Resolved 2014 Passat TDI fender audio question
Resolved
Avetisov22
C?ID=530079
Hey everyone,
I bought a used 2014 Passat TDI SEL with fender audio. Come to find out, the dash tweeters and rear door speakers aren’t producing sound. Front door speakers and subwoofer work. VCDS shows this fault under VCDS:
10485828 - Internal Control Module Memory Check Sum Error
B2000 44 [009] - Data Memory Failure
[Steuergerät Defekt: Datenspeicherfehler]
Reset counter: 177
Mileage: 96793 km
Date: 2022.11.07
Time: 01:14:11
any idea what this could be? Wiring appears to be good. I bought one new fender speaker and tried swapping it out on the rear door, no sound came of it. Fuses also appear to be good, including the one on the radio. Could this be a bad head unit or amp?
Thank you.
Avetisov22
C?ID=530079
Can we get a complete Auto-Scan for context, please?
Yes, my apologies!
Saturday,19,November,2022,13:42:05:61775
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: 1VWCN7A30EC029565   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 75 77
VIN: 1VWCN7A30EC029565   Mileage: 96810km-60154miles
   Component: R4 2.0l TDI   H24 9982
   Revision: 71H24---    Serial number:                CVN: D240C61FD45710C1
   Coding: 001D0012042400008000
   Shop #: WSC 00023 444 00000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B233BD703EAB423FE0-806E
   VINID: 0669D37874430154C0089146146CEF1DD7
   Component: GSG DSG AG6     521 9437
   Revision: 05652104    Serial number: 00001307040358
   Shop #: WSC 09003 957 00200
   VCID: 1471B06B42749B5B5FA-8040
   Revision: 00H31001
   Coding: C54BC0F549240003A31003EA921E0042A71000
   VCID: 7DA7F5CF5DFE7A13804-8028
02214 - Tire Pressure Warning
                    Reset counter: 183
                    Mileage: 96807 km
                    Date: 2017.04.11
                    Time: 19:25:19
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 51201
                    Count: 1535
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0193938492
   Coding: 130C0C
   VCID: 343110EB2EB47B5B3FA-8060
   Part No SW: 561 907 044 AB    HW: 561 907 044 AB
   Component: Climatronic   H03 0505
   Revision: 00001K01
   Coding: 0030019012
   VCID: 57EB87679F827043FA8-8002
          B10AB F0 [009] - Too Low
                    Reset counter: 181
                    Mileage: 96799 km
                    Date: 2022.11.19
                    Time: 01:04:28
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [008] - Open or Short to Plus
                    Reset counter: 223
                    Mileage: 96799 km
                    Date: 2022.11.19
                    Time: 01:04:33
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0173
   Revision: BL122001
   Coding: EF200E1B982B08D4098802013600854800F1A086458015B064806000BC70
   VCID: 78A9E4DB72DC5F3BD32-802C
00956 - Key 2
                    Fault Status: 01100101
                    Reset counter: 182
                    Mileage: 96799 km
                    Date: 2017.04.11
                    Time: 01:54:13
                    Voltage: 12.45 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 183
                    Mileage: 96799 km
                    Date: 2017.04.11
                    Time: 02:21:12
                    Voltage: 13.00 V
                    Reset counter: 183
                    Mileage: 96799 km
                    Date: 2017.04.11
                    Time: 02:21:12
                    Voltage: 13.00 V
   Serial number: 003MWM02NBTF
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B7EDEF654E2253C84-8020
   Serial number: 3572MSME2341227DZZZR
   Serial number: 3582MSME3B24227DZZZ
   Serial number: 3516KSME40624925ZZZL
   Serial number: 3526KSME154C5625ZZZU
   Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3556LSME6A406526ZZZX
   Serial number: 3566LSME385A7926ZZZ2
9445937 - Seat occupied recognition control module
          B1022 31 [137] - No Signal
                    Reset counter: 181
                    Mileage: 96799 km
                    Date: 2022.11.19
                    Time: 01:07:16
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010042    Serial number: 20130712201512
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7F5CF5D7E7A13804-8028
   Coding: E30000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Coding: 231E01
   VCID: 1E65D243B038C10BF9E-804A
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 24081303000048
   Coding: 461000
   VCID: 7BA3FBD743EA7423BE0-802E
   Coding: 000007
   VCID: 6A8DCE933CF0FDAB556-803E
   Revision: 00000000    Serial number: 13000100346003
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 30391CFBDAAC477B5B2-8064
Address 2E: Media Player 3
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0182
   Revision: AA000000    Serial number: 00000070069643
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 221DE6B384C0E5EBDD6-8076
   Part No SW: 3C0 035 684 J    HW: 3C0 035 684 G
   Component: RNS-MID       H03 4366
   Revision: AB001001    Serial number: VWZ6Z7N5080077
   Coding: 04090042010000A6000B
   VCID: 2A0D0E93FCF03DAB956-807E
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V6  7963
                    Reset counter: 183
                    Mileage: 96808 km
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0007265878
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C61D84BA624D31B17A-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630130903084916
   Coding: 800000
67584 - Warning Light for Front Door
          B11F5 01 [008] - Electrical Failure
                    Reset counter: 223
                    Mileage: 96814 km
                    Date: 2022.11.19
                    Time: 21:17:31
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 290    3501
   Revision: 00H22000
   VCID: 392F21DF05568633ECC-806C
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0065701
   ROD: EV_AudioVerst10KanalSTT3_VW36.rod
   VCID: 2615FAA3E86819CBB1E-8072
9463315 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 183
                    Mileage: 96814 km
                    Date: 2022.11.19
                    Time: 20:04:34
9463827 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Reset counter: 183
                    Mileage: 96814 km
                    Date: 2022.11.19
                    Time: 20:04:34
                    Reset counter: 183
                    Mileage: 96814 km
                    Date: 2022.11.19
                    Time: 20:04:33
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FBBDF8707921883028-803A
   Serial number: 53388786011311600258
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0007257879
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D67D54FBD3EDA13E04-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631130903101628
   Coding: 800000
                    Reset counter: 223
                    Mileage: 96814 km
                    Date: 2022.11.19
                    Time: 21:19:07
                    Reset counter: 183
                    Mileage: 96808 km
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0086
   Serial number: 000003554140505
   Coding: 02140102C2423A007F1606000000
   ROD: EV_OCULow_001.rod
   VCID: 53F373778B7A5C63060-8006
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 0
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007664920309
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E050283C098518B49E-807A
End----------(Elapsed Time: 01:45, VBatt start/end: 13.7V/13.8V)-----------
Looks like the amp is defective, but before replacing it, I'd verify the wiring to the speakers that it has "open circuit" faults for (and check that the speakers themselves aren't open-circuit).
Avetisov22
C?ID=530079
Thank you! May I ask why led you to the conclusion of it being the amp? All the wiring looks good from the 2 door panels I took off and checked.
Well, the amp itself says "Internal Control Module Memory Check Sum Error / Data Memory Failure / Steuergerät Defekt: Datenspeicherfehler".
"Looks good" isn't a proper check. A proper check would be to disconnect the harness from the amp, use a wiring diagram to determine which wires at the amp go to the speakers that don't work, and then measure the resistance that the amp would see if the harness was plugged it. You could also momentarily use something like a 1.5V battery at to see if the speakers in question make a sound when connecting/disconnecting the battery.
Avetisov22
C?ID=530079
I appreciate the help! I think I found the issue within the amplifier (thanks to you pointing me in the right direction!) I took the amplifier off. He took it apart, there is a parent water damage to have to circuit board inside of it. Gonna replace the Amplifier first and then check the wiring if the issue persists.
Avetisov22
C?ID=530079
Yeah, that would explain it.
First figure out and address the source of the water. Otherwise a replacement amplifier might suffer the same fate.
I certainly will. I appreciate your help!!
Avetisov22
C?ID=530079
@Uwe thank you for your help. Replacement amplifier came in today. All speakers work flawlessly 👌
