Hi,
I've got problem with VW Touareg 2010+ I want to code 4 new TPMS sensors (customer changed wheels with new sensors). In 65-Tire Pressure (UDS), I go to the Adaptation, and there are two options
IDE03513-IDE03525-Write sensor identification number-Sensor identification (here I can write sensor ID)
IDE03513-Write sensor identification number- (in this channel I can choose left, right, front, rear)
at the moment I've got error in 65-Tire Pressure:
8402177 - System Swithced Off
C106D 99 [009] --
probably because there aren't sensor code.
C106D 99 [009] --
Tuesday,22,November,2022,10:05:20:21580
VCDS Version: 22.9.0.0 (x64) HEX-NET CB: 0.4623.4
Dealer/Shop Name: FHU WARCAR Jaworzno
VIN: WVGZZZ7PZCD033474 License Plate: SJ-1665E
Mileage: 419873km-260896mi Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 28 34 36 3C 42 46
47 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZCD033474 Mileage: 419873km-260896miles
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0002
Revision: 53H37--- CVN: A1BAEB4F
Coding: 292A401A237E01020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
ROD: EV_ECM30TDI011_VW52.rod
VCID: B228811BE57BAD1D05-80E6
VINID: 9E65EAAAA1E0A935000C310710CE4E9AB9
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AG HW: 0C8 927 750 AG
Component: AL1000 AISIN 001 1933
Serial number: CVN: CB541148
Coding: 001568
Shop #: WSC 33060 002 1048576
ROD: EV_TCMAL991031_002_VW52.rod
VCID: F1AA4E1720FDD6053C-80A4
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 J HW: 7P0 907 379 A
Component: MK25A H36 0433
Revision: -------- Serial number: 431410010EC010
Coding: 5B6B13C30B272F56DAF8C89AD0D6F450F700
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: C4C4D7C34FCF13ADA7-8090
Part No SW: 4H0 907 064 BH HW: 4H0 907 064 BH
Component: BCM2 2.0 H31 0333
Coding: 05A60000000000000000
VCID: F0AC4B1323F7DF0D33-80A4
Subsystem 1 - Part No SW: 7P6 959 754 AB HW: 7P6 959 754 AB
Component: FBSTOUAREGIDG H06 0051
Serial number: 0511000049715014
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000232865008
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000017210357
Coding: C018330015004201000001010101202020202121202020
VCID: B522BA071C15BA2520-80E0
03312 - Temperature Sensor for Seat Heating
Fault Status: 00101010
Reset counter: 43
Mileage: 418766 km
Date: 2022.10.08
Time: 22:23:20
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BP HW: 7P6 907 040 BP
Component: Klima 4 Zonen H20 1305
Coding: 369600BE70
VCID: 834614DF0A41D495DE-80D6
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [008] - Signal Amplitude Too Low
Fault Frequency: 61
Reset counter: 43
Mileage: 419384 km
Date: 2022.11.05
Time: 16:42:46
0381 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Funktionseinschränkung wegen fehlender Botschaft]
Reset counter: 42
Mileage: 419753 km
Date: 2022.11.19
Time: 15:30:35
0382 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 41
Mileage: 419755 km
Date: 2022.11.19
Time: 15:33:46
Part No SW: 4H0 907 063 BC HW: 4H0 907 063 C
Component: BCM1 2.0 H12 0100
Revision: 14012002 Serial number: 00000001135542
Coding: 22001011D1B45D010021000080005D0C431C67080E000241800000020000
VCID: EA98597B052B25DD7D-80BE
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 111106 31 0020
Serial number: 90243400111109154020
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10269564
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 D HW: 7P6 941 431 D
Component: E1 - LDS H04 0031
Serial number: 00000000000711110093
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103159000000551404
Coding: 010300
Fault Status: 00101101
Reset counter: 29
Mileage: 419396 km
Date: 2022.11.06
Time: 00:52:00
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28261130701717
Coding: 518D01
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: C2C8D1DB55DB1D9D95-8096
Part No SW: 7P6 907 561 A HW: 7P6 907 561
Component: ACC3 H19 0230
Coding: 3F04010101
ASAM Dataset: EV_AdaptCruisContrVW526 001004
ROD: EV_AdaptCruisContrVW526_001.rod
VCID: BA38A93B3D0B555DCD-80EE
44 Faults Found:
2304 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_RAL_BPC_DRIVER]
Intermittent - Not Confirmed - Not Tested Since Memory Clear
3840 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_MMIC_VCO_FREQ_OFF]
20480 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_MMIC_VCO_POWER]
4096 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_MMIC_VCO_FREQUENCY]
4352 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_MMIC_DRO_FREQUENCY]
4608 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_MMIC_MIX_OFFSET_INIT]
4864 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_MMIC_MIX_OFFSET]
5120 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_R_ASIC_INIT]
5376 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_R_ASIC_BUSTEST]
5632 - Internal Fault
B200F F0 [016] - Unknown Error Elaboration
[FAULT_MON_R_ASIC_COMMUNICATION]
6144 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_R_ASIC_COMM_DEFECT]
6656 - Internal Fault
[FAULT_MON_R_ASIC_MEASUREMENT]
7168 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_R_ASIC_MEAS_DEFECT]
7424 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_R_ASIC_DMA_TIMEOUT]
7680 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_R_ASIC_RAMP_DURATION]
7936 - Internal Fault
[FAULT_MON_R_ASIC_ADC_MAXLEVEL]
8192 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_RAL_R_ASIC_BUSY]
8448 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_RFM_RTCMON_AM]
69376 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_RFM_RTCMON_LF1]
69632 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_RFM_RTCMON_LF2]
8960 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_RFM_RTCMON_FPRZ_OFF]
9216 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_RFM_RTCMON_ADC_FILTER]
69888 - Internal Fault
[FAULT_RCU_RADAR_INIT]
11264 - Sensor for Automatic Distance Regulation
C110B 49 [016] - Internal Electronic Failure
[FAULT_UAR_NVK8_31]
19200 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_5V5ATLAS_HIGH]
19456 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_5V5ATLAS_LOW]
19712 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_5V5ATLAS_OFF]
19968 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_VREF_HIGH]
20224 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_VREF_LOW]
20736 - Internal Control Module Memory Check Sum Error
B2000 00 [016] - -
[FAULT_MON_TEMP_MMIC_FAIL]
70400 - Internal Fault
[FAULT_ACQ_TEMP_PLAUS]
34560 - Function Restricted due to Missing Message(s)
U1111 00 [016] - -
[FAULT_CIM_TIMEOUT_SCU_01]
32000 - Function Restricted due to Missing Message(s)
U1111 00 [016] - -
[FAULT_CIM_TIMEOUT_LRRS_STATUS]
91136 - Function Restricted due to Missing Message(s)
U1111 00 [016] - -
[FAULT_CIM_TIMEOUT_LRRS_LOCATION]
78080 - Function Restricted due to Missing Message(s)
U1111 00 [016] - -
[FAULT_CIM_TIMEOUT_LRRS_FOV_01]
78336 - Function Restricted due to Missing Message(s)
U1111 00 [016] - -
[FAULT_CIM_TIMEOUT_LRRS_FOV_02]
79104 - Function Restriction due to Implausible Message(s)
U1112 00 [016] - -
[FAULT_CIM_CRCSCU_01_FAIL]
80384 - Function Restriction due to Implausible Message(s)
U1112 00 [016] - -
[FAULT_CIM_CRCLRRS_STATUS]
61952 - Function Restriction due to Implausible Message(s)
U1112 00 [016] - -
[FAULT_CIM_ALVSCU_01_FAIL]
138240 - Function Restriction due to Faults in Other Modules
U1113 00 [016] - -
[FAULT_CIS_ADS_FAIL]
138496 - Function Restriction due to Faults in Other Modules
U1113 00 [016] - -
[FAULT_CIS_ADS_SOLL_FAIL]
138752 - Function Restriction due to Implausible Message(s)
U1112 00 [016] - -
[FAULT_CIS_ADS_SOLL_INIT]
87040 - Function limitation due to excessive temperature
B1050 00 [016] - -
[FAULT_MON_TEMP_MMIC_HIGH]
148992 - FlexRay Databus
U1031 00 [016] - No Synchronization
[FAULT_FR_SYNC]
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag009 H05 0025
Revision: -------- Serial number: 003L0000S7FV
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: C1CADED750DD06858C-8094
Serial number: 3575LRB404R0TGJEAOP-
Serial number: 3585LRB404R0TGJE1OMP
Serial number: 3515RRB405R0P7AOIGVV
Serial number: 3525RRB405R0P7AO7GH7
Serial number: 3555NRB405V0TO4MI0MN
Serial number: 3565NRB405V0TO4M1960
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Revision: -------- Serial number: 99999MKH0013S
Coding: 000C9D
VCID: B83CB3330B07474D3B-80EC
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0125950
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 881 A HW: 7P6 920 881 A
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658141111593041
Coding: 131733007F080008000004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 7P0 963 272 C HW: 7P0 963 272 C
Component: Standheizung H23 0241
Revision: 56005006 Serial number: 20111107042649
Coding: 594200
VCID: B73EB00F0619483532-80E2
Part No SW: 7P6 907 530 D HW: 7P6 907 530
Component: GW-CAN-L-FR-M H08 5202
Revision: -------- Serial number: 00000000307886
Coding: 000D077500
GVL: FF5FC4E55D7F6E0000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: B93AB637380D5E45C4-80EC
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650971220
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Component: J532_DCDCStab H17 0042
Serial number: 11318001932011200181
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 7P6 907 049 N HW: 7P6 907 049 N
Component: Klima Fond H14 1305
Coding: 0000000000
ASAM Dataset: EV_AirCondiHeck 001007
ROD: EV_AirCondiHeck.rod
VCID: C8DCC3F373E737CD4B-809C
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 K HW: 7P0 907 553 K
Component: PASM H01 1110
Revision: 00000000 Serial number: 00000113080543
Coding: 14210001
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: BFCED82F26297075FA-80EA
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000016859360
Coding: C0183B0015004201000001010101202020202121202020
Fault Status: 01101010
Reset counter: 1
Mileage: 419753 km
Date: 2022.11.19
Time: 15:30:35
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7P6 907 566 HW: 4H0 907 566
Component: J769 SWA MasterH03 0110
Revision: 00H03000 Serial number: 6PZ 010 316-01
Coding: 0010151
VCID: FEB0652BA9A3B97DB1-80AA
Subsystem 1 - Part No: 7P6 907 568
Component: J770 SWA Slave H01 0110
Subsystem 2 - Serial number: 6PZ 010 316-21
Subsystem 3 - Serial number: 5F13.01.1000H010003C520199˙
Subsystem 4 - Serial number: 520199˙
Part No SW: 4H0 959 793 M HW: 4H0 959 793 E
Component: TSG FA H02 0166
Revision: -------- Serial number: 0000120425526
Coding: 011D1620DE00459205080003
VCID: C3C6D4DF42C114959E-8096
Revision: 00002001 Serial number: 0162543802
Coding: 019A1E2028B91081832006242D0000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
02741 - Bulb for Tail Light 2; Right
Fault Status: 11101100
Fault Frequency: 9
Reset counter: 197
Mileage: 417877 km
Date: 2022.09.07
Time: 15:04:06
01502 - Bulb for Rear Fog; Left (L46)
Fault Status: 00101100
Reset counter: 42
Mileage: 419788 km
Date: 2022.11.19
Time: 16:14:09
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811001014303
VCID: F5A27A075C95FA25E0-80A0
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000122020303
Coding: 011D1620DE00459205080000
VCID: BB36AC3F3A316C55D6-80EE
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A11A2800391
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: B620BD0B0913B13D29-80E2
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 01AA00104F000200
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: FCB46F2377BFAB6D9F-80A8
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0008
Coding: 190000
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0008
Coding: 190000
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109K$0B7537504
Coding: 010105010000000003
VCID: AB169C7FCA51FCD546-80FE
Part No SW: 7P6 035 670 K HW: 7P6 035 670
Component: H-BNT-EU H46 0934
Revision: -------- Serial number: 478K60B7566027
Coding: 020100050040EBEF79102B0E00000003F00401010000000000
VCID: BD32A22724256265E8-80E8
Subsystem 1 - Part No: 7P6 060 884 E
Component: EUR 2016/2017 2302
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9L7800HRC
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 1886
Reset counter: 214
Mileage: 418545 km
Date: 2022.09.27
Time: 12:30:45
Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
Reset counter: 214
Mileage: 418545 km
Date: 2022.09.27
Time: 12:30:43
Voltage: 12.20 V
03623 - Invalid Security/Release Code
Reset counter: 214
Mileage: 418545 km
Date: 2022.09.27
Time: 12:30:44
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000121993881
Coding: 011C14200000259005080000
VCID: BA38A93B350B555DCD-80EE
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000053356
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
8402177 - System Switched Off
C106D 00 [009] - -
Reset counter: 201
Mileage: 418261 km
Date: 2022.09.20
Time: 14:34:52
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 G HW: 7P0 907 383 C
Component: Anhaenger H09 0110
Revision: 5H001001 Serial number: 00000161924545
Coding: 0106040000000000
VCID: BC34AF233F3F6B6DDF-80E8
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 D HW: 7P6 907 441 D
Component: TopView H05 0097
Revision: 11001001 Serial number: 82330JE0001717
Coding: 0100000001010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
10489856 - No Basic Setting
B2010 00 [009] - -
[TopView system not calibrated]
Reset counter: 158
Mileage: 417047 km
Date: 2022.08.08
Time: 15:11:21
Voltage terminal 30: 12.0 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 309100681
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: BD32A2272C256265E8-80E8
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000121989495
Part No SW: 7P6 907 217 A HW: 7P6 907 217
Component: DPC-SG H24 0033
Coding: ED070000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: B83CB3330307474D3B-80EC
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000003024176_2284
Part No SW: 7P6 907 541 A HW: 7P6 907 541
Component: ACC3 H13 0230
Coding: 3F04010101
ASAM Dataset: EV_AdaptCruisContr2VW526 001004
ROD: EV_AdaptCruisContr2VW526_001.rod
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 A HW: 7P6 907 107
Component: BV-SG H29 0031
Serial number: 000040191110117
Coding: 01A03E040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
0185 - Development Code 4
B2F04 00 [008] - -
[MGT_task_stuck_eTask_RSF]
Fault Priority: 9
Reset counter: 43
Mileage: 419845 km
Date: 2022.11.21
Time: 11:58:46
Outside temperature: 7.0 °C
Voltage terminal 15: 13.0 V
Control Module temperature: 6.0 °C
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 006606000317037F00033811594097000000
Shop #: WSC 00001 790 00001
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: B12A8E17E07D96057C-80E4
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
Coding: 00660600031F037F00033811594097000000
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:50, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
