Weird Issue with 2018 Audi Q5 heating system.
Thatguy
C?ID=243503
All,
Thanks is advance for any advice in this and i apologize if . My Q5 has 60k on the clock. Has been flawless up til this point but as the Temps dropped this year my wife noted that the heat has been nonexistant.
I Ran VCDS it and found zero faults on the engine and auto HVAC.
However when I bring up advanced measuring values I have something interesting IDE 00194 coolant temperature at Radiator out put specified value: - 48C
That seems really odd to me.
The IDE 00194 coolant temperature at Engine output read 98.2 C
In addition and likely the actual reason for the lack of heating is the heater core isolation valve located under the cowl at the fire wall is electronically controlled and read no voltage and was closed.
This isolation valve has the coolant inlet and outlet. One side was hot and the other cold.
I'm wondering if there is a connection between a low temp being read or specified and the valve being closed even when the heating system on the interior is calling for over 80 degrees F
Thoughts?
Thanks in advance
Thatguy
C?ID=243503
The scan below is from the 16th. since this scan after clearing the codes it now shows no code on the HVAC system, or engine as mentioned the other night.
i ran output tests on the recirc damper and afterwards the code has not returned. Thanks again for your help. i apologize in advance if im an idiot.
Wednesday,16,November,2022,20:53:14:41174
VCDS Version: 22.9.0.0 (x64)
VIN: WA1CNAFY2J2031901   License Plate: MOMS Q5
Mileage: 110260km-68512mi   Repair Order:
Chassis Type  FY-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 22 29 36 39 3C 42 44 46 47 52 5F
          6C 6D 74 81 82 A5 BB BC CA CF D6 D7
VIN: WA1CNAFY2J2031901   Mileage: 110260km-68512miles
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DAYB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 80A 906 259 A    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0003
   Revision: --H15---    CVN: CA84BD7C
   Coding: 2A6500322526012E74280000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS02080A906259A 001004
   ROD: EV_ECM20TFS02080A906259A.rod
   VCID: 2959BCBC4859F4C534-807C
   VINID: 9D10537915A909A0800C1240041A86DE8D
17178 - Databus
23039 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
   Part No SW: 80A 927 155 AJ    HW: 0CJ 927 156
   Component: 0CJ 20TFSINAR H04 0001
   Revision: --H04---    Serial number: 0000000651 CVN: 9FDB4184
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 71E994DCA009CC05BC-8024
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  0C4 0572
   Serial number: 75117071170131000272
20918 - System Voltage
          P0562 00 [032] - Too Low
22301 - Electric Pump 2 for Transmission
          P276B 00 [032] - Supply Voltage too Low
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 80A 907 379 B    HW: 80A 907 379
   Component: ESP9 Plus     H11 0766
   CVN: C2A13B20
   Coding: 4CAA40BE28A50A9791A74891287E5292E4259A320214508912144A4927A459
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 2E534FA071B793FDE1-807A
352772 - System Voltage
143360 - Function Restricted due to Insufficient Voltage
          U1400 00 [032] - -
331008 - Function Restricted due to Insufficient Voltage
          U1400 00 [032] - -
415488 - TPMS Warning; Front Left Tire
          C1055 00 [032] - Flat
419328 - TPMS Warning; Front Right Tire
          C1057 00 [032] - Flat
   Part No SW: 80A 820 043 G    HW: 80A 820 043 G
   Component: Klima Zone 3  H32 0095
   Coding: 640809095548010D10040100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 2149A49C30693C856C-8074
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001613236
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: AA5903A880PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158 A    HW: 80A 919 158 A
   Component: E265 Kli Fond  H40 0080
328003 - Motor for Recirculation Flap
          B1092 07 [008] - Mechanical Failure
                    Reset counter: 60
                    Mileage: 109665 km
                    Date: 2022.11.13
                    Time: 09:58:54
                    Recirc. air flap motor: spec.value: 9699
                    Recirculation air flap motor: actual value: 11571
                    System run time-Engine running time: 270 s
                    System run time-Terminal 15 on: 271 s
                    Recirculation air flap motor: diagnostic-Last operating state: No routine started
                    Recirculation air flap motor: diagnostic-Operating condition: Blocking handling
                    Voltage terminal 30: 13.06 V
                    Outside temperature: 6.50 °C
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500363E0081CCD051551199C2E18B9110B3D080000000000000000200016010A690122025709
   Shop #: WSC 15927 005 1048576
   VCID: 020BCB1095AFC79D55-8056
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 170407  040 0570
   Serial number: 00000001703212101785
   Coding: 5FC7F7
   Serial number: 20435525X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 14 07 2017  71950183
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z0FUA02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170630122315 00407
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE126061723610723
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 80A 947 135 AN    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00014173
   Coding: 0D0101
   Subsystem 8 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000133132003
   Part No SW: 80A 959 655 L    HW: 80A 959 655 L
   Component: AirbagVW30    023 0513
   Serial number: 003W1M00R9S-
   Coding: AECCFCC000800000A000003FF20C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: 3C7775E8B7CB716D5F-8068
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 80A857705F0137R00296
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 80A857706F0137R00915
   Coding: 80000D
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J170007K8E50+
   Coding: 303033
   Subsystem 4 - Part No SW: -----------    HW: 480 001 505 17
   Serial number: 3570000000027A11B329
   Subsystem 5 - Part No SW: -----------    HW: 480 001 505 17
   Serial number: 358000000009B4A4F32V
   Subsystem 6 - Part No SW: -----------    HW: 480 031 505 17
   Serial number: 351000C2480A483089C3
   Subsystem 7 - Part No SW: -----------    HW: 480 031 505 17
   Serial number: 352000C248020D201D6U
   Subsystem 8 - Part No SW: -----------    HW: 480 032 905 17
   Serial number: 355000C24EDDD9914ED5
   Subsystem 9 - Part No SW: -----------    HW: 480 032 905 17
   Serial number: 356000C24ED615811EBK
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 103 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001A1247F123839M
9859568 - Passenger Airbag Status Indicator
          B1671 F0 [008] - Function Restriction due to Under-Voltage
                    Mileage: 92331 km
                    Date: 2022.05.18
                    Time: 10:15:07
   Part No SW: 80A 907 129 AT    HW: 80A 907 129 AT
   Component: Lenks.Modul   H02 0003
   VCID: 7AFBB3F0FD7F8F5D0D-802E
7340800 - Temperature Sensor for Heated Steering Wheel
          B1455 04 [008] - Internal System Fault
                    Reset counter: 66
                    Mileage: 106483 km
                    Date: 2022.10.20
                    Time: 09:30:12
                    Freeze_Frame_Heated_Steering_Wheel-Current_Average: 0.00 A
                    Freeze_Frame_Heated_Steering_Wheel-Current_Peak: 0.00 A
                    Freeze_Frame_Heated_Steering_Wheel-Operation_time_counter: 121694 min
                    Freeze_Frame_Heated_Steering_Wheel-PWM_Duty_Cycle: 0 %
                    Freeze_Frame_Heated_Steering_Wheel-Steeringwheel_Temperatur_Raw_Busvalue: 0 °
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_12V: 14967.19 mV
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_5VS: 4914.84 mV
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_at_sensor: 2.00 V
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_Output_Power_Switch: 1 bit
   Part No SW: 8W5 920 890 D    HW: 8W5 920 890 D
   Component: FBenUSA       H18 0371
   Coding: 09E68EC5B888CF05022369601800000008000000
   VCID: 44870D08CF3B09AD27-8010
   Part No SW: 8W6 907 468 E    HW: 8W6 907 468 E
   Component: Gateway       H42 0116
   Revision: 6B020002    Serial number: 0286B074917519
   Coding: 03010001000006402907000000590030CCBA0007100000000150000000000000
   GVL: 01D03C080800000040DC08000002C800110C0000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   VCID: 4C972528E76BC1EDEF-8018
   Subsystem 1 - Part No SW: 80A 951 523 E    HW: 80A 951 523 E
   Component: J453 MFL  H06 0002
   Serial number: 20170516101500 00119
   Serial number: 4788385200
8519684 - 12V Electrical System
          C11CB 01 [008] - Electrical Failure
                    Reset counter: 47
                    Mileage: 109378 km
                    Date: 2022.11.10
                    Time: 14:17:00
                    12-Volt Vehicle electrical system: malfunction status: Stage 1
Address 22: AWD (J492)       Labels:* Redir Fail!
   Part No SW: 80A 927 755     HW: 0CJ 927 749
   Component: Q5_DL3_N_SD4  H18 0004
   Serial number: 1715021244
   Coding: 11070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 6CD785A8872B21ED8F-8038
29727 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
29736 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
29775 - System Voltage
32070 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
33483 - Function Restricted due to Insufficient Voltage
          U1400 00 [032] - -
Address 29: Left Light
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 512A1471721664
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
   VCID: 76E3A7C0C967EB3D69-8022
Address 39: Right Light
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 366367C089E7AB3DA9-8062
1311234 - Control Module for Lane-Change Assist
          C1114 F3 [008] - Limited Visibility
                    Reset counter: 37
                    Mileage: 109021 km
                    Date: 2022.11.06
                    Time: 10:05:38
                    Control Module temperature: 25 °C
                    Voltage terminal 30: 13.00 V
                    Vehicle speed: 122.58 km/h
                    Terminal 15 status: On
                    Voltage terminal 15: Measuring value not available
   Part No SW: 4M1 959 793 B    HW: 4M1 959 793 B
   Component: TSG FS006 0737
   Serial number: CLSM1QG300XZ4
   Coding: 005D1B015E001480000100B2
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 3E737FE0A1D7637D71-806A
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000817815
   Coding: 90002001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 34675DC89F9BB92D97-8060
Address 46: Central Conv.
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAHTK00V3ER
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 19398C7C18396445A4-804C
0571 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 43
                    Mileage: 87303 km
                    Date: 2022.03.14
                    Time: 09:12:58
                    Voltage terminal 30: 11.4 V
   Part No SW: 4M1 959 792 B    HW: 4M1 959 792 B
   Component: TSG BFS006 0737
   Serial number: CLSM1QG700B7Z
   Coding: 005D1B015E001480000100B0
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 3D7178ECACD1786568-8068
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 A    HW: 8W5 035 880
   Component: MU-P-LNS-US   034 1118
   Serial number: A798G0HB041048
   Coding: 012406020000000013220002041A00102F0015E501700904FE
   Subsystem 1 - Part No SW: V03 959 803 AF    HW: -----------
   Component: NAR 2020  --- 0076
   Multimedia System 1:
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9HBL01L80
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 20051700000000000099
   Compact disc data bank:
   Component: Gracenote2  --- 3012
          B11CF 53 [009] - Deactivated
                    Reset counter: 43
                    Mileage: 87303 km
                    Date: 2022.03.14
                    Time: 09:28:02
                    Voltage terminal 30: 12.0 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG016587
   Coding: 02240602BA0FA10008404000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0730
   Shop #: WSC 00008 444 00000
   VCID: 489F1938F3132DCDCB-801C
Address 74: Chassis Control
   Part No SW: 80B 713 041 L    HW: 80B 713 041 L
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170627000043
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 2643B7805947DBBD19-8072
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 80A 919 617     HW: 80A 919 617
   Component: HeadUpDisplay H11 1640
   Coding: 2A01E0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 6ADB83B08DDF3FDDFD-803E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217     HW: 80A 907 217
   Component: BVS           H14 0042
   Coding: 0404020600000202022023A2AD0000FE00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 63C5EE946AF56E953E-8036
   Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
   Component: TSG HFS006 0737
   Serial number: CLSM1QG700GHP
   Coding: 000D1B0000001480400000A0
   VCID: 408F0118DB23158D03-8014
   Component: TSG HBFS006 0737
   Serial number: CLSM1QG700GFT
Address CA: Sunroof
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 05:57)--------------------------
That has all the signs of a blocked heater matrix, they are nearly impossible to flush clean
Thatguy
C?ID=243503
ok, can you help me understand that a bit better? the valve/solenoid that controls the heater core flow is closed even when the interior temp is commanded to 80f but reads in the 40s. Why would that valve still be closed? is there a direct relation to that valve and the -48C specified temperature i mentioned earlier?
If the valve were opened and still no heat id be looking at a blockage in the heater core itself. im sorry if im totally off. im trying to make sure i understand. Thank you!
Did you have the key "on" when you tested for voltage? How (what method) did you test this?
I'm not sure how this valve is plumed in, but as a test you could possibly clamp in (if soft hoses are used here) a rigid piece of tubing to bypass the valve (ie remove it) and then test for heat . You could potentially have a defective valve (?).
Also, be sure you have safety glasses or goggles on as if the system gets warm , it will be under pressure.
Thatguy
C?ID=243503
Hi, I tested this voltage by running the vehicle at full temperature and removing the two wire plug Brown/Blue that is connected to the valve. While running, and engine warm, heat set to 80F on the interior hvac system. Voltage present was .3 volts. I check connection to ground etc.
Checked all piping this valve would absolutely have.to.be open to.allow coolant flow through the heater core. It just isn't being told to open by the system. I pulled the plug and I ran wires directly from the battery to the valve and it opens. And no surprise the heat flows.
I'm struggling with why it's not being commanded open. I'm thinking that the engine may not beleive its warmer enough so it's preventing the heating system from taking heat. Or the command for this function is the actual malfunction.
Sadly there is no specific output test for this device. This device actually has its own little access hatch under the cowl because it seems that it's vital to be accessed.
The HVAC control head may just be malfunctioning. I guess this is an unknown issue. If anyone has an other ideas I'm game to try anything. I can bring it to the stealer but its over an hour away. It's stinks. I'll try to send pictures of what it all looks like as well. Seems.to be simplest thing in the world.
An isolation valve for the heater core isn't opening and I have no heat. Duh right? Just need to know why electrically there is no command to open. No volts. Why?
Westbury, UK
Have you checked continuity back to the HVAC module? If there's no volts there it could be the wiring or the module.
The fault code you have is for a faulty air recirculation flap and little to do with temperature control apart from heating outside or cabin air. The matrix is fed by a solenoid valve and evacuated by dual electric pumps so I would use an infrared laser temp pointer to look at the inlet and outlet pipe temps of the matrix to see how they compare with the actual system temp. If they both read the same and there is not heat from the matrix then it is likely it is blocked.
Thatguy
C?ID=243503
Ok my wife just took the car out of town until Saturday. I'll get all the measurements and readings for temp.
As I stated earlier, I know the recirc flap issue is nothing. Please read my earlier post.
I'm confused as to why I would be looking at the heating matrix until I understand why the heating control valve isn't being told to open ? That would be step one no? If that was open, and there was still no heat then I'd be looking for a blockage.
What component tells the valve to open? Unfortunately I can't check it tonight.
Thanks all again. Appreciate you.
Westbury, UK
Without an Auto-Scan we're all guessing, and guessing the cause of a fault using just words posted on the internet is a very inexact method.
The valve and pumps are controlled by the HVAC system
Per post #2, were going to need the Auto-Scan, (to be fair we tried it your way......) ; The Auto-Scan will most likely answer all the questions that you are asking - directly or indirectly.
You do have a VCDS right?
Thatguy
C?ID=243503
Hi guys,
@stefdds I'm not sure what your foolish rude statement was for? Not for me. That's for certain. There is an auto scan posted above. Can you not read? You do have VCDS right? You did graduate kindergarten right? Reading is fundamental. Start there.
I appreciate the assistance of the other helpful gents. Yes I have VCDS and have had and repaired more Audis and VWs than most people on this site, Including you I'm sure. You should know your place chief, In the back of the line. But I know that I don't know everything, that's for sure. And I'd never be rude to users like that.
Flr the rest, I found the issue, it was the heater control valve. It was stuck in the closed position. It was not the heater core. System working again now. It was clear that collectively we didn't know why the specified value was reading from the radiator was reading -48. It's ok to not know. But the system is working. That was my main question as it makes no sense for that value to be there. But I couldn't get an answer. No one had the info.
Again thank you to the other folks. You have been kind and helpful.
One the one of the other 7 Audis I own has an issue that I'm dealing with. I'll be on another thread. Thanks again.
