VCDS upgrade
senna1
C?ID=231631
Hi i have vcds HEX + CAN, today i scanned a 2020 t5/t6 Transporter and it says i need to udate to a different interface, why is this,
is for DOIP as some vehicles now using that and some scanners cant communicate,
senna1
C?ID=231631
Monday,21,November,2022,17:26:29:44675
VCDS Version: 21.9.0.2 (x64)
VIN: WV1ZZZ7HZLH054449   License Plate: VW T5/T6
Chassis Type: 7H (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F 75
Address 01: Engine (J623-CXHC)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 SC    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9970
   Revision: 23301001
   Coding: 001140144344050900000000000000000000000000000000
   Shop #: WSC 00012 790 00028
   ASAM Dataset: EV_ECM20TDI03004L906056SC 005007
   ROD: N/A
   VCID: 000465879BAD808941-8054
   VINID: 9E606AAAA1D8A9C6001441042421E215CD
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM20TDI03004L906056SC" ()
31150 - ROD - Unknown Error Code
          - 00 [236]
                    Mileage: 117388 km
                    Date: 2022.11.10
                    Time: 01:11:11
27277 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 117387 km
                    Date: 2022.11.10
                    Time: 00:47:17
25126 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 117387 km
38427 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 117859 km
                    Date: 2022.11.13
                    Time: 10:37:20
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LB 614 517 A    HW: 7LB 614 517
   Component: ESC_base      H01 0700
   Serial number: 08507298200219
   Coding: 31552452484CEE898C5824A8126F7706392320B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: N/A
   VCID: 3E78DB7FA1D9367973-806A
No ASAM data for: "EV_Brake1ESP90iBOSCHVN46X" ()
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 7LA 907 426 B    HW: 7LA 907 426 B
   Component: AC Manuell    H01 0502
   Coding: A03110000810000001000800504001050000000000000000800000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: N/A
   VCID: 4280AF8FD521529917-8016
No ASAM data for: "EV_AirCondiBHTCT6PA" ()
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01102004800974
   ASAM Dataset: EV_BCMA0 205001
   ROD: N/A
   VCID: 74EC3957DF15AC2955-8020
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S3Y20M02D06H11M28S19
   Coding: 02B8EE
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000038018515
   Coding: 1F000F
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000037417684
   Coding: 050007
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY200303ENP
   Serial number: 00000000000032481054
No ASAM data for: "EV_BCMA0" ()
11530 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Frequency: 34
                    Reset counter: 77
                    Mileage: 107892 km
                    Date: 2022.09.25
                    Time: 17:57:54
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058620044
   Coding: 0451051801
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: N/A
   VCID: 50A495C70B4DB00991-8004
No ASAM data for: "EV_EPHVA18AU3700000" ()
13637426 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 88
                    Mileage: 117774 km
                    Date: 2022.11.10
                    Time: 00:01:09
Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 2A00600201FF8748949C815560508700000000000000000004
   Shop #: WSC 00012 790 00040
   ROD: N/A
   VCID: 438EAA8BCA3B5B911C-8016
No ASAM data for: "EV_ACCMRRCONTIVW376" ()
2101 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 8
                    Reset counter: 88
                    Mileage: 117774 km
                    Date: 2022.11.10
                    Time: 00:01:11
2068 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 8
                    Reset counter: 89
                    Mileage: 117774 km
                    Date: 2022.11.10
                    Time: 00:01:11
2055 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 8
                    Reset counter: 88
                    Mileage: 117774 km
                    Date: 2022.11.10
                    Time: 00:01:12
Address 15: Airbags (J234)       Labels:. 5Q0-959-655.clb
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    015 0506
   Revision: --------
   Coding: 8800C00000000000400000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: N/A
   VCID: 7F06E67BE653FF7138-802A
No ASAM data for: "EV_AirbaVW22BPAVW27X" ()
Address 17: Instruments (J285)       Labels: Redir Fail!
   Part No SW: 7LA 920 941     HW: 7LA 920 941
   Component: KOMBI         205 6750
   Coding: 27A40A002480260001882A010401000000200000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: N/A
   VCID: 7DFA1C73EC5FED612A-8028
No ASAM data for: "EV_DashBoardVDDMQBAB" ()
9456681 - ROD - Unknown Error Code
          - 00 [008]
                    Mileage: 39647 km
                    Date: 2021.07.28
                    Time: 10:06:04
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 17022011602277
   Coding: 030100044F05730000000018000F00010001070000000000000000000000
   Shop #: WSC 00012 790 00160
   GVL: 01443C0000000000400080008000480000000000000000000000000000000000
   ROD: N/A
   VCID: 70E43547AB0D9009B1-8024
   Component: 4-01-09-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036048202611
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 77343301002002110413
No ASAM data for: "EV_GatewNF" ()
Address 44: Steering Assist (J500)       Labels:. 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: N/A
   VCID: 458AB493C40F65A132-8010
No ASAM data for: "EV_SteerAssisMNB" ()
44800 - ROD - Unknown Error Code
          - 00 [104]
                    Reset counter: 161
                    Mileage: 88533 km
                    Date: 2022.05.24
                    Time: 13:43:35
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-ENT2.clb
   Part No SW: 3G0 035 869 B    HW: 3G0 035 869 B
   Component: MU-E-D-ER     720 0740
   Serial number: 29012000020025
   Coding: 066401003C00000041110101008000001F0000C60000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: N/A
   VCID: 2B5EE22B42ABB3D1C4-807E
No ASAM data for: "EV_MUEnt4CGen2LGE" ()
1637 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 117
                    Mileage: 118883 km
                    Date: 2022.11.20
                    Time: 17:13:45
Address 75: Telematics (J949)       Labels: None
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000911NVZC6
   Coding: 06462000196818208005460160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: N/A
   VCID: 0102608390A789814E-8054
No ASAM data for: "EV_OCUGen3Low" ()
2566 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 34
7170 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 30
                    Mileage: 2492 km
                    Date: 2020.12.24
                    Time: 09:27:22
13893632 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 11
                    Mileage: 117775 km
                    Date: 2022.11.10
                    Time: 13:43:24
1644784 - ROD - Unknown Error Code
          - 00 [009]
                    Mileage: 60652 km
                    Date: 2021.12.08
                    Time: 09:11:41
1644276 - ROD - Unknown Error Code
          - 00 [009]
End-------------------------(Elapsed Time: 03:16)--------------------------
Address 01: DTCs cleared
senna1
C?ID=231631
you can see no support for the DTC just unknown error.
why is this`
The HEX+CAN interface was state-of-the-art when it was introduced in 2004. It had a whole 16 kB of room for code, and 1 kB of RAM. At the time, that seemed like plenty, but 11-12 years later, VAG introduced new addressing modes, and the code space in the HEX+CAN was full. In addition, some UDS modules have adaptation channels that are too big for the HEX+CAN to buffer properly. We stopped selling HEX+CANs at the end of 2016 and replaced it with something more modern / more capable. It can be a problem on some MY 2016 and newer cars, and is not suitable at all for MY 2019 or newer.
senna1
C?ID=231631
ok UWE thanks for the info,, i spoke to Gendan in the uk today & asked if VCDS were going to take the next step like top end scanner
doing programming read skc mac etc change vin , if changing replacement modules DONA items, and he said you were vcds doing some of these
features to come next year, can you explain what is to come for Vag
No, we we will not make VCDS into a tool that can be used to steal cars or falsify their electronic identity.
What we are working on is an proper relationship with VAG for SFD access in real time.
senna1
C?ID=231631
Can you explain more of what VCDS will be able to do for Vag, it sounds like no reading of SK etc, Topend scanners are already for some time supporting change vin etc, NOT FOR STEALING , But for when Ecu's or other modules screw up as not everyone can afford to pay stupid prices for new, especially depending on the year of the Vehicle, the poit is also Vag immob is easily by passed, so you dont need Topend scanners to steel Vehicles, IMMOB is just a deterrent, And to quote VCDS if you do have SKC you can use VCDS to do the job ? It is a everyday problem modules needing replacement and matching, The reason i ask i'm looking to spend a few K on a Topend scanner but hearing VCDS were going to update to more
special functions i thought i would wait and buy VCDS but it sounds like the upgrade will be much the same as Now. good tool for most functions
except when your in the shit with modules that need further access programmers to fix the issues , like VVDI2
Bruce
Near Philadelphia, PA, USA
Care to name one other than the VAG tool - ODIS?
Yes, that was the case up to about 2004 model years. After that, we made it clear that the tool could not do Immo iV and beyond. AND to the best of our knowledge, nor can any other aftermarket tool. You have read our Immo page, no? http://wiki.ross-tech.com/wiki/index.php/Immobilizer
Why do you blame us for VAG's methods? There are no other tools that can do this. The only other sanctioned legal tool that we know of for doing the shit you mentioned is the factory tool - ODIS running on their hardware or a J2534 pass through tool - all starting at big dollars with big subscription fees.
So share with the community all the tools you know of that can actually do as you say. We'd sure like to know about those so we might go find out what they did to legally get the right to do these things.
Reactions: JMR
senna1
C?ID=231631
I'm not intersted in the rip of saga, i know there is kit out there for doing replacment modules, do your own research if you are interested, i have my
own opinions and i have seen these tools in use, no tool does all, it is all about kit & Cost and obviously Knowledge, & not just for Vag,
I ask a simple question and the reply suggesting i want a tool for stealing, What a f cheek, everyone i spoke to regarding the reply from UWE said the same suggestion,
And the fact that VVDI was a blatant rip-off of the Abrites AVDI.
SO WHAT as long as it works, i dont give a shit.
cristo_844
Portugal
C?ID=412536
What you are failing to handertend is the vvdi2,AVdi etc are are locksmith tools...Good for making keys!
Good look trying to replace modules other than some clusters and EDC 17 ECus:banghead:
VVDI can't even read most EDC16U34 Mac correctly and support doesn't give a shit :popcorn:
That's great to hear Uwe, even if some sort of vetting process is necessary (similar to ODIS for example) ; I would have no problem sharing that information with RT/VAG and I'd bet may others would agree to it as well. Perhaps offering that to VAG would help RT's request to them as well (?) Looking forward to the "news". :thumbs:
senna1
C?ID=231631
No tool does it it all, whether Clone or original and some even then no joy as vw closed to 3rd party's, here is a link someone trying to get there vehicle to run based on a Dona Module, i know in the new year VCDS is making big gains i have been informed by a reliable source that is why i first set this question in motion, Big cheque have changed hands to speak and discussions so watch this space, https://forums.ross-tech.com/index.php?threads/13725/ . I have a bought a 2.5k scanner covers most manufactures, does Diagnostics immobiliser / keys ( Locksmith ? ) but does not always work out, so you need other tools all money if you want to play with the big Boys, But VCDS is for the money very good , future improvements will help make it even better,
senna1
C?ID=231631
Regarding you say Support doesent give a shit, Depends on who you buy from, and not always cheaper somewhere else same product is best.
and myself even clone tools i have a electronic engineer who looks at the circuit PCB and replaces the crap components for quality items so the tool
is more stable and reliable, The whole idea is to get the job done and If user friendly all the better other wise whats the point.
