamics -- Status: OK 0000
81-Gear Shift -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CE-Drive Motor 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
8114-DC/DC Converter HV 2 -- Status: OK 0000
Address 01: Engine (ESCP5-EBEA)       Labels: None
   Part No SW: 9J1 909 101 DK    HW: 9J1 907 522
   Component: 9J1L1CBAA00   H02 0021
   CVN: 52F79AC2
   Coding: 0F0A0012006604002C280000001000000000000000000000
   ASAM Dataset: EV_VCU00XXX0209J1909101XX 001144
   ROD: N/A
   VCID: 77AAEABEAF473043D69-8022
   VINID: 9E002AAAAA41A9D8D1147042081867B425
   Subsystem 1 - Part No SW: 0ME 325 835 H    HW: 0ME 325 835 H
   Component: EGS            H13 0250
   Serial number: 0132805024
   Subsystem 2 - Part No SW: 0ME 315 249 D    HW: 0ME 315 249 D
004 0061
   Serial number: 75402031210112000229
No ASAM data for: "EV_VCU00XXX0209J1909101XX" ()
41162 - ROD - Unknown Error Code
          - 00 [040]
                    Mileage: 21568 km
                    Date: 2022.09.02
                    Time: 16:29:32
Address 03: ABS Brakes (J104)       Labels:* None
   Part No SW: 9J1 614 095 N    HW: 9J1 614 095 N
   Component: PSM9_Hev      H07 0120
   Serial number:   085060012818
   Coding: 050505210000B4063C4D038B1F9B2E92
   Shop #: WSC 00001 000 00000
   ASAM Dataset: EV_ESP9BOSCHPO513 002000
   ROD: EV_ESP9BOSCHPO513.rod
   VCID: 3B22368ED3EFD423F21-806E
339457 - Unknown Error Code
          C135C F4 [040] - Unknown Error Elaboration
          [BrkCoolgFlapPosnImps]
                    Mileage: 21541 km
                    Date: 2022.09.02
                    Time: 12:19:51
                    86 40 80 03 91 24 00 00 00 00
                    OBD AgingCounter-DataRecordValue: 27
169984 - Databus
          U1123 00 [046] - Received Error Message
          [EFP: FR-Signalfehler]
                    Mileage: 21504 km
                    Date: 2022.09.02
                    Time: 11:11:44
                    83 C0 07 00 43 24 00 00 00 00
                    OBD AgingCounter-DataRecordValue: 28
   Part No SW: 4M8 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0064
   Serial number: 00000426921937
   Coding: 01401210000032858000010101010000210000070700070700000000011000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_AU37.rod
   VCID: 3FDA429EC7F7C803DE9-806A
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001131120402585DB
   Coding: BF2F00
Address 08: Auto HVAC (J301)       Labels:* None
   Part No SW: 9J1 907 040 K    HW: 9J1 907 040 A
   Component: MSB_BB        H52 1160
   Serial number: 21011202351551
   Coding: 80000000010A203106C226000E05A061
   Shop #: WSC 65840 137 00000
   ASAM Dataset: EV_ACClimaBHTCPO513 005001
   ROD: EV_ACClimaBHTCBY736_004.rod
   VCID: 33321EAEFBBF1C632A1-8066
   Subsystem 1 - Part No SW: 972 907 521 C    HW: 972 907 521 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000005569499
   Air quality sensor:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H04 0010
   Serial number: A59502D700PAG0MUFU04
   Sunlight photo sensor:
   Subsystem 3 - Part No SW: 9J1 907 539 B    HW: 971 907 539
   Component: 70A-3DSoSe  H02 0505
   Serial number: 00000000002710200080
   Control module for heating element 1:
   Subsystem 4 - Part No SW: 3F0 959 772     HW: 3F0 959 772
   Component: J215 SG LHR01  003 0009
   Serial number: 00000000002090393086
   Control module for heating element 2:
   Subsystem 5 - Part No SW: 3F0 959 772     HW: 3F0 959 772
   Component: J216 SG LHR02  003 0009
   Serial number: 00000000002090393090
   Button for heated rear seats:
   Subsystem 6 - Part No SW: 9J1 919 709 B    HW: 9J1 919 709 B
   Component: BEB  H03 0750
   Serial number: 00000000440126224040
   Part No SW: 971 907 063 M    HW: 4N0 907 063 D
   Component: BCM1 MLBevo   H10 0712
   Coding: 07000140E12B900D0F0001581CAB8E2000C332210A00018B89000400240116018B410B3A0356050000000100000000001000000000000000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 270AFAFE3F6760C3869-8072
   Subsystem 1 - Part No SW: 9J1 955 119 C    HW: 9J1 955 119 C
   Component: J400FRWISCH  083 0743
   Serial number: 00000002009290401287
   Coding: 004707
   Subsystem 2 - Part No SW: 81A 955 547 B    HW: 81A 955 547
   Serial number: 40020926X81A955547B0
   Coding: 0200CC
   Subsystem 3 - Part No SW: 9J1 920 901 AF    HW: 9J1 920 901 E
   Component: E1     LDS733  017 0661
   Serial number: 0K1X6381-973352
   Subsystem 4 - Part No SW: 971 857 511 A    HW: 971 857 511
   Serial number: GX1CE118112024310160
   Interior Light Module:
   Subsystem 5 - Part No SW: 9J1 959 551 E    HW: 9J1 959 551 E
   Component: DACHKONSOLE  H31 0009
   Serial number: 92032TL100065
   Subsystem 6 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H08 0210
   Serial number: WA145654000094451009
   Coding: 0A0700
67735 - Databus
          [MxB not available]
                    Reset counter: 96
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 15:25:28
                    average_Voltage_terminals: 13.30 V
                    Outside air temperature sensor-Outside air temperature on CAN: 31.50 °C
                    interior_temperature: 29.50 °C
                    Vehicle speed: 0.00 km/h
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 9J1 907 561 G    HW: 9J1 907 561
   Component: LRR4          H03 0496
   Coding: 7C60D7D258082C00000180200000003C353344464C0100DF11
   ASAM Dataset: EV_ACCBOSCHAU65X 002030
   ROD: N/A
   VCID: 372A2ABEEFC7F043169-8062
No ASAM data for: "EV_ACCBOSCHAU65X" ()
2342 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 96
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 15:25:16
2344 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 99
                    Mileage: 21613 km
                    Date: 2022.09.02
                    Time: 20:40:34
2343 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 99
                    Mileage: 21613 km
                    Date: 2022.09.02
                    Time: 20:40:34
2345 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 96
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 15:25:15
Address 15: Airbags (J234)       Labels: None
   Part No SW: 992 959 655 D    HW: 992 959 655 D
   Component: AirbagVW32    H05 3303
   Serial number: 0035GM021K2S
   Coding: DFCCF0C00C200000985000EFF009810000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
   ROD: N/A
   VCID: 2F3A12DE179738834E9-807A
   Subsystem 1 - Part No SW: 9J1 857 705 H    HW: 9J1 857 705 H
   Component: BeltPretRevFL  205 4030
   Serial number: 9J1857705H0337U00540
   Coding: 881036
   Subsystem 2 - Part No SW: 9J1 857 706 H    HW: 9J1 857 706 H
   Component: BeltPretRevFR  205 4030
   Serial number: 9J1857706H0337U00472
   Coding: 881036
   Subsystem 3 - Part No SW: -----------    HW: 480 000 112 20
   Serial number: 35700000000C34D04F4R
   Subsystem 4 - Part No SW: -----------    HW: 480 000 112 20
   Serial number: 3580000000095B68CE4%
   Subsystem 5 - Part No SW: -----------    HW: 480 030 212 20
   Serial number: 351002C10A0CF5709F5G
   Subsystem 6 - Part No SW: -----------    HW: 480 030 212 20
   Serial number: 352002C10A0CB1E14A35
   Subsystem 7 - Part No SW: -----------    HW: 480 030 212 20
   Serial number: 355002C10A047571094W
   Subsystem 8 - Part No SW: -----------    HW: 480 030 212 20
   Serial number: 356002C10A0CF9B03A1E
   Subsystem 9 - Part No SW: -----------    HW: 480 030 211 20
   Component: PedP_Sensor_D  002 014A
   Serial number: 228002C1080890412B8Z
   Subsystem 10 - Part No SW: -----------    HW: 480 030 211 20
   Component: PedP_Sensor_P  002 014A
   Serial number: 229002C10809DCC0482A
   Subsystem 11 - Part No SW: -----------    HW: 480 032 511 20
   Component: PedP_Sensor_C  002 014A
   Serial number: 230002C142DA0960286.
   Subsystem 12 - Part No SW: -----------    HW: 480 002 111 20
   Serial number: I0M00000000665A83DCH
   Subsystem 13 - Part No SW: -----------    HW: 480 002 111 20
   Serial number: I0N00000000945A83DCJ
   Subsystem 14 - Part No SW: -----------    HW: 480 031 611 20
   Component: HVSensor_gSat  002 0149
   Serial number: I0T002C103049650EC2V
   Subsystem 15 - Part No SW: -----------    HW: 480 030 212 20
   Component: SideSens_B_Df  002 0149
   Serial number: I0P002C10A0C7DA128D5
   Subsystem 16 - Part No SW: -----------    HW: 480 030 212 20
   Component: SideSens_B_Pf  002 0149
   Serial number: I0Q002C10A0BF5001C5W
   Subsystem 17 - Part No SW: -----------    HW: 480 031 211 20
   Component: HV2_Sens_gSat  002 0149
   Serial number: I0U002C101E8FCC04BEP
No ASAM data for: "EV_AirbaVW31SMEAU65x" ()
1065481 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 96
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 15:25:20
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 992 953 502 DL    HW: 992 953 502 DL
   Component: Lenks.Modul   H03 0008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 6C80C5D2E601839B2BB-8038
Address 17: Instruments (K)       Labels: None
   Component: KOMBI LG      017 0661
   Coding: 2000000205112014C02608A608A608DA0500F013141E0004040600040000280C28282008507864A0000BC805280A12000028400000028028000000000200
   ASAM Dataset: EV_DashBoardLGEPO513 004001
   ROD: N/A
   VCID: 70B8D1A2CA29677B173-8024
No ASAM data for: "EV_DashBoardLGEPO513" ()
10485848 - ROD - Unknown Error Code
          - 00 [104]
                    Reset counter: 30
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 15:49:00
   Part No SW: 9J1 907 468 K    HW: 9J1 907 468
   Component: Gateway       H04 0708
   Serial number: F0895842899691
   Coding: 02010001010960C0C8C0050001DB01161EAA013018010001000004BF00000000
   GVL: FF5B3C401800000854FC880090024818410C0060000080018000000000007700
   ASAM Dataset: EV_Gatew31xPO513 003230
   ROD: N/A
   VCID: 41DE4466B103BEF3A8D-8014
   Subsystem 1 - Part No SW: 9J1 959 256 C    HW: 9J1 959 256 C
   Component: E221__MFL-TAT  H04 0091
   Serial number: 20201104061641 00188
   Coding: B6C4FF
   Subsystem 2 - Part No SW: 9J1 915 105 M    HW: 9J1 915 105 M
   Component: 12V_LiIon_BMS  H07 4187
   Serial number: C0220480162523492310
No ASAM data for: "EV_Gatew31xPO513" ()
131687 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 105
                    Mileage: 21503 km
                    Date: 2022.09.02
                    Time: 08:13:54
131829 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 99
                    Mileage: 21613 km
                    Date: 2022.09.02
                    Time: 20:44:41
131830 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 105
                    Mileage: 21504 km
                    Date: 2022.09.02
                    Time: 09:28:14
262693 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 94
                    Mileage: 21503 km
                    Date: 2022.09.01
                    Time: 16:12:57
16711779 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 20
                    Reset counter: 106
                    Mileage: 21503 km
                    Date: 2022.09.02
                    Time: 07:38:04
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 9J1 907 107 C    HW: 9J1 907 107 C
   Component: J539 EBKV H05 0100
   Serial number: BPA085231020013
   Coding: 0000000000000000
   ASAM Dataset: EV_BrakeBoostBOSCHPO513 003002
   ROD: EV_BrakeBoostBOSCHPO513.rod
Address 32: Differential Locks (J647)       Labels: None
   Part No SW: 9J1 927 771 D    HW: 9J1 927 771 D
   Component: QUERSPERRE    H02 2021
   ASAM Dataset: EV_GQSZFPO513 002002
   ROD: EV_GQSZFPO513.rod
   VCID: 392E2C86D9D3E633E0D-806C
   Component: MEM-FS        009 0064
   Serial number: 00000426882296
   Coding: 01181240000036858000010101010000210000070700070700000000015000
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ80011411204025808C
   Coding: BF2F00
   Part No SW: 4N0 907 566 K    HW: 4N0 907 566 A
   Component: MRR_HR H14 0486
   Coding: 035000
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_VW53.rod
   VCID: 3E243F9AC0FDC10BD5F-806A
   Part No SW: 4M0 959 793 N    HW: 4M0 959 793 N
   Component: TSG FS        011 0390
   Serial number: 0000427619695
   Coding: 002DCA427E000290A005B410
   VCID: 49CE5C46893376B370D-801C
   Part No SW: 9J1 907 445 H    HW: 9J1 907 445
   Component: EPS_MLBEVO_ZF H07 0430
   Serial number: 008509442811200
   Coding: 0C09B740800000
   Shop #: WSC 69905 204 00001
   ASAM Dataset: EV_EPSBOPO68X 001001
   ROD: EV_EPSBOPO68X.rod
25088 - Databus
          [KFC_KLIMA_03_TIMO]
                    Reset counter: 96
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 15:46:34
                    Extended_ambient_data_1-Terminal 15 status: 0
                    Extended_ambient_data_1-DTC: 0
                    Extended_ambient_data_1-Malfunction type: 0
                    Extended_ambient_data_1-Parallel Parking Assistance: not active
                    Extended_ambient_data_1-Vehicle speed: 0 km/h
                    Extended_ambient_data_1-Hybrid drive: not active
                    Extended_ambient_data_1-Supply voltage: control module: 13.25 V
                    Extended_ambient_data_1-Control Module temperature: 42 °C
                    Extended_ambient_data_1-Active Steering: not active
                    Extended_ambient_data_1-Steering recommendation: not active
                    Extended_ambient_data_1-Constant steering ratio: not active
                    Extended_ambient_data_1-Variable steering ratio: not active
                    Extended_ambient_data_1-Trailer positioning assistant: active
                    Extended_ambient_data_1-Fully automatic parallel parking assistant: not active
                    Extended_ambient_data_1-Activated_variant_of_park_steering_assistant: not active
                    Extended_ambient_data_1-Assitent System Monitor (ASM): active
                    Extended_ambient_data_1-Audi_drive_select: not active
                    Extended_ambient_data_1-BattAb True False: 0
                    Extended_ambient_data_1-Coding_value_1_custom_function: active
                    Extended_ambient_data_1-Coding_value_2_custom_function: inactive
                    Extended_ambient_data_1-Coding_value_3_custom_function: active
                    Extended_ambient_data_1-Collision_avoidance_assis: active
                    Extended_ambient_data_1-Drive Select Generation: Gen1 (Charisma_01)
                    Extended_ambient_data_1-Heading_control_assistant: not active
                    Extended_ambient_data_1-Klemme 15 signal is True/Flase: 0
                    Extended_ambient_data_1-Kodierung J1: active
                    Extended_ambient_data_1-Manövier- und Felgenschutzassistenten (MA): active
                    Extended_ambient_data_1-Online Remote Update (ORU): inactive
                    Extended_ambient_data_1-Oversteer_osc: not active
                    Extended_ambient_data_1-Reserved Bits: 0
                    Extended_ambient_data_1-Start_Stop: not active
                    Extended_ambient_data_1-Status_of_coding: not performed
                    Extended_ambient_data_1-Staupilot (STP): inactive
                    Extended_ambient_data_1-Traffic_jam_guidance_assist: not active
                    Extended_ambient_data_1-Understeer_usc: not active
                    Extended_ambient_data_1-VIN-Monitoring: not active
15872 - Function Restriction
          U13D5 00 [008] - Lane-Hold Assist
          [KFC_HCA]
                    Reset counter: 99
                    Mileage: 21548 km
                    Date: 2022.09.02
                    Time: 16:07:23
                    Extended_ambient_data_1-Control Module temperature: 46 °C
                    Extended_ambient_data_1-Online Remote Update (ORU): active
17920 - Unknown Error Code
          C135D F1 [008] - Unknown Error Elaboration
          [KFC_PAG_HOD_INACTIVE]
                    Reset counter: 99
                    Mileage: 21548 km
                    Date: 2022.09.02
                    Time: 16:07:23
   Part No SW: 992 907 064 DK    HW: 8W1 907 064 K
   Component: BCM2 MLBevo   045 0604
   Coding: 0154350017F0E06D43E9E7040C200C02000040209257045D2B0C00604104807F801F1290010043
   ASAM Dataset: EV_BCM2HellaAU736 020017
   ROD: EV_BCM2HellaAU736_019.rod
   VCID: 6D86C8D6DD1B8A933C5-8038
   Subsystem 1 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY202603426
   Subsystem 2 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14933865
   Part No SW: 9J1 035 223 F    HW: 9J1 035 223
   Component: MIB2_amp_PCA  H01 0150
   Serial number: 00000000000322
   Coding: 0700000800FFFFFFFFFFFF010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 002001
   ROD: N/A
   VCID: 290EFCC6297356B390D-807C
No ASAM data for: "EV_AMPMst16C4Gen2BOSE" ()
   Part No SW: 9J1 907 121 BJ    HW: 9J1 907 123 F
   Component: PO9J160210001 H04 0021
   Serial number: -00116.01.21100
   ASAM Dataset: EV_PWR1HIAMSPO513 001001
   ROD: EV_PWR1HIAMSPO513.rod
   VCID: 74B0DDB2BE315B5BF3B-8020
   Part No SW: 4M0 959 792 N    HW: 4M0 959 792 N
   Component: TSG BFS       011 0390
   Serial number: 0000427819500
   Coding: 002DC2427E000292A005B410
   VCID: 48C8594292398FBB6F3-801C
   ROD: N/A
   VCID: 6888B9C2F2F9AFBB4F3-803C
   Subsystem 2 - Part No: V03 959 817 FD
   Component: MIB3_EU_2022.  0790
1555 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 102
                    Mileage: 21503 km
                    Date: 2022.09.02
                    Time: 07:44:12
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 992 907 273 D    HW: 4M0 907 273 B
   Component: RDKHUFPO68X   H06 0220
   Serial number: 40000000044431
   ASAM Dataset: EV_RDKHUFPO68X 001001
   ROD: N/A
   VCID: 2410EDF24E518BDBA3B-8070
No ASAM data for: "EV_RDKHUFPO68X" ()
Address 6B: Aerodynamics (J223)       Labels: 992-907-483.clb
   Part No SW: 992 907 483 P    HW: 992 907 483 P
   Component:               H06 0134
   ASAM Dataset: EV_MASGMarquPO622 003001
   ROD: EV_MASGMarquPO622_002.rod
   Part No SW: 4M0 980 556 B    HW: 95B 980 551 L
   Component: RVC Compact   H18 0250
   Coding: 0515030102000001C20040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU73.rod
   VCID: 34301DB2FEB11B5B33B-8060
   Part No SW: 8W2 959 107     HW: 8W2 959 107
   Component: HDSG-Modul    H04 0330
   Revision: --------    Serial number: A2-C765-4880-8
   Coding: 2B00
   Shop #: WSC 65792 137 00000
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536_VWE4.rod
   VCID: 55F68036558B2253E45-8000
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 9J1 907 553 R    HW: 9J1 907 553 B
   Component: Fahrwerk-SG   H21 1510
   Serial number: 0412200504
   Coding: 0A19040297001260
   ASAM Dataset: EV_ChassContrContiPO513 004001
   ROD: EV_ChassContrContiPO513_004.rod
   VCID: 43D24E6EAB1FACE3BA1-8016
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132159516
   Part No SW: 4N0 035 282 C    HW: 4N0 035 282
   Component: CB_H_ECE_VTS  039 0450
   Serial number: P114K0LS016738
   Coding: 07E2E0FF8040C038E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_AU65.rod
   Part No SW: 9J1 713 033 C    HW: 9J1 713 033 C
   Component: Waehlhebel115 0190
   Serial number: 00019729
   ASAM Dataset: EV_GSMWaehlJOPPPO68X 001001
   ROD: N/A
   VCID: 2808F9C232796FBB8F3-807C
No ASAM data for: "EV_GSMWaehlJOPPPO68X" ()
24698 - ROD - Unknown Error Code
          - 00 [109]
                    Reset counter: 0
                    Mileage: 21503 km
                    Date: 2022.09.02
                    Time: 07:38:15
Address 8C: HV Battery (AX2)       Labels:* None
   Part No SW: 9J1 915 234 AK    HW: 9J1 915 234 AA
   Component: AA1641A       H13 1641
   Serial number: 000000432000004
   Coding: 0000000000000000000000000000
   ASAM Dataset: EV_BECM1982091 003003
   ROD: EV_BECM19820003.rod
   VCID: 78A8E982A2593F3BDF3-802C
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 108 H    HW: 4K4 907 108
   Component: zFAS Var B    H09 0371
   Coding: 042784000000000000F8060000D44C24319E5600000000F80000000000000000000000000000000000000000000000000000000000000000D2804000000000000000729000A000B00080008000000000008040008000
   ASAM Dataset: EV_ZFASAU516 003010
   ROD: EV_ZFASAU516_003_AU58.rod
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [008] - View Temporarily Restricted
          [temp view limitations]
                    Reset counter: 99
                    Mileage: 21612 km
                    Date: 2022.09.02
                    Time: 20:35:54
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: 47 °C
                    Vehicle speed: 2.98 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: No
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: Yes
221281 - Control Module for Driver Assist Systems
          C12D5 FA [008] - Image Processor does not Repsond.
                    Reset counter: 96
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 15:25:16
                    EyeQ error source: General malfunction
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Reset counter: 96
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 15:25:16
2117741 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [ServiceConnectTimeout_ETH_Update]
                    Reset counter: 100
                    Mileage: 21619 km
                    Date: 2022.09.02
                    Time: 21:04:56
                    Ethernet signal quality: good: link available
   Part No SW: 4M0 959 795 N    HW: 4M0 959 795 N
   Component: TSG HFS       011 0390
   Serial number: 0000428026998
   Coding: 000CC24201000290A000B000
   VCID: 4BC2664E834F64A3421-801E
   Component: TSG HBFS      011 0390
   Serial number: 0000428063638
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
196663 - Motor for Window Regulator
          B1487 4B [008] - Over Temperature
                    Reset counter: 100
                    Mileage: 21624 km
                    Date: 2022.09.02
                    Time: 21:32:00
Address C0: Act. for Ext. Noise (-----)       Labels:* None
   Part No SW: 9J1 035 335 F    HW: 3F0 035 335
   Component: E_SOUND_SGH07 0100
   Serial number: E2047154160000
   Coding: 84
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003008
   ROD: EV_ESoundMLBEvoS1NN.rod
   VCID: 2D0608D61D9B4A937C5-8078
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 J    HW: 4KE 965 429
   Component: TME-Max       H08 0324
   Serial number: 0260435
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002040
   ROD: EV_ThermContrVISAU49X_AU58.rod
   VCID: 51FE742661634E7338D-8004
   Subsystem 1 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G395 pT-Sens1  H11 0010
   A/C compressor sub:
   Subsystem 2 - Part No SW: 9J1 816 797 B    HW: 9J1 816 797 B
   Component: J842 EKK es33  H05 0117
   Serial number: 00000000020100201932
   A/C pressure/coolant temperature sensor 2:
   Subsystem 3 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G826 pT-Sens2  H11 0010
   A/C pressure/coolant temperature sensor 3:
   Subsystem 4 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G827 pT-Sens3  H11 0010
   Coolant heating:
   Subsystem 5 - Part No SW: 9J1 963 507 E    HW: 9J1 963 507 E
   Component: HV_HEIZER  H11 0016
   Serial number: 00000000002227376638
   Expansion valve 2 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151734869
   Expansion valve 3 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N638 EV3_KaMi  H12 0102
   Serial number: 00000000000151731521
   Shut-off valve 2 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000000282921
   Shut-off valve 3 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000000281411
   Shut-off valve 5 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000000282913
   Radiator shutter:
   Subsystem 11 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1  H13 0110
   Serial number: 20201108060103054724
   Radiator louver 2:
   Subsystem 12 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V550KJS2  H13 0110
   Serial number: 20201109060103050665
   Coolant valve 1:
   Subsystem 13 - Part No SW: 9J1 963 375 F    HW: 9J1 963 375 F
   Component: V650 V1_KUEMI  010 0103
   Serial number: 00000000000001813264
   Coolant valve 2:
   Subsystem 14 - Part No SW: 9J1 963 375 E    HW: 9J1 963 375 E
   Component: V651 V2_KUEMI  010 0103
   Serial number: 00000000000002051315
   Coolant valve 3:
   Subsystem 15 - Part No SW: 9J1 906 459 A    HW: 9J1 906 459 A
   Component: V653 V3_KUEMI  010 0103
   Serial number: 00000000000001827996
   Coolant valve 4:
   Subsystem 16 - Part No SW: 9J1 963 375 G    HW: 9J1 963 375 G
   Component: V656 V4_KUEMI  010 0103
   Serial number: 00000000000001821652
   Coolant valve 5:
   Subsystem 17 - Part No SW: 9J1 963 375 J    HW: 9J1 963 375 J
   Component: V632 V5_KUEMI  010 0103
   Serial number: 00000000000001828913
   Coolant valve 6:
   Subsystem 18 - Part No SW: 9J1 963 375 D    HW: 9J1 963 375 D
   Component: V633 V6_KUEMI  010 0103
   Serial number: 00000000000001832553
61010 - Implausible Data Received from Battery Energy Control Module 2
          U0413 00 [040] - -
                    Mileage: 21624 km
                    Date: 2022.09.03
                    Time: 09:30:21
                    Unlearning counter according OBD: 36
                    Expanded ambient data 1-Voltage terminal 30: 0.000 V
                    Expanded ambient data 1-Vehicle speed: 16 km/h
                    Expanded ambient data 1-System status: Drive readiness
                    Expanded ambient data 1-Power quota setting by energy management: 1D
                    Expanded ambient data 1-Status of drive readiness hybrid: Electrical travel
                    Expanded ambient data 1-Ambient temperature: 22.50 °C
                    Expanded ambient data 1-current state of low temp.circ.: 00
                    Expanded ambient data 1-previous state low-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
                    Expanded ambient data 1-current state of high-temp.circ.: 00
                    Expanded ambient data 1-previous state of high-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
                    Expanded ambient data 1-current state of battery low temp.circ.: 05
                    Expanded ambient data 1-previous state of battery low temp.circ.: 00
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 0F
                    Expanded ambient data 1-current state of battery cold circuit: 00
                    Expanded ambient data 1-previous state of battery cold circuit: 00
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 24
   Part No SW: 5QE 915 684 DA    HW: 5QE 915 684 BK
   Component: OBC KOSTAL    H74 1089
   Serial number: EEEEEEEEEEEEEEE
   Coding: 7B588DAF5B044E010000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev16B 004007
   ROD: EV_OBC3Phase1KLOMLBev16B.rod
   VCID: 117EB426A1E30E7378D-8044
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 9J1 959 774 E    HW: 9J1 959 774 E
   Component: V544KJS1       H06 0012
   Serial number: 20201124060105030257
   Flap 2 for charging socket:
   Subsystem 2 - Part No SW: 9J1 959 774 E    HW: 9J1 959 774 E
   Component: V550KJS2       H06 0012
   Serial number: 20201124060105030164
   Button with charging display Flap 1 for charging plug:
   Subsystem 3 - Part No SW: 9J1 915 737 AD    HW: 9J1 915 737
   Component: UX4  ETSA1     H03 0090
   Serial number: 08092010010080000000
   Button with charging display Flap 2 for charging plug:
   Subsystem 4 - Part No SW: 9J1 915 737 AE    HW: 9J1 915 737
   Component: UX5  ETSA2     H03 0090
   Serial number: 28102010010381000000
   Sensor Flap 1 for charging socket:
   Subsystem 5 - Part No SW: 9J1 962 237 B    HW: 9J1 962 237 B
   Component: LKS_li         C00 C4.0
   Serial number:              9483114
   Sensor Flap 2 for charging socket:
   Subsystem 6 - Part No SW: 9J1 962 238 B    HW: 9J1 962 238 B
   Component: LKS_re         C00 C4.0
   Serial number:              9495736
13705826 - Control Module for Active Park System
          U13AE 00 [040] - Implausible
          [error_hold_management_system]
                    Reset counter: 29
                    Mileage: 21504 km
                    Date: 2022.09.02
                    Time: 09:24:03
2097291 - Rapid DC Charging
          U15AB 00 [040] - Communication Error with Charging Station
          [communication_error_between_vehicle_and_charging_station]
                    Reset counter: 30
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 13:26:44
2097294 - Rapid DC Charging
          U15AF 00 [040] - Charging Station Encryption Failed
          [failed_encryption]
                    Reset counter: 30
                    Mileage: 21542 km
                    Date: 2022.09.02
                    Time: 13:26:44
3276840 - Intelligent Charging Function
          U15BF 00 [040] - Communications Error
          [ETHTRCV_30_AR7000_E_ACCESS]
                    Reset counter: 38
                    Mileage: 21754 km
                    Date: 2022.09.03
                    Time: 16:38:11
3280913 - Signal Damping Protocol
          U15AC 00 [040] - Malfunction
          [ETHTRCV_30_AR7000_E_FW_DWLD]
                    Reset counter: 38
                    Mileage: 21754 km
                    Date: 2022.09.03
                    Time: 16:38:11
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 9J1 907 124 AM    HW: 9J1 907 124 L
   Component: PO9J130160001 H04 0021
   Serial number: -00124.08.20200
   ASAM Dataset: EV_PWR2HIAMSPO513 001001
   ROD: EV_PWR2HIAMSPO513.rod
   VCID: 79AEEC8699532633A0D-802C
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H14 0486
   Coding: 035000
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_VW53.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 592 BA    HW: 992 941 592 B
   Component: LED1L         H08 9002
   ROD: N/A
   VCID: 6596B0F605EBB2D3745-8030
No ASAM data for: "EV_LLPGen3LKEBODPO68X" ()
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9002
   ROD: N/A
No ASAM data for: "EV_LLPGen3RKEBODPO68X" ()
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 K    HW: 4N0 907 669 A
   Component: MRR_VR H14 0485
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
   ROD: EV_FrontCorneRadarS1AU651_VW53.rod
   VCID: 42DC4B6AB405A5EBB17-8016
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H14 0485
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
   ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 9J1 035 504 B    HW: 9J1 035 504 B
   Component: WLC           H04 0002
   Coding: 800080
Address 8104: DC/DC Converter HV (A48)       Labels: None
   Part No SW: 9J1 959 663 BE    HW: 9J1 959 663 AN
   Component: DCDC_WandlerH15 1910
   Serial number: 000048602
   ASAM Dataset: EV_DCDC400VBasisPREHPO513 001001
   ROD: EV_DCDC400VBasisPREHPO513.rod
   VCID: 015E8466F1837EF3E8D-8054
Address 8114: DC/DC Converter HV 2 (J1178)       Labels:* None
   Part No SW: 9J1 915 539 DC    HW: 9J1 915 539 CA
   Component: HV_BoosterH14 1910
   Serial number: 000049488
   Coding: 00000000
   ASAM Dataset: EV_HVChargBoostPREHPO513 001002
   ROD: EV_HVChargBoostPREHPO513.rod
   VCID: 7BA2F68E936F1423B21-802E
End----------(Elapsed Time: 03:24, VBatt start/end: 13.4V/13.4V)-----------
rs38
C?ID=519578
I tried like 20301 and that special S12345, but as the ECU refuses the Seed-Generation (which comes before checking SA correctness), it does not matter what I try!
AINils
Germany (AIB)
C?ID=56975
20103 is the correct one. But why do you use login. 5F can be coded without login since MIB1
rs38
C?ID=519578
typo...I am not talking about a wrong login/SA but failing init of $27 secure access. I'd like to understand what happens. Is the requested SA level too high?
I do not use coding but adaption channels. See my initial post.
AINils
Germany (AIB)
C?ID=56975
Coding and adaptions in both case dont need Login. But we will check in live next week if you visit me :)
