2011 A6 C7 with ESP and EPC warning light
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
Hello there
my car is still having this problem now despite replacing the brake light switch as indicated in ABS Brakes Module. I managed to clear the EPC fault but couldn't clear ESP. After the EPC is cleared it will come back after 20 minutes of drive and the rpm will increase to 1000 at idle. The car runs fine without lost of power. The brake switch fault still remains in the DTC of ABS brake. Below are my scans :
Sunday,20,November,2022,12:40:45:34670
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WAUZZZ4G9BN031310   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
          56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310   Mileage: 214503km-133285miles
Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551     HW: 4H0 907 551
   Component: 3.0l V6 TFSI  H05 0007
   Revision: --H05---    CVN: C8FC4A11
   Coding: 0A250034052701020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551 002010
   ROD: EV_ECM30TFS0214G0907551_002.rod
   VCID: 6695B5FFE8EFBBDB71E-8032
   VINID: 9D196AAAA1172527800C10C1005A6DBEFC
6187 - Oxygen (Lambda) Sensor B1 S2
          P0140 00 [039] - No Activity
                    Mileage: 214503 km
                    Date: 2022.11.20
                    Time: 12:33:43
                    Engine RPM: 712.00 /min
                    Normed load value: 14.9 %
                    Coolant temperature: 47 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 13.710 V
                    Engine speed: actual: 704 /min
                    MAF_ENVD: 141.62353 mg/stroke
                    Coolant temperature (unfiltered): 47.25 °C
                    Engine: operating status: IS
                    T_AST_ENVD: 102.80 s
                    STATE_LS_ENVD[1]: 2
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:04:00
                    Engine RPM: 704.00 /min
                    Normed load value: 19.2 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 81 °C
                    Ambient air pressure: 860 mbar
                    Voltage terminal 30: 12.491 V
                    Engine speed: actual: 1216 /min
                    MAF_ENVD: 256.01176 mg/stroke
                    Coolant temperature (unfiltered): 28.50 °C
                    Engine load: 33.593750 %
                    Vehicle speed: actual: 0 km/h
Readiness: 0110 0001
   Part No SW: 4G0 927 156 M    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H10 0024
   Revision: --H10---    Serial number: 0000000785 CVN: 0000744E
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 363525BFF8CF0B5B01E-8062
10617 - Valve for Transmission Fluid Cooler
          P2753 00 [044] - Open Circuit
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:04:01
                    Engine RPM: 680 /min
                    Transmission input speed: 680 /min
                    Engine torque: 8 Nm
                    ATF temperature: 92 °C
                    Accelerator pedal position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 12.600 V
                    Transmission oil cooler valve: Open
                    ATF temperature: 94 °C
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 44A687002265E100DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 6E85CDDFC01F739B09E-803A
0004 - Brake Switch (F)
          P0571 00 [137] - Implausible Signal
                    Reset counter: 133
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:03:34
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 42
                    Bit Info 3: 06
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: F8
                    Uz: A8
   Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
   Component: BCM2 2.0      H24 0217
   Coding: 05B82F00000000000000
   VCID: 77ABE8BBBFC53253DA8-8022
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000097450009
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 06051100040574
   Coding: 6621007824
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 270BF8FB2F6562D38A8-8072
   Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0092
   Revision: 20012002    Serial number: 00000001044197
   Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
   VCID: 33331CABEB3D1E73260-8066
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 110404  H35 0051
   Serial number:         110407090850
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11418017
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 22 04 2011  00000235
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 5228C6A5000000000001
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 133
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:02:00
   Part No SW: 4H0 919 475 J    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0032
   Revision: 11001001    Serial number: 55901107004778
   Coding: 300306
   Shop #: WSC 00097 210 98728
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 392F2E83C9D1E423ECC-806C
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG002BRPH
   Coding: 30323436313330303631554A305234473053
   Serial number: 3575HRB404T0HM766GDR
   Serial number: 3585HRB405H0H0LUC8R2
   Serial number: 3515JRB405D0H4DU9P4N
   Serial number: 3525JRB405F0G944N0G$
   Serial number: 3554VRB40630GR36HOS5
   Serial number: 3564VRB405D0GR36IHD.
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20110505000939
   Coding: 000034
   VCID: 303913A71A2B256B5B2-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H07 0009
   Part No SW: 4G8 920 981 A    HW: 4G8 920 981 A
   Component: TBenGb        H34 0312
   Revision: 19100074    Serial number: 658020411593026
   Coding: 33A709000B012600010000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 313F16A311A12C6354C-8064
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000141378
   Coding: 00CD073000
   GVL: FDA1E848DEE2600D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 303913A71AAB256B5B2-8064
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650387009
   Voltage stabilizer:
   Serial number: 11130001538021200181
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0056
   Serial number: 06051100040012
   Coding: 02
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: 2F3B10DB07953A93428-807A
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006129999
   Coding: 00781B0000006001000001010101102030303232203232
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4200UA850
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D070AD30D994883704-8078
   Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
   Component: TSG FA        H04 0210
   Coding: 011F16205E01628002080002
   Shop #: WSC 02312 785 00200
   VCID: 40D94367AA8BB5EBAB2-8014
01482 - Motors for Central Locking
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Reset counter: 173
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:02:53
                    Fault Status: 00100111
                    Reset counter: 173
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:02:53
02116 - Mirror Adjusting Motor
                    Reset counter: 173
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:02:53
                    Reset counter: 173
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:02:53
02117 - Motor for Mirror Folding
                    Reset counter: 173
                    Reset counter: 173
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0007363453
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D19AF14A7177B2D6-8066
   Revision: 00002001    Serial number: 0149428872
   Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 133
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:02:57
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   VCID: 3FDB409BD775CA13D28-806A
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000070722
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D01CF3C775FBB956-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 110502-0004-033
   Coding: 0000020000020000
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
266752 - Control module not coded
          U1013 00 [137] - -
          [Steuergeraet nicht codiert]
                    Reset counter: 133
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:02:55
530180 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Reset counter: 133
                    Mileage: 214503 km
                    Date: 2022.11.19
                    Time: 12:02:56
   Part No SW: 4G0 035 056 A    HW: 4G0 035 056
   Component: Radio U STD   H52 0050
   Revision: AB001007    Serial number: 051EY0B7516476
   Coding: 010003020100000001
   VCID: 1F1BE01B77B5AA13F28-804A
   Part No SW: 4G0 035 670 B    HW: 4G0 035 670
   Component: H-BNT-EU      H46 0239
   Revision: --------    Serial number: 428EX0B7514227
   Coding: 050101000003E1EF45108B3E000000030000010000000000
   VCID: 221DE9EF44C787FBDD6-8076
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300QPJ1
   Subsystem 3 - Part No SW: 4G2 919 612 L    HW: 4G2 919 612 L
   Component: E380 BDT C7  H08 0120
   Serial number: 90349KDT0007U
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010F14204001628002080002
   VCID: 42DD496FA487A7FBBD6-8016
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H04---    Serial number: 525 PA8J14F0S1
   Coding: 1020004
   VCID: 2517F2F359E970C3B84-8070
   Component: TSG HR        H03 0210
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: 64040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B2F315E9B0C3784-8030
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FBBD0DBC7157A93028-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B9D3A7DA2B656B1B2-8024
End----------(Elapsed Time: 02:10, VBatt start/end: 14.4V/14.4V)-----------
Below is the scan a few days before that. It mention a lot about loss com with ABS module although ABS indicator did not light up.
Friday,18,November,2022,11:29:38:34670
VIN: WAUZZZ4G9BN031310   Mileage: 214494km-133280miles
3B-Sensor Elect. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
          P0140 00 [036] - No Activity
                    Mileage: 214494 km
                    Date: 2022.11.18
                    Time: 11:14:26
                    Engine RPM: 701.00 /min
                    Normed load value: 13.7 %
                    Coolant temperature: 58 °C
                    Intake air temperature: 36 °C
                    Ambient air pressure: 900 mbar
                    Voltage terminal 30: 13.812 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 114.38823 mg/stroke
                    Coolant temperature (unfiltered): 58.50 °C
                    T_AST_ENVD: 257.00 s
                    STATE_LS_ENVD[1]: 2
6385 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
          P0141 00 [039] - Malfunction
                    Mileage: 214494 km
                    Date: 2022.11.18
                    Time: 11:22:47
                    Engine RPM: 696.00 /min
                    Normed load value: 9.4 %
                    Coolant temperature: 78 °C
                    Intake air temperature: 39 °C
                    MAF_ENVD: 92.60000 mg/stroke
                    Coolant temperature (unfiltered): 78.75 °C
                    Battery voltage: 13.812500 V
                    STATE_LS_ENVD[1]: 2
          U1113 00 [039] - -
                    Mileage: 214494 km
                    Date: 2022.11.18
                    Time: 11:16:40
                    Engine RPM: 659.00 /min
                    Normed load value: 43.1 %
                    Coolant temperature: 65 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 11.679 V
                    Engine speed: actual: 992 /min
                    MAF_ENVD: 315.92940 mg/stroke
                    Coolant temperature (unfiltered): 69.00 °C
                    Engine load: 43.359375 %
          P2753 00 [039] - Open Circuit
                    Mileage: 214494 km
                    Date: 2022.11.18
                    Time: 11:18:45
                    Engine RPM: 1519 /min
                    Transmission input speed: 1519 /min
                    Engine torque: 8 Nm
                    ATF temperature: 42 °C
                    Voltage terminal 30: 11.900 V
                    ATF temperature: 43 °C
          P0571 00 [145] - Implausible Signal
          MIL ON - Not Confirmed - Not Tested Since Memory Clear
                    Fault Status: 00101101
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:30
   Coding: 6621007824
0330 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bremsensteuergerät: kein Signal/keine Kommunikation]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:20
                    Voltage terminal 30: 12.12 V
                    Outside temperature: 38.0 °C
                    Engine RPM: 0 /min
0378 - Coolant Circulation Pump
          B10D0 04 [008] - Internal System Fault
                    Reset counter: 169
                    Mileage: 214195 km
                    Date: 2022.11.14
                    Time: 10:21:29
                    Voltage terminal 30: 14.13 V
                    Outside temperature: 29.0 °C
                    Inside temperature: 23.69 °C
0379 - Supply Voltage Terminal 30 for Coolant Pump
          B11D5 01 [008] - Electrical Failure
                    Reset counter: 164
                    Mileage: 214159 km
                    Date: 2022.11.13
                    Time: 17:40:41
                    Voltage terminal 30: 11.75 V
                    Outside temperature: 39.5 °C
                    Inside temperature: 36.93 °C
   Coding: 0045F7
   Coding: 02512B
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:00
01800 - Light Switch (E1)
                    Reset counter: 171
                    Mileage: 214494 km
                    Date: 2022.11.18
                    Time: 10:19:00
03280 - Switch Position of Light-Switch Knob
                    Reset counter: 171
                    Mileage: 214494 km
                    Date: 2022.11.18
                    Time: 10:19:00
                    Reset counter: 120
                    Mileage: 214159 km
                    Date: 2022.11.13
                    Time: 13:26:00
   Coding: 300306
12656912 - Databus
          [Bremsensteuergerät - ESP_01 - kein Signal/keine Kommunikation]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
8 Faults Found:
1048832 - Databus
          [CAN: 0x100 ESP_01 Timeout]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
1049088 - Databus
          [CAN: 0x101 ESP_02 Timeout]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
1049093 - Databus
          [CAN: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Reset counter: 171
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:51:04
1049094 - Databus
          [CAN: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Reset counter: 171
                    Mileage: 214131 km
                    Date: 2022.11.13
                    Time: 12:38:16
1049095 - Databus
          [CAN: 0x101 ESP_02 error value ESP_Gierrate]
                    Reset counter: 171
                    Mileage: 214131 km
                    Date: 2022.11.13
                    Time: 12:38:16
1049344 - Databus
          [CAN: 0x103 ESP_03 Timeout]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
1049605 - Databus
          [CAN: 0x084 ESP_06 error value ESP_v_ref]
                    Reset counter: 171
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:22
1049866 - Databus
          [CAN: 0x39C Gateway_05 Old value from ESP_07]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:20
   Coding: 000034
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
02085 - Incorrect Control Module Installed
                    Reset counter: 171
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:22
                    Voltage: 12.20 V
                    Hex Value: 0x0000
                    Steering Angle: 16.76°
16776968 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ESP_02 keine Kommunikation]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
16776973 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [RDK_01 keine Kommunikation]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:22
   Coding: 00CD073000
   Voltage stabilizer:
4352 - ABS Control Module on FlexRay Data Bus
          U10BD 00 [008] - No Communication
          [Lost Communication With Vehicle Dynamics Control Module]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:18
                    Voltage terminal 30: 10.9 V
                    Voltage terminal 15: 11.1 V
                    Control Module temperature: 35 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: On
                    Datenfeld: 0
   Coding: 02
0034 - Motor for Rear Right Upper Body Vent
          B10D4 21 [008] - Signal Amplitude Too Low
                    Reset counter: 169
                    Mileage: 214161 km
                    Date: 2022.11.13
                    Time: 20:58:36
                    Voltage terminal 30: 13.27 V
                    Outside temperature: 37.5 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 9849
                    Right Rear Upper Body Vent Motor-Target value: 9849
                    Right Rear Upper Body Vent Motor-Stop open: 11400
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
0136 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
                    Voltage terminal 30: 12.21 V
                    Engine RPM: 0 /min
3801346 - Function Restricted due to Missing Message(s)
          U1111 00 [040] - -
          [Internal Monitoring (MSG)]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:18
                    DCU Temperature: 32 °C
                    Voltage Clamp 15: 9.5 V
                    Voltage Clamp 30: 9.1 V
                    Ignition Cycle Count: 42692
                    00000000000000000
                    Fault Status: 01100111
                    Reset counter: 131
                    Mileage: 214308 km
                    Date: 2022.11.15
                    Time: 16:38:59
                    Reset counter: 131
                    Mileage: 214308 km
                    Date: 2022.11.15
                    Time: 16:38:59
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:23
3158273 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Ausfall Botschaft "PDU_ESP_01"]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
                    Write only channel
            014 - Defective
                    Reset counter: 120
                    Mileage: 214159 km
                    Date: 2022.11.13
                    Time: 13:26:44
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:30
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:23
328448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_ESP_01_MESSAGE_TIMEOUT]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:18
                    Voltage terminal 30: 11.3 V
                    Internal Fault ID: 89
                    Vehicle speed: 510 km/h
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
328704 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_ESP_02_MESSAGE_TIMEOUT]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:18
                    Internal Fault ID: 90
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
328960 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_ESP_03_MESSAGE_TIMEOUT]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:18
                    Internal Fault ID: 91
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
329216 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_ESP_05_MESSAGE_TIMEOUT]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:18
                    Internal Fault ID: 92
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
459264 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
                    Reset counter: 171
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:51:04
                    Voltage terminal 30: 13.6 V
                    Internal Fault ID: 138
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: Emergency running mode
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
463616 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
                    Reset counter: 171
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:51:04
                    Internal Fault ID: 185
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          U1013 00 [137] - -
                    Reset counter: 120
                    Mileage: 214159 km
                    Date: 2022.11.13
                    Time: 13:26:42
                    Fault Frequency: 22
                    Reset counter: 131
                    Mileage: 214159 km
                    Date: 2022.11.13
                    Time: 13:26:43
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:27
                    Bin. Bits: 00000000 00000100
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:26
                    Bin. Bits: 00000110 01100000
                    Bin. Bits: 00000000 00000000
   Coding: 1020004
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:19
                        Reverse OFF
                    Count: 3
   Coding: 64040000
0703 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ESP_timeout]
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
                    Outside temperature: -31.0 °C
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 32.0 °C
   ROD: EV_RGS_L.rod
12583684 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
12583686 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
12583687 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
   ROD: EV_RGS_R.rod
          U1111 00 [008] - -
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
          U1111 00 [008] - -
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
          U1111 00 [008] - -
                    Reset counter: 170
                    Mileage: 214461 km
                    Date: 2022.11.17
                    Time: 20:50:21
End----------(Elapsed Time: 02:16, VBatt start/end: 14.2V/14.1V)-----------
Friday,18,November,2022,11:30:51:34670
Gateway Installation List:  4G0 907 468 C
Your feedbacks are apprecited. Thanks guys.
Bruce
Near Philadelphia, PA, USA
I think you have several problems that need attention. You have a problem with the lambda sensor in the engine, the coolant valve in the transmission and I suspect you have a broken wire to the brake switch since you replaced the switch and still have the same result.
Since you seem only interested in working on the brake switch, its time to get the official wiring diagrams from erWin. Then using a multimeter, trace the wiring looking for a break in the wire - bad connection.
For more on how to get the wiring diagram, see the how to menu drop down in the blue bar at the top of most every page of this forum.
So you replaced the switch with Audi part number 4F0 945 459 B, did you fit it pedal up or down?
coconutaudi
C?ID=345326
Thank you,, Bruce. It may well be the wiring. From the wiring I have it has 3 wires one +ve, one ground and the other one presumably the signal wire goes directly to the ECU. I'll look into it. Thanks again.
coconutaudi
C?ID=345326
Hi Crasher,, I did not touch the pedal at all when installing because the brake switch is not located at the top of the brake pedal. This caution is mentioned in the installation instruction. When inserting the brake switch into the slot I heard the audible click of the three tabs engaging and the pointy end did touch the metal rod connected to the brake pedal some 25cm away. Then I turn the catch clock wise locking it. Am I missing something that the pedal is not positioned correctly prior to inserting the brake switch? Can you please tell me the right way of installing. Thank again.
It sounds like you have installed it correctly but I have had new switches fail, you need to watch the switch outputs in measuring blocks.
coconutaudi
C?ID=345326
I did check the measuring block and the last digit changed from 0 to 1 whenever I depressed the brake. So I think the brakelight switch is ok. The engine module keep saying getting implausible signal from the brake switch though.
Westbury, UK
Isn't the switch double pole, one normally open and the other normally closed (this is for the implausible check) - hence the 4 pins on the switch?
It looks to me like the measuring block only checks one of those poles but the ECU checks both?
Time to get the multimeter out I think and check the switch operation by measuring at the actual pins on the switch, and if they're OK then check the wiring back to the ECU - if you don't have a wiring diagram (that's a link) then maybe you need to get one.
coconutaudi
C?ID=345326
Hi PetrolDave thanks for the reply. This brake switch although has 4 pins it is only connected to 3 wires. I do have the wiring diagram and it shows pin 1 to Ground, pin 3 to power (fuse checked) and pin 4 to ECU. Correct me if I'm wrong. From what I can understand the ECU needs to know that the brake is depressed before it allows the car to start or to shift gear. I'm baffled but thankful my car can do both. Meaning the ECU received signal from the brake switch that the brake is being depressed. Yet the ECU set implausible signal from the brake switch code.
Westbury, UK
Have you actually checked the wiring and the ground & power at the switch with a multimeter?
For the ECU to say the brake switch input is implausible I suspect it needs to see the input at ground before the pedal is pressed and at 12V when it is pressed, if it doesn't see both of these that would explain the fault code.
coconutaudi
C?ID=345326
Apart from checking the fuse, I did'nt take the voltage reading. I will do that and get back to you. Thanks again.
coconutaudi
C?ID=345326
Voltage at ground is 0.001v, at the power 13.25v and at the signal wire to ecu 4.76v. This is when the car is running. My mistake, wire 4 is actually the +ve not 3. 3 is the signal wire. One thing I’ve noticed is that wire 4 at the fuse point has no power when key is off despite being connected to Terminal 30 as stated under the fuse assignment. All of the fuses on the same ST3 are all on terminal 30 and they have battery voltage when key off.
coconutaudi
C?ID=345326
Or did the voltage readings taken confirm that the brake switch is faulty?
coconutaudi
C?ID=345326
It should be two digits that change to 1 simultaneously
Yes I’ve noticed only the last 0 from all eight zeros changed to 1. So the last two zeros should changed to 11 simultaneously to say that the brake switch is ok?
coconutaudi
C?ID=345326
My car is a reconditioned unit imported from UK. Apart from manufacturing and importing new cars my country also imports reconditioned car from UK and Japan. I had a bmw e39, a mercedes w211 and now an audi all reconditioned cars imported from UK. They are fairly good cars despite the reconditioned tag. But I know there are also cases of bad purchases. My audi was 2 year old when I bought it in 2013 and was slightly above 1/2 the local retail price.
Back to the problem at hand, is it not save to say now that the failed vcds brake light test is sufficient to condemn the brake switch to the bin. Further the voltage test shows the right voltage on the right wires at the brake switch connector. I think the voltage reading ruled out any problems in the wiring and fuse unless the problem of the missing voltage on terminal 30 when key off has an effect on the whole situation. Any opinion from you guys are valuable before I buy another brake light switch.
coconutaudi
C?ID=345326
However those readings are totally opposite of what you are saying. My mistake again the signal wire reads 0.476v not 4.76v. Apologies. Those reading are taken when the pedal is not pressed. Even after pressing the pedal the readings (ground 0.001v, +13.25v and signal 0.476v) remain the same.
Westbury, UK
So pressing the pedal makes no difference to the 'signal wire', which is neither ground nor 12V which I strongly suspect will be interpreted as implausible.
