Lambo Urus Wheel Circumference Implausible
nardobenz
C?ID=515370
Hi all. I need help coding with vcds. We have a wide body urus in our shop with taller/wider aftermarket wheels that is throwing a trans malfunction. I’m wondering if I can code this out so we don’t have to tune the car and risk voiding the warranty.
I doubt it. But without seeing the a full scan, I can't even begin to check what options there are.
Just out of curiosity: What are the stock wheel & tire sizes, and what's on it now?
nardobenz
C?ID=515370
I can export the full scan if you tell me how!
The stock wheels are 285/35ZR23 front 325/30ZR23 rear.
The aftermarket are 295/30/24 and 355/25/24
Just checking. In principle:
285/35 R23 = 654 revs/mile
325/30 R23 = 658 revs/mile
Those are close to the same diameter -- but about 0.6% different.
295/30 R24 = 652 revs/mile
355/25 R24 = 651 revs/mile
Those are even closer, only about 0.2% different, but the difference is in the opposite direction.
That doesn't seem to me like it should cause a problem, but sometimes tires are not really the size they claim to be. You might want to do some actual diameter measurements on them. Here's an example:
Theoretically, the tire on the left (245/45 R17) should be slightly taller than the tire on the right (235/35 R19) but it clearly isn't.
Go to your Scans sub-folder. Find the relevant scan. Open it with Notepad. Copy & Paste the contents here.
nardobenz
C?ID=515370
Monday,21,November,2022,15:16:30:54804
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: ZPBUA1ZL4LLA07661   License Plate:
Chassis Type: ZL-LB63 (4K0)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 32 36 3C 42 44 46 47 52 5F
          61 65 6D 74 75 81 82 A5 A9 BB BC C4 CA CB CF D4 D5 D6 D7 DB
          DC DE
VIN: ZPBUA1ZL4LLA07661   Mileage: 19394km-12050miles
74-Chassis Control -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
D4-Roll Control 1 -- Status: OK 0000
D5-Roll Control 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (------DHUA)       Labels: None
   Part No SW: 4ML 907 589 G    HW: 0P2 907 309 A
   Component: V8 4.0l TFS   H31 0001
   Revision: 72H31000    CVN: 89758A34
   Coding: 2E2A001225E6050D74040000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114ML907589G 002001
   ROD: EV_ECM40TFS0114ML907589G.rod
   VCID: 5AED9CC83C92189BC56-800E
   VINID: AA04A5441A9C11C71100718604DF786DDE
21139 - Torque Limited due to Pre-Ignition
          P16D4 00 [096] - -
                    Mileage: 19266 km
                    Date: 2022.11.14
                    Time: 11:45:06
                    Engine RPM: 1160.00 /min
                    Vehicle speed: 79 km/h
                    Coolant temperature: 102 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.960 V
                    Unlearning counter according OBD: 35
                    Engine status: COENG_RUNNING
   Part No SW: 4ML 927 158 A    HW: 0D6 927 156 J
   Component: 0D6  40TSIUSA H05 1002
   Revision: --H05---    CVN: E1FE3F47
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 4EC56098705A443B29E-801A
40511 - Front / Rear Wheel Circumference Implausible
          P1B80 00 [237] - -
                    Mileage: 19238 km
                    Date: 2022.11.14
                    Time: 11:17:57
                    Engine RPM: 908.50 /min
                    Transmission input speed: 914 /min
                    Engine torque: -44 Nm
                    ATF temperature: 64 °C
                    Accelerator pedal position: 15.2 %
                    Clutch status: 4
                    M015_Time Normal Mode: 0 s
                    M019_Time Since Reset: 7650 ms
                    M018_Time In Afterrun: 0 s
                    M014_Time Since Shift: 7650 ms
                    Voltage terminal 30: 12.768 V
                    Driving position: P
                    Shift. process-Target gear: P
                    Current N215 Pressure control valve 1: 850.0 mA
                    Current N218 pressure reg.valve 4: 307.4 mA
                    Current N216 pressure reg.valve 2: 50.0 mA
                    Current N233 pressure reg.valve 5: 50.0 mA
                    Current N217 pressure reg.valve 3: 850.0 mA
                    Current N371 pressure reg. valve 6 lock-up clutch: 50.0 mA
                    Current N443 pressure reg.valve 7 main pressure: 653.8 mA
                    Current solenoid: 0.0 mA
                    Status of vehicle condition influence-Traction control system: not active
                    Status of vehicle condition influence-Electronic Differential Lock: not active
                    Status of vehicle condition influence-Electronic Stability Program: not active
                    Status of vehicle condition influence-Engine torque towing regulation: not active
                    Status of vehicle condition influence-Cruise control system: Initialisation
                    Status of vehicle condition influence-Kickdown: not active
                    Status of vehicle condition influence-brakes: active
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M6 907 379 AC    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0856
   CVN: A93D387C
   Coding: 52BE6AB130A20B9D93A45C975C7E16E2E53AC94A560CD0C93A3A6847A75C93
   ROD: EV_ESP9BOSCHCMP_VW53.rod
   VCID: 7EA5F058807A14BB99E-802A
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000392565803
   Coding: 001C12400001BCA14863010101010000810000070700878700000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_LB63.rod
   VCID: 3D273754CDFCCFA3C04-8068
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
   Component: N477 VB1 BFSv  H06 0030
   Serial number: SJ800110101940258374
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4M0 907 182 A    HW: 4M0 907 182 A
   Component: N478 VB2 BFSv  H06 0030
   Serial number: SJ8001131019114702A6
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 KE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0691
   Coding: 07500363E06910CD070E06111CEE9C70030B37110406009701000600020016010863000A0012080000000100004100180802000044010104000000000000000000
   Shop #: WSC 21041 004 1048576
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7BA3F94C93680193BE0-802E
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0301914001649
   Coding: 7DC727
   Serial number: 23761440X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4N1 941 501 C    HW: 4N1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 21S22.10.1900690316
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00RG02
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE108101923610047
   Interior Light Module:
   Subsystem 6 - Part No SW: 4ML 947 135 B    HW: 4ML 947 135
   Component: J528-Dachele  H14 0150
   Serial number: Q00814427
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA139093000073930039
   Coding: 020100
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BJ275A9669
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BJ27596338
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BJ27596291
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BJ275A9599
65896 - Databus
          [Automatic high beam assist control module: high beam assist error value]
                    Reset counter: 251
                    Mileage: 19223 km
                    Date: 2022.11.12
                    Time: 19:02:39
                    average_Voltage_terminals: 12.70 V
                    Outside air temperature sensor-Outside air temperature on CAN: 21.50 °C
                    interior_temperature: 25.50 °C
                    Vehicle speed: 0.00 km/h
66144 - Control Module for Electrically Adjustable Steering Column
          B14A8 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 151
                    Mileage: 17610 km
                    Date: 2022.07.15
                    Time: 19:56:26
                    average_Voltage_terminals: 13.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 31.00 °C
                    interior_temperature: 39.00 °C
   Part No SW: 4ML 907 561 B    HW: 4ML 907 561
   Component: LRR4R         H04 0332
   Coding: B4659F5478082C00010320A10000003E4A1146484401009E05
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_BY63.rod
   VCID: 4BC3698C834871134E0-801E
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Reset counter: 251
                    Mileage: 19223 km
                    Date: 2022.11.12
                    Time: 19:02:38
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 12.6 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: -0.200 °
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.679 °
                    Misalignment angle: horiz: fast algorithm: 0.606 °
                    Congestion pilot: status: OFF
                    Outside temperature: 21.50 °C
                    Sensor blindness: radar: no blindness detected
2345 - Databus
          [FAULT_CAMERA_ERROR]
                    Reset counter: 251
                    Mileage: 19223 km
                    Date: 2022.11.12
                    Time: 19:02:37
                    Adaptive distance regulation: status: ACC_StandBy
   Part No SW: 4N0 959 655 N    HW: 4N0 959 655 N
   Component: AirbagVW31    H15 2720
   Serial number: 003YXM00AGYN
   Coding: AEFCFCC000C00000A054003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 47CB55BC9F2095736A8-8012
   Left seat belt tensioner:
   Serial number: 00AI2019280328600000
   Coding: 02F001
   Right seat belt tensioner:
   Serial number: 00AI2019297342500000
   Coding: 02F001
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000C2HS908
   Coding: 303132
   Subsystem 4 - Part No SW: -----------    HW: 480 001 810 19
   Serial number: 357000000004D87D814U
   Subsystem 5 - Part No SW: -----------    HW: 480 001 810 19
   Serial number: 358000000008F87D814.
   Subsystem 6 - Part No SW: -----------    HW: 480 031 710 19
   Serial number: 351002C00E1AC6E0D8DS
   Subsystem 7 - Part No SW: -----------    HW: 480 031 710 19
   Serial number: 352002C00AF20C713B54
   Subsystem 8 - Part No SW: -----------    HW: 480 032 509 19
   Serial number: 355001C244513030BCC/
   Subsystem 9 - Part No SW: -----------    HW: 480 032 509 19
   Serial number: 356001C2445CB2B09CCP
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 031 710 19
   Component: SideSens_B_Df  002 0149
   Serial number: I0P001C249EBF9316A9K
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 031 710 19
   Component: SideSens_B_Pf  002 0149
   Serial number: I0Q002C00AF209E0FE4C
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4ML 907 129 A    HW: 4ML 907 129 A
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 4ACD6C888C32681B756-801E
   Part No SW: 4ML 920 890 A    HW: 4ML 920 890 A
   Component: FBenUSAACC--- H12 0209
   Coding: 8B4F06E17FB8D7050285FF64B8C0481008003000
   ROD: EV_DashBoardAU65X_001_LB63.rod
16776985 - Databus
          [QSP_03 communication error can_error_timeout]
                    Fault Frequency: 18
                    Reset counter: 1
                    Mileage: 17732 km
                    Date: 2022.07.15
                    Time: 23:14:24
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Fault Frequency: 51
                    Reset counter: 2
                    Mileage: 17732 km
                    Date: 2022.07.15
                    Time: 23:14:24
   Part No SW: 4K0 907 468 L    HW: 4K0 907 468 C
   Component: Gateway       H05 0262
   Serial number: 1YF04087389601
   Coding: 0301000500080F4054370000005901B07C9A000FAC000000097F078E10000000
   GVL: F1593C580800020002FC88008100C800110C0070000000000000000000000100
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_LB63.rod
   Subsystem 1 - Part No SW: 4ML 951 523     HW: 4ML 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20190613184504 31903
   Subsystem 2 - Part No SW: 9Y0 915 105 M    HW: 9Y0 915 105 M
   Component: 12V_LiIon_BMS  H10 1000
   Serial number: LGCKOR030519C1LF0184
8519692 - Unknown Error Code
          P1D6C 00 [008] - -
          [12V_LiIon_Battery_Diagnostic_System_Monitoring_Defect]
                    Reset counter: 252
                    Mileage: 17610 km
                    Date: 2022.07.15
                    Time: 20:00:52
                    Lithium ions starter battery-Battery: fault status: No malfunction
                    Lithium ions starter battery-Battery cut-out element: fault status: No malfunction
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 250
                    Mileage: 17757 km
                    Date: 2022.07.18
                    Time: 11:59:18
                    EM_vehicle_state: 00 00
                    Total static current-current total quiescent current: 76 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000257339018
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 34311270FEB60EEB3FA-8060
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0060
   Revision: 5WK12700    Serial number: 605943116200207
   Coding: 0500
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22.rod
   VCID: 79AFE34499543383ACC-802C
   Serial number: 00000392568503
   Coding: 001C12400001BCA14863010101010000810000070700878700000000004000
   ROD: EV_SCMDriveSideCONTIAU736_LB63.rod
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H06 0030
   Serial number: SJ8001101019402584E6
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H06 0030
   Serial number: SJ8001131019114702C7
   Part No SW: 4N0 907 566 F    HW: 4N0 907 566 A
   Component: MRR_HR H12 0266
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 392F2344D9D4F383ECC-806C
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0425
   Serial number: YE007SHT15658
   Coding: 001CDB425E001482A009A430
   ROD: EV_DCU2DriveSideMAXHKLO_VW53.rod
   VCID: 46D558B8982A8C7B91E-8012
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0505
   Coding: B2000101000100
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D146804A200DB2D6-8066
   Part No SW: 8W1 907 064 AH    HW: 8W1 907 064 H
   Component: BCM2 MLBevo   044 0542
   Coding: 0134000049A302C0650BA0046E01080203000000810405502F0400200F04823F001E0101010001
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 035381ACEB987953F60-8056
   ID - sensor:
   Subsystem 1 - Part No SW: 4ML 959 754 A    HW: 4ML 959 754 A
   Component: ID-Geber  H11 0233
   Serial number: 3619000158796030
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000031847440
131109 - Touch Sensor on Exterior Door Grip; Rear Left
          B116D 13 [009] - Open Circuit
                    Reset counter: 151
                    Mileage: 17610 km
                    Date: 2022.07.15
                    Time: 19:56:46
                    Supply voltages-Terminal 30 power supply: 13.234 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 13.234 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 13.234 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 12 04 98
                    exterior_handle_sensor_freeze_frame: 00000000 00000000 11111111 00000000
   Part No SW: 4N0 035 466 C    HW: 4N0 035 466
   Component: A2PA-3-AU     H01 0033
   Revision: --02S---    Serial number: 2880038302
   Coding: 0836060000A2AAAAAAAAA0010000
   ASAM Dataset: EV_AMPMst24C1Gen2pBAO 001002
   ROD: EV_AMPMst24C1Gen2pBAO.rod
   VCID: 2D0707141D9C5F23704-8078
0527 - Subwoofer
          B106C 13 [008] - Open Circuit
                    Reset counter: 251
                    Mileage: 19223 km
                    Date: 2022.11.12
                    Time: 19:02:22
                    Voltage terminal 30: 13.1 V
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0425
   Serial number: YE007SI530914
   ROD: EV_DCU2PasseSideMAXHKLO_VW53.rod
   VCID: 45D75FB4A52C8763984-8010
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4ML 035 084 D    HW: 4ML 035 084 C
   Component: MU-H-LNS-US   049 2712
   Coding: 0935060200000000C1220002061C00302F0000E4017009048E
   ROD: EV_MUHigGen2pALPI_VW53.rod
   Subsystem 1 - Part No: V03 959 805 DP
   Component: MIB2P_NA_Q318  0326
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4ML 919 605 L    HW: 4ML 919 605 F
   Component: DU LB536 Top  H31 0053
   Serial number: INX00112081900200444
   Compact disc data bank:
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4ML 919 616 A    HW: 4ML 919 616
   Serial number: 00004419000109862017
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4N0 919 603 L    HW: 4N0 919 603 F
   Component: DU AU651 Bot  H32 0053
   Serial number: INX00117061900170636
   Media Player 1:
   Subsystem 6 - Part No SW: 4N0 035 123     HW: 4N0 035 123
   Component: DISC PLAYER  H06 0006
   Serial number: AUZ8ZCKKJ04PDW5
   Media socket:
   Subsystem 7 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900635126012
          B11CF 53 [009] - Deactivated
                    Reset counter: 151
                    Mileage: 17610 km
                    Date: 2022.07.15
                    Time: 19:56:32
                    Voltage terminal 30: 13.0 V
                    Satellite radio tuner status-Audio Signal: available.
                    Satellite radio tuner status-Antenna current: 110 mA
                    Satellite radio tuner status-Reception quality: optimum_signal
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 0C
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 0C
          B201A 00 [009] - -
                    Reset counter: 151
                    Mileage: 17610 km
                    Date: 2022.07.15
                    Time: 19:56:28
                    Status_Software_Version_Management-module_name: UPDATESTARTED
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4M0 915 169 F    HW: 4M0 915 169 E
   Component: BMS_48V_SCAP  H07 0114
   Serial number: 192960001520111
   ASAM Dataset: EV_SCAP0213061 001004
   ROD: EV_SCAP0213061.rod
   VCID: 36352878E8CA1CFB01E-8062
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0010
   Serial number: 40000000049001
   ROD: EV_RDKHUFAU736_AU58.rod
   VCID: 2F3B1D1C17902D33428-807A
8400898 - Tires 01: Tire  Pressure Warning
          C111B 00 [009] - Pressure too Low
                    Reset counter: 208
                    Mileage: 19141 km
                    Date: 2022.10.25
                    Time: 08:54:10
                    Expanded ambient data 6-Vehicle speed: 50.21 km/h
                    Expanded ambient data 6-Outside temperature: 17.50 °C
                    Expanded ambient data 2-Left front tire pressure sensor: nominal pressure: 2.40 bar
                    Expanded ambient data 2-Left front tire pressure sensor: actual pressure: 1.85 bar
                    Expanded ambient data 2-Left front tire pressure sensor: temperature: 21 °C
                    Expanded ambient data 2-Left front tire pressure sensor: identification: 699288197
8400901 - Tires 02: Tire  Pressure Warning
          C111D 00 [009] - Pressure too Low
                    Reset counter: 208
                    Mileage: 19141 km
                    Date: 2022.10.25
                    Time: 08:53:39
                    Expanded ambient data 6-Vehicle speed: 16.19 km/h
                    Expanded ambient data 6-Outside temperature: 18.00 °C
                    Expanded ambient data 3-Right front tire pressure sensor: nominal pressure: 2.40 bar
                    Expanded ambient data 3-Right front tire pressure sensor: actual pressure: 1.88 bar
                    Expanded ambient data 3-Right front tire pressure sensor: temperature: 21 °C
                    Expanded ambient data 3-Right front tire pressure sensor: identification: 699288163
8400904 - Tires 03: Tire  Pressure Warning
          C111F 00 [009] - Pressure too Low
                    Reset counter: 208
                    Mileage: 19141 km
                    Date: 2022.10.25
                    Time: 08:53:44
                    Expanded ambient data 6-Vehicle speed: 4.16 km/h
                    Expanded ambient data 4-Left rear tire pressure sensor: nominal pressure: 2.40 bar
                    Expanded ambient data 4-Left rear tire pressure sensor: actual pressure: 1.88 bar
                    Expanded ambient data 4-Left rear tire pressure sensor: temperature: 19 °C
                    Expanded ambient data 4-Left rear tire pressure sensor: identification: 699288159
8400907 - Tires 04: Tire  Pressure Warning
          C1121 00 [008] - Pressure too Low
                    Reset counter: 252
                    Mileage: 18401 km
                    Date: 2022.08.21
                    Time: 09:43:33
                    Expanded ambient data 6-Vehicle speed: 49.47 km/h
                    Expanded ambient data 6-Outside temperature: 30.50 °C
                    Expanded ambient data 5-Right rear tire pressure sensor: no: 2.40 bar
                    Expanded ambient data 5-Right rear tire pressure sensor: actual pressure: 1.90 bar
                    Expanded ambient data 5-Right rear tire pressure sensor: temperature: 32 °C
                    Expanded ambient data 5-Right rear tire pressure sensor: identification: 699288160
8400906 - Tires 04: Tire  Pressure Warning
          C1122 00 [009] - Tire Flat
                    Reset counter: 212
                    Mileage: 19307 km
                    Date: 2022.11.18
                    Time: 08:07:19
                    Expanded ambient data 6-Vehicle speed: 0.00 km/h
                    Expanded ambient data 6-Outside temperature: 17.00 °C
                    Expanded ambient data 5-Right rear tire pressure sensor: no: 2.55 bar
                    Expanded ambient data 5-Right rear tire pressure sensor: actual pressure: 1.68 bar
                    Expanded ambient data 5-Right rear tire pressure sensor: temperature: 20 °C
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 2530
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M8 907 777 CA    HW: 4M8 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 1610190406
   Coding: 36606848FA40
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 025D84A8F482705BFD6-8056
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130762910
   Coding: 303030
7405568 - Operation of Inclination Display
          C113F F0 [008] - System Not Available
                    Reset counter: 251
                    Mileage: 18474 km
                    Date: 2022.09.08
                    Time: 13:39:00
                    Internal DTC: 278
                    Inclination display: calculated values-Speed in y-direction: 00 00 00 00
                    Inclination display: calculated values-Speed in x-direction: BE 93 86 C7
                    Inclination display: calculated values-Status: longitudinal speed: input: 00
                    Inclination display: calculated values-Driving situation: 00
                    Inclination display: calculated values-Status of incline angles and speeds: 3F
                    Inclination display: calculated values-Status of calculation algorithm: 01
                    Inclination display: calculated values-Calculation algorithm initialized: 00
                    Inclination display: calculated values-Status of rotation rate filter: 00
   Part No SW: 9Y0 035 283 F    HW: 9Y0 035 283 C
   Component: ConBox        H10 0314
   Serial number: 005CCA1BF120785
   Coding: 09C0E0FFC040800000
   ROD: EV_ConBoxAU651_002.rod
458759 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Fault Frequency: 11
                    Mileage: 17991 km
                    Date: 2022.07.31
                    Time: 11:03:15
   Part No SW: 4ML 713 120     HW: 4ML 713 120
   Component: GSM-LL        H11 0080
   Revision: 0L005012    Serial number: 19081654466178
   ASAM Dataset: EV_GSMChariLB636 001009
   ROD: EV_GSMChariLB636.rod
67097 - Control module
          B2001 00 [008] - Incorrect software version
          [Control moduleIncorrect software version]
                    Reset counter: 252
                    Mileage: 19306 km
                    Date: 2022.11.15
                    Time: 08:53:19
                    Voltage terminal 30: 0.0 V
                    Selec. range display: spec. val.: Init
                    Selector lever position: Initialization
                    Standard_FreezeFrame_Extended_Temperature_CAN: 00
                    Standard_FreezeFrame_Extended_Temperature_Celsius: -50.0 °C
                    System run time: 0 s
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4ML 919 617     HW: 4ML 919 617
   Component: HeadupDisplay H04 1818
   Coding: 470040
   ASAM Dataset: EV_HeadUpDisplAU65X 001009
   ROD: EV_HeadUpDisplAU65X.rod
   VCID: 0E45A098B0DA043B69E-805A
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AM    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0293
   Coding: 020888000000000000FBD60000B0C50C1B1F520000000000000000000094D401011BA0000000000000000080000000000000000000000000F980400000000000000072040000009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 0A4DAC88CCB2281BB56-805E
221189 - Front Camera for Driver Assist Systems
          C12B3 FA [008] - Communication Error
                    Reset counter: 251
                    Mileage: 19223 km
                    Date: 2022.11.12
                    Time: 19:02:27
                    Control Module temperature-Printed circuit: 28 °C
                    Control Module temperature-Average temperature: -50 °C
                    Control Module temperature-Application service computer: 31 °C
                    Control Module temperature-Sensor service computer: 28 °C
                    Control Module temperature-Environment recognition service computer: 37 °C
233473 - Parking Sensor(s); Rear
          B107B F0 [008] - Function Limitation due to External Factors
          [Geber für Einparkhilfe - Schmutz bzw. Eisbildung hinten]
                    Fault Frequency: 201
                    Reset counter: 2
                    Mileage: 17610 km
                    Date: 2022.07.15
                    Time: 20:16:28
                    Outside temperature: 40.50 °C
233479 - Parking Sensor(s); Rear
                    Fault Frequency: 20
                    Reset counter: 252
                    Mileage: 17610 km
                    Date: 2022.07.15
                    Time: 20:17:25
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Reset counter: 251
                    Mileage: 19223 km
                    Date: 2022.11.12
                    Time: 19:02:38
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 4ML 907 159 B    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0004
   Serial number: 191003200070
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0425
   Serial number: YE007SHO04023
   Coding: 000CDB4200001482E008A020
   VCID: 48C95680923E9A0B632-801C
   Component: TSG HBFS004 0425
   Serial number: YE007SHO03148
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 682     HW: 4K0 959 682
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC19414000456
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 76B5E878A84A5CFBC1E-8022
   Coding: 228040363602
   ROD: EV_SunRoofCONTIAU736_SK38.rod
   VCID: 75B7EF74B54C57E3C84-8020
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_
   Coding: 42240A00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 6FBBDD1CD7106D33028-803A
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0266
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
Address D4: Roll Control 1 (----)       Labels: None
   Part No SW: 971 907 156 Q    HW: 971 907 156 L
   Component: EAWSH17 0113
   Serial number: 00120190918196
   ASAM Dataset: EV_EAWSSchaeFront 008001
   ROD: EV_EAWSSchaeFront_VW53.rod
   VCID: 2E050018109A243B49E-807A
Address D5: Roll Control 2 (----)       Labels: None
   Serial number: 00120190919002
   ASAM Dataset: EV_EAWSSchaeRear 008001
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 71BFDB64C1247BC314C-8024
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 F    HW: 4N0 907 669 A
   Component: MRR_VR H12 0266
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0266
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   VCID: 2313E12C4B589953D60-8076
End----------(Elapsed Time: 02:32, VBatt start/end: 12.9V/12.9V)-----------
nardobenz
C?ID=515370
I got it working in the trans tune.
