Any advice appreciated!
2014 Beetle Convertible top will not open. Fault presents as follows:
Two primary suspect DTCs:
65603 - Convertible Top Mechanical Malfunction or Open Switch Stuck
B1442
and
65578 - Motor for Convertible Top Locking
B1199 13 [008] - Open Circuit
Full scan:
- Top is closed
- Convertible switch to "open"
- Top just barely opens (many an inch)
- A couple seconds later "error - convertible top service" on display
B1442
and
Full scan:
Monday,21,November,2022,13:35:15:12511
VCDS Version: 22.10.0.1 (x64) HEX-NET CB: 0.4622.4
VIN: 3VW7T7ATXEM805304 License Plate: SCAN
Mileage: 113780km-70699mi Repair Order:
Chassis Type: AT-VW32 (6N0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 26 2B 2E 44 47 56 75 77 B8
B9
VIN: 3VW7T7ATXEM805304 Mileage: 113780km-70699miles
26-Auto Roof -- Status: Malfunction 0010
B8-Elect. Roof 2 -- Status: Malfunction 0010
B9-Aux. Display -- Status: Malfunction 0010
Address 01: Engine (J623-CPPA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 070 AC HW: 06K 907 425
Component: R4 2.0l TFS H09 9346
Revision: --H09--- Serial number: 00000000000000 CVN: F652B51D
Coding: 001D0012242400171000
Shop #: WSC 00066 000 00073
ASAM Dataset: EV_ECM20TFS02006K906070AC 001011
ROD: EV_ECM20TFS02006K906070AC.rod
VCID: 6B961E0A82B52FD547-803E
VINID: 0E69C7907464A157480050C01049471563
7 Faults Found:
15084 - Cylinder 3 Knock Control
P2338 00 [096] - Limit Reached
15357 - Torque Restriction due to Fuel Pressure
P102F 00 [096] - -
15282 - Starter Will Not Turn
P3054 00 [096] - Jammed or Electrical Malfunction
15072 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Fault Frequency: 15
Mileage: 110178 km
Date: 2022.09.12
Time: 22:06:15
Engine RPM: 1245.25 /min
Normed load value: 7.1 %
Coolant temperature: 70 °C
Intake air temperature: 24 °C
Voltage terminal 30: 11.718 V
Unlearning counter according OBD: 33
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 25 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.046 V
FAC_TPS_1_SAE: 11.718750 %
FUP_H_SAE: 10500.0 kPa
15124 - EVAP Emission Control Sys
P0441 00 [096] - Incorrect Flow
15304 - Engine Off Timer Performance
P150A 00 [032] - -
15298 - Internal Control Module
P0606 00 [032] - Processor Fault
Part No SW: 02E 300 062 P HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4007
Revision: 05652104 Serial number: 00001306270435
Shop #: WSC 02069 000 90108
VCID: 2208332EFDFF2E9DB4-8076
Part No SW: 5C0 907 379 C HW: 5C0 907 379 C
Component: ESP MK60EC1 H31 0156
Revision: 00H31001
Coding: F14B6016492200FF8F0E06E4921D0041A71800
Shop #: WSC 00066 000 00000
VCID: 2E10D71E79279AFD20-807A
02846 - Button for Tire Pressure Monitoring Display (E492)
Reset counter: 67
Mileage: 113752 km
Date: 2017.04.13
Time: 12:36:36
Count: 16391
Count: 32780
Count: 157
Count: 43776
Count: 1536
Count: 256
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0193897987
Coding: 030C0C
VCID: 3424C5769F0BB02D56-8060
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BC HW: 5C0 820 047 BC
Component: J301 Klimaanlage 0204
Revision: 2001111S Serial number: 00000001703256
Shop #: WSC 00066 790 00234
VCID: 6288732EBD7F6E9DF4-8036
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 C HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H74 0712
Revision: B8074001 Serial number: 27013230130275
Coding: 3BBC6928088B080000F83930640984C5ADC2420F60844C50B2B054022000
Subsystem 1 - Part No SW: 6R0 959 801 BN HW: 6R0 959 801 BN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 2670
Serial number: KU0KU028061300010047
Coding: 8CBC30
Subsystem 2 - Part No SW: 6R0 959 802 CA HW: 6R0 959 802 CA Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 2670
Serial number: KU0KU001071300013098
Coding: 8CBC30
Subsystem 3 - Part No SW: 5C0 959 442 C HW: 5C0 959 442 C
Component: E221__MFL-YVJ H02 0103
Serial number: 00000000000000743824
Coding: E30000
Subsystem 4 - Part No SW: 5C3 959 811 C HW: 5C3 959 811 C
Component: J388__TSG_HL 009 1046
Serial number: 14102550130710103320
Coding: 800000
Subsystem 5 - Part No SW: 5C3 959 812 C HW: 5C3 959 812 C
Component: J389__TSG_HR 009 1046
Serial number: 14102551130628153456
Coding: 800000
Part No SW: 5C0 959 655 P HW: 5C0 959 655 P
Component: AirbagVW10 302 0931
Serial number: 003LJD014DB%
Coding: 00004E45
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FCE9A5AA64D6375BB-806A
Serial number: 6940000Y130000VXSX0A
Coding: 30304C
Serial number: 3572MSME166F147CZZZ2
Serial number: 3582MSME056B147CZZZ/
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME23613227ZZZK
Subsystem 5 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME261A2327ZZZS
Part No SW: 5C5 920 970 P HW: 5C5 920 970 P
Component: KOMBI H30 0204
Revision: X0030002 Serial number:
Coding: 251E01
Shop #: WSC 00066 000 00126
ASAM Dataset: EV_KombiUDSMM9RM10 A04752
ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
VCID: 383CF1468363544D7A-806C
13639427 - Please Check Fault Codes in Engine Control Module
U101F 00 [008] - -
[Steuergerät für Motor: bitte Fehlerspeicher auslesen Öltemperatur]
Reset counter: 67
Mileage: 99036 km
Date: 2022.02.18
Time: 21:11:10
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H74 0712
Revision: B8074001
Coding: 502000
VCID: 70AC0966A393CC0D72-8024
Part No SW: 5K0 953 234 HW: 5C5 920 970 P
Component: IMMO H30 0204
Coding: 000007
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
VCID: 6A981B0E8D4F36DD3C-803E
9456681 - Key
B104C 29 [008] - Implausible Signal
Reset counter: 67
Mileage: 99011 km
Date: 2022.02.18
Time: 10:46:52
Address 26: Auto Roof (J256) Labels:* 5C3-871-601.clb
Part No SW: 5C3 871 601 A HW: 5C3 871 601
Component: VSG-MASTER 015 0353
ASAM Dataset: EV_VSGWEBASVW36X 005002
ROD: EV_VSGWEBASVW36X_005.rod
VCID: 2306362A2AE52795BF-8076
B1442 00 [009] - -
Reset counter: 27
Mileage: 113456 km
Date: 2022.11.20
Time: 14:11:41
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000132707001
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X.rod
VCID: 302CC9666B138C0D32-8064
Address 2E: Media Player 3
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
VCID: 393AF44270694D4585-806C
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0063447
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 26002F3E59D7D2BDD8-8072
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N3492787
Coding: 01020000010003
VCID: 64847536676B60AD06-8030
Reset counter: 209
Mileage: 99011 km
Date: 2016.07.11
Time: 10:40:20
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140503
Coding: 02230502C21654107F1606C00000
ROD: EV_OCULow_001.rod
VCID: 53E6A6EA3AC597156F-8006
12866048 - Implausible Data Received from Airbag Control Module
U0452 00 [008] - -
[Airbag signal implausible]
Fault Frequency: 51
Reset counter: 63
Mileage: 99517 km
Date: 2022.02.25
Time: 19:23:28
U1400 00 [008] - -
[restriction due to undervoltage]
Mileage: 111206 km
Date: 2022.10.19
Time: 19:46:04
2103041 - Control Module
Fault Priority: 8
Reset counter: 27
Mileage: 113781 km
Date: 2022.11.21
Time: 13:34:28
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 C HW: 5N0 035 729 C
Component: TELEFON H06 0315
Revision: 1B001001 Serial number: 00007664929722
Coding: 0A10031080010110
Shop #: WSC 01383 790 50316
ROD: EV_UHVUMI.rod
Address B8: Elect. Roof 2 (J256) Labels: 5C3-871-601.clb
Component: VSG-SLAVE 015 0353
ASAM Dataset: EV_VSG2WEBASVW36X 005002
ROD: EV_VSG2WEBASVW36X_005.rod
Fault Frequency: 8
Reset counter: 66
Mileage: 113456 km
Date: 2022.11.20
Time: 14:11:52
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 5C5 919 527 G HW: 5C5 919 527 G
Component: ZUSATZANZEIGE H02 0102
Coding: 05
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
VCID: 3522F8729471A92561-8060
2097157 - Databus
[Control unit for engine: please read out error memory oil temperature]
Reset counter: 67
Mileage: 99036 km
Date: 2022.02.18
Time: 21:11:10
End----------(Elapsed Time: 02:00, VBatt start/end: 12.2V/12.2V)-----------
